MA1206XF106K160
MA1206XF106K160
    MERITEK
    贴片电容(MLCC) 1206 10µF ±10% 16V X5R
MA1206XF106K160 数据手册
Multilayer Ceramic Chip Capacitor MA Series High Capacitance Type FEATURE  A wide selection of sized is available (0201 to 2225)  High capacitance in given case size  Capacitor with lead-free termination  RoHS and HALOGEN compliant. PART NUMBERING SYSTEM MA 1812 XR 105 C 250 (1) (2) (3) (4) (5) (6) No Item (1) Meritek Series (2) Size (3) Dielectric MA 1812 XR (4) Capacitance (5) Tolerance (6) Rated Voltage RoHS Code 105 K 250 Description Series Reference Multilayer Ceramic Chip Capacitor High Capacitance Type EIA size or footprint 0201, 0402,0603, 0805, 1206, 1210, 1812, 1825, 2220, 2225 XR: X7R XF: X5R, YV: Y5V, XM: X6S, XS: X7S 5 105: 10x10 pF = 1µF 1µF ~ 220µF K: ±10% K: ±10%, M: ±20%, Z: -20% ~ +80% Working Voltage: 25VDC 4R0: 4.0VDC ~ 631: 630VDC DIMENSIONS EIA Size L(mm) W(mm) 0201 0402 0603 0805 1206 1210 1812 1825 2220 2225 0.60±0.03 1.00±0.10 1.60±0.15 2.00±0.20 3.20±0.20 3.20±0.30 4.50±0.40 4.50±0.40 5.70±0.40 5.70±0.40 0.30±0.03 0.50±0.10 0.80±0.15 1.25±0.20 1.60±0.20 2.50±0.30 3.20±0.30 6.30±0.40 5.00±0.40 6.30±0.40 T MB(mm) See Thickness Specification Reference Table 0.15±0.05 0.25+0.05/-0.10 0.40±0.15 0.50±0.20 0.60±0.20 0.75±0.35 0.75±0.35 0.75±0.35 0.85±0.35 0.85±0.35 THICKNESS SPECIFICATION REFERENCE Code Thickness (mm) Code Thickness (mm) Code Thickness (mm) A B C D E F G H 0.60 ± 0.10 0.8 + 0.15/-0.10 1.25 ±0.10 1.40 ±0.15 1.60 ±0.20 2.00 ±0.20 2.50 ±0.30 2.80 ±0.30 I J K L M N O P 1.25 ±0.20 1.15 ±0.15 0.50 ±0.20 0.30 ±0.03 0.95 ±0.10 0.50 ±0.05 3.50 ±0.20 1.60 +0.3/-0.10 Q R S T U V X Z 0.50 +0.02/-0.05 3.10 ±0.30 0.80 ±0.07 0.85 ±0.10 0.50 ±0.10 0.20 ±0.02 0.80 ±0.10 0.25 ±0.03 Meritek Electronics Corporation | www.meritekusa.com Rev. 8a 03/02/18 Multilayer Ceramic Chip Capacitor MA Series High Capacitance Type ELECTRICAL CHARACTERISTICS Item Characteristics Dielectric X7R X7S X6S X5R Y5V 0402, 0603, 0805, 1206, 1210 0201, 0402, 0603, 0805, 1206, 1210 0201, 0402, 0603, 0805, 1206, 1210 0402, 0603, 0805, 1206, 1210, 1812 6.3V, 10V, 16V, 25V, 50V, 100V 6.3V, 10V, 16V, 25V, 35V, 50V 4V, 6.3V, 10V, 16V, 25V, 35V, 50V 6.3V, 10V, 16V, 25V, 35V, 50V, 100V 1μF ~ 47μF 1μF ~ 100μF 1μF ~ 100μF 1μF ~ 220μF 1μF ~ 100μF K (±10%), M (±20%) K (±10%), M (±20%) K (±10%), M (±20%) K (±10%), M (±20%) Z (-20/+80%) 0402, 0603, 0805, 1206, 