SLESD5Zx
Transient Voltage Suppressors for ESD Protection
General Description
Features
The SLESD5Z series are designed to protect z
voltage sensitive components from ESD and transient z
voltage events. Excellent clamping capability, low
z
leakage, and fast response time, make these parts
Small Body Outline Dimensions
Low Body Height
Peak Power up to 200 Watts @ 8 x 20 _µs
Pulse
ideal for ESD protection on designs where board space
z
Low Leakage current
is at a premium.
z
Response Time is Typically < 1 ns
Applications
Complies with the following standards
z
Cellular phones
IEC61000-4-2
z
Portable devices
Level 4
z
Digital cameras
z
Power supplies
15 kV (air discharge)
8 kV(contact discharge)
MIL STD 883E - Method 3015-7 Class 3
25 kV HBM (Human Body Model)
Functional diagram
SOD-523
Absolute Ratings (Tamb=25°C )
Symbol
Parameter
Value
Units
PPP
Peak Pulse Power (tp = 8/20μs)
200
W
TL
Maximum lead temperature for soldering during 10s
260
°C
Tstg
Storage Temperature Range
-55 to +155
°C
Top
Operating Temperature Range
-40 to +125
°C
Tj
Maximum junction temperature
150
°C
±15
±8
kV
40
A
16
kV
400
V
IEC61000-4-2 (ESD)
air discharge
contact discharge
IEC61000-4-4 (EFT)
ESD Voltage
Per Human Body Model
Per Machine Model
www.slkormicro.com
1
SLESD5Zx
Electrical Parameter
Symbol
IPP
VC
VRWM
IR
IT
VBR
Parameter
Reverse Peak
Maximum
Current
Clamping Voltage @ IPP
Pulse
Working Peak Reverse Voltage
Maximum Reverse Leakage Current
@ VRWM
Test Current
Breakdown Voltage @ IT
Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified.VF = 0.9V at IF = 10mA
VBR
Part Numbers
IT
VRWM
IR
VF
IF
C
Max.
Typ.
Typ. 0v bias
Min.
Typ.
Max.
V
V
V
mA
V
µA
V
mA
pF
SLESD5Z3V3C
5.1
6.0
6.8
1
3.3
1
SLESD5Z5C
5.6
6.7
7.8
1
5.0
1
30
*Surge current waveform per Figure 1.
1. VBR is measured with a pulse test current IT at an ambient temperature of 25℃.
Typical Characteristics
Fig1. Pulse Waveform
www.slkormicro.com
Fig2.Power Derating Curve
2
SLESD5Zx
Application Note
Electrostatic discharge (ESD) is a major cause of failure in electronic systems. Transient Voltage
Suppressors (TVS) are an ideal choice for ESD protection. They are capable of clamping the incoming
transient to a low enough level such that damage to the protected semiconductor is prevented.
Surface mount TVS offers the best choice for minimal lead inductance. They serve as parallel
protection elements, connected between the signal lines to ground. As the transient rises above the
operating voltage of the device, the TVS becomes a low impedance path diverting the transient current to
ground.
The tiny SOD-523 package allows design flexibility in the design of high density boards where the
space saving is at a premium. This enables to shorten the routing and contributes to hardening against
ESD.
SOD-523 Mechanical Data
Dim
Millimeters
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
A
1.10
1.20
1.30
0.043
0.047
0.051
B
0.70
0.80
0.90
0.028
0.032
0.035
C
0.50
0.60
0.70
0.020
0.024
0.028
D
0.25
0.30
0.35
0.010
0.012
0.014
J
0.07
0.14
0.20
0.0028
0.0055
0.0079
K
0.15
0.20
0.25
0.006
0.008
0.010
S
1.50
1.60
1.70
0.059
0.063
0.067
www.slkormicro.com
3
很抱歉,暂时无法提供与“SLESD5Z5C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.09870
- 300+0.07940
- 国内价格
- 50+0.10768
- 500+0.08662
- 3000+0.06815
- 6000+0.06113
- 24000+0.05508
- 51000+0.05174
