S-93L76AD0I-J8T1G
S-93L76AD0I-J8T1G
    ABLIC(艾普凌科)
    SOP8_150MIL
    IC EEPROM 8KBIT SPI 2MHZ 8SOP
S-93L76AD0I-J8T1G 数据手册
S-93L76A N LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM DE SI G www.ablicinc.com Rev.6.0_03 © ABLIC Inc., 2004-2015 The S-93L76A is a low voltage operating, high speed, low current consumption, 3-wire serial E2PROM with a wide operating voltage range. The S-93L76A has the capacity of 8 K-bit, and the organization is 512-word  16 bit. It is capable of sequential read, at which time addresses are automatically incremented in 16-bit blocks. The communication method is by the Microwire bus. Read Write 1.6 V to 5.5 V 1.8 V to 5.5 V (WRITE, ERASE) 2.7 V to 5.5 V (WRAL, ERAL) 2.0 MHz (Vcc = 4.5 V to 5.5 V) 10.0 ms max. DE D FO R  Operating frequency:  Write time:  Sequential read capable  Write protect function during the low power supply voltage  Endurance: 106 cycles / word*1 (Ta = 85C)  Data retention: 100 years (Ta = 25C) 20 years (Ta = 85C)  Memory capacity: 8 K-bit  Initial delivery state: FFFFh  Operation temperature range: Ta = 40°C to 85C  Lead-free, Sn 100%, halogen-free*2 NE  Operating voltage range: W  Features This product is intended to use in general electronic devices such as consumer electronics, office equipment, and communications devices. Before using the product in medical equipment or automobile equipment including car audio, keyless entry and engine control unit, contact to ABLIC Inc. is indispensable. NO T RE C Caution OM  8-Pin SOP (JEDEC)  8-Pin TSSOP  TMSOP-8 M  Packages EN *1. For each address (Word: 16-bit) *2. Refer to “ Product Name Structure” for details. 1 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 8-Pin SOP (JEDEC) Top view Table 1 1 8 2 7 3 6 4 5 Symbol CS Chip select input Description 2 SK Serial clock input 3 DI Serial data input 4 DO Serial data output 5 GND Ground *1 6 TEST Test 7 NC No connection 8 VCC Power supply *1. Connect to GND or VCC. Even if this pin is not connected, performance is not affected so long as the absolute maximum rating is not exceeded. 1 R S-93L76AD0I-J8T1x 8-Pin TSSOP 8-Pin TSSOP Top view Chip select input 2 SK Serial clock input 3 DI Serial data input 4 DO Serial data output D 8 7 6 5 Table 2 Symbol CS DE 1 2 3 4 Pin No. 1 FO 2. Pin No. 1 NE Figure DE SI G 8-Pin SOP (JEDEC) W 1. N  Pin Configurations Description 5 2 M S-93L76AD0I-T8T1x GND Ground *1 6 TEST Test 7 NC No connection 8 VCC Power supply *1. Connect to GND or VCC. Even if this pin is not connected, performance is not affected so long as the absolute maximum rating is not exceeded. EN Figure NO T RE C OM Remark 1. Refer to the “Package drawings” for the details. 2. x: G or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 2 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A TMSOP-8 TMSOP-8 Top view 1 2 3 4 Table 3 8 7 6 5 DE SI G 3. N Rev.6.0_03 Pin No. 1 Symbol CS Chip select input Description 2 SK Serial clock input 3 DI Serial data input 4 DO Serial data output 5 GND Ground *1 6 TEST Test 7 NC No connection 8 VCC Power supply *1. Connect to GND or VCC. Even if this pin is not connected, performance is not affected so long as the absolute maximum rating is not exceeded. W Figure 3 NO T RE C OM M EN DE D FO Remark Refer to the “Package drawings” for the details. R NE S-93L76AD0I-K8T3U 3 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 Address Memory array decoder Data register W Voltage detector NO T RE C OM M EN DE D FO R Clock generator Figure 4 4 GND NE Mode decode logic SK VCC Output buffer DI CS DE SI G N  Block Diagram DO LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 N  Instruction Set Instruction Start Bit Operation Code Address Data SK input clock 1 2 3 4 5 6 7 8 9 10 READ (Read data) 1 1 0 x A8 A7 A6 A5 A4 A3 1 0 1 x A8 A7 A6 A5 A4 A3 ERASE (Erase data) 1 1 1 x A8 A7 A6 A5 A4 A3 WRAL (Write all) 1 0 0 0 1 x x x x x ERAL (Erase all) 1 0 0 1 0 x x x x x EWEN (Write enable) 1 0 0 1 1 x x x x x EWDS (Write disable) 1 0 0 0 