MULTILAYER CERAMIC CHIP CAPACITORS
- GMC SERIES APPLICATIONS
- Can be used on surface mount assembly equipment
- Our fully integrated manufacturing and total quality
control systems ensure unprecedented high standards of
quality and reliability.
FEATURES
- Large capacitance values in small sizes
- Excellent high frequency characteristics
CONSTRUCTION
Solder plate; 100% matte SN; typical thickness
0.003mm to 0.005mm *(Please see note)
CHIP CAPACITOR SELECTION
DIELECTRIC TYPE
COG (NPO) - Capacitance change with temperature is
0-30ppml°C which is less than -0.3%°C from -55°C to
+125°C. Typical capacitance change with life is less than
-0.1 % for NPOs, one-fifth that shown by most other
dielectrics. NPO formulations show no aging characteristics.
Nickel Barrier Layer
(50 Micro-Inches Electroplated Nickel Min.)
Inner
Electrodes
Ultra stable class I dielectric: linear temperature coefficient, low loss, negligible change of electrical properties with
time, voltage and frequency.
-55°C to° +125 C
0±30ppm°C
0±30ppm/°C
0.1% Max,
0.02% Typlical
•25°C, VDCW:
>100GOFor
1000QF, whichever
is less
•125°C, Vocw:
>10GQF or 100QF
whichever is less
3 X VDCW
0% per decade
hour
• C1000pF
f=1KHz V=1.0Vrms
±0.2Vrms T=25°C
X7R/X5R - Its temperature variation of capacitance is within ±15% from -55°C to +125°C (-55°C to +85° C for X5R). The
capacitance change is non-linear.
Stable class II dielectric
X7R=-55C to+125C
X5R=-55C to+85C
±15%
X7R/X5R
Not Applicable
2.5% Max,
1.8% Typical
• 25°C, VDCW:
>100GQFor
1000QF,
whichever is less
•125°C, Vocw:
>10GQF or100QF
whichever is less
2.5 X VDCW
or =
to 10uF 1.0Vrms
120Hz
1
Z5U - Despite their capacitance instability, ZSU formulations are very popular because of their small size, temperature
range low ESL, low ESR and excellent frequency response. These features are particularly important for decoupling
application where only a minimum capacitance value is required.
Y5V - YSV formulations are for general purpose use in a limited temperature range. They have a wide temperature
characteristic of +22% - 82% capacitance change over the operating temperature range of -30°C to +85°C. YSVs high
dielectric constant allows the manufacture of very high capacitance values (up to 22MF) in small physical sizes.
High capacitance per unit volume: general purpose product
-30°C to +85°C
+22%
-82%
N/A
3.0% Max, 2.0%
Typical
10GQ or 100QF
whichever is less,
25°C, Vocw
2.5 X VDCW
3.0% per decade 1 KHz, 1 Vrms 25°C
hour
values > or = to
10uF 1.0Vrms
120Hz
CAPACITANCE VALUE & TOLERANCE
Determined by circuit requirements. Note that chip prices decrease with lower capacitance value and looser tolerance.
VOLTAGE
Determined by circuit requirements. Units are designed to exceed the withstanding voltage specification, i.e., the user
need not incorporate an additional safety margin.
CAPACITOR SIZE
Select the smallest unit permitted by the circuit constraints that provides the required capacitance and voltage rating.
All Cal-Chip capacitors conform to EIA specifications.
CAPACITOR TERMINATION
Nickel barrier is standard and recommended for units exposed to repeated solder cycles, to minimize leaching of the
termination.
GMC
PRODUCT TYPE
21
DIMENSIONS
01: 01005
02: 0201
04: 0402
10: 0603
21: 0805
31: 1206
32: 1210
40: 1808
43: 1812
45: 1825
55: 2220
57: 2225
CG
DIELECTRIC
CG:
COG/NPO
X7R
X5R
Z5U
Y5V
102
CAPACITANCE
0R5: 0.5pF
5R0: 5.0pF
100: 10pF
101: 100pF
102: 1000pF
103: .01uF
104: .1uF
105: 1.0uF
106: 10uF
107: 100uF
J
TOLERANCE
A: +/-.05pF
B: +/-.1pF
C: +/-.25pF
D: +/-.5pF
F: +/-1%
G: +/-2%
J: +/-5%
K: +/-10%
M: +/-20%
Z: -20%/+80%
50
VOLTAGE DC
4R0: 4.0V
6R3: 6.3V
10: 10V
16: 16V
25: 25V
35: 35V
50: 50V
63: 63V
100: 100V
200: 200V
..Note: Cal-Chip has completed the Lead-Free transition. All parts shipped will be lead-free. The customer
designator of "LF" is no longer available.Lead-Free material will continue to have a green RoHS symbol on the
label.
