SLESD3Z5V0C
Transient Voltage Suppressors for ESD Protection
DESCRIPTION
FEATURES
IEC61000-4-2 (ESD) ±15kV (air),
±8kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ηs)
Peak power dissipation: 200W (8/20μs)
Protects one directional I/O line
Low clamping voltage
Working voltages : 5V
Low leakage current
The SLESD3Z5VOC is designed to protect voltage
sensitive components from ESD and transient
voltage events. Excellent clamping capability, low
leakage, and fast response time, make these parts
ideal for ESD protection on designs where board
space is at a premium.
This device has been specifically designed to
protect sensitive components which are connected
to data and transmission lines from overvoltage
caused by ESD (electrostatic discharge), CDE
(Cable Discharge Events),and EFT (electrical fast
transients).
MACHANICAL DATA
SOD-323 package
Terminals: Gold plated, solderable per
MIL-STD-750, method 2026
Packaging: Tape and Reel
Reel size: 7 inch
APPLICATIONS
High Speed Line :USB1.0/2.0, VGA, DVI, SDI,
Serial and Parallel Ports
Notebooks, Desktops, Servers
Projection TV
Cellular handsets and accessories
Portable instrumentation
Peripherals
PIN CONFIGURATION
www.slkormicro.com
PACKAGE OUTLINE
1
SLESD3Z5V0C
ABSOLUTE MAXIMUM RATING
Symbol
Parameter
Value
Units
VESD
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
±15
±8
kV
PPP
Peak Pulse Power (8/20μs)
100
W
TOPT
Operating Temperature
-40~150
°C
TSTG
Storage Temperature
-40~150
°C
ELECTRICAL CHARACTERISTICS (Tamb=25°C)
Symbol
Parameter
Test Condition
VRWM
Reverse Working Voltage
VBR
Reverse Breakdown
Voltage
IT = 1mA
IR
Reverse Leakage Current
VC
Max
Units
5.0
V
7.8
V
VRWM = 5V
1.0
μA
Clamping Voltage
IPP = 5A, tp = 8/20μs
11.6
V
VC
Clamping Voltage
IPPmax = 8A , tp = 8/20μs
16.0
V
CJ
Junction Capacitance
VR = 0V, f = 1MHz
15
pF
ELECTRICAL CHARACTERISTICS CURVE
www.slkormicro.com
2
Min
Typ
5.6
10
SLESD3Z5V0C
SOD-323 PACKAGE OUTLINE DIMENSIONS
www.slkormicro.com
3
很抱歉,暂时无法提供与“SLESD3Z5V0C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.13163
- 500+0.10496
- 3000+0.09018
- 6000+0.08126
- 24000+0.07356
- 51000+0.06946
- 国内价格
- 1+0.31900
- 200+0.10670
- 1500+0.06666
- 3000+0.05291
