FT51AQ-T
FT51AQ-T
    BRIDGETEK
    WFQFN48
    IC MCU 8BIT 16KB MTP 48WQFN
FT51AQ-T 数据手册
FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 Future Technology Devices International Ltd. FT51A (Advanced Microcontroller with 8051 Compatible Core) The FT51A is a multi-featured device that can be targeted at a wide range of functions or applications:  Supports DMA operation  I2C Master & Slave functionality  SPI Master & Slave functionality  Industry compatible 8051 core running at a maximum frequency of 48MHz.  245 FIFO module provides a simple FIFO interface to transmit and receive data  8 KB of data memory  Timer and Watchdog  16 KB of multi-time programmable (MTP) memory  Up to 16 dedicated digital IO pins  16 KB of shadow memory for fast read access by the core.  Up to 16 multiplexed analogue / digital IO pins  USB 2.0 Full Speed hub controller allowing cascading of multiple FT51A devices  Support ADC function on analogue IO pins   USB 2.0 Full Speed device controller compatible to FT12 series IO Mux control for maximum flexibility in pin selection   Supports up to 8 bi-directional endpoints with 2 x 1 KB USB endpoint buffers Configurable IO pin output drive strength; 4 mA (min) and 16 mA (max)  +5V Single Supply Operation  Max packet size is 504 bytes for USB isochronous endpoint and 64 bytes for control / bulk / interrupt endpoint  Internal 3.3V/1.8V voltage regulators  Integrated power-on-reset circuit  Low operating and suspend current; 20 mA (active) and 150 uA (suspend)  Extended operating temperature range; -40 to 85⁰C  Available in compact Pb-free, RoHS compliant packages:  Double buffer scheme for any endpoint, increases data transfer throughput  Fully integrated clock generation with no external crystal required  Data transfer rates from 300 baud to 3M baud (RS422, RS485, and RS232) at TTL levels  PWM Controller  UART interface support for 7 or 8 data bits, 1 or 2 stop bits and odd / even / mark / space / no parity  USB Battery Charger Detection allowing optimized charging profile • 48-pin WQFN • 44-pin LQFP • 32-pin WQFN • 28-pin SSOP N either the whole nor any part of the information c ontained in, or the produc t des c ribed in this manual, may be adapted or re produc ed in any material or elec tronic form without the prior written c ons ent of the c opyright holder. T his product and its doc umentation are s up plied on an as-is bas is and no warranty as to their s uitability for any partic ular purpose is either made or implied. Future T ec hno logy D evic es I nternational L td will not ac c ept any c laim for damages hows oever aris ing as a res ult of us e or failure of this produc t. Y our s tatutory rights are not affec ted. T his produc t or any variant of it is not intended for us e in any medic al applianc e , devic e or s ys tem in whic h the failure of the produc t might reas onably be expected to res ult in pers onal injury. T his doc ument provides preliminary information that may be s ubjec t to c h ange without notic e. N o freedom to us e patents or other intellectual p roperty rights is implied by the public ation of this doc ument. Future T echnology D evices I nternational L td, U nit 1 , 2 Seaward P lace, C enturion Business P ark, G lasgow G 4 1 1 HH U nited Kingdom. Sc otland Registered Company N umber: SC 1 3 6 6 4 0 Copyright © Future Technology Devices International Limited 1 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 1 Typical Applications  USB Data Acquisition  General Purpose Microcontroller  Sensor and Monitoring control  Mass storage data transfers across all segments, including medical, industrial datalogger, power-metering, and test instrumentation  USB to RS232/RS422/RS485 Converters  Incorporate USB interface to enable PC transfers for development systems  Interfacing MCU/PLD/FPGA based designs to add USB connectivity  Industrial equipment control systems  POS systems  USB Bar Code Readers  Internet of things application  Home automation control systems 1.1 Part Numbers Part Number Package FT51AQ-R 48 Pin QFN, body 7x7x0.75 mm, pitch 0.5mm, Taped and Reel, 3000 per reel FT51AQ-T 48 Pin QFN, body 7x7x0.75 mm, pitch 0.5mm, Tray packing, 490 per tray FT51AL-R 44 Pin LQFP, body 10x10x1.4 mm, pitch 0.8mm, Taped and Reel, 1000 per reel FT51AL-T 44 Pin LQFP, body 10x10x1.4 mm, pitch 0.8mm, Tray packing, 160 per tray FT51BQ-R 32 Pin QFN, body 6x6x0.75 mm, pitch 0.5mm, Taped and Reel, 3000 per reel FT51BQ-T 32 Pin QFN, body 6x6x0.75 mm, pitch 0.5mm, Tray packing, 490 per tray FT51CS-R 28 Pin SSOP, body 10.2x5.3x1.75 mm, pitch 0.65mm, Taped and Reel, 2000 per reel FT51CS-U 28 Pin SSOP, body 10.2x5.3x1.75 mm, pitch 0.65mm, Tube packing, 47 per tube Table 1-1 – Part Numbers 1.2 USB Compliant The FT51A is fully compliant with the USB 2.0 specification and has been given the USB-IF Test-ID (TID) 40001701 (Rev C). Copyright © Future Technology Devices International Limited 2 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 Table of Contents 1 Typical Applications...................................................... 2 1.1 Part Numbers ......................................................................... 2 1.2 USB Compliant ........................................................................ 2 2 Device Pin Out and Signal Description ........................... 5 2.1 Pin Out - 28 pin SSOP ............................................................. 5 2.2 Pin Out - 32 pin WQFN ........................................................... 6 2.3 Pin Out - 44-Pin LQFP............................................................. 7 2.4 Pin Out - 48-Pin WQFN ............................................................ 8 2.5 Pin Configuration Description .................................................. 9 3 Functional Description ................................................ 11 3.1 Key Features..........................................................................11 3.1.1 Functional Integration ............................................................................. 11 3.1.2 8051 Core ............................................................................................. 11 3.2 Functional Block Descriptions .................................................12 3.2.1 8051 Ports 0 - 3 ..................................................................................... 12 3.2.2 Timers and Watchdog.............................................................................. 12 3.2.3 PLL Control............................................................................................ 13 3.2.4 16KB Multi-Time Programmable (MTP) memory ........................................... 13 3.2.5 8KB Data RAM ....................................................................................... 13 3.2.6 16KB Shadow RAM ................................................................................. 13 3.2.7 Special Function Register ......................................................................... 13 3.2.8 IO Registers .......................................................................................... 13 3.2.9 LDO Regulators ...................................................................................... 13 3.2.10 BCD Detect ........................................................................................... 13 3.2.11 USB XCVR ............................................................................................. 14 3.2.12 IO Multiplexer ........................................................................................ 14 3.2.13 I2 C Master............................................................................................. 