1210,1812, 1825, 2220, 2225 6.3V, 10V, 16V, 25V, 50V, 100V, 250V, 500V, 630V Chip Size Rated Voltage Capacitance Cap. Tolerance Dissipation Factor See Dissipation Factor Table Below Operating Temperature -55°C ~ 125°C -55°C ~ 125°C -55°C ~ 105°C -55 ~ 85°C -25 ~ 85°C Temperature Coefficient ±15% ±22% ±22% ±15% +30/-80% Termination Cu or Ag / Ni / Sn or Au (lead-free termination) DISSIPATION FACTOR X7R/X5R/X6S/X7S Rated Vol. Y5V D.F. Exception of D.F. ≤3% ≥100V 50V 35V 25V ≤2.5% ≤2.5% ≤3.5% ≤3.5% 0805>0.1µF, 0603≥ 0.068µF, 1206>1µF, 1210≥ 2.2µF ≤10% 0805>0.22µF, 1210≥3.3µF ≤3% 0201(50V), 0603≥ 0.047µF, 0805≥ 0.18µF, 1206≥ 0.47µF, 1210≥3.3µF, 1812≥10µF, 2220≥22µF ≤5% 0201≥ 0.01uF, 1210≥ 4.7µF ≤10% 0402≥ 0.1µF, 0603>0.1µF, 0805≥ 1µF, 1206≥ 2.2µF, 1210≥ 10µF 0603≥ 1µF, 0805≥2.2µF, 1206≥2.2µF, 1210≥10µF ≤5% 0201≥ 0.01µF, 0805≥ 1µF, 1210≥ 10µF ≤7% 0603≥ 0.33µF, 1206≥ 4.7µF ≤10% 0201≥ 0.1µF, 0402≥ 0.10µF, 0603≥ 0.47µF, 0805≥ 2.2µF, 1206≥ 6.8µF, 1210≥ 22µF ≤12.5% ≤5% 16V ≤3.5% ≤10% 10V 6.3V 4V ≤5% ≤10% ≤15% ≤10% ≥50V ≤5% Exception of D.F. ≤ ≤7% ≤12.5% 35V ≤7% --≤7% 25V ≤5% ≤9% 16V (C10µpF, at 20°C at ambient temperature  Y5V: Apply 1.0±0.2Vrms, 1.0KHz±10% for Cap.≤10μF and 0.5±0.2Vrms, 120Hz±20% for Cap.>10μF, at 20°C ambient temperature.  Preconditioning for class II MLCC: perform a heat treatment at 150±10°C for 1 hour, then leave in ambient condition for 24±2 hours before measurement. --- Meritek Electronics Corporation | www.meritekusa.com Rev. 8a 03/02/18 Multilayer Ceramic Chip Capacitor MA Series High Capacitance Type CAPACITANCE RANGE AND THICKNESS X7R Dimension 0402 0603 0805 Cap. Code 6.3V 6.3V 10V 16V 25V 50V 1.0µF 105 N B B B B B 1.2µF 125 1.5µF 155 1.8µF 185 2.2µF 225 2.7µF 275 3.3µF 335 3.9µF 395 4.7µF 475 5.6µF 565 6.8µF 685 8.2µF 825 10µF 106 12µF 126 15µF 156 18µF 186 22µF 226 47µF 476 Dimension Cap. Code 1.0µF 105 1.2µF 125 1.5µF 155 1.8µF 185 2.2µF 225 2.7µF 275 3.3µF 335 3.9µF 395 4.7µF 475 5.6µF 565 6.8µF 685 8.2µF 825 10µF 106 12µF 126 15µF 156 18µF 186 22µF 226 47µF 476 Dimension Cap. Code 1.0µF 105 1.2µF 125 1.5µF 155 1.8µF 185 2.2µF 225 2.7µF 275 3.3µF 335 3.9µF 395 4.7µF 475 5.6µF 565 6.8µF 685 8.2µF 825 10µF 106 12µF 126 15µF 156 18µF 186 22µF 226 47µF 476 B B 6.3V B 6.3V G 25V F F F F F F F F F F F G G H H H H 1210 16V 25V C C 10V C E E E E E E 50V C G G G G G G F F F G F F F G G G G G 50V F F F F F F F F F F F G G 100V F F F F F