HQN
SERIES
HIGH-Q CERAMIC CAPACITORS
FEATURES:
• Excellent Q and low ESR performance at high frequency
• Voltage range: 25V to 500V
• Capacitance range: 0.1pF to 220pF
• Low power consumption
• Suitable for IC decoupling application
PART NUMBER STRUCTURE
C
0805
HQN
201
Ceramic
Capacitor
Size
0201
0402
0603
0805
Series
Rated Voltage
250 = 25VCDW
500 = 50VCDW
101 = 100VCDW
201 = 200VCDW
251 = 250VCDW
501 = 500VCDW
1R0
C
N
P
Capacitance
(picofarads)
1st two digits are
significant, followed by
number of zeroes.
(R denotes decimal)
e.g:
101 = 100pF
0R5 = 0.5pF
Tolerance
**A = ± 0.05pF
*B = ± 0.10pF
*C = ± 0.25pF
*D = ± 0.50pF
F = ± 1%
G = ± 2%
J = ± 5%
K = ± 10%
* For cap. values
below 10pF only.
** For cap. values of
8.2pF and less.
Termination
N = 100% matte tin (Sn)
over nickel.
Packaging
P = paper
E = Embossed Tape
Example P/N: C0805HQN201-1R0CNP
Standard termination finish is 100% matte Tin (Sn).
DIMENSIONS
Unit: inch (mm)
THICKNESS
SPECIFIC VALUES
E/B (Max)
0.012 +/- 0.0012
(0.30 ± 0.03)
All values
0.006 ± 0.002
(0.15 ± 0.05)
0.020 ± 0.002
(0.50 ± 0.05)
0.020 ± 0.002
(0.50 ± 0.05)
All values
0.01 ± 0.004
(0.25 ± 0.10)
0.064 ± 0.004
(1.60 ± 0.10)
0.032 ± 0.004
(0.80 ± 0.10)
0.032 ± 0.0028
(0.80 ± 0.07)
All other values
0.064 +0.006/-0.004
(1.60 +0.15/-0.10)
0.032 +0.006/-0.004
(0.80 +0.15/-0.10)
0.020 ± 0.004
(0.50 ± 0.10)
0.1pF
0.2pF
0.080 ± 0.006
(2.00 ± 0.15)
0.050 ± 0.004
(1.25 ± 0.10)
0.024 ± 0.004
(0.60 ± 0.10)
0.2pF
0.080 ± 0.008
(2.00 ± 0.20)
0.050 ± 0.008
(1.25 ± 0.20)
0.034 ± 0.004
(0.85 ± 0.10)
All other values
SIZE
L
W
T (Max)
0201
0.024 ± 0.012
(0.60 ± 0.3)
0.012 ± 0.012
(0.30 ± 0.03)
0402
0.040 ± 0.002
(1.00 ± 0.05)
0603
0805
0.016 ± 0.006
(0.40 ± 0.15)
0.02 ± 0.008
(0.50 ± 0.20)
ELECTRICAL SPECIFICATIONS
Typical Series Resonant Frequency
Frequency (GHz)
10
Temperature Coefficient:
0% ± 30PPM /°C, -55°C to +125°C
0201
0402
0603
0805
1
Quality Factor:
Q > 5,000 @ 1MHz (Typical 10,000)
0201 Quality Factor:
Q > 1,000 @ 1MHz (Typical 10,000)
Ageing:
None
Insulation Resistance:
1,000 Ω-F or 100 GΩ (whichever is less at 25°C, VDCW). 50mA max.
(IR at 125°C is 10% of the value at 25°C)
0.1
Dielectric Strength:
2.5 x VDCW Min., 25°C, 50 mA max
1
10
100
1000
Capacitance (pF)
Email: sales@venkel.com
Phone: 512.794.0081 |
Toll Free: 800.950.8365 |
Web: www.venkel.com
Rev: 05/2021-A
1
HQN
SERIES
VOLTAGE AND CAPACITANCE RANGE
Values that are typically available.
All measurements in inches (mm)
SIZE
0201
0R1
0R2
0R3
0R4
0R5
0R6
0R7
0R8
0R9
1R0
1R2
1R5
1R8
2R2
2R3
2R7
3R3
3R9
4R7
5R6
5R7
6R8
8R2
9R1
100
120
150
180
200
220
270
330
390
470
560
680
820
101
121
151
181
221
271
331
391
VDCW (MAX)
25V
0402
50V
25V
50V
10OV
0603
200V
50V
100V
200V
0805
250V
100V
200V
250V
500V
0.1pF
0.2pF
0.3pF
0.4pF
0.5pF
0.6pF
0.7pF
0.8pF
0.9pF
1.0pF
1.2pF
1.5pF
1.8pF
2.2pF
2.3pF
2.7pF
3.3pF
3.9pF
4.7pF
5.6pF
5.7pF
6.8pF
8.2pF
9.1pF
10pF
12pF
15pF
18pF
20pF
22pF
27pF
33pF
39pF
47pF
56pF
68pF
82pF
100pF
120pF
150pF
180pF
220pF
270pF
330pF
390pF
TEST PARAMETERS
Test parameters for High-Q NPO Capacitors: 1MHz ± 100Hz at 1.0 ± 0.2 Vrms, 25°C, ~50% relative humidity.
Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available.
Web: www.venkel.com
Rev: 05/2021-A
2
HQN
SERIES
RF PERFORMANCE CHARACTERISTICS
0201, 0402, 0603 & 0805 Maximum ESR
0.25
2.7pF
ESR (ohms)
0.20
5.6pF
0402
10pF
47pF
100pf
10pF
0.10
0.05
100
300
500
800
1000
Frequency (MHz)
TAPE & REEL SPECIFICATIONS
REEL DIMENSIONS
G
B
All tape and reel
specifications must
A
be adhered to per
EIA-481-1-A.
D
N
C
FULL RADIUS
T
TAPING SPECIFICATIONS
To
T
D
10 Pitches
Cumulative
Tolerance
0.008
( 0.2)
A
E
F
W
B
T
Paper
Embossed
Top Tape
P
B min
C
A (7”)
A (13”)
D min
N mIn
G
T max
8mm
0.3
(.012)
13 ± .05
(.512 ± .02)
178 ± 2.0
(7± .079)
330 ± 2.0
(13 ± .08)
20.2
(.795)
50
(1.97)
10 ± 1.5
(.394 ± 1.059)
14.9
(.587)
12mm
0.3
(.012)
13 ± .05
(.512 ± .02)
178 ± 2.0
(7± .079)
330 ± 2.0
(13 ± .08)
20.2
(.795)
50
(1.97)
10 ± 1.5
(.394 ± 1.059)
14.9
(.587)
7 IN. REEL QUANTITIES*
Po
Pz
Unit: mm (inch)
TAPE
SIZE
0201*
0402*
0603
0805
Tape Size
8mm
8mm
8mm
8mm
Min Qty
per Reel
15,000
5000
3000
2000
Max Qty
per eel
15,000
10,000
4000
5000
* Quantity dependent on thickness
Center
Of Cavity
Direction Of Feed
Unit: mm (inch)
PAPER TAPE
CARRIER
DIMENSIONS
(8mm)
SIZE
(inches)
A
B
W
F
E
P0
0201
1.37 ± 0.05
(.014 ± .002)
0.67 ± 0.05
(.026 ± .002)
8.0 ± 0.2
(.315 ± .008)
3.5 ± 0.1
(.138 ± .004)
1.75 ± 0.1
(.069 ± .004)
4.0 ± 0.1
(.157 ± .004)
0402
0.65 ± 0.1
1.10 ± 0.2
(.026 ± .004) (.043 ± .008)
8.0 ± 0.2
(.315 ± .008)
3.5 ± 0.1
(.138 ± .004)
1.75 ± 0.1
(.069 ± .004)
0603
1.10 ± 0.2
(.043 ± .008)
1.90 ± 0.2
(.075 ± .008)
8.0 ± 0.2
(.315 ± .008)
3.5 ± 0.1
(.138 ± .004)
0805
1.16 ± 0.2
2.4 ± 0.2
(.046 ± .008) (.095 ± .008)
8.0 ± 0.2
(.315 ± .008)
3.5 ± 0.1
(.138 ± .004)
t
P
2.0 ± 0.05
- 0.0
1.5 ± 0.1
(.079 ± .002) (.064 ± .004)
- .000
1.15 MAX
(.045 MAX)
2.0 ± 0.05
(.079 ± .002)
4.0 ± 0.1
(.157 ± .004)
2.0 ± 0.05
- 0.0
1.5 ± 0.1
- .000
1.15 MAX
(.045 MAX)
2.0 ± 0.05
(.079 ± .002)
1.75 ± 0.1
(.069 ± .004)
4.0 ± 0.1
(.157 ± .004)
2.0 ± 0.05
- 0.0
1.5 ± 0.1
- .000
1.15 MAX
(.045 MAX)
4.0 ± 0.1
(.157 ± .004)
1.75 ± 0.1
(.069 ± .004)
4.0 ± 0.1
(.157 ± .004)
2.0 ± 0.05
- 0.0
1.5 ± 0.1
- .000
1.15 MAX
(.045 MAX)
4.0 ± 0.1
(.157 ± .004)
Pz
D
Web: www.venkel.com
Rev: 05/2021-A
3
很抱歉,暂时无法提供与“C0402HQN500-330GNP”相匹配的价格&库存,您可以联系我们找货