0 x x x x x 11 12 13 A2 A1 *1 A0 D15 to D0 Output 14 to 29 A2 A1 A0 D15 to D0 Input A2 A1 A0 x x x x x x  x x x  x x x   D15 to D0 Input NE W WRITE (Write data) *1. DE SI G Table 4 When the 16-bit data in the specified address has been output, the data in the next address is output. NO T RE C OM M EN DE D FO R Remark x: Don't care 5 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 N  Absolute Maximum Ratings Item DE SI G Table 5 Symbol Ratings Unit W Power supply voltage VCC 0.3 to 7.0 V Input voltage VIN 0.3 to VCC 0.3 V Output voltage VOUT 0.3 to VCC V Operation ambient temperature Topr 40 to 85 C Storage temperature Tstg 65 to 150 C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Table 6 Symbol VCC High level input voltage VIH Low level input voltage VIL READ, EWDS WRITE, ERASE , EWEN WRAL, ERAL VCC = 4.5 V to 5.5 V VCC = 2.7 V to 4.5 V VCC = 1.6 V to 2.7 V VCC = 4.5 V to 5.5 V VCC = 2.7 V to 4.5 V VCC = 1.6 V to 2.7 V D DE EN  Pin Capacitance Item Symbol Item Endurance RE C  Endurance Symbol NW V V V V V V V V V Table 7 (Ta = 25C, f = 1.0 MHz, VCC = 5.0 V) Conditions Min. Max. Unit VIN = 0 V  8 pF COUT VOUT = 0 V  10 pF OM Output capacitance Unit CIN M Input capacitance Ta =40C to 85C Min. Max. 1.6 5.5 1.8 5.5 2.7 5.5 2.0 VCC 0.8  VCC VCC 0.8  VCC VCC 0.0 0.8 0.0 0.2  VCC 0.0 0.15  VCC FO Power supply voltage Conditions R Item NE  Recommended Operating Conditions Table 8 Operation Ambient Temperature Min. Max. Unit 106  cycles / word*1 Min. Max. Unit Ta =25C 100  year Ta =40C to 85C 20  year Ta =40C to 85C *1. For each address (Word: 16-bit) NO T  Data Retention Item Data retention 6 Table 9 Symbol  Operation Ambient Temperature LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 N  DC Electrical Characteristics Item Current consumption (READ) Symbol ICC1 Conditions DE SI G Table 10 Ta =40C to 85C VCC = 4.5 V to 5.5 V VCC = 2.5 V to 4.5 V VCC = 1.6 V to 2.5 V Unit Min. Max. Min. Max. Min. Max.  DO no load  0.8 Table 11 Current consumption (WRITE) ICC2 Ta =40C to 85C VCC = 4.5 V to 5.5 V VCC = 1.8 V to 4.5 V Min. Max. Min. Max. Conditions  DO no load 2.0 Data hold voltage FO ILO VOUT = GND to VCC VOH VDH Ta =40C to 85C VCC = VCC = 2.5 V to 4.5 V 1.6 V to 2.5 V Min. Max. Min. Max. Unit 2.0  2.0  2.0 A  1.0  1.0  1.0 A  1.0  1.0  1.0 A IOL = 2.1 mA IOL = 100 A IOH = 400 A IOH = 100 A IOH = 10 A   2.4 VCC0.3 VCC0.2 0.4 0.1       VCC0.3 VCC0.2  0.1        VCC0.2  0.1    V V V V V Only program disable mode 1.5  1.5  1.5  V D  DE VOL mA NO T RE C OM of write enable latch ILI CS = GND, DO = Open, Other inputs to VCC or GND VIN = GND to VCC ISB 1.5 EN High level output voltage VCC = 4.5 V to 5.5 V Min. Max. Conditions Unit M Standby current consumption Input leakage current Output leakage current Low level output voltage Symbol  mA R Table 12 Item 0.4 W Symbol NE Item  0.5 7 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 Measurement Conditions DE SI G Table 13 N  AC Electrical Characteristics 0.1  VCC to 0.9  VCC Input pulse voltage 0.5  VCC Output reference voltage Output load 100 pF Table 14 Symbol VCC = 4.5 V to 5.5 V VCC = 2.5 V to 4.5 V Min. Max. Min. Max. VCC = 1.6 V to 2.5 V Min. Max. Unit tCSS 0.2 — 0.4 — 1.0 — s CS hold time tCSH 0 — 0 — 0 — s CS deselect time tCDS 0.2 — 0.2 — 0.4 — s Data setup time tDS 0.1 — 0.2 — 0.4 — s Data hold time tDH 0.1 — 0.2 — 0.4 — s Output delay time tPD — 0.4 — 0.8 — 2.0 s Clock frequency SK clock time “L” *1 SK clock time “H” *1 fSK tSKL tSKH 0 0.1 0.1 2.0 — — 0 0.25 0.25 1.0 — — 0 1.0 1.0 0.25 — — MHz s s Output disable time tHZ1, tHZ2 0.15 0 0.5 0 1.0 s FO D 0 R CS setup time NE Item W Ta =40C to 85C OM Item M EN DE Output enable time tSV 0 0.15 0 0.5 0 1.0 s *1. The clock cycle of the SK clock (frequency: fSK) is 1 / fSK s. This clock cycle is determined by a combination of several AC characteristics, so be aware that even if the SK clock cycle time is minimized, the clock cycle (1 / fSK) cannot be made equal to tSKL (min.)  tSKH (min.). NO T RE C Write time 8 Symbol tPR Table 15 Ta =40C to 85C VCC = 1.8 V to 5.5 V Min. Typ. Max.  4.0 10.0 Unit ms Rev.6.0_03 tCSS tCDS *2 CS tSKH tSKL tCSH SK tDS DI tPD tPD W High-Z tSV tHZ2 High-Z NE (READ) DO High-Z tHZ1 High-Z R (VERIFY) Indicates high impedance. 