14 3.2.14 I2 C Slave .............................................................................................. 15 3.2.15 SPI Slave .............................................................................................. 15 3.2.16 SPI Master ............................................................................................ 15 3.2.17 Debugger .............................................................................................. 15 3.2.18 245 FIF O .............................................................................................. 16 3.2.19 PWM .................................................................................................... 16 3.2.20 Digital IO pins ........................................................................................ 16 3.2.21 Analogue IO pins .................................................................................... 16 Copyright © Future Technology Devices International Limited 3 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 3.2.22 4 C learance N o.: FT DI#420 ADC ..................................................................................................... 16 Device Characteristics and Ratings.............................. 18 4.1 Absolute Maximum Ratings ....................................................18 4.2 DC Characteristics..................................................................19 4.3 MTP Memory Reliability Characteristics...................................23 4.4 Internal Clock Characteristics.................................................23 4.5 Digital IO AC Characteristics ..................................................24 4.6 Analogue IO Characteristics ...................................................25 5 USB Power Configurations .......................................... 26 5.1 6 USB Bus Powered Configuration .............................................26 Connection Examples.................................................. 27 6.1 USB Upstream and downstream port connections (48pin package) .......................................................................................27 6.2 USB Upstream and downstream port connections (44pin package) .......................................................................................28 6.3 USB Upstream port connections (32pin package) ....................28 6.4 USB Upstream port connections (28pin package) ....................29 7 Package Parameters ................................................... 30 7.1 48-Pin WQFN Package Outline ................................................30 7.2 44-Pin LQFP Package Outline .................................................31 7.3 32-Pin WQFN Package Outline ................................................32 7.4 28-Pin SSOP Package Outline .................................................33 7.5 Solder Reflow Profile .............................................................34 8 Contact Information ................................................... 35 Appendix A – References ................................................. 36 Document References ....................................................................36 Acronyms and Abbreviations ..........................................................36 Appendix B - List of Figures and Tables ............................ 37 List of Figures................................................................................37 List of Tables .................................................................................37 Appendix C – List of IO registers ...................................... 39 Appendix D – Revision History ......................................... 43 Copyright © Future Technology Devices International Limited 4 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 2 Device Pin Out and Signal Description FT51A is available in 4 packages: 28 pin SSOP, 32 pin WQFN, 44 pin LQFP and 48 pin WQFN . DEBUGGER 15 GND AIO10 AIO11 AIO14 AIO15 UP_DP UP_DM AIO7 AIO6 AIO5 AIO4 VCC5V 28 VOUT3V3 2.1 Pin Out - 28 pin SSOP DIO15 DIO14 DIO13 DIO12 DIO11 DIO10 DIO9 GND DIO8 RST DIO3 DIO2 DIO1 DIO0 1 14 FTDI XXXXXXXXXXXX FT51CS YYWW-X Figure 2-1 - 28 Pin SSOP Package Copyright © Future Technology Devices International Limited 5 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 DIO8 5 DIO9 6 DIO10 DIO11 DIO3 DIO2 DIO1 DIO0 VOUT3V3 VCC5V AIO4 25 4 26 RST 27 3 28 DIO7 29 2 30 DIO6 31 1 32 DIO5 DIO4 2.2 Pin Out - 32 pin WQFN 24 AIO5 23 AIO6 22 AIO7 21 UP_DM 20 UP_DP 19 AIO15 7 18 AIO14 8 17 AIO11 FTDI 9 10 11 12 13 14 15 16 DIO12 DIO13 DIO14 DIO15 DEBUGGER GND GND AIO10 XXXXXXXXXX FT51BQ YYWW-X Figure 2-2 - 32 Pin WQFN Package Copyright © Future Technology Devices International Limited 6 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 DIO3 DIO2 DIO1 DIO0 VOUT3V3 VCC5V AIO0 AIO1 AIO2 AIO3 20 21 22 AIO12 16 19 15 17 14 18 12 13 AIO11 11 AIO10 DIO13 AIO9 10 AIO8 DIO12 GND 9 GND DIO11 GND 8 DEBUGGER DIO10 XXXXXXXXXX FT51AL YYWW-X DIO15 7 FTDI DIO14 DIO9 34 6 35 VCCIO 36 5 37 DIO8 38 4 39 RST 40 3 41 DIO7 42 2 43 1 DIO6 44 DIO5 DIO4 2.3 Pin Out - 44-Pin LQFP 33 AIO4 32 AIO5 31 AIO6 30 AIO7 29 UP_DM 28 UP_DP 27 DW_DM 26 DW_DP 25 AIO15 24 AIO14 23 AIO13 Figure 2-3 - 44 Pin LQFP Package Copyright © Future Technology Devices International Limited 7 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 AIO1 AIO2 AIO3 VOUT3V3 AIO0 VREF VCC5V DIO0 GND DIO1 37 DIO2 38 40 39 41 43 42 44 47 46 48 45 DIO3 2.4 Pin Out - 48-Pin WQFN DIO4 1 36 DIO5 2 35 AIO5 34 AIO6 33 AIO7 32 UP_DM 31 UP_DP FTDI DIO6 3 DIO7 4 XXXXXXXXXX FT51AQ YYWW-X RST 5 DIO8 6 VCCIO 7 GND 8 AIO4 30 DW_DM 29 DW_DP AIO9 AIO10 AIO11 AIO12 DIO14 24 DIO13 23 19 22 18 20 17 21 15 14 16 13 AIO8 25 AIO13 GND 26 AIO14 DIO12 12 GND DIO11 11 GND AIO15 DEBUGGER GND 27 DIO9 9 DIO15 28 DIO10 10 Figure 2-4 - 48 Pin WQFN Package Copyright © Future Technology Devices International Limited 8 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 2.5 Pin Configuration Description Pin Nos. 48 pin 44 pin 32 pin 28 pin 42 38 26 27 7 6 - - Name Type Description ** POWER Input 5 V (or 3.3 V) supply to IC VCC5V VCCIO ** 43 39 27 28 VOUT3V 3 8, 17, 18, 19, 28, 41, 49* 15,16, 17 14,15, 33* 7, 16 GND POWER Input 1.8V – 3.3V supply for the IO pins. This option is ONLY available on the 44 & 48 pin packages. A fixed 3.3V supply from the internal regulator is supplied to the IO pins for the 28 and 32 pin packages POWER Output 3.3V regulator output. May be used to power VCCIO pin. Note that a 100nF capacitor should be connected to VOUT3V3 for proper operation. This output can also be used to power external circuitry up to a maximum current rating of 50mA (typ). POWER Input Ground Table 2-1 – Power and Ground * Pin 49 of WQFN48 or pin 33 of WQFN32 is the exposed centre pad under the packaged IC. Connect to GND. ** If VCC5V is supplied by 3.3V then VOUT3V3 must also be driven by the same 3.3V source. Copyright © Future Technology Devices International Limited 9 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 Pin Nos. Name Type Description INPUT/ Downstream USB Data Signal Minus. 48 pin 44 pin 32 pin 28 pin 30 27 - - DW_DM 29 26 - - DW_DP 32 29 21 22 UP_DM 31 28 20 21 UP_DP 5 4 4 5 RST INPUT Device Reset. Active HIGH 44 - - - VREF INPUT Reference voltage. Connect to VOUT3V3. 