HVR12JTET0100
HVR12JTET0100
    VIKING(光颉)
    贴片电阻 2512 10Ω ±5% 1W ±100ppm/℃
HVR12JTET0100 数据手册
Data Sheet Customer: Product: High Voltage Thick Film Chip Resistor - HVR Series Size: 0402/0603/0805/1206/2010/2512 Issued Date: 10-Mar-21 Edition: REV.B5 VIKING TECH CORPORATION 光頡科技股份有限公司 VIKING TECH CORPORATION KAOHSIUNG BRANCH 光頡科技股份有限公司高雄分公司 VIKING ELECTRONICS (WUXI) CO., LTD. 光頡電子(無錫)有限公司 No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) 10-Mar-21 10-Mar-21 10-Mar-21 Susan Huang J.C. Liu J.C. Liu Prepared by (Sales) Accepted by (Customer) 【HVR Series】 High Voltage Thick Film Chip Resistor High Voltage Thick Film Chip Resistor ■Scope -This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. ■Features -Highly reliable multilayer electrode construction -Higher component and equipment reliability -Excellent performance at high voltage -Reduced size of final equipment -IEC 62368-1 & IEC 60950-1 Safety Certificate issued by UL Demko ■Construction ■Applications L -Inverter -Outdoor Equipments D1 -Converter     W T    -High Pulse Equipment  D2  Alumina Substrate  Bottom Electrode  Top Electrode  Edge Electrode  Barrier Layer  External Electrode  Resistor Layer  Primary Overcoat  Secondary Overcoat ■Dimensions Type Size (Inch) (mm) (mm) (mm) (mm) (mm) Weight (g) (1000pcs) HVR02 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 HVR03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 HVR05 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 HVR06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 HVR0A 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 HVR12 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 L W T D1 D2 ■IEC 62368-1 & IEC 60950-1 Safety Certificate Scope G.10.2 (2.5KV impulse test) HVR02 HVR03 HVR05 10M~100M 10M~100M 100K~100M G.10.3.2 (10KV surge) 10M~100M G.10.3.3 (5KV impulse) 100K~100M www.viking.com.tw HVR06 HVR0A HVR12 470K~100M 51K~100M 30K~100M For detail questions, contact:sales@viking.com.tw 1 Edition: REV.B5 Revision: 10-Mar-2021 【HVR Series】 High Voltage Thick Film Chip Resistor ■Part Numbering HVR 03 F T E Product Type Dimensions Resistance Tolerance F: ±1% J: ±5% Packaging Code TCR (PPM/°C) 02: 0402 03: 0603 05: 0805 06: 1206 0A: 2010 12: 2512 ■Recommend Land Pattern T: 7”Taping Reel V:10”Taping Reel W:13”Taping Reel X E: ±100 F: ±200 H: ±400 1003 Power Rating Y: 1/16W X: 1/10W W: 1/8W V: 1/4W U: 1/2W T: 1W Resistance 1003: 100KΩ 1004: 1MΩ 1005: 10MΩ ■Derating Curve Derating Curve 100 Power ratio(%) B . C A Type A (mm) B (mm) C (mm) HVR02 0.50 0.45 0.60 HVR03 0.90 0.60 0.90 HVR05 1.20 0.70 1.30 HVR06 2.00 0.90 1.60 HVR0A 3.80 0.90 2.80 HVR12 4.90 1.60 3.50 80 60 40 20 0 0 20 40 60 80 100 120 140 160 180 Ambient Temperature(℃) ■Soldering Condition (IPC/JEDEC J-STD-020) www.viking.com.tw For detail questions, contact:sales@viking.com.tw 2 Edition: REV.B5 Revision: 10-Mar-2021 【HVR Series】 High Voltage Thick Film Chip Resistor ■Standard Electrical Specifications Item Type Power Rating at 70C Operating Temp. Range Max. Operating Voltage Max. Overload Voltage Resistance Range ±1%(E24、E96) ±5%(E24) 39KΩ - 1MΩ HVR02 (0402) 1/16W 100V 200V 1/10W 200V 400V 1.1MΩ - 20MΩ ±200 - 22MΩ - 100MΩ ±400 1/8W 400V 800V 1.1MΩ - 20MΩ ±200 - 22MΩ - 100MΩ ±400 1/4W 1.1MΩ - 20MΩ ±200 - 22MΩ - 100MΩ ±400 100KΩ- 1MΩ 500V 1000V 1/2W 2000V 3000V 1.1MΩ - 20MΩ ±200 - 22MΩ - 100MΩ ±400 1W 3000V 4000V ±100 1.02MΩ - 20MΩ 1.1MΩ - 20MΩ ±200 - 22MΩ - 100MΩ ±400 30KΩ - 1MΩ HVR12 (2512) ±100 1.02MΩ - 10MΩ 