NJM360M-TE1
NJM360M-TE1
    JRC(⽇本无线)
    DMP8_5X5MM
    IC COMPARATOR DIFF HS 8DMP
NJM360M-TE1 数据手册
Designated client product This product will be discontinued its production in the near term. And it is provided for customers currently in use only, with a time limit. It can not be available for your new project. Please select other new or existing products. For more information, please contact our sales office in your region. New Japan Radio Co.,Ltd. www.njr.com NJM360 HIGH SPEED DIFFERENTIAL COMPARATOR ■ GENERAL DESCRIPTION ■ PACKAGE OUTLINE The NJM360 is a very high speed differential input, complementary TTL output voltage comparator. The device has been optimized for greater speed, input impedance and fan-out and lower input offset voltage. Applications involve high speed analog to digital converters and NJM360D NJM360M zero-crossing detectors in disc file systems. ( DIP8 ) ■ FEATURES ● Operating Voltage ( ±4.5V~±6.5V ) ● High Speed Guarantee ( 20ns max. ) ● Both output delay time has been precisely adjusted ● Complementary TTL Output ● High Input Impedance ● Stabilized Speed for Over Driving Change ● Bipolar Technology ● Fan-out is 4 ● Low Input Offset Voltage ● Package Outline DIP8, DMP8, SOP8 JEDEC 150mil ( DMP8 ) NJM360E ( SOP8 ) ■ PIN CONFIGURATION 1 8 2 7 3 6 4 5 NJM360D NJM360M NJM360E PIN FUNCTION 1.NC 2.–INPUT 3.+INPUT 4.V5.GND 6.OUT2 7.OUT1 8.V+ ■ EQUIVALENT CIRCUIT Ver.2011-12-12 -1- NJM360 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Input Voltage SYMBOL V+/VVID VI Power Dissipation PD Maximum Output Current Operating Temperature Range Storage Temperature Range IO Topr Tstg RATINGS ±8 ±5 ± 8 ( note1 ) ( DIP8 ) 500 ( DMP8 ) 300 ( SOP8 ) 300 ± 20 -40~+85 -40~+125 UNIT V V V mW mA ˚C ˚C ( note1 ) For supply voltage less than ±8V,the absolute input voltage is equal to the supply voltage. ■ ELECTRICAL CHARACTERISTICS ( Ta=25˚C ) PARAMETER Operating Supply Voltage Operating Supply Voltage Input Offset Voltage Input Offset Current Input Bias Current Output Resistance Response Time 1 Response Time 2 Response Time 3 Response Time Difference Between Outputs ( tpd of+VIN1 )-( tpd of-VIN2 ) ( tpd of+VIN2 )-( tpd of-VIN1 ) ( tpd of+VIN1 )-( tpd of+VIN2 ) ( tpd of-VIN1 )-( tpd of-VIN2 ) Input Resistance Input Capacitance Average Temperature Coefficient of Input Offset Voltage Average Temperature Coefficient of Input Offset Current Common Mode Input Voltage Range Differential Input Voltage Range Output High Voltage ( High ) Output Low Voltage ( Low ) Positive Supply Current Negative Supply Current SYMBOL V+ VVIO IIO IB RO tR1 tR2 tR3 RIN CIN ΔVIO/ΔT ΔIIO/ΔT VICM VID VOH VOL I+ I- TEST CONDITION RS≤200Ω VOUT=VOM V+/V-=± 5V ( note1 ) V+/V-=± 5V ( note2 ) V+/V-=± 5V ( note3 ) ( note1 ) ( note1 ) ( note1 ) ( note1 ) f=1MHz f=1MHz RS=50Ω V+/V-=± 6.5V V+/V-=± 4.5V,IOUT=-320μA V+/V-=± 4.5V,ISINK=6.4mA V+/V-=± 6.5V V+/V-=± 6.5V MIN. 4.5 -4.5 - TYP. 5 -5 2 0.5 5 100 13 12 14 MAX. 6.5 -6.5 5 3 20 25 20 - UNIT V V mV μA μA Ω ns ns ns ±4 ±5 2.4 - 2 2 2 2 17 3 8 7 ± 4.5 3 0.25 18 -9 0.4 32 -16 ns ns ns ns kΩ pF μV/˚C nA/˚C V V V V mA mA ( note1 ) Response time measured from the 50% point of a 30mVP-P 10MHz sinusoidal input to the 50% point of the output. ( note2 ) Response time measured from the 50% point of a 2VP-P 10MHz sinusoidal input to the 50% point of the output. ( note3 ) Response time measured from the start of a 100mV input step with 5mV overdrive to the time when the output crosses the logic threshold. -2- Ver.2011-12-12 NJM360 ■ TYPICAL CHARACTERISTICS Ver.2011-12-12 -3- NJM360 ■ AC TEST CIRCUIT [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -4- Ver.2011-12-12
NJM360M-TE1 价格&库存
很抱歉,暂时无法提供与“NJM360M-TE1”相匹配的价格&库存,您可以联系我们找货