16 14 13 15 DEBUGG ER INPUT/ 1,2,3, 4, P1.0_ P1.7 6,8,9, 10,11 P3.0_ P3.7 (DIO0_D IO15) 1,2,3,4,6, 9,10,11,12 13,14,15 45,46,47,48 20,21,22,23 24,25,26,27 33,34,35,36 37,38,39,40 1,2,3,5,7,8 9,10,11 12,13, 40,41,42 43,44 18,19,20,21 22,23,24,25 30,31,32,33 34,35,36,37 1,2,3 5,6,7 8,9,10 11,12, 28,29,30 31,32 16,17,181 9,22,23 24,25 12,13 ,14 17,18 ,19 20,23 ,24 25,26 P0.0_ P0.7 P2.0_ P2.7 (AIO0_A IO15) OUTPUT INPUT/ OUTPUT INPUT/ OUTPUT INPUT/ OUTPUT OUTPUT INPUT/ OUTPUT INPUT/ OUTPUT Downstream USB Data Signal Plus. Upstream USB Data Signal Minus. Upstream USB Data Signal Plus. Chip Debug Port General Purpose digital IO pins. Weak internal pull up enabled on exit from POR or hardware reset. ADC analogue input pins. Can also be used as digital IO pins. AIO0 – AIO7 have no pull ups when using 44 or 48 pin packages. Table 2-2 – Common Function pins Copyright © Future Technology Devices International Limited 10 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 3 Functional Description Figure 3-1 – FT51A Block Diagram The FT51A acts as a USB hub supporting two downstream ports; the internal 8051 core and other peripherals (SPI, UART, etc.) and an external downstream port (typical devices can be a mouse, keyboard, mass storage device, etc.). The hub can optionally be disabled (under register control) resulting in the 8051 core appearing at the upstream port. 3.1 3.1.1 Key Features Functional Integration Fully integrated MTP memory with built in shadow RAM for fast memory access , internally generated clock, Power-On-Reset (POR) and LDO regulators. 3.1.2 8051 Core The FT51A is based around the industry standard 8051 microcontroller capable of running at a maximum frequency of 48MHz. The core is an ultra-high performance, speed optimized single -chip 8-bit embedded controller dedicated for operation with fast on-chip memories. Copyright © Future Technology Devices International Limited 11 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 3.1.2.1 C learance N o.: FT DI#420 On-chip Debugger The 8051 works with a high‐performance “Hardware Assisted Debugger” which manages the communication between the core and the software. 3.1.2.2 UART / FTDI UART There are two UARTs in the system – one designed by FTDI and the second incorporated within the 8051 core. The 8051 UART has a maximum baud rate of up to 60kbps. The FTDI UART gives speeds up to 3Mbps. When the data and control bus are configured in UART mode, the interface implements a standard asynchronous serial UART port with full modem control. The UART can support baud rates from 183 baud to 3 Mbaud. The maximum UART speed is limited by the CPU clock. The following maximum UART speed applies: 3.2 CPU Frequency Maximum UART Speed 48 MHz 3 Mbaud 24 MHz 3 Mbaud 12 MHz 1.5 Mbaud Functional Block Descriptions The following paragraphs detail each function within the FT51A. Please refer to the block diagram shown in Figure 3-1 – FT51A Block Diagram. 3.2.1 8051 Ports 0 - 3 The 8051 core has four 8-bit bidirectional ports: P0, P1, P2 and P3. These ports can be fully or partially mapped to external pins on the AIO and DIO bus. Firmware can change the pin mapping through IOMUX programming. Table 3-1 shows the default pin mapping for all the 4 ports on the LQFP44 and WQFN48 packages. PIN TYPE DESCRIPTION AIO7 - AIO0 Input / output P0.7 – P0.0 AIO15 - AIO8 Input / output P2.7 – P2.0 DIO7 - DIO0 Input / output P1.7 – P1.0 DIO15 - DIO8 Input / output P3.7 – P3.0 Table 3-1 – 8051 Ports 3.2.2 Timers and Watchdog Apart from standard 8051 timers the FT51A has four general purpose 16-bit timers A, B, C and D. A 32bit watchdog timer is also provided. Copyright © Future Technology Devices International Limited 12 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 3.2.3 C learance N o.: FT DI#420 PLL Control The block provides an internally generated 48MHz clock to the system without the need of an external reference clock. This block is trimmed at factory test to 48MHz. During USB transactions the PLL will provide an accurate clock, locked to the incoming USB data rate. 3.2.4 16KB Multi-Time Programmable (MTP) memory 16K bytes of MTP memory are available for firmware programming. Code stored with the MTP memory is copied to the Shadow RAM on power up or an external reset. See section 3.2.6. 3.2.5 8KB Data RAM 8K bytes of data RAM are provided. 3.2.6 16KB Shadow RAM To facilitate fast program memory access, limit any bottlenecks and to allow fast programming times in a debug environment, a shadow RAM exists that the CPU will run from. The Shadow RAM has the following features:   The contents of the MTP are copied to the shadow RAM after a system reset – i.e. a POR reset or a pin reset. A single command (register write access) initiates a hard copy of the program memo ry – i.e. the contents of the shadow RAM are copied to the MTP. 3.2.7 Special Function Register The 8051 core has a special function register area (SFR) and is limited to 128 locations. This area facilitates access to IO registers and the USB Full-Speed Device Controller command/data through indirect addressing method. 3.2.8 IO Registers The FT51A contains approximately 300 IO registers. See Appendix C for a full list of the IO registers. 3.2.9 LDO Regulators The +3.3V LDO regulator generates the +3.3V re ference voltage for driving the USB transceiver cell output buffers. It requires an external decoupling capacitor to be attached to the regulator output pin. The main function of the LDO is to power the USB Transceiver and the Reset Generator Cells rather than to power external logic. However, it can be used to supply external circuitry requiring a +3.3V nominal supply with a maximum current of 50mA. The +1.8V LDO regulator generates the +1.8V supply voltage for internal digital circuits. 3.2.10 BCD Detect Special circuitry inside the FT51A detects when the USB upstream port is connected to a dedicated charging port. When it detects that it is connected to a dedicated charging port, the FT51A can use a DIO or AIO pin to notify a microcontroller or logic on the application board which in turn controls the battery charging circuits. Copyright © Future Technology Devices International Limited 13 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 3.2.11 C learance N o.: FT DI#420 USB XCVR The USB Transceiver Cell provides the USB 2.0 full-speed physical interface to the USB cable. The output drivers provide +3.3V level slew rate control signalling, whilst a differential input receiver and two single ended input receivers provide USB data in, Single -Ended-0 (SE0) and USB reset detection conditions respectfully. This function also incorporates a 1.5kΩ pull up resistor on the USBUPDP pin. 3.2.12 IO Multiplexer With the addition of the IO multiplexer any function can be configured to any DIO pin, excluding the analogue ADC function which is constrained to the AIO pins. All other digital functionality is recommended to map to DIO pins. The IO multiplexer allows the designer to select which peripherals are connected to which IO pins. In order to assign a signal to a particular pin, two register writes are required, one to select the signal and the other to select the IO pin. The FT51A Programmer’s Guide details the pins and signals which can be connected. The selectable peripheral interfaces are only limited by the number of IO pins available. The number of IOs available is dependent on the package type. Table 3-2 lists the peripherals which can be multiplexed to IO and the typical number of pins required for each one. The designer can choose any mix of peripheral configurations as long as they are within the specific package IO pin count. Peripherals Number of pins required (typical) UART (FTDI) 4 UART (8051) 2 ADC 1-16 8051 Port 0-3 32 SPI Master 4 SPI Slave 4 245 FIFO 12 I2C Master 2 I2C Slave 2 PWM 1-8 Table 3-2 – Peripheral Pin Requirements 3.2.13 I2C Master The FT51A provides an interface between the core and an I2C bus. It can be programmed to operate with arbitration and clock synchronization allowing it to operate in multi‐master systems. I2C Master supports transmission speeds up to 3.4 Mb/s including Normal, Fast and High Speed modes . Copyright © Future Technology Devices International Limited 14 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 3.2.14 C learance N o.: FT DI#420 I2C Slave The FT51A provides an interface between the core and an I2C bus. It can work as a slave receiver or transmitter depending on the working mode determined by the core. The core incorporates all features required by the I2C specification. The Slave supports all the transmission modes: Standard, Fa st, Fast‐ plus and High Speed. Clock stretching is supported. 