AS03FTE2150A
AS03FTE2150A
    VIKING(光颉)
    贴片电阻 0603 215Ω ±1% 1/10W ±100ppm/℃
AS03FTE2150A 数据手册
Data Sheet Customer: Product: Automotive Grade Anti-Sulfurated Chip Resistor – AS..A Series Size: 0201/0402/0603/0805/1206/1210/2010/2512 Issued Date: 10-Mar-21 Edition: REV.A9 VIKING TECH CORPORATION 光頡科技股份有限公司 VIKING TECH CORPORATION KAOHSIUNG BRANCH 光頡科技股份有限公司高雄分公司 VIKING ELECTRONICS (WUXI) CO., LTD. 光頡電子(無錫)有限公司 No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) Prepared by (Sales) 10-Mar-21 10-Mar-21 10-Mar-21 10-Mar-21 Susan Huang J.C. Liu J.C. Liu Accepted by (Customer) 【AS..A (Chip) Series】 Automotive Grade Anti-Sulfurated Chip Resistor ■Scope -This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. ■Features -Special construction to prevent sulfuration in a sulfur containing environment -AEC-Q200 Compliance -100% CCD inspection ■Construction ■Applications L -Automotive -High-end Computer D1 -Industrial Equipment W     T    D2  Alumina Substrate  Bottom Electrode  Top Electrode -Automatic Equipment Controller -Medical Equipment -High-end Multimedia Electronics -Outdoor Electronic Applications   Edge Electrode  Barrier Layer  External Electrode  Resistor Layer  Primary Overcoat  Secondary Overcoat ■Dimensions Size L W T D1 D2 (Inch) (mm) (mm) (mm) (mm) (mm) Weight (g) (1000pcs) AS01 0201 0.60±0.03 0.30±0.03 0.23±0.03 0.15±0.05 0.15±0.05 0.150 AS02 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 AS03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 AS05 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 AS06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 AS10 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 AS0A 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 AS12 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 Type www.viking.com.tw For detail questions, contact:sales@viking.com.tw 1 Edition : REV.A9 Revision: 10-Mar-2021 【AS..A Series (Chip)】 Automotive Grade Anti-Sulfurated Chip Resistor ■Part Numbering AS 06 F T E 1002 A Product Type Dimensions Resistance Tolerance Packaging Code TCR (PPM/°C) Resistance Making 01: 0201 02: 0402 03: 0603 05: 0805 06: 1206 10: 1210 0A: 2010 12: 2512 D: ±0.5% F: ±1% J: ±5% T: Taping Reel V:10”Taping Reel W:13”Taping Reel E: ±100 F: ±200 - : No Specified 1000: 100Ω 1002: 10KΩ 2201: 2.2KΩ 1003: 100KΩ : Standard A: Automotive Grade Derating Curve ■Recommend Land Pattern ■Derating Curve Power ratio (%) . 100 C B A AS02 AS03 AS05 AS06 AS10 AS0A AS12 80 60 40 AS01 20 0 0 Type A (mm) B (mm) C (mm) AS01 0.30 0.25 0.30 AS02 0.50 0.45 0.60 AS03 0.90 0.60 0.90 AS05 1.20 0.70 1.30 AS06 2.00 0.90 1.60 AS10 2.00 0.90 2.80 AS0A 3.80 0.90 2.80 AS12 4.90 1.60 3.50 20 40 60 80 100 120 140 160 Ambient Temperature ( ℃ ) ■Soldering Condition (IPC/JEDEC J-STD-020) www.viking.com.tw For detail questions, contact:sales@viking.com.tw 2 Edition : REV.A9 Revision: 10-Mar-2021 【AS..A Series (Chip)】 Automotive Grade Anti-Sulfurated Chip Resistor ■Standard Electrical Specifications Item Type Power Rating at 70C Jumper Rated Current Operating Temp. Range Max. Operating Voltage Max. Overload Voltage 1/20W AS01 (0201) Resistance Range ±0.5% ±1% ±5% (E24,E96) (E24,E96) (E24) 25V - 1/16W 50V 100V Jumper: 1A 1/10W 50V 100V Jumper: 1A AS05 (0805) 150V 300V Jumper: 2A AS06 (1206) 1/4W -55 ~ +155C 200V 400V Jumper: 2A AS10 (1210) 200V 400V Jumper: 2.5A AS0A (2010) 3/4W 200V 400V Jumper: 3.5A AS12 (2512) 1W 500V Jumper: 4A 0Ω (
AS03FTE2150A
物料型号:Viking Automotive Grade Anti-Sulfurated Chip Resistor - AS..A Series
器件简介:这是一系列用于汽车级应用的抗硫化芯片电阻器,具备特殊的结构设计,以防止在含硫环境中发生硫化。
引脚分配:文档中没有明确指出具体的引脚分配,但提到了边缘电极和外部电极。
参数特性: - 尺寸范围:0201/0402/0603/0805/1206/1210/2010/2512 - 符合AEC-Q200标准 - 100% CCD检测 - 特殊的结构设计以防止硫化 - 操作温度范围:-55~+125°C 或 -55~+155°C,具体取决于型号 - 最大操作电压和过载电压根据型号有所不同
功能详解: - 适用于汽车、高端计算机、工业设备、自动设备控制器、医疗设备、高端多媒体电子和户外电子应用。
应用信息: - 这些电阻器设计用于在严苛的汽车环境中提供可靠性和稳定性。
封装信息: - 提供多种尺寸的封装选项,每种尺寸都有详细的尺寸参数和重量(1000pcs)。
AS03FTE2150A 价格&库存
很抱歉,暂时无法提供与“AS03FTE2150A”相匹配的价格&库存,您可以联系我们找货
