LM321
Low Power Single Operational Amplifier
Description
LM321 is a low power, wide power range performance
operational amplifier;The static current is only 430 μA per
4.OUT
5.V+
amplifier (5V) with high unit gain frequency and A voltage swing
rate of 0.4V/μs.Input common model circuit includes ground, so
the device can operate in single - and dual-power applications.It
can also comfortably drive large capacity loads.
Features
Low quiescent current
Low input bias current
Wide range of supply voltage
High capacity load stability
1.+IN
2.V-
3.-IN
SOT-23-5
Pin arrangement diagram
Application
Communication infrastructure
Battery charger
Power supply
www.slkormicro.com
1
LM321
Absolute Maximum Ratings (TA =25℃)
Parameter
Symbol
VCC
Value
24 or ±12
Units
V
Differential Input Voltage
VID
24
V
Input Voltage
VIN
-0.3~VCC
V
Power Dissipation
PD
530
mW
IO
Continuous
IIN
50
mA
TJ
150
°C
Operating Temperature Range
TOPR
0 to 70
°C
Storage Temperature Range
TSTG
-65 to 150
°C
Supply Voltage
Output Short Circuit to GND
Input Current VIN
很抱歉,暂时无法提供与“LM321”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34755
- 100+0.27378
- 300+0.23685
- 3000+0.19786
- 6000+0.17572
- 9000+0.16470
- 国内价格
- 10+0.31536
- 100+0.24843
- 300+0.21491
- 国内价格 香港价格
- 1+0.888001+0.11463
- 10+0.5574110+0.07195
- 25+0.4848725+0.06259
- 100+0.40698100+0.05254
- 250+0.36949250+0.04770
- 500+0.34701500+0.04480
- 1000+0.328251000+0.04237
- 国内价格
- 1+0.65890
- 200+0.22000
- 1500+0.13750
- 3000+0.10901
- 国内价格 香港价格
- 3000+0.305133000+0.03939
- 6000+0.293836000+0.03793
- 9000+0.288169000+0.03720
- 15000+0.2818815000+0.03639
- 21000+0.2782121000+0.03592
- 30000+0.2746930000+0.03546