3.2.15 SPI Slave The Serial Peripheral Interface Bus is an industry standard communications interface. Devices communicate in Master / Slave mode, with the Master initiating the data transfer. The SPI slave module has four signals – clock, slave select, MOSI (master out – slave in) and MISO (master in – slave out). 3.2.16 SPI Master CLK SS# SPI Master MOSI External - SPI Slave MISO Figure 3-2 – SPI Master The SPI Master interface is used to interface to applications such as SD Cards. The main purpose of the SPI Master block is to transfer data between an external SPI interface and the FT51A. It does this under the control of the CPU and DMA engine via the o n-chip IO bus. The SPI master module has seven signals – clock, slave select 0..3, MOSI (master out – slave in) and MISO (master in – slave out). The SPI Master protocol by default does not support any form of handshaking and the only available mode is unmanaged. The SPI Master clock can operate up to half of the CPU system clock:  CPU running at 48 Mhz would set the SPI maximum clock to 24 Mhz  CPU running at 24 Mhz would set the SPI maximum clock to 12 Mhz  CPU running at 12 Mhz would set the SPI maximum clock to 6 Mhz 3.2.17 Debugger The purpose of the debugger interface is to provide the Integrated Development Environment (IDE) with the following capabilities:  MTP Program.  Application debug - application code can have breakpoints, be single stepped and can be halted.  Detailed internal debug - memory read/write access. The single wire interface has the following features:  Half Duplex Operation  1Mbps speed  1 start bit Copyright © Future Technology Devices International Limited 15 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877  1 stop bit  8 data bits  Pull up 3.2.18 C learance N o.: FT DI#420 245 FIFO The 245 FIFO interface operating in asynchronous mode has an eight bit data bus, individual read and write strobes with two hardware flow control signals . 3.2.19 PWM The Pulse Width Modulation (PWM) block can generate a signal in which parameters such as period and duty cycle are controlled by the 8051 core. It provides 8 outputs and can generate a core interrupt if set. The main purpose is to generate PWM signals which can be used to control motors, DC/DC converters, AC/DC supplies, etc. 3.2.20 Digital IO pins Up to 16 General Purpose digital IO pins are available depending on the package type. 3.2.21 Analogue IO pins Up to 16 AIO pins are available depending on the package type. The pin can function in either analogue or digital mode, but not both modes at the same time . When in analogue mode all 16 AIO pins can be configured to the ADC mode. AIO_mode_1 AIO_mode_0 Configuration 0 0 Analogue off. If the pin is configured for digital mode, it can be controlled similar to digital IO pins. 0 1 Reserved. 1 0 ADC mode. Analogue input signal for the internal ADC convertor. 1 1 Reserved. Table 3-3 – AIO Modes To configure these modes, specific registers of the AIOs must be configured. On top of these modes sits a global mode which allows multiple control of AIO pins. All 16 pins can be configured depending on the package type. 3.2.22 ADC The ADC block can convert the analogue input signal to a digital value and store the value in the registers. The ADC block can be configured to work in single -ended mode and differential mode. In single-ended mode, an input signal from any of the AIO pins can be the input to the ADC block, with the reference voltage connected to VOUT3V3. In differential mode, two AIO pins are used together to form a pair of differential inputs. The voltage difference between these two pins will be converted to digital values. Copyright © Future Technology Devices International Limited 16 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 The ADC supports single sample and global sample. In single sample mode only one selected AIO input will be sampled at a time. In global sample mode, all the selected AIO inputs will be sampled at the same time. The sample and hold settling time of the ADC is programmable. Once conversion is done, the respective interrupt bit will be set, and an interrupt can be generated if enabled. The accuracy of the ADC convertor is 8-bit. Copyright © Future Technology Devices International Limited 17 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 4 Device Characteristics and Ratings 4.1 Absolute Maximum Ratings The absolute maximum ratings for the FT51A devices are as follows. These are in accordance with the Absolute Maximum Rating System (IEC 60134). Exceeding these may cause permanent damage to the device. Parameter Value Unit Storage Temperature -65°C to 150°C Degrees C Conditions 168 Hours Floor Life (Out of Bag) At Factory Ambient (30°C / 60% Relative Humidity) (IPC /JEDEC JSTD-033A MSL Level 3 C ompliant)* Ambient Operating Temperature (Power Applied) -40°C to 85°C Degrees C VC C 5V Supply Voltage -0.3 to +6.0 V VC C IO IO Voltage -0.3 to +3.8 V DC Input Voltage – USB DP/DM pins -0.5 to +3.8 V Hours -0.3 to DC Input Voltage – digital pins (powered from VC C IO) + (VC C IO V DC Output C urrent – Outputs 22 mA +0.5) Table 4-1 – Absolute Maximum Ratings * If devices are stored out of the packaging beyond this time limit the devices should be baked before use. The devices should be ramped up to a temperature of +125°C and baked for up to 17 hours. Copyright © Future Technology Devices International Limited 18 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 4.2 DC Characteristics DC Characteristics (Ambient Temperature = -40°C to +85°C) Parameter Description Minimum Typical Maximum Units Conditions Vcc1 VCC5V Operating Supply Voltage 4.0 5 5.5 V Normal Operation VCC5V and VOUT3V3 pins must connect to the same 3V3 power source Vcc2 VCC5V Operating Supply Voltage 3.0 3.3 3.6 V Vio1 VCCIO Operating Supply Voltage 3.0 3.3 3.6 V Vio2 VCCIO Operating Supply Voltage 2.3 2.5 2.7 V Vio3 VCCIO Operating Supply Voltage 1.65 1.8 1.95 V Icc1 Operating Supply Current 6.5 20 28.3 mA Normal Operation at 48MHz Icc2 Operating Supply Current μA USB Suspend, internal clock stops VOUT3V3 3.3v regulator output V VCC5V=4.0-5.5V 150 3.0 3.3 3.6 Table 4-2 – Operating Voltage and Current Copyright © Future Technology Devices International Limited 19 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 Parameter Description Minimum Typical C learance N o.: FT DI#420 Maximum Units Conditions VC C IO V IO Drive strength = 4mA VC C IO V IO Drive strength = 8mA VC C IO V IO Drive strength = 12mA VC C IO V IO Drive strength = 16mA 0.4 V 0.4 V IO Drive strength = 8mA 0.4 V IO Drive strength = 12mA 0.4 V IO Drive strength*= 16mA 0.8 V LVTTL V LVTTL Ioh = +/-2mA 2.9 2.9 Voh Output Voltage High 2.9 2.9 Iol = +/-2mA Vol Output Voltage Low IO Drive strength = 4mA Vil Input low Switching Threshold Vih Input High Switching Threshold Vt Switching Threshold 1.49 V Vt- Schmitt trigger negative going threshold voltage 1.15 V Vt+ Schmitt trigger positive going threshold voltage 1.64 V Rpu Input pull-up resistance 40 75 190 KΩ Vin = 0 Rpd Input pull-down resistance 40 75 190 KΩ Vin =VC C IO Iin Input Leakage C urrent -10 10 μA Vin = 0 2.0 Table 4-3 – IO Characteristics VCCIO = +3V3 