51KΩ- 1MΩ HVR0A (2010) ±100 1.02MΩ - 10MΩ -55 ~ +155C HVR06 (1206) ±100 1.02MΩ - 10MΩ 100KΩ - 1MΩ HVR05 (0805) ±100 1.02MΩ - 10MΩ 56KΩ - 1MΩ HVR03 (0603) TCR (PPM/C) ±100 1.02MΩ - 20MΩ 1.1MΩ - 20MΩ ±200 - 22MΩ - 100MΩ ±400 Operating Voltage=√(P*R) or Max. Operating Voltage listed above, whichever is lower. Overload Voltage=2.5*√(P*R) or Max. Overload Voltage listed above, whichever is lower. ■ Viking is capable of manufacturing the optional spec based on customer’s requirement. www.viking.com.tw For detail questions, contact:sales@viking.com.tw 3 Edition: REV.B5 Revision: 10-Mar-2021 【HVR Series】 High Voltage Thick Film Chip Resistor ■Environmental Characteristics Requirement Item Temperature Coefficient of Resistance (T.C.R.) JIS-C-5201-1 4.8 IEC-60115-1 4.8 As Spec. Short Time Overload (1.0%+0.05Ω) Insulation Resistance 10G Endurance Test Method 5% 1% (2.0%+0.10Ω) (2.0%+0.05Ω) At 25C/-55C and 25C/+125C, 25C is the reference temperature JIS-C-5201-1 4.13 IEC-60115-1 4.13 RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds JIS-C-5201-1 4.6 IEC-60115-1 4.6 (3.0%+0.10Ω) Damp Heat with Load (2.0%+0.10Ω) (3.0%+0.10Ω) Dry Heat (1.0%+0.05Ω) (1.5%+0.10Ω) Max. Overload Voltage for 1 minute JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 702C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.24 IEC-60115-1 4.24 402C, 90~95% R.H., RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 at +155C for 1000 hrs Bending Strength (1.0%+0.05Ω) Solderability 95% min. coverage Bending once for 60 seconds 2010, 2512 sizes: 2mm Other sizes: 3mm JIS-C-5201-1 4.17 IEC-60115-1 4.17 (0.5%+0.05Ω) 2455C for 3 seconds JIS-C-5201-1 4.18 IEC-60115-1 4.18 Resistance to Soldering Heat Voltage Proof (1.0%+0.05Ω) JIS-C-5201-1 4.33 IEC-60115-1 4.33 (1.0%+0.05Ω) 2605C for 10 seconds JIS-C-5201-1 4.7 IEC-60115-1 4.7 HVR02: 150V for 1 minute HVR03: 300V for 1 minute HVR05/HVR06/HVR0A/HVR12: 500V for 1 minute JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 No breakdown or flashover Individual leaching area ≦5% Leaching Total leaching area ≦ 10% Rapid Change of Temperature (0.5%+0.05Ω) (1.0%+0.05Ω) 2605C for 30 seconds JIS-C-5201-1 4.19 IEC-60115-1 4.19 -55C to +155C, 5 cycles RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. ■ Storage Temperature: 15~28°C; Humidity < 80%RH www.viking.com.tw For detail questions, contact:sales@viking.com.tw 4 Edition: REV.B5 Revision: 10-Mar-2021 【HVR Series】 High Voltage Thick Film Chip Resistor ▓Packaging Reel Specifications & Packaging Quantity Type HVR02 Paper HVR03 HVR05 Paper HVR06 HVR0A HVR12 Tape Width Reel Diameter ΦA (mm) 10K 8mm 7 inch 178.5±1.5 20K 8mm 10 inch 254±1.0 40K 8mm 13 inch 330±1.0 5K 8mm 7 inch 178.5±1.5 10K 8mm 10 inch 254±1.0 20K 8mm 13 inch 330±1.0 4K 12mm 7 inch 178.5±1.5 8K 12mm 10 inch 250±1.0 Bottom Tape Top Tape Packaging Quantity ΦB (mm) ΦC (mm) W (mm) T (mm) 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 +1/-0 13.0±0.5 13.0±0.5 15.5±0.5 62±0.5 13.0±0.5 12.5±0.5 16.5±0.5 60 60 60 +1/-0 +1/-0 Embossed Paper Tape Specifications ψ D0 E A F W B T Paper Tape Type A (mm) B (mm) W (mm) P1 Resistor E (mm) F (mm) P0 (mm) P2 P0 P1 (mm) Direction of unreeling P2 (mm) ΦD0 (mm) T (mm) HVR02 0.65±0.10 1.15±0.10 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.45±0.10 HVR03 1.10±0.10 1.90±0.10 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.70±0.10 HVR05 1.60±0.10 2.40±0.20 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 HVR06 1.90±0.10 3.50±0.20 