2
NT
TERMINATION
NT: Sn/Ni
PT: Pd/Ag
D
PACKAGING CODE
Blank: 7" reel
D: See page 19 & 20
G: See page 19 & 20
Q: See page 19 & 20
DIMENSION (MM)
GMC01
L(L1)
0.4 ± 0.02
W
0.2 ± 0.02
H
0.2 ± 0.02
BW(L2/L3)
0.07 ~ 0.14
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
0.5pF
0.75
1
1.2
1.5
1.8
2
2.2
2.7
3
3.3
3.6
3.9
4
4.7
5
5.6
6
6.8
7
8
8.2
10
11
12
15
18
27
30
33
39
43
47
51
56
62
68
82
100
120
150
180
220
270
330
390
470
560
680
820
1.0nF
1.2
1.5
1.8
2.2
2.7
3.3
3.9
4.7
5.6
6.8
8.2
10
12
15
18
22
27
33
39
47
56
68
82
100
120
220
470
1uf
NPO/COG
6.3
10/16
6.3
X7R
10
16
6.3
X5R
10
16
0R5
R75
1R0
1R2
1R5
1R8
2R0
2R2
2R7
3R0
3R3
3R6
3R9
4R0
4R7
5R0
5R6
6R0
6R8
7R0
8R0
8R2
100
110
120
150
180
200
220
270
300
330
390
430
470
510
560
620
680
820
101
121
151
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
563
683
823
104
124
224
474
105
3
GMC02
DIMENSION (MM)
0.6 ± 0.03
L(L1)
0.3 ± 0.03
W
H
0.3 ± 0.03
BW(L2/L3)
0.15 ± 0.05
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
4
0.1pF
0R1
0.2
0R2
0.3
0R3
0.4
0R4
0.47
R47
0.5
0.56
0.6
0.7
0.75
0.8
0.82
0.9
1
1.2
1.3
1.5
1.6
1.8
2
2.2
2.5
2.7
2.8
3.3
3.9
4.3
4.7
5.6
6.8
8.2
10
11
12
15
18
24
27
30
33
39
43
47
51
56
62
68
75
82
100
120
150
180
220
270
330
390
470
560
680
820
1.0nF
1.2
1.5
1.8
2.2
2.7
3.3
3.9
4.7
5.6
6.8
8.2
10
12
15
18
22
27
33
39
47
56
68
82
100
220
470
1.0uF
2.2
4.7
0R5
R56
0R6
0R7
R75
0R8
R82
0R9
1R0
1R2
1R3
1R5
1R6
1R8
2R0
2R2
2R5
2R7
2R8
3R3
3R9
4R3
4R7
5R6
6R8
8R2
100
110
120
150
180
200
220
240
270
300
330
390
430
470
510
560
620
680
750
820
101
121
151
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
563
683
823
104
224
474
105
225
475
NPO/COG
25
50
4/6.3V
10
X5R
16
25
6.3
10
X7R
16
25
50
Y5V/Z5U
6.3
DIMENSION (MM)
GMC04
L(L1)
1.0 ± 0.05
W
0.5 ± 0.05
H
0.5 ± 0.1
BW(L2/LW)
DIELECTRIC
RATED VOLTAGE
0.1 ~ 0.35
6.3/10 16
NPO/COG
25
50
100
200 6.3 10
X5R
16
25
X7R
50 6.3/10 16/25 50
100
Y5V & Z5U
200 6.3 10
16
25
50
CAP. RANGE
0.47
0.5
0.56
0.6
0.68
0.7
0.75
0.8
0.9
1
1.2
1.3
1.5
1.6
1.8
2
2.2
2.4
2.7
3
3.3
3.5
3.6
3.9
4
4.3
4.7
5
5.1
5.6
6
6.2
6.8
7
7.5
8
8.2
9
9.1
10
11
12
13
15
18
24
27
30
33
36
39
43
47
51
56
62
68
75
82
91
100
110
120
130
150
180
200
220
240
270
300
330
360
390
430
470
560
680
750
820
1.0nF
1.2
1.5
1.8
R47
0R5
R56
0R6
R68
0R7
R75
0R8
0R9
1R0
1R2
1R3
1R5
1R6
1R8
2R0
2R2
2R4
2R7
3R0
3R3
3R5
3R6
3R9
4R0
4R3
4R7
5R0
5R1
5R6
6R0
6R2
6R8
7R0
7R5
8R0
8R2
9R0
9R1
100
110
120
130
150
180
200
220
240
270
300
330
360
390
430
470