Copyright © Future Technology Devices International Limited 20 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 Parameter Description Minimum Typical C learance N o.: FT DI#420 Maximum Units Conditions 2.25 VC C IO V 2.25 VC C IO V IO Drive strength* = 8mA 2.25 VC C IO V IO Drive strength = 12mA 2.25 VC C IO V IO Drive strength = 16mA Ioh = +/-2mA Voh Output Voltage High IO Drive strength* = 4mA Iol = +/-2mA Vol Output Voltage Low 0.4 V 0.4 V IO Drive strength = 8mA 0.4 V IO Drive strength = 12mA 0.4 V IO Drive strength = 16mA 0.8 V LVTTL V LVTTL IO Drive strength = 4mA Vil Input low Switching Threshold Vih Input High Switching Threshold Vt Switching Threshold 1.1 V Vt- Schmitt trigger negative going threshold voltage 0.8 V Vt+ Schmitt trigger positive going threshold voltage 1.2 V Rpu Input pull-up resistance 40 75 190 KΩ Vin = 0 Rpd Input pull-down resistance 40 75 190 KΩ Vin =VC C IO Iin Input Leakage C urrent -10 10 μA Vin = 0 1.7 Table 4-4 – IO Characteristics VCCIO = +2V5 Copyright © Future Technology Devices International Limited 21 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 Parameter Description Minimum Typical C learance N o.: FT DI#420 Maximum Units Conditions 1.62 VC C IO V IO Drive strength* = 4mA 1.62 VC C IO V IO Drive strength* = 8mA 1.62 VC C IO V IO Drive strength* = 12mA 1.62 VC C IO V IO Drive strength* = 16mA 0.4 V 0.4 V IO Drive strength* = 8mA 0.4 V IO Drive strength* = 12mA 0.4 V IO Drive strength* = 16mA 0.63 V LVTTL V LVTTL Ioh = +/-2mA Voh Output Voltage High Iol = +/-2mA Vol Output Voltage Low IO Drive strength* = 4mA Vil Input low Switching Threshold Vih Input High Switching Threshold Vt Switching Threshold 0.77 V Vt- Schmitt trigger negative going threshold voltage 0.557 V Vt+ Schmitt trigger positive going threshold voltage 0.893 V Rpu Input pull-up resistance 40 75 190 KΩ Vin = 0 Rpd Input pull-down resistance 40 75 190 KΩ Vin =VC C IO Iin Input Leakage C urrent -10 10 μA Vin = 0 1.17 Table 4-5 – IO Characteristics VCCIO = +1V8 * The IO drive strength and slow slew -rate are configurable in the IO registers. Copyright © Future Technology Devices International Limited 22 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 Parameter Description Minimum Typical Maximum Units Voh Output Voltage High 2.8 Vol Output Voltage Low 0.2 V Vil Input low Switching Threshold 0.8 V Vih Input High Switching Threshold C learance N o.: FT DI#420 Conditions V 2.0 V Table 4-6 – USB DP/DM Pin Characteristics 4.3 MTP Memory Reliability Characteristics The internal 16K Byte MTP memory has the following reliability characteristics: Parameter Value Unit Data Retention 10 Years Write C ycle 2,000 C ycles Read C ycle Unlimited C ycles Table 4-7 – MTP Memory Characteristics 4.4 Internal Clock Characteristics The internal Clock Oscillator has the following characteristics: Value Parameter Unit Minimum Typical Maximum Frequency of Operation (see Note 1) 47.98 48.00 48.02 MHz Duty Cycle 45 50 55 % Table 4-8 – Internal Clock Characteristics Note 1: Equivalent to +/-1667ppm (USB upstream port is active) Copyright © Future Technology Devices International Limited 23 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 4.5 Digital IO AC Characteristics Please refer to the DIO section of the FT51A Programmer’s Guide on how to enable / disable the Schmitt trigger, control the slew rate and determine drive strength. Parameter Value Input load load 0.004pF 1.32pF Timings tplh tphl tplh tphl 0 1.25 0.98 2.48 2.13 1 1.27 1.08 2.51 2.24 (ns) Schmitt Trigger Output Timings (ns) Slew Rate 6pF 120pF = Normal tplh tphl tplh tphl 00 3.33 2.37 13.34 11.13 01 3.13 2.21 8.22 6.78 10 3.02 2.15 6.46 5.32 11 2.95 2.10 5.57 4.59 Drive Strength Output Timings (ns) Slew Rate 6pF 120pF = Slow tplh tphl tplh tphl 00 3.33 2.37 13.34 1.13 01 3.33 2.37 9.24 7.81 2.4 7.80 6.61 2.39 7.05 5.97 Drive Strength 10 11 3.33 3.32 Table 4-9 – Digital IO AC Characteristics Copyright © Future Technology Devices International Limited 24 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 4.6 Analogue IO Characteristics Parameter INL DNL Description Min Max +/- 2 Non-Linearity Differential Non-Linearity +/- 1 Units Conditions LSB LSB Table 4-10 – ADC Characteristics Copyright © Future Technology Devices International Limited 25 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 5 USB Power Configurations The following sections illustrate a possible USB power configuration for the FT51A. The illustrations have omitted pin numbers for ease of understanding since the pins differ between the various package options. 5.1 USB Bus Powered Configuration VCC Ferrite Bead 1 VCC5V 2 27R 3 27R USBDM USBDP 4 47pF 47pF FT51A 5 SHIELD 10nF GND VCC3V3 GND VCC 100nF + 4.7uF 100nF GND GND Figure 5-1 Bus Powered Configuration Figure 5-1 illustrates the FT51A in a typical USB bus powered design configuration. A USB bus powered device gets its power from the USB bus. Basic rules for USB bus powered devices are as follows – i) ii) iii) iv) On plug-in to USB, the device should draw no more current than 50mA. In USB Suspend mode the device should draw no more than 500uA. A device that consumes more than 100mA cannot be plugged into a USB bus powered hub. No device can draw more than 500mA from the USB bus. The power descriptors in the internal MTP memory of the FT51A should be programmed to match the current drawn by the device. A ferrite bead is connected in series with the USB power supply to reduce EMI noise from the FT51A and associated circuitry being radiated down the USB cable to the USB host. The value of the Ferrite Bead depends on the total current drawn by the application. A suitable range of Ferrite Beads is available from Laird Technologies (http://www.lairdtech.com) for example Laird Technologies Part # MI0805K601R-10. Copyright © Future Technology Devices International Limited 26 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 6 Connection Examples The following sections illustrate possible connections of the FT51A. 6.1 USB Upstream package) and downstream port connections (48pin Figure 6-1 Application Example showing USB upstream and downstream connection(48pin package) Shown above are the necessary connections to connect the upstream & downstream USB ports. The debugger module is also included for added information should it be required. Copyright © Future Technology Devices International Limited 27 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 6.2 USB Upstream package) and downstream port C learance N o.: FT DI#420 connections (44pin Figure 6-2 Application Example showing USB upstream and downstream connection (44pin package) 6.3 USB Upstream port connections (32pin package) Figure 6-3 Application Example showing USB upstream connection (32pin package) Copyright © Future Technology Devices International Limited 28 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 6.4 USB Upstream port connections (28pin package) Figure 6-4 Application Example showing USB upstream connection (28pin package) Copyright © Future Technology Devices International Limited 29 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 7 Package Parameters The FT51A is available in 4 package type s. The package is lead (Pb) free, RoHS compliant, and uses a ‘green’ compound. The package is fully compliant with European Union directive 2002/95/EC. 7.1 48-Pin WQFN Package Outline 48 1 FTDI XXXXXXXXXX FT51AQ YYWW-C Line 1 – FTDI Logo Line 2 – Wafer Lot Number Line 3 – FTDI Part Number Line 4 – Date Code, Revision Figure 7-1 48 pin WQFN Package Marking Figure 7-2 48 pin WQFN Package Dimensions Note: The centre pad on the base of the FT51A is internally connected to ground. Dimensions are in mm. Copyright © Future