F F F F F F G G H 2220 200V F G G G G H 16V 25V 50V C C C I I B 250V F G G G G H 100V F G G G G G G G 500V H 1206 10V I I I I I I I I I I I I* I I 10V C 16V C 25V C C C E E F F F G G G G G 1812 50V F F F F F F F F G G G G G 630V H 25V F F F F F F F F F F F G G H H H H 50V F F F F F F F F F F F G G 100V F F F F F F F F G G G G G 100V F F F F G G G G G G 2225 200V F G G G G G H H 6.3V 10V 16V 25V 50V 100V J J J P P P P P P P J J J P P J J J P P P P P P P P P P P P P P P P P P* 200V G 250V G 25V G 250V F G G G G G H H 500V G H H 630V G H H 50V F F F F F F F F F G G G G 1825 100V F F F F F F F F G G G G G 200V F G G G G H P 250V F G G G G H H Note: * indicates M tolerance only. Meritek Electronics Corporation | www.meritekusa.com Rev. 8a 03/02/18 Multilayer Ceramic Chip Capacitor MA Series High Capacitance Type CAPACITANCE RANGE AND THICKNESS (CONTINUED) X7S Dimension Cap. Code 1.0µF 105 2.2µF 225 2.7µF 275 4.7µF 475 6.8µF 685 10µF 106 22µF 226 47µF 476 100µF 107 0402 6.3V 0603 10V 10V 16V 0805 25V 16V 25V 1206 50V K K 100V 6.3V 1210 16V 6.3V I K B B B B I I I I P* P* G* X6S Dimension 0201 0402 0603 Code 4V 6.3V 6.3V 10V 16V 25V 1.0µF 105 L L* K K K K 2.2µF 225 K K 4.7µF 475 10µF 106 22µF 226 47µF 476 I* 100µF 107 I* K K* Code 1.0µF 105 2.2µF 225 4.7µF 475 10µF 106 22µF 226 47µF 476 100µF 107 B* B* 1206 6.3V 6.3V 10V 16V 25V B B B B B K* Dimension Cap. 4V 0805 Cap. B* B* 4V 6.3V 10V 16V I I I I I* I* I* B* 25V 50V I I I I* 1210 10V 16V P P* 25V 6.3V 10V 16V G G G G* G* 25V P P P G X5R Dimension 0201 0402 Cap. Codee 6.3V 10V 16V 1.0µF 105 L L L 1.5µF 155 2.2µF 225 3.3µF 335 4.7µF 475 6.8µF 685 10µF 106 22µF 226 47µF 476 100µF 107 220µF 227 Code 1.0µF 105 1.5µF 155 2.2µF 225 3.3µF 10V 16V 25V N N N N L N K N K K K K 25V 50V C C C I I I I I I I I I 335 I I I I 4.7µF 475 I I I I 6.8µF 685 10µF 106 I I I I 22µF 226 I I I I I I 476 107 220µF 227 6.3V 10V 16V 25V 50V B B B B B K B B B B B B B B B B B B B B B B B B B B B 50V 4V K K 4V I 6.3V 1206 16V 47µF 4V 0805 10V 100µF 0603 6.3V B Dimension Cap. 4V 4V 6.3V 10V 1210 16V 25V 6.3V 10V 16V 25V 35V 50V G P J J J J P P P P P P P P P P P P P P P P I I I I F F P F F P P F F P P P P P P P Meritek Electronics Corporation | www.meritekusa.com G F F F F F G G G G G G G G G G G G G G Rev. 8a 03/02/18 Multilayer Ceramic Chip Capacitor MA Series High Capacitance Type CAPACITANCE RANGE AND THICKNESS (CONTINUED) Y5V