RMCW0612FT100K
RMCW0612FT100K
    SEI
    贴片电阻 1206 100KΩ ±1% 3/4W ±100ppm/℃
RMCW0612FT100K 数据手册
RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions Features: • • • • • • Small size and light weight Reliability and high quality Wider terminations provide higher power handling and more robust thermal performance Qualified to AEC-Q200 RoHS compliant, lead free and halogen free REACH compliant Electrical Specifications Type / Code Power Rating (W) @ 70°C RMCW0612 0.75 RMCW1020 1 RMCW1218 1 RMCW1225 2 RMCW2030 3 Maximum Working Voltage (V) (1) Maximum Overload Voltage (V) 200 400 Ohmic Range (Ω) and Tolerance(2) 1%, 5% 1 - 9.1 10 - 10M 1 - 9.1 10 - 10M 1 - 9.1 10 - 10M 1 - 9.1 10 - 10M 1 - 9.1 10 - 10M TCR (ppm/ºC) ±400 ±100 ±400 ±100 ±400 ±100 ±400 ±100 ±400 ±100 (1) Lesser of √PR or maximum working voltage (2) E96 resistance values may be available in 1% tolerance but will be subject to a high MOQ's - contact Stackpole Electrical Specifications - Jumper Type / Code Jumper Rated Current (A) RMCW0612 RMCW1020 RMCW1218 RMCW1225 RMCW2030 4 6 6 8 10 Maximum Overload Current (A) < 1 second and 1 time 15 22 22 30 35 Jumper Resistance Value 0.02 max. Mechanical Specifications Type / Code L W H I1 I2 Unit RMCW0612 0.063 ± 0.008 1.60 ± 0.20 0.126 ± 0.008 3.20 ± 0.20 0.022 ± 0.004 0.55 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 inches mm RMCW1020 0.098 ± 0.008 2.50 ± 0.20 0.197 ± 0.008 5.00 ± 0.20 0.022 ± 0.004 0.55 ± 0.10 0.016 ± 0.008 0.40 ± 0.20 0.030 ± 0.008 0.75 ± 0.20 inches mm RMCW1218 0.122 ± 0.004 3.10 ± 0.10 0.181 ± 0.004 4.60 ± 0.10 0.022 ± 0.002 0.55 ± 0.05 0.016 ± 0.008 0.40 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 inches mm RMCW1225 0.126 ± 0.008 3.20 ± 0.20 0.256 ± 0.008 6.50 ± 0.20 0.022 ± 0.008 0.55 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.030 ± 0.008 0.75 ± 0.20 inches mm RMCW2030 0.201 ± 0.004 5.10 ± 0.10 0.299 ± 0.004 7.60 ± 0.10 0.042 ± 0.004 1.06 ± 0.10 0.031 ± 0.008 0.80 ± 0.20 0.031 ± 0.008 0.80 ± 0.20 inches mm Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions Performance Characteristics Test Item Test Method Temperature Coefficient of Resistance JIS-C-5201-1 4.8 Short Time Overload JIS-C-5201-1 4.13 IEC-60115-1 4.13 Leaching Resistance to Soldering Heat Rapid Change of Temperature Resistance to Solvent Test Specification 1% 5% Test Condition Within the specified tolerance At 25 / -55°C and 25°C / +155°C, 25°C is the reference temperature IEC-60115-1 4.8 ± (1% + 0.05Ω) ± (2% + 0.1Ω) Jumper: overload current for 5 seconds 0612=10A, 1020=15A, 1218=15A, 1225=20A, 2030=25A Jumper: max 0.02 Ω after test JIS-C-5201-1 4.18 Individual leaching area ≤ 5% Total leaching area ≤ 10% IEC-60068-2-58 8.2.1 JIS-C-5201-1 4.18 ± (0.5% + 0.05Ω) ± (1% + 0.05Ω) IEC-60115-1 4.18 JIS-C-5201-1 4.19 ± (0.5% + 0.05Ω) ± (1% + 0.1Ω) IEC-60115-1 4.19 ± (0.5% + 0.05Ω) ± (0.5% + 0.05Ω) JIS-C-5201-1 4.29 Jumper: max 0.02 Ω after test Damp Heat with Load ± (1% + 0.05Ω) JIS-C-5201-1 4.24 IEC-60115-1 4.24 ± (2% + 0.05Ω) Jumper: max 0.02 Ω after test Load Life (Endurance) 2.5 times RCWV or max. overload voltage whichever is less for 5 seconds ± (1% + 0.05Ω) JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 ± (3% + 0.1Ω) Jumper: max 0.02 Ω after test