1 / fSK is the SK clock cycle. This clock cycle is determined by a combination of several AC characteristics, so be aware that even if the SK clock cycle time is minimized, the clock cycle (1 / fSK) cannot be made equal to tSKL (min.)  tSKH (min.). FO *1. *2. tDH Valid data Valid data *1 DO tDS tDH DE SI G 1 / fSK N LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Timing Chart NO T RE C OM M EN DE D Figure 5 9 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 N  Initial Delivery State DE SI G Initial delivery state of all addresses is “FFFFh”.  Operation 1. NE W All instructions are executed by making CS “H” and then inputting DI at the rising edge of the SK pulse. An instruction is input in the order of its start bit, instruction, address, and data. The start bit is recognized when “H” of DI is input at the rising edge of SK after CS has been made “H”. As long as DI remains “L”, therefore, the start bit is not recognized even if the SK pulse is input after CS has been made “H”. The SK clock input while DI is “L” before the start bit is input is called a dummy clock. By inserting as many dummy clocks as required before the start bit, the number of clocks the internal serial interface of the CPU can send out and the number of clocks necessary for operation of the serial memory IC can be adjusted. Inputting the instruction is complete when CS is made “L”. CS must be made “L” once during the period of tCDS in between instructions. “L” of CS indicates a standby status. In this status, input of SK and DI is invalid, and no instruction is accepted. Reading (READ) FO R The READ instruction is used to read the data at a specified address. When this instruction is executed, the address A0 is input at the rising edge of SK and the DO pin, which has been in a high-impedance (High-Z) state, outputs “L”. Subsequently, 16 bits of data are sequentially output at the rising edge of SK. If SK is output after the 16-bit data of the specified address has been output, the address is automatically incremented, and the 16-bit data of the next address is then output. By inputting SK sequentially with CS kept at “H”, the data of the entire memory space can be read. When the address is incremented from the last address (A8 … A1 A0 = 1 … 1 1), it returns to the first address (A8 … A1 A0 = 0 … 0 0). DI 1 1 2 1 3 0 4 5 6 7 8 9 10 11 12 13 14 15 16 High-Z DO M OM RE C T 42 43 44 45 46 47 48 High-Z 0 D15 D14 D13 NO 10 26 27 28 29 30 31 32 X A8 A7 A6 A5 A4 A3 A2 A1 A0 EN SK DE D CS D2 D1 D0 D15 D14 D13 A8A7A6A5A4A3A2A1A0+1 Figure 6 Read Timing D2 D1 D0 D15 D14 D13 A8A7A6A5A4A3A2A1A0+2 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 Writing (WRITE, ERASE, WRAL, ERAL) N 2. Writing data (WRITE) R 2. 1 NE W DE SI G Write instructions (WRITE, ERASE, WRAL, and ERAL) are used to start writing data to the non-volatile memory by making CS “L” after the specified number of clocks has been input. The write operation is completed within the write time tPR (10 ms) no matter which write instruction is used. The typical write time is less than half 10 ms. If the end of the write operation is known, therefore, the write cycle can be minimized. To ascertain the end of a write operation, make CS “L” to start the write operation and then make CS “H” again to check the status of the DO output pin. This series of operations is called a verify operation. If DO outputs “L” during the verify operation period in which CS is “H”, it indicates that a write operation is in progress. If DO outputs “H”, it indicates that the write operation is finished. The verify operation can be executed as many times as required. This operation can be executed in two ways. One is detecting the positive transition of DO