510
560
620
680
750
820
910
101
111
121
131
151
181
201
221
241
271
301
331
361
391
431
471
561
681
751
821
102
122
152
182
5
GMC04
DIMENSION (MM)
L(L1)
1.0 ± 0.05
W
0.5 ± 0.05
0.5 ± 0.1
H
BW(L2/LW)
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
2.2
2.7
3.3
3.9
4.7
5.6
6.8
8.2
10
12
15
18
22
27
33
39
47
56
68
82
100
150
220
270
390
470
560
680
820
1.0 uF
2.2
2.7
3.3
3.9
4.7
5.6
6.8
8.2
10
15
22
33
47
0.1 ~ 0.35
NPO/COG
6.3/10 16
25
50 100 200 6.3 10
X5R
16
25
35
50 6.3/10 16
X7R
25
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
563
683
823
104
154
224
274
394
474
564
684
824
105
225
275
335
395
475
565
685
825
106
156
226
336
476
****Please note L/W/H deviation for the 10uF is +/-.2mm****
****Please note L/W/H deviation for the 22uF is +/-.3mm****
6
Y5V & Z5U
50 100 200 6.3 10
16
25
50
DIMENSION (MM)
GMC10
L(L1)
1.6 ± 0.2
W
0.8 ± 0.2
H
1.0 max
BW(L2/LW)
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
0.4PF
0.47
0.5
0.6
0.7
0.75
0.8
1
1.2
1.3
1.5
1.8
2
2.2
2.4
2.7
3
3.3
3.6
3.9
4
4.3
4.7
5
5.1
5.6
6
6.2
6.8
7
7.5
8
8.2
9
9.1
10
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
82
91
100
120
130
150
160
180
200
220
240
270
300
330
390
430
470
510
560
620
680
750
820
910
25
NPO/COG
50
100 200
6.3
X5R
10
16
0.1 ~ 0.4
25
6.3
10
16
X7R
25
50
100 200
6.3
Y5V & Z5U
10
16
25
50
R40
R47
0R5
0R6
R70
R75
0R8
1R0
1R2
1R3
1R5
1R8
2R0
2R2
2R4
2R7
3R0
3R3
3R6
3R9
4R0
4R3
4R7
5R0
5R1
5R6
6R0
6R2
6R8
7R0
7R5
8R0
8R2
9R0
9R1
100
110
120
130
150
160
180
200
220
240
270
300
330
360
390
430
470
510
560
620
680
750
820
910
101
121
131
151
161
181
201
221
241
271
301
331
391
431
471
511
561
621
681
751
821
911
7
GMC10
DIMENSION (MM)
1.6 ± 0.2
0.8 ± 0.2
1.0 max
0.1 ~ 0.4
L(L1)
W
H
BW(L2/LW)
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
1.0nF
1.2
1.5
1.8
2.2
2.7
3.3
3.9
4.7
5.6
6.8
7.5
8.2
10
12
15
18
22
27
33
39
47
56
68
82
100
120
150
220
270
330
470
560
680
820
1.0 uF
2.2
2.7
3.3
3.9
4.7
10
22
47
8
102
122
152
182
222
272
332
392
472
562
682
752
822
103
123
153
183
223
273
333
393
473
563
683
823
104
124
154
224
274
334
474
564
684
824
105
225
275
335
395
475
106
226
476
25
NPO/COG
50
100 200
6.3
10
X5R
16/25
35
6.3
10
16
X7R
25
50
100 200
6.3
Y5V & Z5U
10
16
25
50
GMC21
DIMENSION (MM)
L(L1)
2.0 ± 0.3
2.0 ± 0.3
2.0 ± 0.3
2.0 ± 0.3
W
1.25 ± 0.2
1.25 ± 0.2
1.25 ± 0.2
1.25 ± 0.2
H
1.4
1.5
1.5
1.5
BW(L2/L3)
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
0.4pF
16
NPO/COG
25
50
100
200
6.3
10
16
X7R
