HCSM2818FT10L0
HCSM2818FT10L0
    SEI
    贴片电阻 - 10mΩ ±1% 5W ±75ppm/℃
HCSM2818FT10L0 数据手册
HCSM Series Stackpole Electronics, Inc. High Power Metal Element Current Shunt Resistor Resistive Product Solutions Features: • • • • • • 5W power rating in a small chip size 2818 size Excellent long-term stability 100% RoHS compliant and lead free without exemption Halogen free AEC-Q200 compliant REACH compliant Applications: • • • • • Power modules Frequency converters Inverter control Power management Current sensor for power hybrid sources Electrical Specifications Type / Code Power Rating (W) TCR (ppm/ºC) HCSM2818 5 ± 200 ± 75 Ohmic Range (Ω) and Tolerance 1% and 5% 0.003, 0.004, 0.005 (*) 0.01, 0.015, 0.02, 0.025 (*) (*) Other values may be available, but may require higher MOQ. Contact Stackpole. Mechanical Specifications Type / Code L W H T Unit HCSM2818 0.281 ± 0.010 7.15 ± 0.25 0.195 ± 0.010 4.95 ± 0.25 0.065 ± 0.010 1.65 ± 0.25 0.114 ± 0.010 2.90 ± 0.25 inches mm Power Derating Curve: Percent Rated Power (%) 100 -55ºC 100ºC 80 60 40 20 0 -60 170ºC 0 20 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 60 80 100 120 140 160 180 Terminal Temperature (ºC) Operating temperature range of -55ºC to 170ºC. Storage condition: 5ºC ~ 35ºC, humidity of 40% ~ 75%. Rev Date: 3/11/2021 40 1 www.seielect.com marketing@seielect.com HCSM Series High Power Metal Element Current Shunt Resistor Stackpole Electronics, Inc. Resistive Product Solutions Environmental Performance Characteristics Test Test Method Test Specification Test Condition Short Time Overload JIS-C5202-5.5 ΔR: ± (1% + 0.0005 Ω) 4 times rated power for 5 seconds Temperature Coefficient of Resistance (TCR) JIS-5202-5.2 Refer to Electrical Specifications Damp Heat with Load MIL-STD-202 Method 103 ΔR: ± (1% + 0.0005 Ω) The specimens shall be placed in a chamber and subjected to a relative humidity of 90 ~ 95% and a temperature of 40°C ± 2°C for a period of 1000 hours with applied rated power, 1.5 hours ON and 0.5 hour OFF. High Temperature Exposure JIS-C5202-7.2 ΔR: ± (1% + 0.0005 Ω) The chip (mounted on board) is exposed in the heat chamber, 125ºC ± 3°C for 1000 hours Load Life JIS-C5202-7.10 ΔR: ± (1% + 0.0005 Ω) Apply rated power at 70°C ± 2°C for 1000 hours with 1.5 hours ON and 0.5 hour OFF. +25ºC / +125ºC TCR (ppm/ºC) = ΔR R x Δt 6 x 10 The chip (mounted on board) is exposed, -55°C ± 3ºC (30 minutes) / +125 ± 2ºC (30 minutes) for 5 cycles. The following conditions as the figure below. Rapid Change of Temperature JIS-C5202-7.4 ΔR: ± (1% + 0.0005 Ω) Operating temperature range is -55°C to +170°C Function Performance Characteristics Test Test Method Test Specification Test Condition Mount the chip to test substrate. Apply pressure in direction of arrow unit band width reaches 2 mm (+0.2 / -0 mm) illustrated in the picture below and hold for 10 ± 1 seconds. (JIS-C5202-6.1) JIS-C5202-6.1 ΔR: ± (1% + 0.0005 Ω) Solvent Resistance MIL-STD-202, Method 215 Verify marking permanency. (Not required for laser etched parts or parts with no marking). The chip is completely immersed in isopropyl alcohol for 3 (+5/-0) minutes at 25°C ± 5°C. Resistance to Solder Heat MIL-STD-202, Method 210 ΔR: ± (1% + 0.0005 Ω) The chip shall be immersed into the flux specified in the solder bath 260°C ± 5°C for 10 ± 1 seconds. Bending Strength Rev Date: 3/11/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com HCSM Series Stackpole Electronics, Inc. High Power Metal Element Current Shunt Resistor Resistive Product Solutions Function Performance Characteristics (cont.) Test Test Method Test Specification Test Condition The chip shall be immersed into the flux specified in the solder bath 235°C ± 5°C for 2 ± 0.5 seconds. It shall be immersed to a point 10mm from its root. (Sn96.5/Ag3.0/Cu0.5) Solderability JIS-C5202-6.11 Solder shall cover 95% or more of the electrode area 2 Note: 5W with total solder pad trace size of 500 mm . The surface temperature of component should be below 100°C. Taping Specifications – Embossed Plastic Tape Type / Code A B E F W t Unit 0.205 ± 0.004 5.21 ± 0.10 0.303 ± 0.004 7.69 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.295 ± 0.004 7.50 ± 0.10 0.630 ± 0.012 16.00 ± 0.30 0.012 ± 0.002 0.30 ± 0.05 inches mm P0 P1 P2 D0 D1 Unit 0.157 ± 0.004 4.00 ± 0.10 0.315 ± 0.004 8.00 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 0.059 ± 0.004 1.50 ± 0.10 inches mm HCSM2818 Recommended Pad Layouts Type / Code a b c d Unit HCSM2818 0.138 3.50 0.209 5.30 0.020 0.50 0.024 0.60 inches mm Rev Date: 3/11/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com HCSM Series High Power Metal Element Current Shunt Resistor Stackpole Electronics, Inc. Resistive Product Solutions Soldering Recommendations: • • • Peak reflow temperatures and durations ✓ IR Reflow Peak = 260ºC max for 10 seconds ✓ Wave Solder = 260ºC max for 10 seconds Compatible with lead and lead-free solder reflow processes Recommended IR reflow profile: RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type HCSM High Current Shunt Resistor SMD Standard Series RoHS Compliant YES Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) 100% Copper Always Lead-Free Effective Date Code (YY/WW) Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 3/11/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com HCSM Series Stackpole Electronics, Inc. High Power Metal Element Current Shunt Resistor Resistive Product Solutions Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 H C S M 2 8 1 8 F T 2 0 L 0 Product Series HCSM Size 2818 Tolerance Code Tol F 1% J 5% Code T Packaging Description 13" Reel - Plastic Tape Resistance Value Size 2818 Quantity 3500 Four characters with "L" used as multiplier of 10-3 for any value under 0.1 ohm 0.004 ohm = 4L00 0.01 ohm = 10L0 0.015 ohm = 15L0 Rev Date: 3/11/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com
HCSM2818FT10L0 价格&库存
很抱歉,暂时无法提供与“HCSM2818FT10L0”相匹配的价格&库存,您可以联系我们找货
HCSM2818FT10L0
  • 3500+4.077103500+0.52297
  • 7000+3.828207000+0.49105
  • 10500+3.7004110500+0.47465
  • 17500+3.5558917500+0.45612
  • 24500+3.5326324500+0.45313
库存:5957
HCSM2818FT10L0
    HCSM2818FT10L0
    • 1+13.605091+1.74513
    • 10+8.9725310+1.15091
    • 25+7.7081325+0.98873
    • 50+6.9168150+0.88722
    • 100+6.24040100+0.80046
    • 250+5.50099250+0.70562
    • 500+5.03771500+0.64619
    • 1000+4.644251000+0.59572
    库存:5957