output from “L” to “H” while holding CS at “H”. The other is detecting the positive transition of DO output from “L” to “H” by making CS “H” once and checking DO output, and then returning CS to “L”. During the write period, SK and DI are invalid. Do not input any instructions during this period. Input an instruction while the DO pin is outputting “H” or is in a high-impedance state. Even while the DO pin is outputting “H”, DO immediately goes into a high-impedance (High-Z) state if “H” of DI (start bit) is input at the rising edge of SK. Keep DI “L” during the verify operation period. FO This instruction is used to write 16-bit data to a specified address. After making CS “H”, input a start bit, the WRITE instruction, an address, and 16-bit data. If data of more than 16 bits is input, the written data is sequentially shifted at each clock, and the 16 bits input last are the valid data. The write operation is started when CS is made “L”. It is not necessary to set data to “1” before it is written. tCDS D SK 1 2 3 4 5 DI 0 1 X A8 DE CS Verify 6 7 8 9 10 11 12 A7 A6 A5 A4 A3 A2 A1 13 14 29 A0 D15 D0 tSV High-Z Figure 7 Busy tPR tHZ1 Ready High-Z Data Write Timing NO T RE C OM M EN DO Standby 11 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Erasing data (ERASE) N 2. 2 Rev.6.0_03 DE SI G This instruction is used to erase specified 16-bit data. All the 16 bits of the data are “1”. After making CS “H”, input a start bit, the ERASE instruction, and an address. It is not necessary to input data. The data erase operation is started when CS is made “L”. tCDS Verify CS SK 1 2 3 4 5 6 DI 1 1 X A8 A7 7 8 9 10 11 12 13 A6 A5 A4 A3 A2 A1 A0 tSV High-Z Busy Figure 8 2. 3 tHZ1 Ready High-Z tPR NE W DO Standby Data Erase Timing Writing to chip (WRAL) CS 1 2 3 4 5 DI 0 0 0 1 6 7 8 9 DE SK D FO R This instruction is used to write the same 16-bit data to the entire address space of the memory. After making CS “H”, input a start bit, the WRAL instruction, an address, and 16-bit data. Any address may be input. If data of more than 16 bits is input, the written data is sequentially shifted at each clock, and the 16-bit data input last is the valid data. The write operation is started when CS is made “L”. It is not necessary to set the data to “1” before it is written. High-Z EN DO 11 12 13 14 29 D15 D0 Standby tSV 8Xs Busy tHZ1 Ready tPR High-Z Chip Write Timing Erasing chip (ERAL) OM 2. 4 Verify M Figure 9 10 tCDS RE C This instruction is used to erase the data of the entire address space of the memory. All the data is “1”. After making CS “H”, input a start bit, the ERAL instruction, and an address. Any address may be input. It is not necessary to input data. The chip erase operation is started when CS is made “L”. tCDS Verify CS SK 1 2 3 4 5 DI 0 0 1 0 7 8 High-Z 9 10 11 12 13 8Xs NO 12 tSV Busy tPR T DO 6 Figure 10 Standby Chip Erase Timing tHZ1 Ready High-Z LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 Write enable (EWEN) and write disable (EWDS) N 3. DE SI G The EWEN instruction is used to enable a write operation. The status in which a write operation is enabled is called the program-enabled mode. The EWDS instruction is used to disable a write operation. The status in which a write operation is disabled is called the program-disabled mode. The write operation is disabled upon power application and detection of a low supply voltage. To prevent an unexpected write operation due to external noise or a CPU malfunctions, it should be kept in write disable mode except when performing write operations, after power-on and before shutdown. Standby CS 1 2 3 DI 0 0 4 5 6 7 9 10 11 8Xs 12 13 NE 11 = EWEN 00 = EWDS Write Enable / Disable Timing R Figure 11 8 W SK FO  Start Bit NO T RE C OM M EN DE D A start bit is recognized by latching the high level of DI at the rising edge of SK after changing CS to high (start bit recognition). A write operation begins by inputting the write instruction and setting CS to low. Subsequently, by