Dimension 0402 0603 6.3V 0805 Cap. Code 6.3V 10V 1.0µF 105 N N 1.5µF 155 2.2µF 225 3.3µF 335 4.7µF 475 6.8µF 685 10µF 106 I I 22µF 226 I I 47µF 476 100µF 107 Code 1.0µF 16V 25V S B B 6.3V S S S B B B 1206 10V 16V 25V 50V X X C C C C C C C C C C I 6.3V I I I I 10V 16V 25V M M M M M M M M M J J J J J J J J J J P P 35V 50V M J J P P P Dimension Cap. 10V 1210 6.3V 1812 10V 16V 25V 105 M M M 1.5µF 155 M M M 2.2µF 225 M M M 3.3µF 335 M M M 4.7µF 475 M M C 6.8µF 685 M M C 10µF 106 C C E 22µF 226 F F 47µF 476 F 100µF 107 G 35V 50V 10V 16V 25V 50V 100V M C C C C C C C C C C C C C C C C C E C C C C F C C C C F C C C F E F F G RELIABILITY TEST CONDITIONS AND REQUIREMENTS Item Visual and Dimensions Capacitance Q/ D.F. (Dissipation Factor) Test Condition --Class II: X7R,X7S, X6S, X5R,Y5V Cap≤10μF, 1.0±0.2Vrms, 1kHz±10% Cap>10μF, 0.5±0.2Vrms, 120Hz±20% Requirements No remarkable defect. Dimensions to confirm to individual specification sheet. Within specification Test condition: 0.5±0.2Vrms,1KHz±10% X7R: 0603=475(6.3V), 0805=106(6.3V&10V) X6S: 0201≥104(6.3V&10V), 0402≥225(6.3V), 0402/475(10V), 0603/106(6.3V). X5R: 01R5≥103, 0201≥224 (6.3V, 10V, 16V), 0402≥475 (6.3V, 16V), 0402≥225(10V), 0603=106 (6.3V, 10V) Dielectric Strength To apply voltage : Rated Voltage Condition ≤100 2.5 times of UR 1000.1μF, 0402≥1μF, 0603≥10μF, 0805≥47μF 6.3V : 0201≥0.1μF, 0603>4.7μF, 0805≥47μF, 1206≥10μF 4V : 0603≥22μF, 0805≥47μF, 1206≥100μF Temperature Coefficient With no electrical load. T.C. Operation Temp. X7R -55~125°C at 25°C X7S -55~125°C at 25°C X6S -55~105°C at 25°C X5R -55~85°C at 25°C Y5V -25~85°C at 20°C Measurement Voltage for Class II: Size Cap Condition Cap
MA1206XF106K160
物料型号:MERITEK MA系列,是多层陶瓷片式电容器的高电容型。
器件简介: - 提供多种尺寸选择(0201至2225)。 - 在给定的封装尺寸下具有高电容。 - 无铅端子的电容器。 - 符合RoHS和无卤素标准。
引脚分配:未在文档中明确说明具体的引脚分配,但通常这类电容器为表面贴装元件,具有两个端子用于连接电路。
参数特性: - 尺寸范围广,从0201到2225的EIA尺寸。 - 根据电介质类型(如X7R、X5R、Y5V等),有不同的电容值、公差和额定电压。 - 电容值范围从1pF到220μF。 - 公差有±10%、±20%和-20%到+80%等。 - 额定电压范围从4VDC到630VDC。
功能详解: - 电容器的电气特性,包括介电类型、额定电压、电容值、公差、耗散因子、工作温度范围和温度系数。 - 提供了不同额定电压下的耗散因子表格。
应用信息: - 适用于需要高电容值和小型化设计的应用场合。
封装信息: - 提供了详细的尺寸信息,包括EIA尺寸、长度、宽度、厚度和最大尺寸偏差。
可靠性测试条件和要求: - 包括视觉和尺寸检查、电容值测试、耗散因子、耐电压、额定电压、焊接性和耐焊接热性测试等。
推荐焊接曲线:提供了预热、回流和冷却阶段的温度和时间设置。
包装尺寸和数量:列出了不同尺寸电容器的卷装尺寸和数量。
存储和处理:建议在推荐的条件下存储,并注意处理时避免损坏。
预热、焊接和清洁:提供了焊接前的预热、焊接过程中的注意事项以及焊接后的清洁指南。
MA1206XF106K160 价格&库存
很抱歉,暂时无法提供与“MA1206XF106K160”相匹配的价格&库存,您可以联系我们找货
