SM4527FTR100
SM4527FTR100
    SEI
    贴片电阻 4527 100mΩ ±1% 2W ±100ppm/℃
SM4527FTR100 数据手册
SM/SMH Series Stackpole Electronics, Inc. Surface Mount Wirewound Resistor Features: • • • • • Resistive Product Solutions High temperature molded encapsulation Flex termination for absorbing thermal expansion All welded construction Non-inductive winding available (contact Stackpole with requirements) RoHS compliant, lead-free and halogen-free Electrical Specifications Type/Code Power Rating @ 70ºC Maximum Working Voltage Dielectric Withstanding Voltage Resistance Temperature Coefficient SM2615 1W 25V >500V ±75 ppm/ºC ±100 ppm/ºC ±20 ppm/ºC SM4124 2W 50V >500V ±75 ppm/ºC ±100 ppm/ºC ±20 ppm/ºC SM4527 2W 60V >500V SM4527…-LP SMH4527 2W 3W 60V 60V >500V >500V SM6227 3W 100V >500V SM8035 4W 100V Ohmic Range (Ω) and Tolerance 0.1% 5 - 10 10.1 - 400 5 - 10 3 - 10 10.1 - 1K 5 - 10 3 -10 10.1 - 1K - ±75 ppm/ºC ±100 ppm/ºC ±20 ppm/ºC ±75 ppm/ºC ±75 ppm/ºC ±75 ppm/ºC ±100 ppm/ºC ±20 ppm/ºC 10.1 - 3K - ±75 ppm/ºC ±100 ppm/ºC ±20 ppm/ºC >500V 0.5% 3 - 10 10.1 - 5K 1% 1 - 10 10.2 - 400 5% 0.01 - 0.098 0.1 - 10 11 - 400 0.05 - 0.098 0.01 - 0.098 0.1 - 10 10.2 - 1K 11 - 1K 0.05 - 0.098 0.01 - 0.098 0.1 - 10 10.2 - 1K 11 - 1K 0.01 - 0.05 0.01 - 0.05 0.05 - 0.098 1 - 10 10.2 - 3K 11 - 3K 0.05 - 0.098 1 - 10 10.2 - 5K 11 - 5K Performance Characteristics Test Moisture Resistance Thermal Shock Load Life @ 70ºC - 1,000 hours Resistance to Soldering Heat Terminal Strength Dielectric Withstanding Voltage Short Time Overload Test Specification ±1% ±0.5% ±1% ±1% ±0.5% ±0.001% / V ±0.2% Operating Temperature Range: -55ºC to +275ºC -55ºC Power Derating Curve: 70ºC Percent Rated Power (%) 100 80 60 40 20 275°C 0 -60 -40 0 40 80 120 160 200 240 280 320 Ambient Temperature (ºC) Rev Date: 10/25/2018 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com SM/SMH Series Stackpole Electronics, Inc. Surface Mount Wirewound Resistor Resistive Product Solutions Mechanical Specifications A B C D E F Body Total Body Body Termination Termination Length Length Height Width Width Length SM2615 0.260 ± 0.015 6.60 ± 0.38 0.280 ± 0.032 7.11 ± 0.81 0.140 ± 0.015 3.56 ± 0.38 0.150 ± 0.015 3.81 ± 0.38 0.100 ± 0.015 2.54 ± 0.38 SM4124 0.410 ± 0.015 10.41 ± 0.38 0.430 ± 0.032 10.92 ± 0.81 0.180 ± 0.015 4.57 ± 0.38 0.240 ± 0.015 6.10 ± 0.38 SM4527 0.455 ± 0.015 11.56 ± 0.38 0.475 ± 0.032 12.07 ± 0.81 0.215 ± 0.015 5.46 ± 0.38 SM4527…-LP 0.455 ± 0.015 11.56 ± 0.38 0.475 ± 0.032 12.07 ± 0.81 SMH4527 0.455 ± 0.015 11.56 ± 0.38 SM6227 SM8035 Type/Code W H L Unit 0.090 ± 0.015 2.29 ± 0.38 0.138 3.51 0.130 3.30 0.350 8.89 inches mm 0.122 ± 0.015 3.10 ± 0.38 0.090 ± 0.015 2.29 ± 0.38 0.181 4.60 0.157 3.99 0.583 14.81 inches mm 0.270 ± 0.015 6.86 ± 0.38 0.122 ± 0.015 3.10 ± 0.38 0.105 ± 0.015 2.67 ± 0.38 0.169 4.29 0.157 3.99 0.587 14.91 inches mm 0.150 ± 0.015 3.81 ± 0.38 0.270 ± 0.015 6.86 ± 0.38 0.122 ± 0.015 3.10 ± 0.38 0.105 ± 0.015 2.67 ± 0.38 0.169 4.29 0.157 3.99 0.587 14.91 inches mm 0.475 ± 0.032 12.07 ± 0.81 0.150 ± 0.015 3.81 ± 0.38 0.270 ± 0.015 6.86 ± 0.38 0.122 ± 0.015 3.10 ± 0.38 0.105 ± 0.015 2.67 ± 0.38 0.169 4.29 0.157 3.99 0.587 14.91 inches mm 0.625 ± 0.015 15.88 ± 0.38 0.645 ± 0.032 16.38 ± 0.81 0.250 ± 0.015 6.35 ± 0.38 0.275 ± 0.015 6.99 ± 0.38 0.122 ± 0.015 3.10 ± 0.38 0.130 ± 0.015 3.30 ± 0.38 0.236 5.99 0.157 3.99 0.850 21.59 inches mm 0.800 ± 0.015 20.32 ± 0.38 0.825 ± 0.032 20.96 ± 0.81 0.362 ± 0.015 9.19 ± 0.38 0.350 ± 0.015 8.89 ± 0.38 0.122 ± 0.015 3.10 ± 0.38 0.122 ± 0.015 3.10 ± 0.38 0.340 8.64 0.157 3.99 0.950 24.13 inches mm SM Series Hot Spot Temperature Rev Date: 10/25/2018 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com SM/SMH Series Stackpole Electronics, Inc. Surface Mount Wirewound Resistor Resistive Product Solutions RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) SM Surface Mount - General Purpose and Precision Wirewound Resistor SMD YES 100% Matte Sn Jan-06 06/01 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 S M 4 1 2 4 F T 1 K 0 0 - L P Product Series Code Description SM Standard SMH High Power NSM Non-inductive Power Rating Size Power 2615 1W 4124 2W 4527 2W (H)4527 3W 6227 3W 8035 4W Tolerance Code Tol B 0.1% D 0.5% F 1% J 5% Code T Rev Date: 10/25/2018 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. Packaging Size Quantity 2615 1,500 4527(-LP), H4527 1,200 13" Reel 4527 900 Plastic Tape 4124 800 6227 750 8035 350 Description 3 Resistance Value Four characters with the multiplier used as the decimal holder. "L" used as multiplier of 10-3 for any value under 0.1 ohm. 0.01 ohm = 10L0 0.1 ohm = R100 1 Kohm = 1K00 Code (blank) -LP Special Description Standard Low Profile www.seielect.com marketing@seielect.com
SM4527FTR100
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:适用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm。
SM4527FTR100 价格&库存
很抱歉,暂时无法提供与“SM4527FTR100”相匹配的价格&库存,您可以联系我们找货
SM4527FTR100
  • 1200+0.385701200+0.04985
