SL10S60F
SL10S60F
    SLKOR(萨科微)
    TO-220F(TO-220IS)
    玻璃钝化超快速反应器
SL10S60F 数据手册
SL10S20F-SL10S60F GLASS PASSIVATED SUPER FAST RECTIFIER FEATURES TO-220F   Plastic package has Underwriters Laboratory Flammability Classification 94V-0 Fast switching for high efficiency 0.190(4.75) 0.165(4.25) 0.145(3.55) Low forward voltage drop 0.128(3.25) DIA 0.130(3.31) Single rectifier construction 0.110(2.81) 0.111(2.83) High surge capability 0.101(2.57) For use in low voltage ,high frequency inverters, 0.174(4.42) 0.165(4.18) free wheeling ,and polarity protection applications 0.410(10.41) High temperature soldering guaranteed:260 C/10 seconds, 0.388(9.85) PIN 1 2 3 0.25"(6.35mm)from case 0.666(16.92) 0.325(8.25) 0.633(16.08) 0.321(8.15) 0.610(15.5) 0.571(14.5) 1.161(29.5) 0.177(4.50) 0.136(3.45) 1.083(27.5) 0.138(3.50) 0.116(2.95) 0.551(14.00) 0.512(13.00) 0.029(0.73) 0.019(0.47) 0.104(2.64) 0.096(2.44) 0.029(0.73) 0.019(0.47) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (Ratings at 25 C ambient temperature unless otherwise specified ,Single phase ,half wave ,resistive or inductive load. For capacitive load,derate by 20%.) Symbols Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage VRRM VRMS VDC SL10S20F SL10S40F SL10S60F Units 200 400 600 140 280 420 200 400 600 Volts Volts Volts Per leg Total device I(AV) 5.0 10.0 Amps Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) IFSM 150.0 150 Amps Maximum average forward rectified current(see Fig.1) Maximum instantaneous forward voltage at 10.0 A(Note 1 ) Maximum instantaneous reverse current at rated DC blocking voltage(Note 1) T A =25 C T A =125 C Maximum Reverse Recovery Time (Note 2) VF IR 1.3 R Operating junction temperature range TJ TSTG 500 JC Notes: 1. Pulse test: 300 s pulse width,1% duty cycle 2. Reverse recovery test conditions IF=0.5A,IR=1.0A, Irr=0.5A 3. Thermal resistance from junction to case www.slkormicro.com 1.7 10 5 Trr Typical thermal resistance (Note 3) Storage temperature range 0.975 1 Volts uA 35 ns 3.0 C/W -40 to+150 C -40 to+150 C SL10S20F-SL10S60F FIG.2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 12 180 10 150 RESISTIVE OR INDUCTVE LOAD 8 PEAK FORWARD SURGE CURRENT(AMPERES) AVERAGE FORWARD CURRENT AMPERES FIG.1-FORWARD CURRENT DERATING CURVE 6 4 2 0 0 20 40 60 80 100 120 120 90 60 30 0 180 150 0.1 1 10 100 LEAD TEMPERATURE ( C) NUMBER OF CYCLES AT 60Hz FIG.3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS FIG.4-TYPICAL REVERSE CHARACTERISTICS 20 50 400V 10 TJ=100 C (UA) 200V 600V INSTANTANEOUS REVERSE CURRENT INSTANTANEOUS FORWARD CURRENT( AMPERES) 10 PULSE WIDTH=300 S 1% DUTY CYCLE 1 0.1 1 TJ=25 C 0.1 0.01 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 0.001 0 INSTANTANEOUS FORWARD VOLTAGE (VOLTS) 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLTAGE% FIG.6-TYPICAL TRANSIENT THERMAL IMPEDANCE TRANSIENT THERMAL IMPEDANCE, C/ W FIG.5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE(pF) 400 TJ=25 C f=1.0MHZ Vsig=50mVp-p 100 10 0.1 1 10 100 10 1 0.1 0.01 REVERSE VOLTAGE. VOLTS www.slkormicro.com 100 0.1 1 T, PULSE DURATION ,sec. 2 10 100
SL10S60F 价格&库存
很抱歉,暂时无法提供与“SL10S60F”相匹配的价格&库存,您可以联系我们找货
SL10S60F
  • 1+1.21500
  • 10+1.17000
  • 100+1.06200
  • 500+1.00800
