PU3921FKN130U5L
PU3921FKN130U5L
    YAGEO(国巨)
    贴片电阻 - 500μΩ ±1% 3W ±175ppm/℃
PU3921FKN130U5L 数据手册
DATA SHEET SHUNT RESISTOR PU series 5%, 1% sizes 2512/ 3921/ 5931 Product specification – April 08, 2019 V.6 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SERIES PU 2 9 2512/ 3921/ 5931 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes shunt resistor PU series with lead-free terminations made by welding technology. Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER PU XXXX X X X XX XXXX L (1) APPLICATIONS  Power  Telecom base station  Automotive (Headlight/ Window control/ Engine control unit/ Steering control…)  Alternative energy (2) (3) (4) (5) (6) (7) (1) SIZE 2512/ 3921/ 5931 (2) TOLERANCE F = ± 1% J = ± 5% (3) PACKAGING TYPE K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE FEATURES  AEC-Q200 qualified M = ± 75 ppm/°C  Resistance value down to 0.0001Ω and high power up to 15W G = ± 200 ppm/°C  Welding metal plate construction O = ± 325 ppm/°C N = ± 175 ppm/°C H = ± 225 ppm/°C I = ± 300 ppm/°C (5) TAPING REEL 13 = 13 inch Dia. reel, standard power, 4W for 2512, 3W for 3921 and 5W for 5931 P5 = 5W , 13 inch Dia. reel P6 = 6W , 13 inch Dia. Reel P7 = 7W , 13 inch Dia. reel P9 = 9W , 13 inch Dia. reel T3 = 3W , High temperature 13 inch Dia. reel T5 = 5W , High temperature 13 inch Dia. reel PA = 10W, 13 inch Dia. Reel PB = 15W, 13 inch Dia. reel (6) RESISTANCE VALUE 0.1 mΩ to 5 mΩ There are 3~5 digits indicated the resistance value. Letter R/ U is decimal point. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance code rule Example 0RXXX 0UX 0R001 = 1 mΩ 0U2 = 0.0002 Ω ORDERING EXAMPLE The ordering code of a PU3921, value 0.0005Ω with ±1% tolerance, 3W and high temperature(275°C) supplied in 13-inch tape reel is : PU3921FKNT30U5L NOTE 1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead-Free Process" www.yageo.com Apr. 08, 2019 V.6 3 Product specification Chip Resistor Surface Mount PU SERIES 9 2512/ 3921/ 5931 MARKING PU2512 No marking Fig. 1 Value = 0.2mΩ PU3921/ 5931 - 0.1~0.7mΩ 4 digits The "m" is used as a decimal point ; the other 3 digits are significant and the unit is milliohm Fig. 2 Value = 0.2mΩ 0.1mΩ to 0.7mΩ PU3921/ 5931 - 1~5mΩ 4 digits The "R" is used as a decimal point ; the other 3 digits are significant Fig. 3 Value = 1mΩ 1mΩ to 5mΩ OUTLINES AND DIMENSION Fig. 4-1 Chip resistor outlines Table 1-1 For outlines, please refer to Fig. 3-1 TYPE L (mm) W (mm) H (mm) I1 (mm) PU2512 6.35± 0.25 3.18± 0.25 0.35± 0.15 1.14± 0.25 PU3921 10.0± 0.25 5.20± 0.25 0.50± 0.13 2.00± 0.25 PU5931 15.0± 0.25 7.75± 0.25 0.50± 0.13 4.00± 0.25 Resistance Value PU2512 T (mm) PU3921 Thickness 0.1mΩ ----- 0.2mΩ 0.25mΩ 0.3 mΩ 0.4mΩ 0.5 mΩ 0.7 mΩ --- --- 0.95± 0.13 --- 0.84± 0.13 --- 1 mΩ 2 mΩ 3 mΩ 4 mΩ 5 mΩ 0.43± 0.13 0.66± 0.13 0.44± 0.13 0.33± 0.13 0.31± 0.13 1.35± 0.13 1.05± 0.10 1.35± 0.13 1.05 ± 0.13 0.86± 0.13 0.60± 0.10 0.43± 0.13 0.72± 0.13 0.48± 0.13 0.36± 0.13 0.25± 0.13 PU5931 1.42± 0.13 1.33± 0.13 --- 1.00± 0.13 -- 0.60± 0.13 --- 0.33± 0.13 0.49± 0.13 0.33± 0.13 0.25± 0.13 --- www.yageo.com Apr. 08, 2019 V.6 Product specification Chip Resistor Surface Mount Fig. 4-2 PU SERIES 2512/ 3921/ 5931 4 9 Solder pad dimensions Note: Series resistors are suitable for IR reflow soldering Table 1-2 For outlines, please refer to Fig. 4-2 TYPE A (mm) B (mm) C (mm) PU2512 1.80± 0.15 3.40± 0.15 3.40± 0.13 PU3921 2.75± 0.25 6.20± 0.25 5.60± 0.13 PU5931 5.20± 0.25 8.75± 0.25 5.60± 0.13 Table 2 ELECTRICAL CHARACTERISTICS POWER OPERATING RATING TEMP. RANGE SIZE 4W PU2512 Fig. 4 5W -65°C to 170°C -65°C to 170°C 9W 3W PU5931 TEMPERATURE COEFFICIENT OF RESISTANCE -65°C to 275°C -65°C to 170°C 0.3/ 0.5mΩ: ± 200ppm/°C 1mΩ: ± 175ppm/°C 2~5mΩ: ± 75ppm/°C ± 1%, ± 5% 0.3/ 0.5mΩ 0.2/ 0.25/ 0.3/ 0.4/ 0.5/ 0.7mΩ 1/ 2/ 3/ 4/ 5mΩ 0.2/ 0.25/ 0.3/ 0.4/ 0.5/ 0.7mΩ: ± 175ppm/°C 1~5mΩ: ± 75ppm/°C ± 1%, ± 5% 0.2/ 0.25/ 0.3/ 0.4/ 0.5/ 0.7/ 1mΩ 5W 7W 1/ 2mΩ 0.2/ 0.25/ 0.3/ 0.4/ 0.5/ 0.7mΩ 1/ 2/ 3/ 4/ 5mΩ 3W PU3921 TOLERANCE 3/ 4/ 5mΩ Chip resistor 6W outlines 5W RESISTANCE RANGE 0.2mΩ: ± 325ppm/°C 0.2/ 0.25/ 0.3/ 0.4/ 0.5/ 0.7mΩ: ± 175ppm/°C 1~5mΩ: ± 75ppm/°C 0.5/1/ 2/ 3/ 4mΩ 0.5mΩ: ± 175pm/°C 1~4mΩ: ± 75ppm/°C 0.2/ 0.3/ 0.5/ 1/ 2/ 3/ 4mΩ 0.2mΩ: ± 225ppm/°C 0.3/ 0.5mΩ: ± 175ppm/°C 1~4mΩ: ± 75ppm/°C 0.2/ 0.3/ 0.5/ 1/ 2/ 3/ 4mΩ 0.1mΩ: ± 300ppm/°C ± 1%, ± 5% 0.2mΩ: ± 225ppm/°C 10W 0.2/ 0.3/ 0.5mΩ 15W 0.1mΩ 1~4mΩ: ± 75ppm/°C 0.3/ 0.5/ 1/ 2/ 3/ 4mΩ 0.3/ 0.5mΩ: ± 175ppm/°C 1~4mΩ: ± 75ppm/°C 5W -65°C to 275°C 0.3/ 0.5mΩ: ± 175ppm/°C Note: Please contact with sales offices, distributors and representatives in your region before ordering. www.yageo.com Apr. 08, 2019 V.6 Product specification Chip Resistor Surface Mount PU SERIES 5 9 2512/ 3921/ 5931 FUNCTIONAL DESCRIPTION OPERATING TEMPERATURE RANGE High Temperature Range Type: -65°C to +275°C (Fig. 5-1) Normal Temperature Range Type: -65°C to +170°C (Fig. 5-2) POWER RATING Standard rated power at 70°C: PU2512 = 4W PU3921 = 3W PU5931 = 5W Fig. 5-1 Maximum dissipation (P max ) in percentage of rated power as a function of the operating ambient temperature (T amb ) Fig. 5-2 Maximum dissipation (P max ) in percentage of rated power as a function of the operating ambient temperature (T amb ) For detail power value, please refer to Table 2. RATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= (PxR ) Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) www.yageo.com Apr. 08, 2019 V.6 Product specification Chip Resistor Surface Mount PU SERIES 6 9 2512/ 3921/ 5931 PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE REEL DIMENSION 2512 3921 5931 Embossed taping reel (K) 13" (330 mm) 4,000 3,000 1,500 EMBOSSED TAPE Fig. 5 Embossed Tape Table 4 Dimensions of embossed tape for relevant chip resistors size A0 B0 D0 DIMENSION D1 E F MIN. K0 P0 P1 P2 MAX. T1 T2 T W MA MAX. MAX. MAX. X. PU2512 3.58± 0. 1 3.58± 0. 1 6.7± 0.1 1.5± 0.1 1.5 1.75± 0.1 5.5± 0.1 1.52 4± 0.1 8± 0.1 2± 0.1 0.1 1.92 0.3 12.3 6.7± 0.1 1.5± 0.1 1.5 1.75± 0.1 5.5± 0.1 1.14 4± 0.1 8± 0.1 2± 0.1 0.1 1.54 0.3 12.3 0.5 / 0.7/ 2mΩ 5.59± 0. 10.41± 0.1 1.5± 0.1 1 1.5 1.75± 0.1 7.5± 0.1 2.13 4± 0.1 8± 0.1 2± 0.1 0.1 2.64 0.41 16.3 1 /3 /4 /5mΩ 5.59± 0. 10.41± 0.1 1.5± 0.1 1 1.5 1.75± 0.1 7.5± 0.1 1.14 4± 0.1 8± 0.1 2± 0.1 0.1 1.65 0.41 16.3 ≦0.3mΩ 8.3± 0.1 15.62± 0.1 1.5± 0.1 1.5 1.75± 0.1 11.5± 0.1 2.39 4± 0.1 12± 0.1 2± 0.1 0.1 2.9 0.41 24.3 ≧0.5mΩ 8.3± 0.1 15.62± 0.1 1.5± 0.1 1.5 1.75± 0.1 11.5± 0.1 1.22 4± 0.1 12± 0.1 2± 0.1 0.1 1.73 0.41 24.3 0.3 /0.5 /2mΩ 1 /3 /4 /5mΩ PU3921 0.2/ 0.25/ 0.3/ 0.4 PU5931 Unit : mm www.yageo.com Apr. 08, 2019 V.6 Product specification Chip Resistor Surface Mount PU SERIES 7 9 2512/ 3921/ 5931 REEL SPECIFICATION Fig. 6 Table 5 Dimensions of reel specification for relevant chip resistors size; see Fig. 6 PRODUCT SIZE CODE REEL SIZE SYMBOL A N C D W1 W2 max. 2512 13" (Φ 330mm) 330+0 /-3 100± 0.5 13.5± 0.5 21± 0.8 13± 0.3 17.5 3921 13" (Φ 330mm) 330+0 /-3 100± 0.5 13.5± 0.5 21± 0.8 16.4+2.0/-0 22.4 5931 13" (Φ 330mm) 330+0 /-3 100± 0.5 13.5± 0.5 21± 0.8 24.4+2.0/-0 30.4 Unit : mm www.yageo.com Apr. 08, 2019 V.6 Product specification Chip Resistor Surface Mount PU SERIES 8 9 2512/ 3921/ 5931 TESTS AND REQUIREMENTS Table 6 Test condition, procedure and requirements TEST Short Time Overload TEST METHOD PROCEDURE REQUIREMENTS IEC60115-1 4.13 5 times of rated power for 5 seconds at room temperature ± (1%+0.0005 Ω) No visible damage High Temperature Exposure AEC-Q200 Test 3 MIL-STD-202 method 108A 1,000 hours at maximum operating temperature depending on specification, unpowered, Normal Temperature Range Type:170± 3°C High Temperature Range Type: 275± 5°C ± (1%+0.0005 Ω) IEC 60115-1 4.25.3 Moisture Resistance AEC-Q200 Test 6 MIL-STD-202 method 106F Each temperature / humidity cycle is defined at 8 hours (method 106F), 3 cycles / 24 hours for 10d with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered Parts mounted on test-boards, without condensation on parts Measurement at 24± 2 hours after test conclusion ± (1%+0.0005 Ω) Biased Humidity