Designated client product
This product will be discontinued its production in the near term.
And it is provided for customers currently in use only, with a time limit.
It can not be available for your new project. Please select other new or
existing products.
For more information, please contact our sales office in your region.
New Japan Radio Co.,Ltd.
www.njr.com
NJM319
VOLTAGE COMPARATOR
■ GENERAL DESCRIPTION
The NJM319 is precision high-speed dual comparator
fabricated on a single monolithic chip. It is designed to operate
over a wide range of supply voltages down to single 5V logic and
ground. The uncommitted collector of the output stage makes the
NJM319 compatible with RTL, DTL and TTL as well as capable of
driving lamps and relays at currents up to 25mA.
■ FEATURES
● Operating Voltage
● Single Supply Operation
● Response Time
● Output Current
● Package Outline
● Bipolar Technology
■ PACKAGE OUTLINE
NJM319M
NJM319D
+5V~+18V(Single Supply)
±5V~±18V(Dual Supply)
NJM319V
80ns typ.
25mA @ Sink Current
DIP14, DMP14, SSOP14
■ PIN CONFIGURATION
(TOP VIEW)
NJM319D
NJM319M
NJM319V
PIN FUNCTION
1. NC
2. NC
3. A GND
4. A +INPUT
5. A −INPUT
6. V7. B OUTPUT
8. B GND
9. B +INPUT
10. B −INPUT
11. V+
12. A OUTPUT
13. NC
14. NC
■ EQUIVALENT CIRCUIT ( 1/2 Shown )
Ver.2014/01/10
-1-
NJM319
■ ABSOLUTE MAXIMUM RATINGS
PARAMETER
SYMBOL
Supply Voltage
Input Voltage
Differential Input Voltage
V /V
VIC
VID
Power Dissipation
PD
Output to Negative Supply Voltage
Output to GND
GND to Negative Supply Voltage
GND to Positive Supply Voltage
Operating Temperature Range
Storage Temperature Range
∆VO-N
∆VO-G
∆VG-N
∆VG-P
Topr
Tstg
RATINGS
UNIT
± 18
± 15
( note1 )
±5
( note2 )
( DIP14 ) 500
( DMP14, SSOP14) 300
36
36
25
18
-40 to +85
-40 to +125
V
V
V
mW
V
V
V
V
˚C
˚C
( note1 ) For supply voltage less than ±15V,the absolute maximum input voltage is equal to the supply voltage.
( note2 ) Do not apply voltage more than ±5V at the point between +INPUT and –INPUT.
Power Dissipation vs. Temperature
Power Dissipation PD [mW]
600
DIP14
500
400
300
200
100
SSOP14/DMP14
50
75
100
125
Ambient Temperature Ta [ºC]
150
■ RECOMMENDED OPERATING VOLTAGE (Ta=25˚C)
PARAMETER
SYMBOL
MIN.
TYP.
MAX.
+5
+18
−18
GND= V−
+5
+18
V
This Voltage is with respect to the GND terminal.
+5
+18
V
TEST CONDITION
Dual Supply
Single Supply
-2-
V
V
V+
VG-P
GND=0V
UNIT
V
Ver.2014/01/10
NJM319
■ ELECTRICAL CHARACTERISTICS
( Ta=25˚C,V+/V-=±15V )
PARAMETER
SYMBOL
TEST CONDITION
MIN.
TYP.
RS≦5kΩ
MAX.
UNIT
Input Offset Voltage
VIO
2.0
8.0
mV
Input Offset Current
IIO
80
200
nA
Input Bias Current
IB
250
1000
nA
Voltage Gain
AV
Input Voltage Range
VICM
Response Time
tR
Saturation Voltage
VSAT
78
92
dB
− 13 to 13
V
V =5V, V =0V
1 to 3
V
VIN :100mV Step Input ,
5mV Over Drive
80
ns
VIN+≦-10mV,ISINK=25mA
0.75
1.5
V
0.2
10
µA
4.3
mA
V+=15V,V− =-15V
VIN+≥
Output Leakage Current
ILEAK
Positive Supply Current
I+1
10mV,V =GND=0V,VOUT=35V
I+2
8
12.5
mA
Negative Supply Current
I-
3
5
mA
V+=5V,V-=0V
■ TYPICAL APPLICATION
V+
V+
V
V ++
RL
RL
-INPUT
+INPUT
OUTPUT
-INPUT
+INPUT
OUTPUT
GND
GND
V-
Single Supply
Ver.2014/01/10
V-
Dual Supply
-3-
NJM319
■ TYPICAL CHARACTERISTICS
Input Offset Voltage vs.Temperature
Input Bias Current vs. Temperature
(V+/V-=±15V)
400
Input Offset Voltage VIO(mV)
350
Input Bias Current IB (nA)
(V+/V-=±15V)
4
300
250
200
150
100
50
3
2
1
-2
-3
-4
12
-25
50
75
100
Ambient Temperature Ta (ºC)
125
-50
-25
50
75
100
Operating Current vs. Operating Voltage
Transfer Function
(Ta= 25ºC)
(V+/V-=±15V, RL=1.4kΩ, Ta=25ºC)
40
125
8
Positive
Supply
Voltage
8
6
Positive
Supply
Voltage
4
2
30
6
V++=5.0V
25
5
15
3
10
2
5
1
±5
±10
±15
Operating Voltage V+/V- (V)
±20
vs. Common-Mode Input Voltage
-0.6
-0.2
0.2
0.6
Differential Input VoltageVID (V)
1
V+=5V
5
Output Voltage Low VOL (V)
35
10
Output Voltage High VOH (V)
Operating Current I+/I- (mA)
V++=36V
V+/V-=±15V
5
4
Input Offset Voltage [mV]
4
Ta=-40°C
3
Ta=+25°C
Ta=+85°C
2
1
3
Ta=+85°C
Ta=+25°C
2
Ta=-40°C
1
-2
-3
-4
1
2
3
4
Common-Mode Input Voltage [V]
5
-15
-10
-5
10
15
Ver.2014/01/10
NJM319
Response Time for
Various Input Overdrives
Response Time for
300
4
250
Input
Over Drive
3
2
200
20mV
5.0mV
2.0mV
150
1
100
-1
-50
-3
-100
-4
-50
-150
100 150 200 250 300 350
Time t (ns)
(V+/V-=±15V, RL=500Ω, V++=5.0V, Ta=25ºC)
6
5
400
4
3
2
2.0mV
-1
100
-2
50
-3
(V =5V, RL=500Ω, V++=5.0V, Ta=25ºC)
6
300
250
200
20mV
2
5.0mV
150
1
100
-1
-50
-3
-100
-4
-50
-50
time t (ns)
Response Time for
-150
Time t (ns)
Output Voltage Vo (V)
4
50
Input Voltage VIN (mV)
Input
Over Drive
250
200
-4
350
2.0mV
Input
Over Drive
1
(V /V =±15V, RL=500Ω, V =5.0V, Ta=25ºC)
5
300
5.0mV
6
350
20mV
Response Time for
450
5
350
(V =5V, RL=500Ω, V =5.0V, Ta=25ºC)
6
5
450
400
4
350
20mV
2.0mV
3
2
300
250
5.0mV
1
200
-1
100
-2
50
-3
-50
-50
time t (ns)
Input Voltage VIN(mV)
■ TYPICAL APPLICATIONS
Relay Driver
Window Detector
TTL Output
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
Ver.2014/01/10
-5-
很抱歉,暂时无法提供与“NJM319V-TE1”相匹配的价格&库存,您可以联系我们找货
