PRG3216P-5102-B-T5
PRG3216P-5102-B-T5
    SUSUMU
    贴片电阻 1206 51KΩ ±0.1% 1W ±25ppm/℃
PRG3216P-5102-B-T5 数据手册
High power thin film chip resistors (long side terminal) ■PRG series AEC-Q200 Compliant Features ・ Long side terminal enabling higher power capability ・ Significantly larger power handling capability than conventional same size resistors Thin film surface mount resistors Size: 2010 ~ 6432, power ratings: 0.5 ~ 3.0W, Resistance range: 2.5 ~ 250KΩ ・ Precision resistance tolerance: ±0.1%, very small TCR: ±25ppm/°C ・ Thin film structure enabling low noise and anti-sulfur Applications ・ Automotive electronics ・ DC motor, inverters PRG series ・ Robotics, Industrial control system ◆Part numbering system PRG 3216 Series code P - 1001 - B - T5 Packaging quantity: T4(4,000pcs) (PRG6432, PRG5025) T5(5,000pcs) (PRG3216, PRG2010) Size: PRG2010, PRG3216    PRG5025, PRG6432 Resistance tolerance Temperature coefficient of resistance Nominal resistance value (E-24, E-96: all 4 digit) ◆Electrical Specification Type Power ratings Temperature coefficient of resistance (ppm/°C) Resistance range(Ω) Resistance tolerance ±0.1% (B) 0.5W Resistance value series Operating temperature Packaging quantity ±0.5% (D) 10≦R≦25k ±25(P) PRG2010 Maximum voltage 47≦R≦25k 100V ±50(Q) 2.5≦R≦25k ±25(P) 10≦R≦100k T5 PRG3216 1.0W 47≦R≦100k 150V ±50(Q) 2.5≦R≦100k ±25(P) 10≦R≦200k E-24, E-96 PRG5025 1.5W ~ 2.0W 47≦R≦200k 200V ±50(Q) 2.5≦R≦200k ±25(P) 10≦R≦250k T4    PRG6432 2.0W ~ 3.0W 47≦R≦250k ±50(Q) 25 -55℃ ~ 155℃ 400V 2.5≦R≦250k ◆Dimensions Type L a a W Size (inch) W L a b t 0804 2.00±0.20 1.00±0.20 0.20±0.10 0.25±0.10 0.35±0.10 PRG3216 1206 3.20+0.40/-0.20 1.60±0.20 0.30±0.20 0.35±0.20 0.45+0.15/-0.10 PRG5025 2010 5.00±0.20 2.50±0.20 0.55±0.20 0.60±0.20 0.45+0.15/-0.10 PRG6432 2512 6.40+0.20/-0.40 3.20±0.20 0.40±0.20 0.55±0.20 0.45+0.15/-0.10 t b b (unit:mm) PRG series ◆Reliability specification Standard ≦47Ω ≧47Ω Test items Condition (test methods (JIS C5201-1) Life (biased) 70℃, rated voltage,* 1 90min on 30min off, 1000hours ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) High temperature high humidity 85℃, 85%RH, 1/10 of rated power, 90min on 30min off, 1000hours ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) Temperature shock -55℃ (30min) ~ 125℃ (30min) 1000cycles ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) High temperature exposure 155℃, no bias, 1000hours ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) Resistance to soldering heat 260±5℃, 10 seconds (reflow) *1 Thin film surface mount resistors PRG2010 ±(0.1%+0.01Ω) ±(0.05%+0.01Ω) Rated voltage is given by E= R x P E= rated voltage (V), R=nominal resistance value(Ω), P=rated power(W) If rated voltage exceeds maximum voltage /element, maximum voltage/element is the rated voltage. 