25
35
50
100
200
4
6.3
10
X5R
16
25
35
50
63
6.3
Y5V/Z5U
10
16
25
50
0R4
0.47
R47
0.5
R50
0.56
R56
0.75
R75
0.8
0R8
0.82
R82
1
1R0
1.1
1R1
1.2
1R2
1.3
1R3
1.5
1R5
1.6
1R6
1.8
1R8
2
2R0
2.2
2R2
2.4
2R4
2.7
2R7
3
3R0
3.3
3R3
3.6
3R6
3.9
3R9
4
4R0
4.3
4R3
4.7
4R7
5
5R0
5.1
5R1
5.6
5R6
6
6R0
6.2
6R2
6.8
6R8
7
7R0
7.5
7R5
8
8R0
8.2
8R2
9
9R0
9.1
9R1
10
100
11
110
12
120
13
130
15
150
16
160
18
180
22
220
24
240
27
270
30
300
33
330
36
360
39
390
43
430
47
470
51
510
56
560
62
620
68
680
75
750
82
820
91
910
100
101
120
121
130
131
150
151
160
161
180
181
200
201
220
221
240
241
270
271
300
301
9
GMC21
DIMENSION (MM)
L(L1)
2.0 ± 0.3
2.0 ± 0.3
2.0 ± 0.3
2.0 ± 0.3
W
1.25 ± 0.2
1.25 ± 0.2
1.25 ± 0.2
1.25 ± 0.2
H
1.4
1.5
1.5
1.5
BW(L2/L3)
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
10
330
331
360
361
390
391
430
431
470
471
510
511
560
561
620
621
680
681
750
751
820
821
910
911
1.0nF
102
1.2
122
1.5
152
1.8
182
2.2
222
2.4
242
2.7
272
3.3
332
3.9
392
4.7
472
5.6
562
6.8
682
8.2
822
10
103
12
123
15
153
18
183
22
223
27
273
33
333
39
393
47
473
56
563
68
683
82
823
100
104
120
124
150
154
180
184
220
224
270
274
330
334
390
394
470
474
560
564
680
684
820
824
1.0 uF
105
1.2
125
1.5
155
1.8
185
2.2
225
3.3
335
4.7
475
4.7
475
6.8
685
10
106
15
156
22
226
33
336
47
476
100
107
150
157
220
227
330
337
16
NPO/COG
25
50
100
200
6.3
10
16
X7R
25
35
50
100
200
4
6.3
10
X5R
16
25
35
50
63
6.3
Y5V/Z5U
10
16
25
50
GMC31
DIMENSION (MM)
L(L1)
3.2 ± 0.3
3.2 ± 0.3
3.2 ± 0.3
3.2 ± 0.3
W
1.6 ± 0.2
1.6 ± 0.2
1.6 ± 0.2
1.6 ± 0.2
H
1.8 max
1.8 max
1.8 max
1.8 max
BW(L2/L3)
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
0.47pF
0R47
0.5
R50
0.56
R56
0.68
R68
0.75
R75
0.8
0R8
1
1R0
1.1
1R1
1.2
1R2
1.3
1R3
1.5
1R5
1.6
1R6
1.8
1R8
2
2R0
2.2
2R2
2.4
2R4
2.7
2R7
3
3R0
3.3
3R3
3.6
3R6
3.9
3R9
4
4R0
4.3
4R3
4.7
4R7
5
5R0
5.1
5R1
5.6
5R6
6
6R0
6.2
6R2
6.8
6R8
7
7R0
7.5
7R5
8
8R0
8.2
8R2
9
9R0
9.1
9R1
10
100
11
110
12
120
13
130
15
150
16
160
18
180
22
220
24
240
27
270
30
300
33
330
36
360
39
390
43
430
47
470
51
510
56
560
62
620
68
680
75
750
82
820
91
910
100
101
120
121
130
131
150
151
160
161
180
181
200
201
220
221
240
241
270
271
25
NPO/COG
50
100 200
6.3
10
16
X7R
25
50
100 200
4
6.3
X5R
10
16
25
50
6.3
Y5V/Z5U
10
16
25
50
11
GMC31
DIMENSION (MM)
L(L1)
3.2 ± 0.3
3.2 ± 0.3
3.2 ± 0.3
3.2 ± 0.3
W
1.6 ± 0.2
1.6 ± 0.2
1.6 ± 0.2
1.6 ± 0.2
H
1.8 max
1.8 max
1.8 max
1.8 max
BW(L2/L3)
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