Technology Devices International Limited 30 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 7.2 44-Pin LQFP Package Outline 44 1 FTDI XXXXXXXXXX FT51AL YYWW-C Line 1 – FTDI Logo Line 2 – Wafer Lot Number Line 3 – FTDI Part Number Line 4 – Date Code, Revision Figure 7-3 44 pin LQFP Package Marking Figure 7-4 44 pin LQFP Package Dimensions Copyright © Future Technology Devices International Limited 31 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 7.3 32-Pin WQFN Package Outline 32 1 FTDI XXXXXXXXXX FT51BQ YYWW-C Line 1 – FTDI Logo Line 2 – Wafer Lot Number Line 3 – FTDI Part Number Line 4 – Date Code, Revision Figure 7-5 32 pin WQFN Package Marking Note: The centre pad on the base of the FT51A is internally connected to ground. Dimensions are in mm. Figure 7-6 32 pin WQFN Package Dimensions Copyright © Future Technology Devices International Limited 32 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 7.4 28-Pin SSOP Package Outline FTDI XXXXXXXXXX FT51CS YYWW-C Line 1 – FTDI Logo Line 2 – Wafer Lot Number Line 3 – FTDI Part Number Line 4 – Date Code, Revision Figure 7-7 28 pin SSOP Package Marking Figure 7-8 28 pin SSOP Package Dimensions Copyright © Future Technology Devices International Limited 33 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 7.5 Solder Reflow Profile The FT51A is supplied in a Pb free package. The recommended solder reflow profile is shown in Figure 7-9 FT51A Solder Reflow Profile. Temperature, T (Degrees C) tp Tp Critical Zone: when T is in the range TL to Tp Ramp Up TL tL TS Max Ramp Down TS Min tS Preheat 25 T = 25º C to TP Time, t (seconds) Figure 7-9 FT51A Solder Reflow Profile The recommended values for the solder reflow profile are detailed in Error! Reference source not found.. Values are shown for both a completely Pb free solder process (i.e. the FT51A is used with Pb free solder), and for a non-Pb free solder process (i.e. the FT51A is used with non-Pb free solder). Profile Feature Pb Free Solder Process Non-Pb Free Solder Process Average Ramp Up Rate (T s to Tp) 3°C / second Max. 3°C / Second Max. Preheat - Temperature Min (T s Min.) 150°C 100°C - Temperature Max (T s Max.) 200°C 150°C - Time (ts Min to ts Max) 60 to 120 seconds 60 to 120 seconds 217°C 183°C 60 to 150 seconds 60 to 150 seconds 260°C 240°C 20 to 40 seconds 20 to 40 seconds Ramp Down Rate 6°C / second Max. 6°C / second Max. Time for T= 25°C to Peak Temperature, T p 8 minutes Max. 6 minutes Max. Time Maintained Above Critical Temperature T L: - Temperature (T L) - Time (tL) Peak Temperature (T p) Time within 5°C of actual Peak Temperature (tp) Table 7-1 – Reflow Profile Parameters Copyright © Future Technology Devices International Limited 34 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 8 Contact Information Head Office – Glasgow, UK Branch Office – Tigard, Oregon, USA Future Technology Devices International Limited Unit 1, 2 Seaward Place, Centurion Business Park Glasgow G41 1HH United Kingdom Tel: +44 (0) 141 429 2777 Fax: +44 (0) 141 429 2758 Future Technology Devices International Limited (USA) 7130 SW Fir Loop Tigard, OR 97223-8160 USA Tel: +1 (503) 547 0988 Fax: +1 (503) 547 0987 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) E-mail (Sales) E-mail (Support) E-mail (General Enquiries) sales1@ftdichip.com support1@ftdichip.com admin1@ftdichip.com us.sales@ftdichip.com us.support@ftdichip.com us.admin@ftdichip.com Branch Office – Taipei, Taiwan Branch Office – Shanghai, China Future Technology Devices International Limited (Taiwan) 2F, No. 516, Sec. 1, NeiHu Road Taipei 114 Taiwan , R.O.C. Tel: +886 (0) 2 8791 3570 Fax: +886 (0) 2 8791 3576 Future Technology Devices International Limited (China) Room 1103, No. 666 West Huaihai Road, Shanghai, 200052 C hina Tel: +86 21 62351596 Fax: +86 21 62351595 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) E-mail (Sales) E-mail (Support) E-mail (General Enquiries) tw.sales1@ftdichip.com tw.support1@ftdichip.com tw.admin1@ftdichip.com cn.sales@ftdichip.com cn.support@ftdichip.com cn.admin@ftdichip.com Web Site http://ftdichip.com Distributor and Sales Representatives Please visit the Sales Network page of the FTDI Web site for the contact details of our distributor(s) and sales representative(s) in your country. Sys tem and equipment manufacturers and des igners are responsible to ens ure that their s ystems, and any Future T echnology D evi c es I nternational L td (FTDI) devices incorporated in their s ystems, meet all applic able s afety, regulatory and s ys tem- level performanc e requirements. A ll application-related information in this doc ument (inc luding application descriptions, s uggested FTD I devices and other materials ) is provided for referenc e only. While FT DI has taken c are to as s ure it is ac c urate, this information is s ubjec t to c us tomer c onfirmation, and FT DI disclaims all liability for s ys tem des igns and for any applic ations as s is tanc e provided by FT D I . U s e o f FT D I devic es in life s upport and/or s afety applic ations is e ntirely at the us er’s ris k, and the us er agrees to defend, indemnify and hold harmles s FTDI from any and all damages , c laims, s uits or expense resulting from s uc h us e. T his document is s ubject to c hange without notic e. N o freedom to us e patents or other intellectual property rights is implied by the public ation of this doc ument. N either the whole nor any part of the information c ontained in, or the produc t des cribed in this document, may be adapted or reproduc ed in any material or elec tronic form without the prior written c ons ent of the c opyright holder. Future T ec hnology D evic es I nternational L td, U nit 1 , 2 Seaward P lac e, C enturion Business P ark, G las gow G 4 1 1 H H , U nited Kingdom. Sc otland Regis tered C ompany N umber: SC 1 3 6 6 4 0 Copyright © Future Technology Devices International Limited 35 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 Appendix A – References Document References TN_100 USB Vendor ID / Product ID Guidelines AN_352 FT51A Installation Guide AN_345 FT51A Keyboard Sample AN_346 FT51A Mouse Sample AN_347 FT51A Test and Measurement Sample AN_348 FT51A FT800 Sensors Sample AN_349 FT51A FT800 Spaced Invaders Sample AN_354 FT51A Standalone Demo Application AN_289 FT51A Programming Guide Acronyms and Abbreviations Terms Description ADC Analog to Digital Converter CPU Central Processing Unit FPGA Field Programmable Gate Array LQFP Low Profile Quad Flat Package MCU Micro Controller Unit PLD Programmable Logic Device QFN Quad Flat No-leads RoHS Restriction of Hazardous Substances Directive SPI UART USB Serial Peripheral Interface Universal Asynchronous Receiver/Transmitter Universal Serial Bus Copyright © Future Technology Devices International Limited 36 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 Appendix B - List of Figures and Tables List of Figures Figure 2-1 - 28 Pin SSOP Package .......................................................................................................... 5 Figure 2-2 - 32 Pin WQFN Package ......................................................................................................... 6 Figure 2-3 - 44 Pin LQFP Package ........................................................................................................... 7 Figure 2-4 - 48 Pin WQFN Package ......................................................................................................... 8 Figure 3-1 – FT51A Block Diagram........................................................................................................ 11 Figure 3-2 – SPI Master........................................................................................................................ 