SL210N06
SL210N06
    SLKOR(萨科微)
    TO-220-3
    MOS管 N-Channel VDS=60V VGS=±20V ID=210A Pd=300W SOT23
SL210N06 数据手册
SL210N06 N-Channel Power MOSFET General Description Features This type used advanced trench technology and design to provide excellent RDS(ON) with low gate charge. l High density cell design for ultra low RDS(ON) l Excellent package for good heat dissipation For a single MOSFET l l l VDS = 60V RDS(ON) = 2.2mΩ @ VGS=10V Pin configurations See Diagram below Absolute Maximum Ratings Parameter Symbol Rating Units Drain-Source Voltage VDS 60 V Gate-Source Voltage VGS ±20 V Continuous 210 Drain Current ID Pulsed Total Power Dissipation @TA=25℃ Operating Junction Temperature Range www.slkormicro.com A 800 1 PD 300 W TJ -55 to 175 ℃ SL210N06 Electrical Characteristics (TJ=25℃ unless otherwise noted) Symbol Parameter Test Conditions Min Typ Max Units OFF CHARACTERISTICS (Note 2) BVDSS Drain-Source Breakdown Voltage ID=250μA, VGS=0 V IDSS Drain to Source Leakage Current VDS= 48V, VGS=0V IGSS Gate-Body Leakage Current VGS=20V Gate Threshold Voltage VDS= VGS, ID=250μA VGS(th) RDS(ON) Static Drain-Source On-Resistance VGS=10V, ID=20A 60 2.0 V 1 μA 100 nA 3.0 4.0 V 2.2 2.6 mΩ DYNAMIC PARAMETERS Ciss Input Capacitance VGS=0V, VDS=30V, Coss Output Capacitance Crss Reverse Transfer Capacitance f=1MHz 7070 pF 2140 pF 63 pF 85 nC 24 nC 14 nC SWITCHING PARAMETERS Qg Total Gate Charge 2 VGS=10V, VDS=30V, Qgs Gate Source Charge Qgd Gate Drain Charge td(on) Turn-On Delay Time VGS=10V, VDS=30V, 36 ns td(off) Turn-Off Delay Time RGEN=10Ω 95 ns td(r) Turn-On Rise Time 62 ns td(f) Turn-Off Fall Time 34 ns ID=20A Thermal Resistance Symbol RθJC Parameter Typ Units Junction to Case 0.5 ℃/W www.slkormicro.com 2 SL210N06 Typical Characteristics www.slkormicro.com 3 SL210N06 Typical Characteristics www.slkormicro.com 4 SL210N06 Package Outline Dimension TO-220 www.slkormicro.com 5
SL210N06
- 物料型号:SIkor SL210N06 - 器件简介:使用先进的沟槽技术和电荷设计,具有在VDS=60V下的低栅极电压和优秀的RDS(ON)。 - 引脚分配:见下图,具体引脚分配未在文本中详述,但通常TO-220封装有3个引脚。 - 参数特性: - 漏源击穿电压(BVpss):最小60V - 栅漏电流(IGss):最大100nA - 栅源阈值电压(VGs(th)):2.0V至4.0V - 静态漏源导通电阻(RDS(ON)):在VGs=10V和Ip=20A条件下,典型值为2.2mΩ - 功能详解:包含静态特性、动态参数、开关参数和热阻等详细电气特性。 - 应用信息:文档中未明确提供应用信息,但根据电气特性,通常用于电源管理、电机驱动等。 - 封装信息:TO-220封装,提供了详细的尺寸信息。
SL210N06 价格&库存
很抱歉,暂时无法提供与“SL210N06”相匹配的价格&库存,您可以联系我们找货
SL210N06
  • 1+3.51000
  • 10+3.38000
  • 100+3.06800
  • 500+2.91200