AEC-Q200 Test 7 MIL-STD-202 method 103 1,000 hours; 85 °C / 85% RH 10% of operating power Measurement at 24± 4 hours after test conclusion. ± (1%+0.0005 Ω) Life/ Operational Life/ Endurance AEC-Q200 Test 8 MIL-STD-202 method 108A IEC 60115-1 4.25.1 1,000 hours at 70± 5 °C applied RCWV 1.5 hours on, 0.5 hour off, still air required ± (1%+0.0005 Ω) - Resistance to Soldering Heat AEC-Q200 Test 15 MIL-STD-202 method 210F IEC 60115-1 4.18 Condition B, no pre-heat of samples Lead free solder, 260 °C, 10 seconds immersion time Procedure 2 for SMD: devices fluxed and cleaned with isopropanol ± (0.5%+0.0005 Ω) No visible damage Thermal Shock AEC-Q200 Test 16 MIL-STD-202 method 107 -55/+150 °C Number of cycles is 300. Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air ± (1%+0.0005 Ω) No visible damage AEC-Q200 Test 21 AEC-Q200-005 Chips mounted on a 90mm glass epoxy resin PCB (FR4) Bending: 2 mm Holding time: minimum 60 seconds ± (1%+0.0005 Ω) Board Flex Bending / www.yageo.com Apr. 08, 2019 V.6 Product specification Chip Resistor Surface Mount PU SERIES 9 9 2512/ 3921/ 5931 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION POWER RESISTANCE TOLERANCE - Extend resistor value for 3921RANGE Jun. 28, 2018 1/10W, 1/5W, 3/10W, 2/5W, 1/2W 0603 Version 4 Nov. 23, 2017 1/8W, 1/4W, 1/3W, 1/2W 0805 Version 31206 May 24, 2017 1/4W, 1/2W - Update packing 5quantity mΩ ≦ for R
PU3921FKN130U5L
物料型号:文档描述了YAGEO Phicomp品牌的PU系列贴片电阻,具体型号包括2512、3921和5931。
器件简介:这些电阻是表面贴装型的,具有无铅端子,通过焊接技术制造,符合RoHS标准,不含卤素,且通过了AEC-Q200认证。
引脚分配:文档中没有明确提到引脚分配,但提到了焊接垫尺寸,适用于红外回流焊接。
参数特性:电阻值范围从0.0001Ω到5mΩ,功率范围从3W到15W,公差等级包括±1%和±5%,温度系数有多个选项,从±75 ppm/°C到±325 ppm/°C不等。
功能详解:文档提供了电阻的详细功能描述,包括在不同温度范围内的电阻值稳定性和功率额定值。
应用信息:这些电阻适用于替代能源、电信基站、汽车(包括前灯、车窗控制、发动机控制单元、转向控制等)。
封装信息:提供了不同型号的尺寸和厚度信息,以及焊接垫的尺寸。
PU3921FKN130U5L 价格&库存
很抱歉,暂时无法提供与“PU3921FKN130U5L”相匹配的价格&库存,您可以联系我们找货
PU3921FKN130U5L
    • 1+49.50570
    • 100+32.52520
    • 1000+22.05230
    • 3000+10.81810
    库存:3130
    PU3921FKN130U5L
    • 1+15.174911+1.96943
    • 10+10.0248310+1.30104
    • 25+8.6132025+1.11784
    • 50+7.7287550+1.00305
    • 100+6.97608100+0.90537
    • 250+6.15197250+0.79842
    • 500+5.63589500+0.73144
    • 1000+5.197481000+0.67454
    库存:469
    PU3921FKN130U5L
      • 1+4.73040
      • 10+3.87720
      • 30+3.44520
      • 100+3.02400
      • 500+2.76480
      • 1000+2.63520
      PU3921FKN130U5L
      • 5+12.20710
      • 750+11.94259
      • 1500+11.68225
      库存:90
      PU3921FKN130U5L
      • 3000+4.371513000+0.56735
      • 6000+4.100266000+0.53214
      • 9000+3.960969000+0.51406
      • 15000+3.8034315000+0.49362
      • 21000+3.7095721000+0.48144
      库存:469
      PU3921FKN130U5L
