PLR0524
PLR0524
    YENJI(台湾元基)
    DFN2510-10
    TVS二极管 VRWM=5V VC=18V DFN10
PLR0524 数据手册
PLR0524 ESD Protection Array RoHS Device Halogen Free Features - IEC61000-4-2 (ESD)±15kV(Contact) DFN-10 - Working voltage: 5 V - Low leakage current. PIN#1 DOTBYMARKING Mechanical data - Case: DFN-10 package, molded plastic. - Terminals: Gold plated, solderable per MIL-STD-750,method 2026. 0.041(1.05) 0.037(0.95) 0.100(2.55) 0.096(2.45) - Low capacitance: 0.5 pF typical (I/O to GND) 0.041(0.55) 0.037(0.45) - Mounting position: Any Circuit Diagram 0.002(0.05) MAX. I/O Pin 4 I/O Pin 2 I/O Pin 1 0.039(0.99) 0.035(0.89) 0.016(0.40) 0.012(0.30) I/O Pin 5 0.001(0.03) BSC. 0.020(0.50) BSC. 0.020(0.50) BSC. 0.079(2.00) BSC. GND Pin 3 & 8 Dimensions in inches and (millimeters) Package N/C N/C 10 9 N/C N/C 8 7 6 ● GND 1 I/O 2 I/O 3 4 I/O 5 I/O 1 = Pin 1 indicator BSC. 0.010(0.255) 0.096(0.245) 0.023(0.59) 0.018(0.45) 0.014(0.35) PLR0524 ESD Protection Array Maximum Rating (at TA=25°C unless otherwise noted) Symbol Value Unit Peak pulse power ( tp = 8/20us) PPP 90 W Peak pulse current ( tp = 8/20us) IPP 5 A ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) ESD ±15 kV TJ -55 to +125 °C TSTG -55 to +150 °C Parameter Operating temperature range Storage temperature range Electrical Characteristics (at TA=25°C unless otherwise noted) Parameter Symbol Conditions Reverse stand-off voltage Typ Max Unit VRWM 5 V 1.2 V Forward voltage IF = 10 mA VF Breakdown voltage IT = 1 mA VBR Leakage current VRWM = 5V IR IPP = 1A, TP = 8/20us, I/O Pin to GND VC IPP = 5A, TP = 8/20us, I/O Pin to GND VR = 0V, f = 1MHZ I/O Pin to GND Min 6 V 0.1 uA 9 12 V VC 15 18 V Cj 0.5 0.7 pF Clamping voltage Junction capacitance 2 PLR0524 ESD Protection Array RATING AND CHARACTERISTIC CURVES (PLR0524) Fig.1 - 8/20us Peak Pulse Current Waveform ACC. IEC 61000-4-5 Percentage of Ipp 100 Test Waveform parameters tf=8us td=20us Ta=25°C Peak Valur Ipp 100% Fig.2 - Forward Characteristics Forward Current, (mA) 120% e-t 80% 60% 40% td= t Ipp/2 T A =125°C T A =100°C 10 T A =75°C T A =50°C T A =25°C 1 20% 0% 0 0 5 10 15 20 25 0.4 30 0.6 0.8 1.0 Time, (us) Forward Voltage, (V) Fig.3 - Typical Clamping Voltage Vs. Peak Pulse Current Fig.4 - Power Rating Derating Curve 20 1.2 120 16 Power Rating, (%) Clamping Voltage, (V) Mounting on glass epoxy PCBs 100 12 8 4 Waveform Parameters: tr=8us td=20us 0 1 3 2 4 0 Capacitance Between Terminals, (pF) 0.6 0.4 0.2 0 3 25 50 75 100 Ambient Temperature, ( °C ) 0.8 2 40 0 5 Fig.5 - Typical Capacitance Between Terminals Characteristics 1 60 20 Peak Pulse Current, (A) 0 80 4 5 Reverse Voltage, (V) 3 125 PLR0524 ESD Protection Array Reel Taping Specification d P0 P1 T E Index hole .xxxx F W B C P A 12 o 0 D2 D1 D W1 Trailer Device ....... ....... End ....... ....... Leader ....... ....... ....... ....... 160mm (min) Start 400mm (min) Direction of Feed DFN-10 DFN-10 SYMBOL A B C d D D1 D2 (mm) 1.14 ± 0.05 2.64 ± 0.05 0.64 ± 0.05 1.50 + 0.10 - 0 178.00 ± 1.00 60.00 ± 0.50 13.50 ± 0.20 (inch) 0.045 ± 0.002 0.104 ± 0.002 0.025 ± 0.002 0.059 + 0.004 - 0 7.008 ± 0.039 2.362 ± 0.020 0.531 ± 0.008 SYMBOL E F P P0 P1 T W W1 (mm) 1.75 ± 0.10 3.50 ± 0.05 4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 0.20 ± 0.05 8.00 ± 0.30 12.00 + 0.50 - 0 (inch) 0.069 ± 0.004 0.138 ± 0.002 0.157 ± 0.004 0.157 ± 0.004 0.079 ± 0.002 0.008 ± 0.002 0.315 ± 0.012 0.472 + 0.020 - 0 4 PLR0524 ESD Protection Array Suggested PAD Layout DFN-10 SIZE (mm) (inch) A 2.30 0.091 B 1.00 0.039 C 0.38 0.015 D 0.30 0.012 A B G C E 0.30 0.012 F 0.50 0.020 G 0.24 0.009 D Standard Packaging Case Type DFN-10 Qty Per Reel Reel Size (Pcs) (inch) 3,000 7 5 E F
PLR0524 价格&库存
很抱歉,暂时无法提供与“PLR0524”相匹配的价格&库存,您可以联系我们找货
