Data Sheet
Customer:
Product:
High Ohmic Chip Resistor - HMR Series
Size:
0805/1206
Issued Date:
10-Mar-21
Edition:
REV.A5
VIKING TECH CORPORATION
光頡科技股份有限公司
VIKING TECH CORPORATION KAOHSIUNG BRANCH
光頡科技股份有限公司高雄分公司
VIKING ELECTRONICS (WUXI) CO., LTD.
光頡電子(無錫)有限公司
No.70 Guangfu N. Rd., Hukou
Township, Hsinchu County 303,
Taiwan
No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung,
806, Taiwan
TEL:886-3-5972931
FAX:886-3-5972935•886-3-5973494
E-mail:sales@viking.com.tw
TEL:886-7-8217999
FAX:886-7-8228229
No.22 Xixia Road, Machinery & Industry Park,
National Hi-Tech Industrial Development Zone
of Wuxi, Wuxi, Jiangsu Province, China
Zip Code:214028
TEL:86-510-85203339
FAX:86-510-85203667•86-510-85203977
E-mail:china@viking.com.tw
Produced by
(QC)
Checked
(QC)
Approved by
(QC)
10-Mar-21
10-Mar-21
10-Mar-21
Susan Huang
J.C. Liu
J.C. Liu
Prepared by
(Sales)
Accepted by
(Customer)
【HMR Series】
■Scope
-This specification applies to all sizes of rectangular-type fixed
chip resistors with Ruthenium-base as material.
■Features
-Extended resistance range(110MΩ ~ 1GΩ )
-Surface mount package
-Highly reliable multilayer electrode construction
■Construction
■Applications
-Voltage dividers and hybrids
-X-Ray equipment
-Low signal detection or amplification circuits
-High input impedance quartz amplifiers
-Testing devices
Alumina Substrate
Bottom Electrode
Top Electrode
Edge Electrode
Barrier Layer
External Electrode
Resistor Layer
Primary Overcoat
Secondary Overcoat
■Dimensions
Type
Size
(Inch)
HMR05
HMR06
D1
D2
(mm)
T
(mm)
(mm)
(mm)
Weight
(g)
(1000pcs)
2.00±0.10
1.25±0.10
0.50±0.10
0.35±0.20
0.40±0.20
4.368
3.10±0.10
1.55±0.10
0.55±0.10
0.50±0.25
0.50±0.20
8.947
L
W
(mm)
0805
1206
■Part Numbering
HMR
05
J
Product
Type
Dimensions
Resistance
Tolerance
J: ±5%
05: 0805
06: 1206
www.viking.com.tw
L
Function
Code
L: Standard
7
--200M
Packaging
Code
7: 7” Reel 5Kpcs
A: 10” Reel 10Kpcs
D: 13” Reel 20Kpcs
F: Bulk
Resistance
For detail questions, contact:sales@viking.com.tw
1
- - 200M: 200MΩ
- - - -1G: 1GΩ
“-“ to fill up 6 spaces
Edition: REV.A5
Revision: 10-Mar-2021
【HMR Series】
Derating
Curve
■Derating
Curve
■Recommend Land Pattern
100
B
Power ratio (%)
C
A
Type
A
(mm)
B
(mm)
C
(mm)
HMR05
1.20
0.70
1.30
HMR06
2.00
0.90
1.60
80
60
40
60
80
100
120
140
160
Ambient Temperature ( ℃ )
■Soldering Condition (IPC/JEDEC J-STD-020)
■Standard Electrical Specifications
Item
Type
HMR05 (0805)
Power Rating
at 70C
Operating
Temp. Range
1/8W
Max.
Operating
Voltage
Max.
Overload
Voltage
150V
300V
Resistance Range
±5%
TCR
(PPM/C)
110MΩ ~ 500MΩ
±500
510MΩ ~ 1GΩ
±1000
110MΩ ~ 500MΩ
±500
510MΩ ~ 1GΩ
±1000
-55 ~ +125C
HMR06 (1206)
1/4W
200V
400V
Operating Voltage=√(P*R) or Max. Operating Voltage listed above, whichever is lower.
Overload Voltage=2.5*√(P*R) or Max. Overload Voltage listed above, whichever is lower.
■ Viking is capable of manufacturing the optional spec based on customer’s requirement.
www.viking.com.tw
2
Edition: REV.A5
【HMR Series】
■Environmental Characteristics
Requirement
Item
Temperature Coefficient of
Resistance (T.C.R.)
