M1F~M7F
1.0Amp Standard Surface Mounted Rectifiers
SMAF
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Idea for printed circuit board
Glass passivated Junction chip
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed
250 C/10 seconds at terminals
Mechanical Data
Case : Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0014 ounce, 0.038 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,
for capacitive load current derate by 20%.
Parameter
SYMBOLS
M1F
M2F
M3F
M4F
M5F
M6F
M7F
UNITS
Maximum repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC blocking voltage
VDC
50
100
200
400
600
800
1000
V
Maximum average forward rectified current
at TL =100 C
I(AV)
1.0
A
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
IFSM
30.0
A
Maximum instantaneous forward voltage at 1.0A
VF
1.10
V
Maximum DC reverse current T A =25 C
at rated DC blocking voltage TA=125 C
IR
5.0
500
uA
Typical junction capacitance (Note1)
CJ
15.0
pF
RqJA
70.0
C/W
-55 to +150
C
Typical thermal resistance
Operating junction and storage temperature range TJ,TSTG
Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
1/3
M1F~M7F
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT PERLEG
35
Peak Forward Surage Current
Amperes
1.0
0.9
0.8
Amperes
Average Forward Rectified Current
FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT
0.7
0.6
0.5
0.4
0.3
0.2
60
80
100
120
140
30
25
f=60Hz
10
5
1Cycle
1
100
Number of cycles
FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS
FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS
Amperes
1
0.1
TJ=25
Pulse Width=300us
1% Duty Cycle
0.01
0.2 0.4
0.6
0.8
1.0
1.2
1.4
1.6
100
Micro Amperes
Instantaneous Reverse Leakage Current
Lead Temperature
10
Instantneous Forward Current
10
Volts
Instantaneou Foward Voltage
Tj = 125°C
10
1.0
Tj = 25°C
0.1
0.01
60
80
100
120
140
Percent Of Rated Peak Reverse Voltage(%)
Suggested Pad Layout
2/3
Symbol
Unit (mm)
Unit (inch)
A
0.066
B
1.68
1.52
C
3.90
0.154
D
2.00
0.078
E
5.10
0.200
0.060
M1F~M7F
Suggested Soldering Temperature Profile
Note
R ecom m ended reflow m ethods: IR , vap or phase ov en, hot air oven, w ave solder.
Th e dev ice can b e exp osed to a m axim um tem p erature of 265 °C for 10 second s.
D evices can b e cleaned using standa rd industry m ethods and solvents.
If reflow tem peratures exceed the re c o m m e n d e d p ro file , d e v ic e s m a y n o t m e e t th e
p e rfo rm a n c e re q u ire m e n ts .
Package Information
Carrier Dimension(mm)
A0
B0
K0
D0
E
F
2.83
4.75
1.42
1.55
1.75
5.50
P0
P1
P2
T
W
Tolerance
4.0
4.0
2.0
0.25
12
0.1
Package Specifications
Reel DIA.
(mm)
Q'TY/Reel
(Kpcs)
Box Size
(mm)
QTY/Box
(Kpcs)
Carton Size
(mm)
Q'TY/Carton
(Kpcs)
7'
178
3
180
12
380*200*200
120
11'
278
7.5
285
15
355*310*310
120
Package Reel Size
SMAF
3/3
很抱歉,暂时无法提供与“M7F(M7)”相匹配的价格&库存,您可以联系我们找货