26 High power thin film chip resistors (long side terminal) ■PRG series ◆Reliability test data 0.12 0.12 0.10 0.10 0.08 0.08 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 -0.08 -0.10 -0.10 -0.12 PRG series Resistance drift(%) Resistance drift(%) Thin film surface mount resistors ○Biased life test -0.12 10         100        1000       10000 Test duration(h) 10         100        1000       10000 Test duration(h) 0.30 Resistance drift(%) 0.25 0.20 0.15 0.10 0.05 0.00 -0.05 -0.10 -0.15 -0.20 -0.25 -0.30 10         100        1000       10000 Test duration(h) 0.30 0.12 0.25 0.10 0.20 0.08 Resistance drift(%) Resistance drift(%) ○High temperature high humidity (biased) 0.15 0.10 0.05 0.00 -0.05 -0.10 -0.15 -0.20 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 -0.25 -0.30 0.06 -0.10 -0.12 10        100         1000       10000 0.12 0.12 0.10 0.10 0.08 0.08 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.10 10        100        1000       10000 Test duration(h) 27 0.06 -0.08 -0.10 -0.12 10        100         1000       10000 Test duration(h) Resistance drift(%) Resistance drift(%) Test duration(h) -0.12 10        100        1000       10000 Test duration(h) 0.12 0.12 0.10 0.10 0.08 0.08 Resistance drift(%) Resistance drift(%) ○Temperature shock 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 -0.10 -0.10 -0.12 10cycle    100cycle     1000cycle    10000cycle Test duration(h) 0.12 0.25 0.10 0.20 0.08 Resistance drift(%) 0.30 0.15 0.10 0.05 0.00 -0.05 -0.10 -0.15 -0.20 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 -0.25 -0.30 10cycle    100cycle     1000cycle    10000cycle PRG series Resistance drift(%) Test duration(h) Thin film surface mount resistors -0.12 0.06 -0.10 -0.12 10cycle    100cycle     1000cycle    10000cycle Test duration(h) 10cycle    100cycle     1000cycle    10000cycle Test duration(h) 0.12 0.12 0.10 0.10 0.08 0.08 Resistance drift(%) Resistance drift(%) ○High temperature exposure 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 -0.10 -0.12 0.06 -0.10 -0.12 10        100         1000       10000 0.30 0.12 0.25 0.10 0.20 0.08 0.15 0.10 0.05 0.00 -0.05 -0.10 -0.15 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.20 -0.08 -0.25 -0.10 -0.30 10        100         1000       10000 10        100         1000       10000 Test duration(h) Resistance drift(%) Resistance drift(%) Test duration(h) -0.12 Test duration(h) 10        100         1000       10000 Test duration(h) ◆Derating Curve ○PRG6432 Ratio to rated power (%) Ratio to rated power (%) ○PRG3216 100 50 0 -55     0     50 70  100     155 Ambient temperature (℃) 100 2.0W 50 0 3.0W -55     0   25  50 70  100     155 Ambient temperature (℃) 28
PRG3216P-5102-B-T5
物料型号:PRG系列
器件简介:PRG系列是高功率薄膜芯片电阻器,符合AEC-Q200标准,无卤素,符合RoHS指令。
引脚分配:长边端子设计,提高了功率承载能力。
参数特性: - 尺寸范围:2010至6432,功率等级:0.5至3.0W - 电阻范围:2.5至250KΩ - 精度电阻公差:±0.1%,温度系数:±25ppm/°C - 薄膜结构,低噪音,抗硫
功能详解: - 适用于汽车电子、直流电机、变频器、机器人、工业控制系统等。
应用信息: - 根据尺寸和功率等级,PRG系列有多种型号,如PRG2010、PRG3216、PRG5025和PRG6432。
封装信息: - 包装数量:T4(4000件)和T5(5000件)。
电气规格表提供了不同型号的功率等级、电阻温度系数、电阻范围、电阻公差、最大电压、电阻值系列和工作温度范围。
可靠性规格表列出了寿命测试、高温高湿测试、温度冲击测试、高温暴露测试和耐焊热测试的条件和标准。
图表显示了在不同条件下电阻值的漂移情况,包括偏置寿命测试、高温高湿(偏置)、温度冲击和高温暴露测试。
PRG3216P-5102-B-T5 价格&库存
很抱歉,暂时无法提供与“PRG3216P-5102-B-T5”相匹配的价格&库存,您可以联系我们找货
