TJ-S2012YFJ06YJY-A3
TJ-S2012YFJ06YJY-A3
    TOGIALED(台湾统佳)
    LED指示灯 0805 黄色 585~595nm 250~500mcd 正贴 反极
TJ-S2012YFJ06YJY-A3 数据手册
TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 承 認 書 Specification For Approval Customer: (客戶) Description: (產品描述) LED(SMD)0805 反极性黄光 Part number:(產品型號) TJ-S2012YFJ06YJY-A3 Date: (日期) Approved By: (客戶承認) Prepared By:(我司承認) Approval 核准 Check Design 審核 製作 Sales 業務 Customer Service Hotline:400-676-8616 TEL:0769-8662 5999 0769-8200 2226 E-MIAL∶dg@togialed.com FAX:0769-8200 2227 WEB:www.togialed.com TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Features 2.0mmⅹ1.25mm SMT LED, 0.8mm thickness Low power consumption Wide view angle Package: 3000pcs/reel RoHS Compliant Applications Ideal for back light and indicator Various colors and lens types available Package outlines Recommend Pad Layout 1 2 1.25 [0.05"] Polarity mark 2.00 [0.08"] 0.50 [0.02"] 0.80 [0.03"] 1.30 [0.05"] 3.00° ATTENTION OBSERVE PRECAUTIONS FOR HANDLING 1 ELECTROSTATIC SENSITIVE DEVICES 2 SENSITIVE DEVICES DEVICES   Part No. Emitted color Dice Lens color TJ-S2012YFJ06YJY-A3 Yellow AlGaInP Water transparent Notes: 1. All dimensions are in millimeters (inches); 2. Tolerances are ±0.1mm (0.004inch) unless otherwise noted. TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Absolute maximum ratings (TA=25℃) Parameter Symbol Value Unit Forward current If 20 mA Reverse voltage Vr 5 V Power dissipation Pd 72 mW Operating temperature Top -40 ~+80 ℃ Storage temperature Tstg -40 ~+85 ℃ Ifp 125 mA Peak pulsing current (1/8 duty f=1kHz) Electro-optical characteristics (TA=25℃) Parameter Test Condition Value Symbol Unit Min Typ Max Wavelength at peak emission If=20mA λp -- 595 -- nm Spectral half bandwidth If=20mA △λ -- 18 -- nm Dominant wavelength If=20mA λd 58 5 -- 59 5 nm Forward voltage If=20mA Vf 1.8 -- 2.4 V Luminous intensity If=20mA Iv 250 -- 500 mcd Viewing angle at 50% Iv If= 10mA 2θ1/2 -- 120 -- Deg Vr=5V Ir -- -- 10 µA Reverse current TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Optical characteristic curves Relative Intensity (%) Relative Intensity vs. Wavelength Forward Voltage (V) Wavelength (nm) Forward Current vs. Forward Voltage     Forward Current (mA) Directive Characteristics TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Reflow Profile � Reflow Temp/Time 300 (℃ ) 10 S Max. 260℃ Max. 250 230℃ 4℃ /S Max. Temperature 200 1 5 0~ 1 8 0 ℃ 4℃ /S Max. 150 6 0~ 1 2 0 S 100 3 0~ 5 0 S 50 25℃ 0 50 100 150 200 250 Time 300 (sec) Notes: 1.We recommend the reflow temperature 245℃(±5℃).the maximum soldering temperature should be limited to 260℃. 2.Don’t cause stress to the epoxy resin while it is exposed to high temperature. 3.Number of reflow process shall be 2 times or less. �Soldering iron Basic spec is  5sec when 260℃. If temperature is higher, time should be shorter (+10℃� -1sec ).Power dissipation of iron should be smaller than 20W, and temperatures should be controllable .Surface temperature of the device should be under 230℃ . �Rework 1.Customer must finish rework within 5 sec under 260℃. 2.The head of iron can not touch copper foil 3.Twin-head type is preferred. Correct( ) Mistake( ) � Avoid rubbing or scraping the resin by any object, during high temperature, for example reflow solder etc. TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Test circuit and handling precautions � Test circuit + - R V LED � Handling precautions 1. Over-current-proof Customer must apply resistors for protection; otherwise slight voltage shift will cause big current change (Burn out will happen). 2. Storage 2.1 It is recommended to store the products in the following conditions: Humidity: 60% R.H. Max. Temperature : 5℃~30℃(41℉~86℉) 2.2 Shelf life in sealed bag: 12 month at <5℃~30℃ and <30% R.H. after the package is Opened, the products should be used within a week or they should be keeping to stored at≦20 R.H. with zip-lock sealed. 