JIS-C-5201-1 4.6 ≥ 10 GΩ IEC-60115-1 4.6 JIS-C-5201-1 4.33 Bending Strength ± (1% + 0.05Ω) ± (1% + 0.05Ω) IEC-60115-1 4.33 Operating temperature range is -55°C to 155°C 260 ± 5°C for 30 seconds 260 ± 5°C for 10 seconds -55°C to +155°C, 5 cycles The tested resistor should be immersed into isopropyl alcohol of 20 ~ 25°C for 60 seconds. Then the resistor is left in room temperature for 48 hours 40 ± 2°C, 90 ~ 95% R.H. RCWV or Max. Working voltage whichever is less for 1000 hours with 1.5 hours "ON" and 0.5 hour "OFF" 70 ± 2°C, RCWV or Max. Working voltage whichever is less for 1000 hours with 1.5 hours "ON" and 0.5 hour "OFF" Insulation Resistance Apply 100 VDC for 1 minute Bending once for 5 seconds. D: 0612, 1020, 1218, 1225, 2030 = 2 mm Power Derating Curve: 100 -55ºC 70ºC Power Load (%) 80 60 40 20 0 -60 155ºC 0 20 40 60 80 100 120 140 160 180 Ambient Temperature (ºC) Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions Surface Temperature vs. Power Rating 1. 2. 3. 4. Resistance value used for each size was at or near critical value. Used poor heat conduction PCB. Applied full power for 10 minutes prior to measurement. Data for reference only. Actual performance under customer conditions may vary. Recommended Pad Layouts Type / Code RMCW0612 RMCW1020 RMCW1218 RMCW1225 RMCW2030 A 0.024 0.60 0.030 0.75 0.080 2.04 0.033 0.85 0.138 3.50 Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. B 0.114 2.90 0.134 3.40 0.167 4.24 0.146 3.70 0.295 7.50 3 C 0.126 3.20 0.197 5.00 0.189 4.80 0.252 6.40 0.307 7.80 Unit inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions Recommended Customer Soldering Parameters Wave Solder Temperature Condition Solder Reflow Temperature Condition Rework temperature (hot air equipment): 350°C, 3 ~ 5 seconds Recommended reflow methods: • IR, vapor phase oven, hot air oven • If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. Reel Specifications Type / Code Size Reel Quantity RMCW0612 7" 5000 RMCW1020 7" 4000 RMCW1218 7" 4000 RMCW1225 7" 4000 RMCW2030 7" 1000 A 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± ± ± B 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 0.531 13.50 Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. ± ± ± ± ± ± ± ± ± ± C 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.827 21.00 0.827 21.00 0.827 21.00 0.827 21.00 0.827 21.00 4 ± ± ± ± ± ± ± ± ± ± D 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 2.362 60.00 ± ± ± ± ± ± ± ± ± ± W 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.039 1.00 0.453 11.50 0.630 16.00 0.630 16.00 0.630 16.00 0.748 19.00 ± ± ± ± ± ± ± ± ± ± M 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 7.008 178.00 ± ± ± ± ± ± ± ± ± ± Unit 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions Packaging Specifications – Paper Tape Type / Code A B W RMCW0612 0.075 ± 0.008 1.90 ± 0.20 G 0.157 ± 0.004 4.00 ± 0.10 0.138 ± 0.008 3.50 ± 0.20 H 0.079 ± 0.002 2.00 ± 0.05 0.315 ± 0.008 8.00 ± 0.20 T 0.030 ± 0.004 0.75 ± 0.10 E 0.069 ± 0.004 1.75 ± 0.10 D 0.059 +0.004 / -0 1.50 +0.10 / -0 F Unit 0.138 ± 0.002 3.50 ± 0.05 P 0.157 ± 0.004 4.00 ± 0.10 inches mm Unit inches mm Packaging Specifications – Embossed Tape Type / Code A B W E F G Unit RMCW1020 0.110 ± 0.008 2.80 ± 0.20 0.220 ± 0.008 5.60 ± 0.20 0.472 ± 0.004 12.