setting CS to high again, the DO pin outputs a low level if the write operation is still in progress and a high level if the write operation is complete (verify operation). Therefore, only after a write operation, in order to input the next command, CS is set to high, which switches the DO pin from a high-impedance state (High-Z) to a data output state. However, if start bit is recognized, the DO pin returns to the high-impedance state (refer to Figure 5 Timing Chart). Make sure that data output from the CPU does not interfere with the data output from the serial memory IC when configuring a 3 -wire interface by connecting the DI input pin and DO output pin, as such interference may cause a start bit fetch problem. Take the measures described in “ 3-Wire Interface (Direct Connection between DI and DO)”. 13 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A  Write Protect Function during the Low Power Supply Voltage N Rev.6.0_03 W DE SI G The S-93L76A provides a built-in detection circuit to detect a low power supply voltage. When the power supply voltage is low or at power-on, the write instructions (WRITE, ERASE, WRAL, and ERAL) are cancelled, and the write disable state (EWDS) is automatically set. The detection voltage and the release voltage are 1.4 V typ. (refer to Figure 12). Therefore, when a write operation is performed after the power supply voltage has dropped and then risen again up to the level at which writing is possible, a write enable instruction (EWEN) must be sent before a write instruction (WRITE, ERASE, WRAL, or ERAL) is executed. When the power supply voltage drops during a write operation, the data being written to an address at that time is not guaranteed. NE Power supply voltage Release voltage (VDET) 1.4 V typ. R Detection voltage (VDET) 1.4 V typ. Operation during Low Power Supply Voltage NO T RE C OM M EN DE D Figure 12 FO Write instruction cancelled Write disable state (EWDS) automatically set 14 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 N  3-Wire Interface (Direct Connection between DI and DO) CPU SIO NE DI DO W S-93L76A DE SI G There are two types of serial interface configurations: a 4-wire interface configured using the CS, SK, DI, and DO pins, and a 3-wire interface that connects the DI input pin and DO output pin. When the 3-wire interface is employed, a period in which the data output from the CPU and the data output from the serial memory collide may occur, causing a malfunction. To prevent such a malfunction, connect the DI and DO pins of the S-93L76A via a resistor (10 k to 100 k) so that the data output from the CPU takes precedence in being input to the DI pin (refer to Figure 13). R: 10 k to 100 k Connection of 3-Wire Interface FO R Figure 13  Input Pin and Output Pin 1. Connection of input pins 2. EN DE D All the input pins of the S-93L76A have the CMOS structure. Do not set these pins in high impedance during operation when you design. Especially, set the CS pin to “L” at power-on, power-off, and during standby. The error write does not occur as long as the CS pin is “L”. Set the CS pin to GND via a resistor (the pull-down resistor of 10 k to 100 k). To prevent the error for sure, it is recommended to use equivalent pull-down resistors for input pins other than the CS pin. Equivalent circuit of input pin and output pin NO T RE C OM M The following shows the equivalent circuits of input pins of the S-93L76A. None of the input pins incorporate pull-up and pull-down elements, so special care must be taken when designing to prevent a floating status. Output pins are high-level / low-level / high-impedance tri-state outputs. The TEST pin is disconnected from the internal circuit by a switching transistor during normal operation. As long as the absolute maximum rating is satisfied, the TEST pin and internal circuit will never be connected. 15 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A N Input pin DE SI G 2. 1 Rev.6.0_03 CS Pin R Figure 14 NE W CS DE D FO SK, DI SK, DI Pin NO T RE C OM TEST M EN Figure 15 16 Figure 16 TEST Pin LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 VCC N Output pin DE SI G 2. 2 NE W DO 3. R DO Pin FO Figure 17 Input pin noise elimination time DE D The S-93L76A has a built-in low-pass filter at the SK pin, the DI pin and the CS pin to suppress noise. If the supply voltage is 5.0 V, noise with a pulse width of 20 ns or less at room temperature can be suppressed by the low-pass filter. Note that noise with a pulse width of more than 20 ns is recognized as a pulse since the noise can not be suppressed if the voltage exceeds VIH / VIL.  Precaution EN ● Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. NO T RE C OM M ● ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement of the products including this IC upon patents owned by a third party. 17 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 DC Characteristics 1. 1 Current consumption (READ) ICC1 vs. ambient temperature Ta 1. 2 Current consumption (READ) ICC1 vs. ambient temperature Ta VCC  3.3 V fSK  500 kHz DATA  0101 VCC  5.5 V fSK  2 MHz DATA  0101 0.4 0.4 ICC1 (mA) ICC1 (mA) 0.2 0 85 Ta (C) 1. 4 Current consumption (READ) ICC1 vs. ambient temperature Ta VCC  1.8 V fSK  10 kHz DATA  0101 D 0.4 DE ICC1 (mA) 0 40 0 Ta  25C fSK  1 MHz, 500 kHz DATA  0101 ICC1 (mA) 1 MHz 0.2 500 kHz 0 85 M Ta (C) Current consumption (READ) ICC1 vs. power supply voltage VCC 1. 6 OM 1. 5 ICC1 (mA) 100 kHz T NO 18 3 4 5 VCC (V) 6 6 7 0.2 0 10 kHz 2 4 5 VCC (V) 0.4 0.2 0 3 VCC  5.0 V Ta  25C RE C ICC1 (mA) 2 Current consumption (READ) ICC1 vs. Clock frequency fSK Ta  25C fSK  100 kHz, 10 kHz DATA  0101 0.4 85 0.4 EN 0.2 0 Ta (C) Current consumption (READ) ICC1 vs. power supply voltage VCC FO 1. 3 40  0 R 40 NE W 0.2 0 DE SI G 1. N  Characteristics (Typical Data) 7 10 k 100 k 1 M 2M 10M fSK (Hz) 1. 7 Current consumption (WRITE) ICC2 vs. ambient temperature Ta 1. 8 Current consumption (WRITE) ICC2 vs. ambient temperature Ta VCC  3.3 V VCC  5.5 V 1.0 1.0 ICC2 (mA) ICC2 (mA) 0.5 0 0 85 Ta (C) 1. 10 Current consumption (WRITE) ICC2 vs. ambient temperature Ta FO VCC  2.7 V 1.0 0.5 40 0 85 EN 0 1.0 ICC2 (mA) 0.5 0 2 3 OM M Current consumption in standby mode ISB vs. ambient temperature Ta 1. 12 1.0 Ta  25C CS  GND RE C ISB (A) T 0 Ta (°C) 85 0 2 3 4 5 6 7 VCC (V) NO 40 1.0 0.5 0.5 0 5 6 7 Current consumption in standby mode ISB vs. power supply voltage VCC VCC  5.5 V CS  GND ISB (A) 4 VCC (V) Ta (C) 1. 11 85 Ta  25C DE D ICC2 (mA) 0 Ta (C) Current consumption (WRITE) ICC2 vs. power supply voltage VCC R 1. 9 40 NE 40 W 0.5 0 DE SI G Rev.6.0_03 N LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A 19 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Input leakage current ILI vs. ambient temperature Ta VCC  5.5 V CS, SK, DI, TEST  0 V VCC  5.5 V CS, SK, DI, TEST  5.5 V 1.0 1.0 ILI (A) ILI (A) 0.5 W 0.5 40 0 85 Ta (C) 1. 16 Output leakage current ILO vs. ambient temperature Ta FO VCC  5.5 V DO  0 V 1.0 0.5 40 0 85 EN 0 Ta (C) VCC  5.5 V DO  5.5 V ILO (A) 0.5 0 40 0 Ta (C) M High-level output voltage VOH vs. ambient temperature Ta 4.6 4.4 RE C VOH (V) NO T 40 20 1. 18 High-level output voltage VOH vs. ambient temperature Ta 2.7 VOH (V) 4.2 0 Ta (C) 85 Ta (°C) VCC  4.5 V IOH  400 A OM 1. 17 85 1.0 DE D ILO (A) 0 Output leakage current ILO vs. ambient temperature Ta R 1. 15 40 NE 0 0 N 1. 14 Input leakage current ILI vs. ambient temperature Ta DE SI G 1. 13 Rev.6.0_03 VCC  2.7 V IOH  100 A 2.6 2.5 85 40 0 Ta (C) 85 1. 19 High-level output voltage VOH vs. ambient temperature Ta High-level output voltage VOH vs. ambient temperature Ta VCC  2.5 V IOH  100 A 2.5 VOH (V) 1. 20 1.9 VOH (V) 2.4 2.3 85 40 Ta (C) Low-level output voltage VOL vs. ambient temperature Ta 40 0 R 85 EN Ta (C) M High-level output current IOH vs. ambient temperature Ta 40 OM RE C 85 Ta (C) 1. 24 High-level output current IOH vs. ambient temperature Ta VCC  2.7 V VOH  2.4 V IOH (mA) 1 10.0 0 Ta (C) 85 0 40 0 85 Ta (C) NO T 40 0 2 20.0 0 VCC  1.8 V IOL  100 A 0.01 VCC  4.5 V VOH  2.4 V IOH (mA) 85 VOL 0.02 (V) DE 0.1 1. 