15 Figure 5-1 Bus Powered Configuration .................................................................................................. 26 Figure 6-1 Application Example showing USB upstream and downstream connection(48pin package) .... 27 Figure 6-2 Application Example showing USB upstream and downstream connection (44pin package) ... 28 Figure 6-3 Application Example showing USB upstream connection (32pin package) ............................. 28 Figure 6-4 Application Example showing USB upstream connection (28pin package) ............................. 29 Figure 7-1 48 pin WQFN Package Marking............................................................................................. 30 Figure 7-2 48 pin WQFN Package Dimensions ....................................................................................... 30 Figure 7-3 44 pin LQFP Package Marking .............................................................................................. 31 Figure 7-4 44 pin LQFP Package Dimensions ......................................................................................... 31 Figure 7-5 32 pin WQFN Package Marking............................................................................................. 32 Figure 7-6 32 pin WQFN Package Dimensions ....................................................................................... 32 Figure 7-7 28 pin SSOP Package Marking.............................................................................................. 33 Figure 7-8 28 pin SSOP Package Dimensions ........................................................................................ 33 Figure 7-9 FT51A Solder Reflow Profile ................................................................................................. 34 List of Tables Table 1-1 – Part Numbers....................................................................................................................... 2 Table 2-1 – Power and Ground ............................................................................................................... 9 Table 2-2 – Common Function pins....................................................................................................... 10 Table 3-1 – 8051 Ports ......................................................................................................................... 12 Table 3-2 – Peripheral Pin Requirements............................................................................................... 14 Table 3-3 – AIO Modes ......................................................................................................................... 16 Table 4-1 – Absolute Maximum Ratings ................................................................................................ 18 Table 4-2 – Operating Voltage and Current ........................................................................................... 19 Table 4-3 – IO Characteristics VCCIO = +3V3....................................................................................... 20 Table 4-4 – IO Characteristics VCCIO = +2V5....................................................................................... 21 Table 4-5 – IO Characteristics VCCIO = +1V8....................................................................................... 22 Table 4-6 – USB DP/DM Pin Characteristics........................................................................................... 23 Table 4-7 – MTP Memory Characteristics............................................................................................... 23 Table 4-8 – Internal Clock Characteristics ............................................................................................. 23 Copyright © Future Technology Devices International Limited 37 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 Table 4-9 – Digital IO AC Characteristics .............................................................................................. 24 Table 4-10 – ADC Characteristics.......................................................................................................... 25 Table 7-1 – Reflow Profile Parameters .................................................................................................. 34 Table 0-1 – IO Registers....................................................................................................................... 42 Copyright © Future Technology Devices International Limited 38 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 Appendix C – List of IO registers User should refer to the FT51A Programmer’s Guide for more detail. Register Address (0x0) (0x1) (0x2) (0x3) (0x4) (0x5) (0x6) (0x9) (0xA) to (0x19) (0x1A) to (0x29) (0x2A) (0x2B) (0x2C) (0x2D) (0x2E) (0x34) (0x36) (0x37) (0x38) (0x39) (0x40) (0x41) (0x42) (0x43) (0x44) (0x48) (0x4A) (0x4B) (0x4C) (0x4D) (0x4E) (0x50) (0x51) (0x52) (0x53) (0x54) (0x55) (0x56) (0x57) (0x58) (0x59) (0x5A) (0x5B) (0x60) (0x61) (0x62) (0x63) (0x64) Register Name Description DEVICE_CONTROL_REGISTER SYSTEM_CLOCK_DIVIDER TOP_USB_CONTROL PERIPHERAL_INT0 PERIPHERAL_IEN0 PERIPHERAL_INT1 PERIPHERAL_IEN1 PIN_CONFIG DIGITAL_CONTROL_AIO_0 to DIGITAL_CONTROL_AIO15 DIGITAL_CONTROL_DIO0 to DIGITAL_CONTROL_DIO15 AIO_DIFFERENTIAL_ENABLE MTP_CONTROL MTP_PROG_ADDR_L MTP_PROG_ADDR_U MTP_PROG_DATA PIN_PACKAGE_CONFIG CRC_CONTROL CRC_RESULT_L CRC_RESULT_U SECURITY_LEVEL IOMUX_CONTROL IOMUX_OUTPUT_PIN_SEL IOMUX_OUTPUT_SIG_SEL IOMUX_INPUT_SIG_SEL IOMUX_INPUT_PIN_SEL SPI_SLAVE_CONTROL SPI_SLAVE_TX_DATA SPI_SLAVE_RX_DATA SPI_SLAVE_IEN SPI_SLAVE_INT SPI_SLAVE_SETUP SPI_MASTER_CONTROL SPI_MASTER_DATA_TX SPI_MASTER_DATA_RX SPI_MASTER_IEN SPI_MASTER_INT SPI_MASTER_SETUP SPI_MASTER_CLK_DIV SPI_MASTER_DATA_DELAY SPI_MASTER_SS_SETUP SPI_MASTER_TRANSFER_SIZE_L SPI_MASTER_TRANSFER_SIZE_U SPI_MASTER_TRANSFER_PENDING UART_CONTROL UART_DMA_CTRL UART_RX_DATA UART_TX_DATA UART_TX_IEN Device Control Register System Clock Divider USB Top-level Control Register Peripheral Interrupt Status 0 Peripheral Interrupt Enable 0 Peripheral Interrupt Status 1 Peripheral Interrupt Enable 1 Miscellaneous Pin Configuration AIO Pins 0 to 15 Digital Control DIO Pins 0 to 15 Digital Control AIO Differential Pin Enable MTP Memory Control MTP Program Address Lower Byte MTP Program Address Upper Byte MTP Program Data Device Package Information CRC Control of MTP Memory CRC Result Lower Byte CRC Result Upper Byte Device Security Status Register IOMUX Control Register Select Output Pin Number Register Select Output Signal Register Select Input Signal Register Select Input Pin Number Register SPI_SLAVE Control Register SPI Slave Transmit Data SPI Slave Receive Data SPI Slave Interrupt Enable SPI Slave Interrupt Status SPI Slave Setup SPI_MASTER Control Register SPI Master Transmit Data SPI Master Receive Data SPI Master Interrupt Enable SPI Master Interrupt Status SPI Master Setup SPI Master Clock Divider SPI Master Data Delay SPI Master Slave Select Setup SPI Master Transfer Size Lower Byte SPI Master Transfer Size Upper Byte SPI Master Transfer Pending UART Control Register UART DMA Control UART Receive Data UART Transmit Data UART Tx Interrupt Enable Copyright © Future Technology Devices International Limited 39 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 Register Address (0x65) (0x66) (0x67) (0x68) (0x69) (0x6A) (0x6B) (0x6C) (0x6D) (0x70) (0x71) to (0x74) (0x75) (0x76) (0x77) (0x78) (0x79) (0x7A) (0x7B) (0x7C) (0x7D) (0x80) (0x81) (0x82) C learance N o.: FT DI#420 Register Name Description UART_TX_INT UART_RX_IEN UART_RX_INT UART_LINE_CTRL UART_BAUD_0 UART_BAUD_1 UART_BAUD_2 UART_FLOW_CTRL UART_FLOW_STAT