CSM Series
Stackpole Electronics, Inc.
Molded Metal Plate Sensing Resistor
Resistive Product Solutions
Features:
High power metal alloy current sense resistor
Molded package for superior heat dissipation
Typical inductance < 5nH
Ideal for power supplies and motor drives
Package size 2512 is qualified to AEC-Q200
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications
Type / Code
Power Rating
(W)
Maximum Working
Voltage (V)
CSM0603
0.33
CSM2512
3
P = Rated Power (W)
R = Resistance Value (Ω)
Maximum Current
(A)
TCR (ppm/ºC)
(P*R) 1/2
5.6
± 70
Ohmic Range (Ω) and Tolerance
1%, 5%
0.01
(P*R) 1/2
54.8
± 50
0.001 - 0.1
Mechanical Specifications
Type / Code
CSM0603
CSM2512
(0.001 Ω - 0.004 Ω)
CSM2512
(> 0.004 Ω - 0.1 Ω)
L
0.063
1.60
0.252
6.40
0.252
6.40
W
0.004
0.10
0.008
0.20
0.008
0.20
0.031
0.80
0.126
3.20
0.126
3.20
C
0.004
0.10
0.008
0.20
0.008
0.20
0.008
0.20
0.079
2.00
0.035
0.90
H
0.004
0.10
0.008
0.20
0.008
0.20
0.012
0.30
0.028
0.70
0.028
0.70
d
0.004
0.10
0.008
0.20
0.008
0.20
0.012
0.30
0.079
2.00
0.035
0.90
Unit
0.004
0.10
0.008
0.20
0.008
0.20
inches
mm
inches
mm
inches
mm
Performance Characteristics
Test Item
Temperature Coefficient of Resistance
Test Specification
CSM2512 ± 50 ppm/ºC
CSM0603 ± 100 ppm/ºC
Load Life
± 1%
Short Time Overload
± 0.5%
Moisture No Load
± 0.5%
Temperature Cycling
< ± 0.5%
Resistance to Soldering Heat
± 0.5%
At least 95% of surface area of electrode
must be covered with new solder
Solderability
Rev Date: 10/22/2020
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
Test Condition
+25ºC ~ +125ºC
1000 hours at rated power, 70ºC,
1.5 hours ON, 0.5 hours OFF
5 X rated power for 5 seconds
(for 0.04 - 0.1 Ω > rated power x 2.5
for 5 seconds)
85ºC, 85% R.H., 1000 hours
1000 cycles (-55°C to 125°C)
Measurement at 24 hours after test
conclusion
JESD22 Method JA-104
260 ± 5ºC for 20 ± 1 seconds
245 ± 5ºC for 2 ± 0.5 seconds
www.seielect.com
marketing@seielect.com
CSM Series
Performance Characteristics (cont.)
Test Item
Test Specification
Test Condition
High Temperature Exposure
± 0.5%
170ºC for 1000 hours
Low Temperature Storage
± 0.5%
-55ºC for 1000 hours
Substrate Bending
± 1%
Bending width 2 mm
Insulation Resistance
> 100MΩ
100VDC for 1 minute
Storage Conditions: Temperature 5°C ~ 35°C; R.H. 40% ~ 75%
Operating temperature range for CSM0603 is -55°C to +155°C and for CSM2512 is -55°C to +170°C
Power Derating Curve:
CSM0603
-55ºC
100
70°C
Rated Power (%)
80
60
40
155°C
60
80
100
120
Ambient Temperature (ºC)
140
160
180
CSM2512
100
-55ºC
70°C
Rated Power (%)
80
60
40
170°C
40
60
80
100
120
2
140
160
180
www.seielect.com
CSM Series
Terminal Temperature:
CSM2512
100
-55 ºC
120°C
Rated Power (%)
80
60
40
175°C
60
80
100
120
Terminal Temperature (ºC)
140
160
180
Recommended Pad Layout
Type / Code
CSM0603
CSM2512 (≤ 0.004 Ω)
CSM2512 (> 0.004 Ω)
a
b
L
Unit
0.039
1.00
0.157
4.00
0.157
4.00
0.028
0.70
0.122
3.10
0.083
2.10
0.035
0.90
0.051
1.30
0.161
4.10
inches
mm
inches
mm
inches
mm
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
3
www.seielect.com
CSM Series
Wave Soldering
Description
Maximum
Recommended
Minimum
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
Taping Specifications – CSM0603
Type / Code
CSM0603
A
B
W
F
E
Unit
0.075 ± 0.008
1.90 ± 0.20
0.045 ± 0.006
1.15 ± 0.15
0.315 ± 0.008
8.00 ± 0.20
0.138 ± 0.002
3.50 ± 0.05
0.069 ± 0.004
1.75 ± 0.10
inches
mm
P1
P0
ØD
T
Unit
0.157 ± 0.004
4.00 ± 0.10
0.157 ± 0.004
4.00 ± 0.10
0.059 +0.004 / -0
1.5 +0.10 / -0
0.031 max.
0.8 max.
inches
mm
4
www.seielect.com
CSM Series
Taping Specifications – CSM2512
Type / Code
A
B
W
F
E
Unit
CSM2512
0.142 ± 0.008
3.60 ± 0.20
P1
0.272 ± 0.008
6.90 ± 0.20
P2
0.472 ± 0.008
12.00 ± 0.20
P0
0.217 ± 0.002
5.50 ± 0.05
D0
0.069 ± 0.004
1.75 ± 0.10
t
inches
mm
Unit
0.157 ± 0.004
4.00 ± 0.10
0.079 ± 0.002
2.00 ± 0.05
0.157 ± 0.002
4.00 ± 0.05
0.059 +0.004 / -0
1.5 +0.10 / -0
0.047 ± 0.006
1.20 ± 0.15
inches
mm
Packaging Specifications
Type / Code
CSM0603
CSM2512
A
7.087
180.00
7.087
180.00
B
0.059
1.50
0.059
1.50
2.362
60.00
2.362
60.00
C
0.039
1.00
0.039
1.00
0.512
13.00
0.512
13.00
D
0.008
0.20
0.008
0.20
0.354
9.00
0.606
15.40
Unit
0.039
1.00
0.079
2.00
inches
mm
inches
mm
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
CSM
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Molded Metal Plate
Sensing Resistor
SMD
YES
100% Matte Sn over Ni
Always
Always
5
www.seielect.com
CSM Series
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
C
S
M
2
5
1
2
F
T
1
L
Product Series
Size
Description
Code
W
Molded Metal Plate 0603 0.33
CSM
Sensing Resistor
2512
3
Code
Tolerance
Code Tol
F
1%
J
5%
Packaging
Code Description
Size
Paper Tape
0603
T
Emboss
2512
6
Quantity
5000
4000
Resistance Value
Four characters with the multiplier
used as the decimal holder.
"L" used as multiplier of 10-3 for any
value under 0.1 ohm
0.001 = 1L00
0.01 = 10L0
0.1 ohm = R100
www.seielect.com
很抱歉,暂时无法提供与“CSM2512FT10L0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.08473
- 50+1.65035
- 150+1.46416
- 500+1.23196
- 2500+1.12850