Test Method
5%
JIS-C-5201-1 4.8
IEC-60115-1 4.8
As Spec.
Short Time Overload
(2.0%+0.05Ω)
Insulation Resistance
10G
At 25C/-55C and 25C/+125C, 25C is the
reference temperature
JIS-C-5201-1 4.13
IEC-60115-1 4.13
RCWV*2.5 or Max. Overload Voltage whichever is
lower for 5 seconds
JIS-C-5201-1 4.6
IEC-60115-1 4.6
Max. Overload Voltage for 1 minute
Endurance
Damp Heat with Load
Dry Heat
JIS-C-5201-1 4.25
IEC-60115-1 4.25.1
(3.0%+0.10Ω)
702C, RCWV for 1000 hrs with 1.5 hrs “ON” and
0.5 hr “OFF”
JIS-C-5201-1 4.24
IEC-60115-1 4.24
(3.0%+0.10Ω)
402C, 90~95% R.H., RCWV for 1000 hrs with
1.5 hrs “ON” and 0.5 hr “OFF”
JIS-C-5201-1 4.23
IEC-60115-1 4.23.2
(1.5%+0.10Ω)
at +125 C for 1000 hrs
JIS-C-5201-1 4.33
IEC-60115-1 4.33
Bending Strength
(1.0%+0.05Ω)
Bending once for 60 seconds
0805, 1206 sizes: 3mm
Solderability
JIS-C-5201-1 4.17
IEC-60115-1 4.17
95% min. coverage
2455C for 3 seconds
Resistance to Soldering Heat
JIS-C-5201-1 4.18
IEC-60115-1 4.18
(1.0%+0.05Ω)
2605C for 10 seconds
Voltage Proof
JIS-C-5201-1 4.7
IEC-60115-1 4.7
No breakdown or flashover
1.42 times Max. Operating Voltage for 1 minute
Leaching
Individual leaching area ≦5%
JIS-C-5201-1 4.18
IEC-60068-2-58 8.2.1
Total leaching area ≦ 10%
2605C for 30 seconds
JIS-C-5201-1 4.19
IEC-60115-1 4.19
Rapid Change of Temperature (1.0%+0.05Ω)
-55C to +125C, 5 cycles
RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower.
■ Storage Temperature: 15~28°C; Humidity < 80%RH
www.viking.com.tw
3
Edition: REV.A5
【HMR Series】
▓Packaging
Reel Specifications & Packaging Quantity
Tape Width
Reel
Diameter
ΦA
(mm)
5K
8mm
7 inch
178.5±1.5
10K
8mm
10 inch
254±1.0
20K
8mm
13 inch
330±1.0
Packaging
Quantity
Type
HMR05
Paper
HMR06
ΦB
(mm)
ΦC
(mm)
W
(mm)
T
(mm)
13.0±0.2
9.0±0.5
12.5±0.5
100±0.5
13.0±0.2
9.5±0.5
13.5±0.5
100±0.5
13.0±0.2
9.5±0.5
13.5±0.5
60
+1/-0
Paper Tape Specifications
Bottom Tape
Top Tape
ψ D0
E
A
F
W
B
T
A
(mm)
Type
B
(mm)
W
(mm)
P1
Resistor
Paper Tape
E
(mm)
F
(mm)
P2
P0
(mm)
P0
Direction of unreeling
P1
(mm)
ΦD0
(mm)
P2
(mm)
T
(mm)
HMR05
1.60±0.10 2.40±0.20
8.0±0.20
1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10
HMR06
1.90±0.10 3.50±0.20
8.0±0.20
■Marking
5% for 0805/1206: 3 digits marking in E24
st
Example: 101=100Ω 102=1KΩ (1 and 2
E24
code
10
11
www.viking.com.tw
12
13
15
16
nd
18
rd
are E24 code and 3 code is multiplier)
24
27
30
33
36
39
43
4
47
51
56
62
68
75
82
91
Edition: REV.A5
【HMR Series】
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version A2 Jun 03, 2014
Environmental Characteristics updated
Version A3 Jul 15, 2016
Remove Material Description
Modify Storage Temperature
Version A4 May 20, 2019
- Modify TCR Test description
Version A5 Mar 10, 2021
- Modify Soldering Condition (IPC/JEDEC
J-STD-020)
- Modify Bending Test description
www.viking.com.tw
5
Edition: REV.A5
很抱歉,暂时无法提供与“HMR05JL7--560M”相匹配的价格&库存,您可以联系我们找货