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.217 ± 0.002 5.50 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 inches mm RMCW1225 0.134 ± 0.008 3.40 ± 0.20 0.264 ± 0.008 6.70 ± 0.20 0.472 ± 0.004 12.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.217 ± 0.002 5.50 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 inches mm RMCW1218 0.130 ± 0.008 3.30 ± 0.20 0.181 ± 0.008 4.60 ± 0.20 0.472 ± 0.004 12.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.217 ± 0.002 5.50 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 inches mm RMCW2030 0.217 ± 0.008 5.50 ± 0.20 0.311 ± 0.008 7.90 ± 0.20 0.630 ± 0.004 16.00 ± 0.10 0.069 ± 0.004 1.75 ± 0.10 0.295 ± 0.002 7.50 ± 0.05 0.157 ± 0.004 4.00 ± 0.10 inches mm Type / Code H T D D1 T1 P Unit 0.059 ± 0.004 1.50 ± 0.10 0.033 ± 0.006 0.85 ± 0.15 0.157 ± 0.004 4.00 ± 0.10 inches mm 0.059 ± 0.004 1.50 ± 0.10 0.033 ± 0.006 0.85 ± 0.15 0.157 ± 0.004 4.00 ± 0.10 inches mm 0.059 ± 0.004 1.50 ± 0.10 0.033 ± 0.006 0.85 ± 0.15 0.157 ± 0.004 4.00 ± 0.10 inches mm 0.059 ± 0.004 1.50 ± 0.10 0.051 ± 0.004 1.30 ± 0.10 0.315 ± 0.008 8.00 ± 0.20 inches mm RMCW1020 0.079 ± 0.002 2.00 ± 0.05 0.009 ± 0.004 0.23 ± 0.10 0.059 1.50 RMCW1225 0.079 ± 0.002 2.00 ± 0.05 0.009 ± 0.004 0.23 ± 0.10 0.059 1.50 RMCW1218 0.079 ± 0.002 2.00 ± 0.05 0.009 ± 0.004 0.23 ± 0.10 0.059 1.50 RMCW2030 0.079 ± 0.002 2.00 ± 0.05 0.010 ± 0.004 0.25 ± 0.10 0.059 1.50 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 Peel Force of Top Cover Tape Top adhesive peel off strength: 10~70g Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RMCW Series Stackpole Electronics, Inc. Wide Termination Thick Film Chip Resistor Resistive Product Solutions RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Package / Termination Type Description Wide Termination Thick Film Chip SMD Resistors Note (1): RoHS compliant by means of exemption 7c-I RMCW Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) YES(1) 100% Matte Sn over Ni Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 R M C W 0 6 1 2 J T 1 0 R 0 Product Series Wide RMCW Termination Thick Film Size Code W 0612 0.75 1020 1 1218 1 2 1225 2030 3 Tolerance Code Tol Value(*) F 1% E24 J 5% Z Jumper Code T Packaging Description Size Quantity 0612 5000 7" Reel - Paper Tape 1020, 1218, 1225 4000 2030 1000 Resistance Value Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 100 ohm = 100R 10 Kohm = 10K0 10 Mohm = 10M0 (*) E96 resistance values may be available in 1% tolerance but will be subject to high MOQ's. Contact Stackpole. Rev Date: 11/13/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com
RMCW0612FT100K 价格&库存
很抱歉,暂时无法提供与“RMCW0612FT100K”相匹配的价格&库存,您可以联系我们找货
RMCW0612FT100K
  • 1+1.593641+0.20559
  • 10+0.8224910+0.10611
  • 25+0.6438825+0.08307
  • 50+0.5465550+0.07051
  • 100+0.46965100+0.06059
  • 250+0.39236250+0.05062
  • 500+0.34778500+0.04487
  • 1000+0.312491000+0.04031
库存:24785
RMCW0612FT100K
  • 5000+0.256045000+0.03303
  • 10000+0.2396210000+0.03091
  • 15000+0.2316215000+0.02988
  • 25000+0.2229425000+0.02876
  • 35000+0.2179935000+0.02812
  • 50000+0.2132950000+0.02752
  • 60000+0.2110960000+0.02723
  • 120000+0.20386120000+0.02630
  • 125000+0.20348125000+0.02625
库存:24785