3. Baking It is recommended to baking before soldering when the pack is unsealed after 72hrs. The Conditions are as followings: 3.1 60±3℃ x(12~24hrs) and <5%RH, taped reel type 3.2 100±3℃ x(45min~1hr), bulk type 3.3 130±3℃ x(15~30min), bulk type TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD Test items and results of reliability Operation Sequence Environmental Sequence Type Number of Test Item Test Conditions Note Temperature Cycle -20℃ 30min ↑↓ 80℃ 30min 100 cycle 0/22 Thermal Shock -20℃ 15min ↑↓ 80℃ 15min 100 cycle 0/22 High Humidity Heat Cycle 30℃⇔ 65℃ 90%RH 24hrs/1cycle 10 cycle 0/22 High Temperature Storage Ta=80℃ 1000 hrs 0/22 Humidity Heat Storage Ta=60℃ RH=90% 1000 hrs 0/22 Low Temperature Storage Ta=-30℃ 1000 hrs 0/22 Life Test Ta=25℃ IF=20mA 1000 hrs 0/22 High Humidity Heat Life Test 60℃ RH=90% IF=10mA 500 hrs 0/22 Low Temperature Life Test Ta=-20℃ IF=20mA 1000 hrs 0/22 Damaged TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 2012 Series SMD Chip LED Lamps Packaging Specifications � � Feeding Direction Dimensions of Reel (Unit: mm) RoHS 57.54 [2.27"] Feeding Direction 13.30 [0.52"] 颜色标签 Lable 9.40 [0.37"] Dimensions of Tape (Unit: mm) SEC.A-A 2.00 [0.08"] 5.25 [0.21"] 1.75 [0.07"] 0.20 [0.01"] 8.00 [0.31"] A 4.00 [0.16"] 1.10 [0.04"] � 178.50 [7.03"] 1.05 [0.04"] 4.00 [0.16"] � A Arrangement of Tape Empty parts (Min.20pcs) Loaded parts (LED:3000pcs) Empty parts (Min.40pcs) Feeding Direction Conclusion parts (Min.80mm) Introduction parts (Min.160mm) Notes: 1. Empty component pockets are sealed with top cover tape; 2. The maximum number of missing lamps is two; 3. The cathode is oriented towards the tape sprocket hole in accordance with ANSI/EIA RS-481 specifications. 4. 3,000 pcs/Reel. TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD 2012 Series SMD Chip LED Lamps Packaging Specifications Packaging specifications Moisture-proof bag 颜色标签 Reel(3,000PCS) RoHS RoHS Lable Lable Ro HS La bl ble e HS La Inside box Maximums ten reels Ro � Outside box Maximums six inside boxes Notes: Reeled products (numbers of products are 3,000pcs) packed in a seal off moisture-proof bag along with a desiccant one by one, Seven moisture-proof bag of maximums (total maximum number of products are 30,000pcs) packed in an inside box (about size: 260x 220x 130mm) and four inside boxes of maximums are put in the outside box (about size: 450mm x 260mm x 400mm) Together with buffer material, and it is packed. (Part No., Lot No., quantity should appear on the label on the moisture-proof bag, part No. And quantity should appear on the label on the cardboard box.) The number of the loading steps of outside box (cardboard box) has it to three steps.
TJ-S2012YFJ06YJY-A3
物料型号:TJ-S2012YFJ06YJY-A3
器件简介: - 尺寸:2.0mm x 1.25mm SMT LED,厚度0.8mm - 低功耗 - 宽视角 - 包装:每卷3000个 - 符合RoHS标准 - 应用:适用于背光和指示器,提供多种颜色和透镜类型
引脚分配: - 极性标记 - 推荐焊盘布局
参数特性: - 正向电流:20mA - 反向电压:5V - 功耗:72mW - 工作温度:-40°C至+80°C - 存储温度:-40°C至+85°C - 峰值脉冲电流(1/8占空比,频率1kHz):125mA
功能详解: - 发光波长:595nm - 光谱半带宽:18nm - 主波长:585至595nm - 正向电压:1.8至2.4V - 发光强度:250至500mcd - 50%发光强度时的视角:120度 - 反向电流:在5V反向电压下小于10μA
应用信息: - 适用于背光和指示器
封装信息: - 封装轮廓 - 推荐焊盘布局 - 包装规格:每卷3000个,符合RoHS标准
其他注意事项: - 回流焊接温度/时间:最高300℃,不超过10秒 - 焊接铁规格:260℃下不超过5秒,功率小于20W,表面温度不超过230℃ - 重工:在260℃下5秒内完成重工,焊接头不能接触铜箔 - 测试电路和处理注意事项:包括过流保护和存储条件
可靠性测试结果: - 温度循环、热冲击、高湿热循环、高温存储、湿热存储、低温存储、寿命测试、高温湿热寿命测试、低温寿命测试均未发现损坏。
包装规格: - 卷轴尺寸:178.50mm x 57.54mm - 胶带尺寸:9.40mm x 13.30mm - 装载部分:每卷3000个LED - 空位(最小20个) - 结束部分(最小80mm) - 引线方向
包装说明: - 防潮袋 - 每卷3000个LED - 颜色标签 - RoHS标签 - 内盒最多装10卷 - 外盒最多装6个内盒
注意事项: - 空元件口袋用上盖胶带密封 - 缺失灯的最大数量为2个 - 阴极朝向胶带棘轮孔,符合ANSI/EIA RS-481规范
TJ-S2012YFJ06YJY-A3 价格&库存
很抱歉,暂时无法提供与“TJ-S2012YFJ06YJY-A3”相匹配的价格&库存,您可以联系我们找货