TIMER_CONTROL TIMER_CONTROL_1 to TIMER_CONTROL_4 TIMER_INT TIMER_SELECT TIMER_WDG TIMER_WRITE_LS TIMER_WRITE_MS TIMER_PRESC_LS TIMER_PRESC_MS TIMER_READ_LS TIMER_READ_MS PWM_CONTROL PWM_CTRL PWM_PRESCALER UART Tx Interrupt Status UART Rx Interrupt Enable UART Rx Interrupt Status UART Line Control UART Baud Rate Byte 0 UART Baud Rate Byte 1 UART Baud Rate Byte 2 UART Flow Control UART Flow Control Status TIMER Top Control (0x83) PWM_CNT16_LSB (0x84) PWM_CNT16_MSB (0x85) to (0x94) (0x95) to (0x9C) (0x9D) (0x9E) (0x9F) (0xA0) (0xA1) (0xA2) (0xA3) (0xA4) (0xA5) (0xB0) (0xB1) PWM_CMP16_0_LSB to PWM_CMP16_7_MSB PWM_OUT_TOGGLE_EN_0 to PWM_OUT_TOGGLE_EN_7 PWM_OUT_CLR_EN PWM_CTRL_BL_CMP8 PWM_INIT FIFO_CONTROL FIFO_CTRL_STATUS FIFO_RX_DATA FIFO_TX_DATA FIFO_INTERRUPT_ENA FIFO_INTERRUPT DMA_CONTROL_1 DMA_ENABLE_1 (0xB2) DMA_IRQ_ENA_1 (0xB3) DMA_IRQ_1 (0xB4) DMA_SRC_MEM_ADDR_L_1 (0xB5) DMA_SRC_MEM_ADDR_U_1 (0xB6) DMA_DEST_MEM_ADDR_L_1 (0xB7) DMA_DEST_MEM_ADDR_U_1 Timer Control Register 1 to 4 Timer Interrupt Status Timer Select Register Watchdog Start Value Timer Start Value 7:0 Timer Start Value 15:8 Timer Prescaler Value 7:0 Timer Prescaler Value 15:8 Timer Current Value 7:0 Timer Current Value 15:8 PWM Control Register PWM Control PWM PRESCALER Comparator value PWM COUNTER16 Comparator LSB value PWM COUNTER16 Comparator MSB value PWM Comparator 0 LSB value to PWM Comparator 7 MSB value PWM Out toggle enable register 0 to 7 PWM Out clear enable PWM Control CMP8 value PWM Initialization register FIFO Control Register FIFO Control Status FIFO Receive Data FIFO Transmit Data FIFO Interrupt Enable FIFO Interrupt DMA Control Register IO DMA Enable Register DMA IO Interrupt Enable & Control Register DMA IO Interrupt Register DMA IO Source Mem Addr Register (Lower Bits) DMA IO Source Mem Addr Register (Upper Bits) DMA IO Destination Mem Addr Register (Lower Bits) DMA IO Destination Mem Addr Register (Upper Bits) Copyright © Future Technology Devices International Limited 40 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 Register Address (0xB8) (0xB9) C learance N o.: FT DI#420 Register Name Description DMA_IO_ADDR_L_1 DMA_IO_ADDR_U_1 DMA IO Addr Register (Lower Bits) IO DMA IO Addr Register (Upper Bits) IO DMA Transfer Byte Count Register (Lower Bits) IO DMA Transfer Byte Count Register (Upper Bits) IO DMA Current Byte Count Register (Lower Bits) IO DMA Current Byte Count Register (Upper Bits) IO DMA FIFO DATA IO DMA Almost Full Flag Trigger Value DMA Control Register IO DMA Enable Register DMA IO Interrupt Enable & Control Register DMA IO Interrupt Register DMA IO Source Mem Addr Register (Lower Bits) DMA IO Source Mem Addr Register (Upper Bits) DMA IO Destination Mem Addr Register (Lower Bits) DMA IO Destination Mem Addr Register (Upper Bits) DMA IO Addr Register (Lower Bits) IO DMA IO Addr Register (Upper Bits) IO DMA Transfer Byte Count Register (Lower Bits) IO DMA Transfer Byte Count Register (Upper Bits) IO DMA Current Byte Count Register (Lower Bits) IO DMA Current Byte Count Register (Upper Bits) IO DMA FIFO DATA IO DMA Almost Full Flag Trigger Value DMA Control Register IO DMA Enable Register DMA IO Interrupt Enable & Control Register DMA IO Interrupt Register DMA IO Source Mem Addr Register (Lower Bits) DMA IO Source Mem Addr Register (Upper Bits) DMA IO Destination Mem Addr Register (Lower Bits) DMA IO Destination Mem Addr Register (Upper Bits) DMA IO Addr Register (Lower Bits) IO DMA IO Addr Register (Upper Bits) IO DMA Transfer Byte Count Register (Lower Bits) IO DMA Transfer Byte Count Register (Upper Bits) IO DMA Current Byte Count Register (Lower Bits) (0xBA) DMA_TRANS_CNT_L_1 (0xBB) DMA_TRANS_CNT_U_1 (0xBC) DMA_CURR_CNT_L_1 (0xBD) DMA_CURR_CNT_U_1 (0xBE) (0xBF) (0xC0) (0xC1) DMA_FIFO_DATA_1 DMA_AFULL_TRIGGER_1 DMA_CONTROL_2 DMA_ENABLE_2 (0xC2) DMA_IRQ_ENA_2 (0xC3) DMA_IRQ_2 (0xC4) DMA_SRC_MEM_ADDR_L_2 (0xC5) DMA_SRC_MEM_ADDR_U_2 (0xC6) DMA_DEST_MEM_ADDR_L_2 (0xC7) DMA_DEST_MEM_ADDR_U_2 (0xC8) (0xC9) DMA_IO_ADDR_L_2 DMA_IO_ADDR_U_2 (0xCA) DMA_TRANS_CNT_L_2 (0xCB) DMA_TRANS_CNT_U_2 (0xCC) DMA_CURR_CNT_L_2 (0xCD) DMA_CURR_CNT_U_2 (0xCE) (0xCF) (0xD0) (0xD1) DMA_FIFO_DATA_2 DMA_AFULL_TRIGGER_2 DMA_CONTROL_3 DMA_ENABLE_3 (0xD2) DMA_IRQ_ENA_3 (0xD3) DMA_IRQ_3 (0xD4) DMA_SRC_MEM_ADDR_L_3 (0xD5) DMA_SRC_MEM_ADDR_U_3 (0xD6) DMA_DEST_MEM_ADDR_L_3 (0xD7) DMA_DEST_MEM_ADDR_U_3 (0xD8) (0xD9) DMA_IO_ADDR_L_3 DMA_IO_ADDR_U_3 (0xDA) DMA_TRANS_CNT_L_3 (0xDB) DMA_TRANS_CNT_U_3 (0xDC) DMA_CURR_CNT_L_3 Copyright © Future Technology Devices International Limited 41 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 Register Address Register Name (0xDD) DMA_CURR_CNT_U_3 (0xDE) (0xDF) (0xE0) (0xE1) DMA_FIFO_DATA_3 DMA_AFULL_TRIGGER_3 DMA_CONTROL_4 DMA_ENABLE_4 (0xE2) DMA_IRQ_ENA_4 (0xE3) DMA_IRQ_4 (0xE4) DMA_SRC_MEM_ADDR_L_4 (0xE5) DMA_SRC_MEM_ADDR_U_4 (0xE6) DMA_DEST_MEM_ADDR_L_4 (0xE7) DMA_DEST_MEM_ADDR_U_4 (0xE8) (0xE9) DMA_IO_ADDR_L_4 DMA_IO_ADDR_U_4 (0xEA) DMA_TRANS_CNT_L_4 (0xEB) DMA_TRANS_CNT_U_4 (0xEC) DMA_CURR_CNT_L_4 (0xED) DMA_CURR_CNT_U_4 (0xEE) (0xEF) (0x100) (0x101) (0x102) to (0x105) (0x108) (0x109) (0x10A) DMA_FIFO_DATA_4 DMA_AFULL_TRIGGER_4 AIO_CONTROL AIO_GLOBAL_CTRL AIO _MODE_0 to AIO _MODE_3 AIO_SAMPLE_0 AIO_SAMPLE_1 (0x10B) AIO_GLOBAL_PORT_SELECT_0_7 (0x10C) AIO_GLOBAL_PORT_SELECT_8_15 (0x13E) to (0x15D) (0x16E) (0x16F) (0x170) (0x171) AIO_0_ADC_DATA_L to AIO_15_ADC_DATA_U AIO_INTERRUPT_0_7 AIO_INT_ENABLE_0_7 AIO_INTERRUPT_8_15 AIO_INT_ENABLE_8_15 (0x176) (0x177) (0x17A) C learance N o.: FT DI#420 Description IO DMA Current Byte Count Register (Upper Bits) IO DMA FIFO DATA IO DMA Almost Full Flag Trigger Value DMA Control Register IO DMA Enable Register DMA IO Interrupt Enable & Control Register DMA IO Interrupt Register DMA IO Source Mem Addr Register (Lower Bits) DMA IO Source Mem Addr Register (Upper Bits) DMA IO Destination Mem Addr Register (Lower Bits) DMA IO Destination Mem Addr Register (Upper Bits) DMA IO Addr Register (Lower Bits) IO DMA IO Addr Register (Upper Bits) IO DMA Transfer Byte Count Register (Lower Bits) IO DMA Transfer Byte Count Register (Upper Bits) IO DMA Current Byte Count Register (Lower Bits) IO DMA Current Byte Count Register (Upper Bits) IO DMA FIFO DATA IO DMA Almost Full Flag Trigger Value AIO Control Register AIO Global Control Register Mode Select for AIO pins 0-15. Initiates a SAMPLE of AIO 0 to 7 Initiates a SAMPLE of AIO 8 to 15 Selects the AIOs to be included in a Global function Selects the AIOs to be included in a Global function Sampled ADC data for AIO0 to AIO15 Interrupt status for ports 0-7 Interrupt enable for ports 0-7 Interrupt status for ports 8-15 Interrupt enable for ports 8-15 Sample&Hold Settling time counter, AIO_SH_COUNTER_L lower 8 bits Sample&Hold Settling time, upper 2 AIO_SH_COUNTER_U bits AIO_CLOCK_DIVIDER Clock Divider Table 0-1 – IO Registers Copyright © Future Technology Devices International Limited 42 FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Version 1.5 D oc ument N o.: FT _000877 C learance N o.: FT DI#420 Appendix D – Revision History Document Title : FT51A Advanced MCU with 8051 Compatible Core IC Datasheet Document Reference No. : FT_000877 Clearance No. : FTDI#420 Product Page : http://www.ftdichip.com/Products/ICs/FT51A.html Document Feedback : DS_FT51A Revision Changes Date Version 1.0 Initial Release 2014-03-17 Version 1.1 Second Release 2014-11-05 Version 1.2 Updated Pin out Diagram 2014-12-12 Version 1.3 Updated branding from FT51 to FT51A 2015-03-23 Version 1.4 Removed DAC references 2015-11-18 Version 1.5 Updated Figure 7.8 28 pin SSOP Package Dimensions 2016-04-07 Copyright © Future Technology Devices International Limited 43
FT51AQ-T 价格&库存
很抱歉,暂时无法提供与“FT51AQ-T”相匹配的价格&库存,您可以联系我们找货