23 0.03 D 0.2 0 Ta (C) Low-level output voltage VOL vs. ambient temperature Ta FO VCC  4.5 V IOL  2.1 mA 0.3 VOL (V) 1. 22 NE 0 VCC  1.8 V IOH  10 A W 1.7 40 1. 21 1.8 DE SI G Rev.6.0_03 N LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A 21 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A 1. 26 High-level output current IOH vs. ambient temperature Ta VCC  2.5 V VOH  2.2 V VCC  1.8 V VOH  1.6 V 2 1.0 IOH (mA) IOH (mA) 1 W 0.5 0 40 0 85 Ta (C) Low-level output current IOL vs. ambient temperature Ta 1. 28 20 VCC  1.8 V VOL  0.1 V 1.0 IOL (mA) IOL (mA) 0 Ta (C) 85 0.5 DE 40 EN 0 D 10 Input inverted voltage VINV vs. power supply voltage VCC 0 Ta  25C CS, SK, DI RE C 1.5 0 1 2 3 4 NO T VCC (V) 22 5 0 Ta (C) 85 VCC  5.0 V CS, SK, DI OM 3.0 VINV (V) 40 1. 30 Input inverted voltage VINV vs. ambient temperature Ta M 1. 29 85 Low-level output current IOL vs. ambient temperature Ta FO VCC  4.5 V VOL  0.4 V 0 Ta (C) R 1. 27 40 NE 0 N High-level output current IOH vs. ambient temperature Ta DE SI G 1. 25 Rev.6.0_03 3.0 VINV (V) 2.0 6 7 0 40 0 Ta (C) 85 1. 31 Low supply voltage detection voltage VDET vs. ambient temperature Ta 1. 32 Low supply voltage release voltage VDET vs. ambient temperature Ta 2.0 2.0 VDET (V) VDET (V) 1.0 0 0 85 Ta (C) AC Characteristics 2. 1 Maximum operating frequency fMAX. vs. power supply voltage VCC 2. 2 Ta  25C D 100k 1 2 3 4 tPR (ms) 2 5 1 2 3 M VCC (V) Write time tPR vs. ambient temperature Ta OM 2. 3 2. 4 tPR (ms) 2 2 Ta (C) 85 40 0 85 Ta (C) NO T 6 4 0 7 Write time tPR vs. ambient temperature Ta 4 40 5 6 VCC  3.0 V RE C 6 4 VCC (V) VCC  5.0 V tPR (ms) Ta (C) 4 EN 10k 85 Ta  25C DE fMAX. (Hz) 2M 1M 0 Write time tPR vs. power supply voltage VCC FO 2. 40 NE 40 R 0 W 1.0 DE SI G Rev.6.0_03 N LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A 23 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A 2. 6 Data output delay time tPD vs. ambient temperature Ta VCC  2.7 V tPR (ms) VCC  4.5 V 6 tPD (s) 4 2 85 40 2. 8 VCC  2.7 V 0.6 FO tPD (s) 0.2 40 0 85 NO T RE C OM M EN Ta (C) DE D 0.4 24 0 Ta (C) 85 Data output delay time tPD vs. ambient temperature Ta R Data output delay time tPD vs. ambient temperature Ta NE 0 W 0.1 Ta (C) 2. 7 0.3 0.2 40 N Write time tPR vs. ambient temperature Ta DE SI G 2. 5 Rev.6.0_03 tPD (s) VCC  1.8 V 1.5 1.0 0.5 40 0 Ta (C) 85 LOW VOLTAGE OPERATION 3-WIRE SERIAL E2PROM S-93L76A Rev.6.0_03 Product name 1. 1 DE SI G 1. N  Product Name Structure 8-Pin SOP (JEDEC), 8-Pin TSSOP S-93L76A D0I - xxxx x Environmental code U: Lead-free (Sn 100%), halogen-free G: Lead-free (for details, please contact our sales office) W Package name (abbreviation) and IC packing specifications Fixed 1. 2 FO R Product name S-93L76A: 8 K-bit NE J8T1: 8-Pin SOP (JEDEC), Tape T8T1: 8-Pin TSSOP, Tape TMSOP-8 - K8T3 U D S-93L76A D0I DE Environmental code U: Lead-free (Sn 100%), halogen-free EN Package name (abbreviation) and IC packing specifications K8T3: TMSOP-8, Tape Packages RE C 2. Package Name 8-Pin SOP (JEDEC) Environmental code = G Environmental code = U Environmental code = G Environmental code = U Package Drawing Code Tape Reel FJ008-A-P-SD FJ008-A-P-SD FT008-A-P-SD FT008-A-P-SD FM008-A-P-SD FJ008-D-C-SD FJ008-D-C-SD FT008-E-C-SD FT008-E-C-SD FM008-A-C-SD FJ008-D-R-SD FJ008-D-R-S1 FT008-E-R-SD FT008-E-R-S1 FM008-A-R-SD NO T 8-Pin TSSOP TMSOP-8 Product name S-93L76A: 8 K-bit OM M Fixed 25 1 4 DE SI G 5 NE W 8 N 5.02±0.2 DE D FO R 0.20±0.05 1.27 NO T RE C OM M EN 0.4±0.05 No. FJ008-A-P-SD-2.2 TITLE SOP8J-D-PKG Dimensions FJ008-A-P-SD-2.2 No. ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) N 2.0±0.05 ø1.55±0.05 2.1±0.1 FO R NE 8.0±0.1 ø2.0±0.05 W DE SI G 0.3±0.05 5 Feed direction NO T RE C OM M 4 8 EN 1 DE D 6.7±0.1 No. FJ008-D-C-SD-1.1 TITLE SOP8J-D-Carrier Tape No. FJ008-D-C-SD-1.1 ANGLE UNIT mm ABLIC Inc. N DE SI G FO R NE W 60° D 13.5±0.5 2±0.5 ø13±0.2 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part 2±0.5 No. FJ008-D-R-SD-1.1 TITLE SOP8J-D-Reel No. FJ008-D-R-SD-1.1 QTY. ANGLE UNIT mm ABLIC Inc. 2,000 N DE SI G FO R NE W 60° D 13.5±0.5 2±0.5 ø13±0.2 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part 2±0.5 No. FJ008-D-R-S1-1.0 TITLE SOP8J-D-Reel No. FJ008-D-R-S1-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 N +0.3 5 1 4 R NE W 8 DE SI G 3.00 -0.2 DE D FO 0.17±0.05 EN 0.2±0.1 NO T RE C OM M 0.65 No. FT008-A-P-SD-1.2 TITLE TSSOP8-E-PKG Dimensions No. FT008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 4.0±0.1 2.0±0.05 ø1.55±0.05 +0.1 8.0±0.1 NE ø1.55 -0.05 W DE SI G N 0.3±0.05 FO R (4.4) +0.4 EN DE D 6.6 -0.2 8 M 1 4 NO T RE C OM 5 Feed direction No. FT008-E-C-SD-1.0 TITLE TSSOP8-E-Carrier Tape FT008-E-C-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. N DE SI G W NE R FO D 17.5±1.0 2±0.5 ø13±0.5 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part 13.4±1.0 No. FT008-E-R-SD-1.0 TITLE TSSOP8-E-Reel No. FT008-E-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 3,000 N DE SI G W NE R FO D 17.5±1.0 2±0.5 ø13±0.5 NO T RE C OM M EN ø21±0.8 DE Enlarged drawing in the central part 13.4±1.0 No. FT008-E-R-S1-1.0 TITLE TSSOP8-E-Reel FT008-E-R-S1-1.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 4,000 N DE SI G 2.90±0.2 5 1 4 NE W 8 D FO R 0.13±0.1 0.2±0.1 NO T RE C OM M EN DE 0.65±0.1 No. FM008-A-P-SD-1.2 TITLE TMSOP8-A-PKG Dimensions No. FM008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 1.00±0.1 N 4.00±0.1 +0.1 1.5 -0 NE W DE SI G 4.00±0.1 1.05±0.05 FO R 0.30±0.05 1 EN 4 DE D 3.25±0.05 8 Feed direction NO T RE C OM M 5 No. FM008-A-C-SD-2.0 TITLE TMSOP8-A-Carrier Tape FM008-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. N FO R NE W DE SI G 16.5max. 13±0.2 OM M EN Enlarged drawing in the central part DE D 13.0±0.3 NO T RE C (60°) (60°) No. FM008-A-R-SD-1.0 TITLE TMSOP8-A-Reel No. FM008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 Disclaimers (Handling Precautions) All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not responsible for damages caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not responsible for damages caused by the incorrect information described herein. 4. Be careful to use the products within their specified ranges. Pay special attention to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not responsible for damages caused by failures and / or accidents, etc. that occur due to the use of the products outside their specified ranges. 5. When using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products must not be used or provided (exported) for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not responsible for any provision (export) to those whose purpose is to develop, manufacture, use or store nuclear, biological or chemical weapons, missiles, or other military use. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses. Do not apply the products to the above listed devices and equipments without prior written permission by ABLIC Inc. Especially, the products cannot be used for life support devices, devices implanted in the human body and devices that directly affect human life, etc. Prior consultation with our sales office is required when considering the above uses. ABLIC Inc. is not responsible for damages caused by unauthorized or unspecified use of our products. 9. Semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system must be sufficiently evaluated and applied on customer's own responsibility. EN DE D FO R NE W DE SI G N 1. M 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. OM 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. RE C 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party without the express permission of ABLIC Inc. is strictly prohibited. T 14. For more details on the information described herein, contact our sales office. NO 2.0-2018.01 www.ablicinc.com
S-93L76AD0I-J8T1G 价格&库存
很抱歉,暂时无法提供与“S-93L76AD0I-J8T1G”相匹配的价格&库存,您可以联系我们找货