12
300
301
330
331
360
361
390
391
430
431
470
471
510
511
560
561
620
621
680
681
750
751
820
821
910
911
1.0nF
102
1.2
122
1.5
152
1.8
182
2.2
222
2.4
242
2.7
272
3.3
332
3.9
392
4.7
472
5.6
562
6.8
682
8.2
822
10
103
12
123
15
153
18
183
22
223
27
273
33
333
39
393
47
473
56
563
68
683
82
823
100
104
120
124
150
154
180
184
220
224
270
274
330
334
390
394
470
474
560
564
680
684
820
824
1.0 uF
105
1.2
125
1.5
155
1.8
185
2.2
225
2.7
275
3.3
335
4.7
475
4.7
475
6.8
685
10
106
15
156
22
226
33
336
47
476
68
686
100
107
220
227
330
337
25
NPO/COG
50
100
200
6.3
10
16
X7R
25
50
100
200
4
6.3
X5R
10
16
25
50
6.3
10
Y5V/Z5U
16
25
50
DIMENSION (MM)
L(L1)
W
H
BW(L2/L3)
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
0.5pF
0R5
0.4
R40
0.47
R47
0.7
R70
0.75
R75
1
1R0
1.1
1R1
1.2
1R2
1.3
1R3
1.5
1R5
1.6
1R6
1.8
1R8
2
2R0
2.2
2R2
2.4
2R4
2.7
2R7
3
3R0
3.3
3R3
3.6
3R6
3.9
3R9
4
4R0
4.3
4R3
4.7
4R7
5
5R0
5.1
5R1
5.6
5R6
6
6R0
6.2
6R2
6.8
6R8
7
7R0
7.5
7R5
8
8R0
8.2
8R2
9
9R0
9.1
9R1
10
100
11
110
12
120
13
130
15
150
16
160
18
180
22
220
24
240
27
270
30
300
33
330
36
360
39
390
43
430
47
470
51
510
56
560
62
620
68
680
75
750
82
820
91
910
100
101
120
121
130
131
150
151
160
161
180
181
200
201
220
221
240
241
270
271
300
301
330
331
16
GMC32
3.2 ± 0.3
3.2 ± 0.3
3.2 ± 0.3
3.2 ± 0.3
2.5 ± 0.3
2.5 ± 0.3
2.5 ± 0.3
2.5 ± 0.3
2.2 max
2.8 max
2.8 max
2.8 max
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
NPO/COG
25
50
100
200
6.3
10
16
X7R
25
50
100
200
4
6.3
X5R
10
16
25
50
6.3
Y5V/Z5U
10
16
25
50
13
GMC32
DIMENSION (MM)
L(L1)
3.2 ± 0.3
3.2 ± 0.3
3.2 ± 0.3
3.2 ± 0.3
W
2.5 ± 0.3
2.5 ± 0.3
2.5 ± 0.3
2.5 ± 0.3
H
2.2 max
2.8 max
2.8 max
2.8 max
BW(L2/L3)
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
360
361
390
391
430
431
470
471
510
511
560
561
680
681
750
751
820
821
910
911
1.0nF
102
1.2
122
1.5
152
1.8
182
2.2
222
2.4
242
2.7
272
3.3
332
3.9
392
4.7
472
5.6
562
6.8
682
8.2
822
10
103
12
123
15
153
18
183
22
223
27
273
33
333
39
393
47
473
56
563
68
683
82
823
100
104
120
124
150
154
180
184
220
224
270
274
330
334
390
394
470
474
560
564
680
684
820
824
1.0 uF
105
1.2
125
1.5
155
1.8
185
2.2
225
2.7
275
3.3
335
4.7
475
4.7
475
6.8
685
8.2
825
10
106
15
156
22
226
33
336
47
476
68
686
100
107
150
157
220
227
330
337
16
NPO/COG
25
50
100
200
6.3
10
16
X7R
25
50
100
200
4
6.3
X5R
10
16
25
50
6.3
Y5V/Z5U
10
For GMC32X5R (1210) size (L) tolerance for values > 100uf, tolerance increases to 3.2mm +/- 0.4 mm.