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 www.viking.com.tw For detail questions, contact:sales@viking.com.tw 5 Edition: REV.B5 Revision: 10-Mar-2021 【HVR Series】 High Voltage Thick Film Chip Resistor Embossed Plastic Tape Specifications Top Tape ψ D0 E A F W B ψD11.5+0.25,-0 T P1 Resistor P2 P0 Direction of unreeling Embossed Tape P1 (mm) ΦD0 (mm) Type A (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P2 (mm) T (mm) HVR0A 2.80±0.10 5.40±0.20 12.0±0.30 1.75±0.10 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.2 +0 HVR12 3.50±0.10 6.70±0.10 12.0±0.30 1.75±0.10 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.2 +0 ■Marking No Marking for 0402 1% for 0805/1206/2010/2512: 4 digits marking Example: Resistance Marking 49.9KΩ 4992 100KΩ 1003 1MΩ 1004 4.99MΩ 4994 10MΩ 1005 5% for 0603/0805/1206/2010/2512: 3 digits marking in E24 st Example: 124=120KΩ 106=10MΩ (1 and 2 E24 code 10 11 12 13 15 16 18 nd rd are E24 code and 3 code is multiplier) 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 1% for 0603: 3 digits marking in E96 14C www.viking.com.tw 3 digits marking for Example: 75C=59KΩ 39E=2.49MΩ For detail questions, contact:sales@viking.com.tw 6 Edition: REV.B5 Revision: 10-Mar-2021 【HVR Series】 High Voltage Thick Film Chip Resistor ■Marking Table Code E96 Code E96 Code E96 Code E96 01 100 25 178 49 316 73 562 02 102 26 182 50 324 74 576 03 105 27 187 51 332 75 590 04 107 28 191 52 340 76 604 05 110 29 196 53 348 77 619 06 113 30 200 54 357 78 634 07 115 31 205 55 365 79 649 08 118 32 210 56 374 80 665 09 121 33 215 57 383 81 681 10 124 34 221 58 392 82 698 11 127 35 226 59 402 83 715 12 130 36 232 60 412 84 732 13 133 37 237 61 422 85 750 14 137 38 243 62 432 86 768 15 140 39 249 63 442 87 787 16 143 40 255 64 453 88 806 17 147 41 261 65 464 89 825 18 150 42 267 66 475 90 845 19 154 43 274 67 487 91 866 20 158 44 280 68 499 92 887 21 162 45 287 69 511 93 909 22 165 46 294 70 523 94 931 23 169 47 301 71 536 95 953 174 48 309 72 549 96 976 24 Code A Multiplier 10 B 0 www.viking.com.tw 10 C 1 10 D 2 10 E 3 10 F 4 10 X 5 10 -1 Y 10 For detail questions, contact:sales@viking.com.tw 7 -2 Edition: REV.B5 Revision: 10-Mar-2021 【HVR Series】 High Voltage Thick Film Chip Resistor REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version B Jun 03, 2014 - - Environmental Characteristics updated Version B1 Oct 27, 2014 - Version B2 Jul 15, 2016 - Version B3 Jan 12, 2018 - Version B4 May 20, 2019 - - Modify TCR Test description - - Modify Bending Test description - Increase large reel packaging code - modify 2010 Embossed Plastic Tape B Specification - modify Soldering Condition (IPC/JEDEC J-STD-020) Version B5 Mar 10, 2021 www.viking.com.tw - Standard Electrical Specifications updated - Environmental Characteristics updated - Remove Material Description - Modify Storage Temperature - Increase IEC 62368-1 & IEC 60950-1 Safety Certificate Scope For detail questions, contact:sales@viking.com.tw 8 Edition: REV.B5 Revision: 10-Mar-2021
HVR12JTET0100
物料型号:HVR系列高压厚膜芯片电阻,尺寸包括0402/0603/0805/1206/2010/2512。
器件简介:这些电阻采用钌基材料制成,具有高可靠性的多层电极结构,适用于高压环境,有助于减小最终设备的尺寸,并获得了UL Demko颁发的IEC 62368-1和IEC 60950-1安全认证。
引脚分配:文档中描述了电阻的结构,包括铝基板、边缘电极、电阻层、底层电极、阻挡层、主覆盖层、顶层电极和外部电极。
参数特性:提供了不同尺寸的电阻的尺寸、重量(每1000件)、安全认证范围、功率额定值、工作温度范围、最大工作电压、电阻范围、温度系数(TCR)、推荐焊盘图案和去额定曲线。
功能详解:这些电阻适用于多种应用,包括逆变器、户外设备、转换器和高脉冲设备。
应用信息:适用于高压环境,如逆变器、户外设备、转换器和高脉冲设备。
封装信息:提供了不同尺寸的电阻的封装信息,包括尺寸、重量、引脚分配和推荐焊盘图案。
HVR12JTET0100 价格&库存
很抱歉,暂时无法提供与“HVR12JTET0100”相匹配的价格&库存,您可以联系我们找货
