Designated client product
This product will be discontinued its production in the near term.
And it is provided for customers currently in use only, with a time limit.
It can not be available for your new project. Please select other new or
existing products.
For more information, please contact our sales office in your region.
New Japan Radio Co.,Ltd.
www.njr.com
NJM555
TIMER
■ GENERAL DESCRIPTION
The NJM555 monolithic timing circuit is a highly stable controller
capable of producing accruate time delays or oscillation. In the time
delay mode, delay time is precisely controlled by only two external
parts : a resistor and a capacitor. For operation as an oscillator, both
the free running frequency and the duty cycle are accurately controlled
by two external resistors and a capacitor.
Terminals are provided for triggering and resetting. The circuit will
trigger and reset on falling waveforms. The output can source or sink
up to 200mA or drive TTL circuits.
■ FEATURES
● Operating Voltage
(4.5V to 16V)
● Less Number of External Components
● Package Outline
DIP8, DMP8, SSOP8, SIP8
● Bipolar Technology
■ PACKAGE OUTLINE
NJM555D
NJM555M
NJM555L
NJM555V
■ PIN CONFIGURATION
NJM555D
NJM555M
NJM555V
NJM555L
■ EQUIVALENT CIRCUIT
Ver.2012-11-27
-1-
NJM555
■ ABSOLUTE MAXIMUM RATINGS
PARAMETER
(Ta=25°C)
SYMBOL
RATINGS
UNIT
Supply Voltage
V+
18
V
Power Dissipation
PD
(DIP8)
1000(Note1)
(DMP8)
580(Note1)
(SSOP8) 480(Note1)
(SIP8)
1600(Note1)
mW
mW
mW
mW
Operating Temperature Range
Topr
-40 to +85
°C
Storage Temperature Range
Tstg
-40 to +125
°C
Note1: Mounted on the EIA/JEDEC standard board (76.2×114.3×1.6mm, four layer, FR-4).
(V+=5 to 15V, Ta=25°C)
■ ELECTRICAL CHARACTERISTICS
PARAMETER
Operating Voltage
Operating Current
Operating Current
Timing Error
Initial Accuracy
Drift with Temperature
Drift with Supply Voltage
Threshold Voltage
Trigger Voltage
Trigger Voltage
Trigger Current
Reset Voltage
Reset Current
Threshold Curret
Control Voltage Level
Output Voltage (Low)
Output Voltage (High)
Rise time of Output
Fall time of Output
SYMBOL
TEST CONDITION
V
ICC
ICC
Et
Et
Et
Vth
VT
VT
IT
VR
IR
Ith
VCL
VCL
VOL
VOL
VOL
VOL
VOL
VOH
VOH
VOH
VOH
tr
tf
V+=5V, RL=∞(Note 2)
V+=15V, RL=∞(Note 2)
Ta=-20 to 75°C, V+=5 to 15V(Note 3)
V+=15V
V+=5V
V+=15V
V+=5V
V+=15V Isink=10mA
V+=15V Isink=50mA
V+=15V Isink=100mA
V+=15V Isink=200mA
V+=5V Isink=5mA
V+=15V Isource=200mA
V+=15V Isource=100mA
V+=15V Isource=40mA
V+=5V Isource=100mA
No Loading
No Loading
MIN.
TYP.
MAX.
UNIT
4.5
3.0
10
16
6.0
15
V
mA
mA
0.4
9
2.6
12.75
2.75
1.0
50
0.1
2/3
5.0
1.67
0.5
0.5
0.1
0.1
10
3.33
0.1
0.4
2.0
2.5
0.25
12.5
13.3
13.5
3.3
100
100
1.0
0.25
11
4.0
0.25
0.75
2.5
0.35
ppm / °C
%/V
×V+
V
V
µA
V
mA
µA
V
V
V
V
V
V
V
V
V
V
V
ns
ns
Note 2 : Low output condition (When the output is high, it is lower than the low output condition by 1mA in the standard specificatio.)
Note 3 : RA, RB=1k to 100kΩ, C=0.1µF, V =15V from 5V
-2-
Ver.2012-11-27
NJM555
■ TYPICAL APPLICATION
(1) 50% Duty Cycle Oscillator
(2) Oscillation frequency can be changed by changing the control voltage.
(3) Pulse Width Modulation
Ver.2012-11-27
-3-
NJM555
■ TYPICAL CHARACTERISTICS
Operating Current vs. Operating Voltage
Delay Time vs. Temperature
Delay Time vs. Operating Voltage
High Output Voltage Drop vs. Output Source Current
Low Output Voltage vs. Output Sink Current
-4-
Ver.2012-11-27
NJM555
1. Monostable Operation
Ver.2012-11-27
2. Free Running Operation
-5-
NJM555
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
-6-
Ver.2012-11-27
很抱歉,暂时无法提供与“NJM555M-TE1”相匹配的价格&库存,您可以联系我们找货
