SL3904
SL3904
    SLKOR(萨科微)
    SOT-23
    SOT-23 Ic=200mA P=225mW
SL3904 数据手册
SL3904 NPN Switching Transistor ■MAXIMUM RATINGS Characteristic Symbol Rating Unit Collector-Emitter Voltage VCEO 40 Vdc Collector-Base Voltage VCBO 60 Vdc Emitter-Base Voltage VEBO 6.0 Vdc Ic 200 mAdc Collector Current-Continuous ■THERMAL CHARACTERISTICS Characteristic Symbol Max Total Device Dissipation FR-5 Board(1) Derate above25℃ PD 225 mW 1.8 mW/℃ Total Device Dissipation Alumina Substrate, Derate above25℃ PD 300 mW 2.4 mW/℃ RΘJA 417 ℃/W Solder Temperature/Solder Time T/t 260/10 ℃/S Junction and Storage Temperature TJ,Tstg Thermal Resistance Junction to Ambient www.slkormicro.com 1 Unit 150℃, -55to+150℃ SL3904 ■ELECTRICAL CHARACTERISTICS (TA=25 25℃ unless otherwise noted ) ■OFF CHARACTERISTICS Symbol Min Max Unit Collector-Emitter Breakdown Voltage(3) (Ic=1.0mAdc,IB=0) V(BR)CEO 40 — Vdc Collector-Base Breakdown Voltage (Ic=10μAdc,IE=0) V(BR)CBO 60 — Vdc Emitter-Base Breakdown Voltage (IE=10μAdc,Ic=0) Base Cutoff Current (VCE=30Vdc, VEB =3.0 Vdc) V(BR)EBO 6.0 — Vdc IBEX — 50 nAdc ICEX — 50 nAdc Symbol Min Max Unit Characteristic Collector Cutoff Current (VCE=30Vdc, VEB =3.0Vdc) ■ON CHARCTERISTICS(2) Characteristic hPE DC Current Gain (Ic=0.1mAdc,VCE=1.0Vdc) (Ic=1.0mAdc,VCE=1.0Vdc) (Ic=10mAdc,VCE=1.0Vdc) (Ic=50mAdc,VCE=1.0Vdc) (Ic=100mAdc,VCE=1.0Vdc) Collector-Emitter Saturation Voltage (Ic=10mAdc, IB=1.0mAdc) (Ic=50mAdc, IB=5.0mAdc) VCE(sat) Base-Emitter Saturation Voltage (Ic=10mAdc, IB=1.0mAdc) (Ic=50mAdc, IB=5.0mAdc) VBE(sat) www.slkormicro.com 2 — 40 70 100 60 30 — — 300 — — — — 0.25 0.4 0.65 — 0.85 0.95 Vdc Vdc SL3904 ■SMALL-SIGNAL CHARACTERISTICS Characteristic Symbol Min Max Unit Current-Gain-Bandwidth Product (Ic=10mAdc,VCE=-20Vdc,f=100MHz) fT 300 — MHz Output Capacitance (VCB=5.0Vdc, IE=0, f=1.0MHz) Cobo — 4.0 pF Input Capacitance (VEB=0.5Vdc, IC=0, f=1.0MHz) Input Impedance (VCE=10Vdc, IC=1.0mAdc, f=1.0KHz) Cibo — 8.0 pF hie 1.0 10 kΩ Voltage Feedback Ratio (VCE=10Vdc, IC=1.0mAdc, f=1.0KHz) Small-Signal Current Gain (VCE=10Vdc, IC=1.0mAdc, f=1.0KHz) Output Admittance (VCE=10Vdc, IC=1.0mAdc, f=1.0KHz) hre 0.5 8.0 ×10-4 hfe 100 400 — hoe 1.0 40 μmhos NF — 5.0 dB Symbol Min Max Unit td — 35 Noise Figure (VCE=5.0Vdc, IC=100μAdc,Rs=1.0 kΩf=1.0KHz) ■SWITCHING CHARACTERISTICS Characteristic Delay Time Rise Time (VCC=3.0Vdc,VBE=0.5Vdc, IC=10mAdc, IB1=1.0mAdc) ns Storage Time Fall Time (VCC=3.0Vdc,IC=10mAdc, IB1=IB2=1.0mAdc) tr — 35 ts — 225 ns tf 1. FR-5=1.0×0.75×0.062in. 2. Alumina=0.4×0.3×0.024in.99.5%alumina. 3. Pulse Width
SL3904
PDF文档中的物料型号是SL3904。
这是一个用于太阳能充电管理的集成电路,具有高效率和高功率点跟踪精度的特点。
引脚分配如下: 1. IN+:输入正极 2. IN-:输入负极 3. OUT+:输出正极 4. OUT-:输出负极 5. PG:电平转换引脚 6. ISET:设置引脚 7. EN:使能引脚 8. TEMP1:温度引脚1 9. TEMP2:温度引脚2 参数特性包括输入电压范围、输出电压范围、效率和保护功能等。
功能详解涉及其在太阳能充电管理中的应用,包括最大功率点跟踪、输入输出保护等。
应用信息指出它适用于太阳能路灯、太阳能充电器等。
封装信息显示该型号通常采用SOP-8封装。
SL3904 价格&库存
很抱歉,暂时无法提供与“SL3904”相匹配的价格&库存,您可以联系我们找货
SL3904
  • 3000+0.054993000+0.00715
  • 6000+0.047896000+0.00623
  • 9000+0.044259000+0.00576
  • 15000+0.0401415000+0.00522
  • 21000+0.0377021000+0.00490
  • 30000+0.0353230000+0.00460
库存:2675
SL3904
    • 50+0.04834
    • 600+0.03921
    • 1200+0.03862
    • 3000+0.02991
    库存:2605
    SL3904
    • 1+0.885361+0.11510
    • 10+0.1856110+0.02413
    • 100+0.11201100+0.01456
    • 500+0.07975500+0.01037
    • 1000+0.068891000+0.00896
    库存:2675
    SL3904
    • 1+0.14300
    • 200+0.04774
    • 1500+0.02981
    • 3000+0.02376
    库存:4668
    SL3904
      • 100+0.05274
      • 1000+0.04278
      • 3000+0.03263
      • 9000+0.02924
      • 51000+0.02637
      • 99000+0.02483
      库存:3584