14
16
25
50
GMC40
DIMENSION (MM)
DIMENSION (MM)
L(L1)
4.57 ± 0.25
4.57 ± 0.25
W
2.03 ± 0.25
2.03 ± 0.25
H
2.1 max
3 max
BW(L2/L3)
0.25 ~ 0.75
0.25 ~ 0.75
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
NPO/COG
50
100
200
25
50
X7R
100
L(L1)
4.5 ± 0.35
4.5 ± 0.35
H
2.2 max
3 max
W
3.2 ± 0.3
BW(L2/L3)
Rated Voltage
Cap. Range
0.5pF
0R5
0.4
R40
110
0.47
R47
12
120
13
130
0.7
R70
15
150
0.75
R75
16
160
1
1R0
18
180
1.1
1R1
1.2
1R2
22
220
1.3
1R3
24
240
27
270
1.5
1R5
30
300
1.6
1R6
33
330
1.8
1R8
36
360
2
2R0
39
390
2.2
2R2
43
430
2.4
2R4
47
470
2.7
2R7
51
510
56
560
3
3R0
62
620
3.3
3R3
68
680
3.6
3R6
75
750
3.9
3R9
82
820
4
4R0
91
910
4.3
4R3
100
101
120
121
4.7
4R7
130
131
5
5R0
150
151
5.1
5R1
160
161
5.6
5R6
180
181
6
6R0
200
201
6.2
6R2
220
221
6.8
6R8
240
241
270
271
7
7R0
300
301
7.5
7R5
330
331
8
8R0
360
361
8.2
8R2
390
391
9
9R0
430
431
9.1
9R1
470
471
510
511
10
100
560
561
11
110
620
621
12
120
680
681
13
130
750
751
15
150
820
821
16
160
910
911
18
180
1.0nF
102
1.2
122
1.5
152
22
220
1.8
182
24
240
2.2
222
27
270
2.4
242
30
300
2.7
272
33
330
3.3
332
3.9
392
36
360
4.7
472
39
390
5.6
562
43
430
6.8
682
47
470
8.2
822
51
510
10
103
56
560
12
123
62
620
15
153
18
183
68
680
22
223
75
750
27
273
82
820
33
333
91
910
39
393
100
101
47
473
120
121
56
563
68
683
130
131
82
823
150
151
100
104
160
161
120
124
180
181
150
154
200
201
180
184
220
221
220
224
240
241
270
274
330
334
270
271
390
394
300
301
470
474
330
331
560
564
360
361
9.1
9R1
10
100
11
3.2 ± 0.3
0.25 ~ 0.75
Dielectric
200
NPO/COG
50 100 200 10
GMC43
0.25 ~ 0.75
16
X7R
25
50 100 200 6.3
4.5 ± 0.35
4.5 ± 0.35
3.2 ± 0.3
3.2 ± 0.3
3 max
3 max
0.25 ~ 0.75
X5R
10
16
0.25 ~ 0.75
25
6.3
Y5V/Z5U
10
16
25
50
15
DIMENSION (MM)
L(L1)
BW(L2/L3)
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
390
391
430
431
470
471
510
511
560
561
680
681
750
751
820
821
910
911
1.0nF
102
1.2
122
1.5
152
1.8
182
2.2
222
2.4
242
2.7
272
3.3
332
3.9
392
4.7
472
5.6
562
6.8
682
8.2
822
10
103
12
123
15
153
18
183
22
223
27
273
33
333
39
393
47
473
56
563
68
683
82
823
100
104
120
124
150
154
180
184
220
224
270
274
330
334
470
474
560
564
680
684
820
824
1.0 uF
105
1.2
125
1.5
155
1.8
185
2.2
225
2.7
275
3.3
335
4.7
475
6.8
685
10
106
15
156
22
226
33
336
47
476
68
686
100
107
150
157
220
227
330
337
100
200
0.25 ~ 0.75
X7R
10
16
25
50
100
3 max
0.25 ~ 0.75
X5R
200
6.3
10
16
