SL60N06
N-Channel Power MOSFET
General Features
● VDS =60V,ID =60A
RDS(ON) < 11.5mΩ @ VGS=10V (Typ:9.1mΩ)
● High density cell design for ultra low Rdson
● Fully characterized avalanche voltage and current
● Good stability and uniformity with high EAS
● Excellent package for good heat dissipation
Schematic diagram
● Special process technology for high ESD capability
Application
● Power switching application
● Hard switched and high frequency circuits
● Uninterruptible power supply
TO-220-3L top view
Absolute Maximum Ratings (TC=25℃unless otherwise noted)
Parameter
Symbol
Limit
Unit
Drain-Source Voltage
VDS
60
V
Gate-Source Voltage
VGS
±20
V
ID
60
A
ID (100℃)
50
A
Pulsed Drain Current
IDM
300
A
Maximum Power Dissipation
PD
110
W
0.73
W/℃
EAS
450
mJ
TJ,TSTG
-55 To 175
Drain Current-Continuous
Drain Current-Continuous(TC=100℃)
Derating factor
Single pulse avalanche energy
(Note 5)
Operating Junction and Storage Temperature Range
www.slkormicro.com
1
SL60N06
Thermal Characteristic
Thermal Resistance,Junction-to-Case(Note 2)
RθJC
1.36
℃/W
Electrical Characteristics (TC=25℃unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
Drain-Source Breakdown Voltage
BVDSS
VGS=0V ID=250μA
60
68
V
Zero Gate Voltage Drain Current
IDSS
VDS=60V,VGS=0V
1
μA
Gate-Body Leakage Current
IGSS
VGS=±20V,VDS=0V
±100
nA
Gate Threshold Voltage
VGS(th)
VDS=VGS,ID=250μA
2
3
4
V
Drain-Source On-State Resistance
RDS(ON)
VGS=10V, ID=30A
9.1
11.5
mΩ
gFS
VDS=25V,ID=30A
S
2350
PF
237
PF
205
PF
16
nS
Off Characteristics
On Characteristics
(Note 3)
Forward Transconductance
Dynamic Characteristics
(Note4)
Input Capacitance
Clss
Output Capacitance
Coss
Reverse Transfer Capacitance
Switching Characteristics
VDS=25V,VGS=0V,
F=1.0MHz
Crss
(Note 4)
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
VDD=30V,ID=2A,RL=15Ω
10
nS
td(off)
VGS=10V,RG=2.5Ω
45
nS
12
nS
50
nC
12
nC
16
nC
1.2
V
60
A
TJ = 25°C, IF =60A
28
nS
(Note3)
49
nC
Turn-Off Delay Time
Turn-Off Fall Time
tf
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
VDS=30V,ID=30A,
VGS=10V
Drain-Source Diode Characteristics
Diode Forward Voltage (Note 3)
Diode Forward Current
(Note 2)
Reverse Recovery Time
VSD
VGS=0V,IS=30A
IS
trr
Reverse Recovery Charge
Qrr
Forward Turn-On Time
ton
di/dt = 100A/μs
Intrinsic turn-on time is negligible (turn-on is dominated by LS+LD)
Notes:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production
5. EAS condition: Tj=25℃,VDD=30V,VG=10V,L=0.5mH,Rg=25Ω
www.slkormicro.com
2
SL60N06
ID- Drain Current (A)
Normalized On-Resistance
Typical Electrical and Thermal Characteristics (Curves)
TJ-Junction Temperature(℃)
Vds Drain-Source Voltage (V)
Figure 4 Rdson-JunctionTemperature
Vgs Gate-Source Voltage (V)
Figure 1 Output Characteristics
Qg Gate Charge (nC)
Figure 2 Transfer Characteristics
Figure 5 Gate Charge
Is- Reverse Drain Current (A)
Rdson On-Resistance(mΩ)
Vsd Source-Drain Voltage (V)
Figure 3 Rdson- Drain Current
www.slkormicro.com
Figure 6 Source- Drain Diode Forward
3
C Capacitance (pF)
SL60N06
Figure 7 Capacitance vs Vds
Figure 9 BVDSS vs Junction Temperature
Figure 8 Safe Operation Area
Figure 10 VGS(th) vs Junction Temperature
r(t),Normalized Effective
Transient Thermal Impedance
Square Wave Pluse Duration(sec)
Figure 11 Normalized Maximum Transient Thermal Impedance
www.slkormicro.com
4
SL60N06
TO-220-3L Package Information
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
4.400
4.600
0.173
0.181
A1
2.250
2.550
0.089
0.100
b
0.710
0.910
0.028
0.036
b1
1.170
1.370
0.046
0.054
c
0.330
0.650
0.013
0.026
c1
1.200
1.400
0.047
0.055
D
9.910
10.250
0.390
0.404
E
8.9500
9.750
0.352
0.384
E1
12.650
12.950
0.498
0.510
e
2.540 TYP.
0.100 TYP.
e1
4.980
5.180
0.196
0.204
F
2.650
2.950
0.104
0.116
H
7.900
8.100
0.311
0.319
h
0.000
0.300
0.000
0.012
L
12.900
13.400
0.508
0.528
L1
2.850
3.250
0.112
0.128
V
Φ
www.slkormicro.com
7.500 REF.
3.400
0.295 REF.
3.800
5
0.134
0.150
很抱歉,暂时无法提供与“SL60N06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.16000
- 10+2.08000
- 100+1.88800
- 500+1.79200
- 国内价格
- 1+2.62440
- 10+2.07360
- 50+1.71720
- 100+1.42560
- 500+1.29600
- 1000+1.20960