L(L1)
4.5 ± 0.35
4.5 ± 0.35
W
6.3 ± 0.4
6.3 ± 0.4
H
2.2 max
3.2 max
BW(L2/L3)
0.25 ~ 0.75
0.25 ~ 0.75
3.2 ± 0.3
3 max
25
0.25 ~ 0.75
Y5V/Z5U
6.3
10
16
25
GMC45
DIMENSION (MM)
4.5 ± 0.35
3.2 ± 0.3
3 max
0.25 ~ 0.75
NPO/COG
50
4.5 ± 0.35
3.2 ± 0.3
2.2 max
H
GMC43
4.5 ± 0.35
3.2 ± 0.3
W
16
4.5 ± 0.35
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
50
9.1
9R1
10
100
11
110
12
120
13
130
15
150
16
160
18
180
22
220
24
240
27
270
30
300
33
330
36
360
39
390
43
430
47
470
51
510
56
560
62
620
68
680
75
750
82
820
91
910
100
101
120
121
130
131
150
151
160
161
180
181
200
201
220
221
240
241
270
271
300
301
330
331
360
361
390
391
430
431
470
471
510
511
560
561
680
681
750
751
820
821
910
911
1.0nF
102
1.2
122
1.5
152
1.8
182
2.2
222
2.4
242
2.7
272
3.3
332
3.9
392
4.7
472
5.6
562
6.8
682
8.2
822
10
103
12
123
15
153
18
183
22
223
27
273
33
333
39
393
47
473
56
563
68
683
82
823
100
104
120
124
150
154
180
184
220
224
270
274
330
334
470
474
560
564
680
684
820
824
1.0 uF
105
1.2
125
1.5
155
1.8
185
2.2
225
2.7
275
NPO/COG
50
100
200
16
25
X7R
50
100
200
GMC55
DIMENSION (MM)
L(L1)
5.7 ± 0.4
5.7 ± 0.4
5.7 ± 0.4
5.7 ± 0.4
W
5.0 ± 0.4
5.0 ± 0.4
5.0 ± 0.4
5.0 ± 0.4
H
2.2 max
3.5 max
3.5 max
3.5 max
BW(L2/L3)
DIELECTRIC
0.25 ~ 0.75
NPO/COG
0.25 ~ 0.75
X7R
0.25 ~ 0.75
X5R
0.25 ~ 0.75
Y5V/Z5U
RATED VOLTAGE
CAP. RANGE
270pF
271
300
301
330
331
360
361
390
391
430
431
470
471
510
511
560
561
680
681
750
751
820
821
910
911
1.0nF
102
1.2
122
1.5
152
1.8
182
2.2
222
2.4
242
2.7
272
3.3
332
3.9
392
4.7
472
5.6
562
6.8
682
8.2
822
10
103
12
123
15
153
18
183
22
223
27
273
33
333
39
393
47
473
56
563
68
683
82
823
100
104
120
124
150
154
180
184
220
224
270
274
330
334
390
394
470
474
560
564
680
684
820
824
1.0 uF
105
1.2
125
1.5
155
1.8
185
2.2
225
2.7
275
3.3
335
3.9
395
4.7
475
5.6
565
6.8
685
8.2
825
10
106
15
156
22
226
33
336
47
476
68
686
100
107
150
157
220
227
330
337
50
100
200
16
25
50
100
200
6.3
10
16
25
50
6.3
10
16
25
50
17
GMC57
DIMENSION (MM)
L(L1)
5.7 ± 0.4
5.7 ± 0.4
5.7 ± 0.4
W
6.3 ± 0.4
5.0 ± 0.4
5.0 ± 0.4
H
2.2 max
3.5 max
3.5 max
BW(L2/L3)
0.25 ~ 0.75
0.25 ~ 0.75
0.25 ~ 0.75
NPO/COG
BW(L2/L3)
DIELECTRIC
RATED VOLTAGE
CAP. RANGE
18
270
271
300
301
330
331
360
361
390
391
430
431
470
471
510
511
560
561
620
621
680
681
750
751
820
821
910
911
1.0nF
102
1.2
122
1.5
152
1.8
182
2.2
222
2.4
242
2.7
272
3.3
332
3.9
392
4.7
472
5.6
562
6.8
682
7.5
752
8.2
822
10
103
12
123
15
153
18
183
22
223
27
273
33
333
39
393
47
473
56
563
68
683
82
823
100
104
120
124
150
154
180
184
220
224
270
274
330
334
390
394
470
474
560
564
680
684
820
824
1.0 uF
105
1.2
125
1.5
155
1.8
185
2.2
225
2.7
275
3.3
335
4.7
475
5.6
565
6.8
685
8.2
825
10
106
15
156
22
226
33
336
47
476
68
686
100
107
150
157
220
227
330
337
50
100
X7R
200
16
25
50
Y5V/Z5U
100
200
6.3
10
16
25
50
PACKAGING (TAPING)
Per EIA-481 - Reel Type Size
t
SYMBOL
7” Reel
A
E min
10” Reel
13” Reel
B
C
TAPE WIDTH
A
B
C
D
E
W
t
4mm
φ178±2.0
MINφ50
φ13±0.5
21±0.8
2.0±0.5
5±0.5
1.2±0.2
8mm
φ178±2.0
MINφ50
φ13±0.5
21±0.8
2.0±0.5
10±0.5
0.9±0.2
12mm
φ178±2.0
MINφ50
φ13±0.5
21±0.8
2.0±0.5
13±0.5
1.2±0.2
8mm
φ258±2.0
MINφ70
φ13±0.5
21±0.8
2.0±0.5
10±0.5
1.8±0.2
8mm
φ330±2.0
MINφ70
φ13±0.5
21±0.8
2.0±0.5
10±0.5
1.8±0.2
12mm
φ330±2.0
MINφ70
φ13±0.5
21±0.8
2.0±0.5
13±0.5
2.2±0.2
D
W
- To peel off the cover tape by the method shown in the
right figure apply a peel-off force of 20GF - 60GF (card
board); 10GF - 75GF (plastic tape).
-The cover tape should not touch the top or bottom
ofthe chip.
- If the cover tape has been peeled off it may be
difficult to remove the chip due to punch-hole clearance,
dirt, and debris. Make sure therefore that no paper
waste will adhere to and block the absorption nozzle.
- If the cover tape has been peeled off from the top,
stick it back on with a suitable adhesive.
- Follow the illustration for the start and end of the
winding operation.
DIMENSION OF PAPER TAPE
CARDBOARD CARRIER TAPE FOR 01005, 0201, 0402, 0603, 0805, 1206
UNIT=mm
19
PACKAGING (TAPING)
Tape & Reel Dimensions
• Embossed plastic carrier tape for 0805/1206/1210/1808/1812/1825/2220 AND 2225 type
TYPE
A0
B0
T
K0
W
P0
10XPo
P1
P2
D0
D1
E
F
MOUNTING STD. REEL
HOLE
QTY 7”
0805
很抱歉,暂时无法提供与“GMC02X5R104J6R3NT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 15000+0.0493015000+0.00618
- 30000+0.0450030000+0.00564
- 45000+0.0428545000+0.00537
- 75000+0.0404775000+0.00507
- 105000+0.03909105000+0.00490
- 150000+0.03775150000+0.00473
- 180000+0.03711180000+0.00465
- 360000+0.03498360000+0.00439
- 375000+0.03488375000+0.00437
- 国内价格 香港价格
- 1+0.880031+0.11025
- 10+0.2194810+0.02750
- 50+0.1473850+0.01847
- 100+0.12543100+0.01572
- 500+0.08856500+0.01110
- 1000+0.077161000+0.00967
- 2500+0.065232500+0.00818
- 5000+0.058095000+0.00728
