1539M14
1539M14
    HAMMONDMANUFACTURING
    插件,D=31mm
    固定电感器 Radial, Vertical Cylinder ±10% 34mΩ
1539M14 数据手册
R.F. CHOKES (1537-1538 Series) HIGH CURRENT CHOKES Chokes • Large ferrite core for extended saturation point, optimum frequency range .01-2 Mhz. • 1.5" long leads (+/- 0.1") • Test frequency 1 Khz. • Core length 1.25". Coil is covered with vinyl shrink sleeve. Part No. Inductance +/- 5% uH Min. Q 1537E 1537F 1537G 1537H 1537J 1537K 1537L 1537M 1537N 1537P 1537R 10 20 30 40 50 75 100 250 500 750 1000 4.5 6.5 5.3 5.2 3.4 3.2 10.5 12.0 11.6 10.0 7.4 D.C. Resistance Ohms 0.006 0.013 0.024 0.039 0.064 0.128 0.05 0.114 0.26 0.465 0.83 Max. D.C. Current Amps 20 12.5 8 5 3.2 2 8 5 3.2 2 1.25 Coil Dia. Lead Dia. In. Gauge 0.63 0.60 0.58 0.57 0.56 0.54 0.71 0.69 0.65 0.61 0.59 14 16 18 20 20 20 18 18 20 20 20 EMI/RFI CHOKES • High saturation flux density ferrite rods. • 1" long leads, tinned to within 1/8" of body. • Ideal for filtering or energy storage inductors. • Inductance measured at @ 1Khz. with 0 amps. D.C. current, typical inductance change is less than 5% @ twice rated current. Part No. Inductance L uH +/- 10% 1538M01 1538M02 1538M03 1538M04 1538M05 1538M06 1538M07 1538M08 1538M09 1538M10 1538M11 1538M12 1538M13 1538M14 1538M15 1538M16 1538M17 1538M18 1538M19 1538M20 1538M21 1538M22 1538M23 1538M24 5 10 27 50 100 150 250 5 10 27 50 68 100 150 5 10 27 50 68 100 5 10 27 50 Fo Min. MHz 32.4 21.6 5.6 3.44 2.08 1.84 1.1 27.2 21.7 5.6 4.4 3.6 2.4 1.6 34.7 20 6.2 3.8 3.2 2.2 30.8 20 6.4 3.5 R - D.C. Max. Ohms 0.013 0.017 0.03 0.04 0.061 0.069 0.089 0.009 0.012 0.022 0.028 0.034 0.038 0.046 0.006 0.008 0.014 0.02 0.023 0.027 0.004 0.006 0.010 0.013 CANADA © Max. Dim. A Max. Dim. B Typ. Dim. C Typ. Dim. D 0.88 1.12 0.88 0.88 1.12 1.38 1.62 0.88 1.12 0.88 1.12 1.12 1.38 1.62 1.12 1.38 1.12 1.38 1.38 1.62 1.38 1.69 1.38 1.62 0.63 0.63 0.81 0.81 0.81 0.81 0.81 0.64 0.64 0.88 0.88 0.88 0.88 0.88 0.69 0.94 0.94 0.94 0.94 0.94 0.72 0.72 1.00 1.00 0.50 0.69 0.44 0.75 0.94 1.06 1.31 0.75 1.00 0.56 0.75 0.88 1.00 1.25 0.81 1.22 0.69 0.94 1.12 1.31 0.94 1.50 0.94 1.12 0.042 0.042 0.042 0.042 0.042 0.042 0.042 0.053 0.053 0.053 0.053 0.053 0.053 0.053 0.065 0.065 0.065 0.065 0.065 0.065 0.082 0.082 0.082 0.082 EUROPE Guelph, Ontario (519) 822-2960 St. Laurent, Quebec (514) 343-9010 www.hammondmfg.com Cheektowaga, NY (716) 630-7030 52 USA I - D.C. Max. Amps 10 9 7 5.6 4.9 4.6 4 14 12 9 8 7.3 6.8 6.3 19 16 12.5 10.5 10 10 23 20 15 15 Basingstoke, UK 01256 812812 AUSTRALIA Queenstown, Australia 61-8-8240-2244 EMI / RFI (1539 Series) Chokes EMI/RFI CHOKES • High saturation flux density ferrite bobbins. • 1" long leads, tinned to within 1/8" of body. • Ideal for filtering or energy storage inductors. • Inductance measured at @ 1Khz. with 0 amps. D.C. current, typical inductance change is less than 5% @ twice rated current. Part No. Inductance L uH +/- 10% 1539M01 1539M02 1539M03 1539M04 1539M05 1539M06 1539M07 1539M08 1539M09 1539M10 1539M11 1539M12 1539M13 1539M14 1539M15 1539M16 1539M17 1539M18 1539M19 1539M20 1539M21 1539M22 1539M23 1539M24 1539M25 1539M26 1539M27 1539M28 1539M29 1539M30 1539M31 1539M32 5 10 25 50 100 250 500 1000 2500 5 10 25 50 100 250 500 1000 2500 50 100 250 500 1000 2500 5000 100 250 500 1000 2500 5000 10000 Fo Min. MHz 24.7 11.4 6.2 4.1 2.4 1.6 1 0.7 0.43 26.7 15.6 5.2 3.6 2.2 1.2 0.89 0.58 0.35 3.4 2 1.3 0.9 0.54 0.34 0.24 1.8 1 0.7 0.44 0.26 0.19 0.13 R - D.C. Max. Ohms 0.007 0.008 0.023 0.034 0.072 0.173 0.378 0.801 2.04 0.005 0.006 0.009 0.017 0.034 0.083 0.129 0.279 0.69 0.012 0.025 0.059 0.09 0.195 0.499 1.08 0.018 0.040 0.085 0.183 0.464 0.714 1.55 I - D.C. Max. Amps 15 14 8 6.6 4.5 2.9 2 1.3 0.85 20 17 14 10 7 4.6 3.7 2.5 1.6 14 9.8 6.4 5 3.5 2.2 1.5 14 9 6.5 4.4 2.8 2.2 1.5 Max. Dim. A Max. Dim. B Typ. Dim. C Typ. Dim. D 0.83 0.83 0.83 0.83 0.83 0.83 0.83 0.83 0.83 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.22 1.50 1.50 1.50 1.50 1.50 1.50 1.50 1.50 1.50 1.50 1.50 1.50 1.50 1.50 0.91 0.91 0.91 0.91 0.91 0.91 0.91 0.91 0.91 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.50 1.50 1.50 1.50 1.50 1.50 1.50 0.59 0.60 0.57 0.65 0.69 0.65 0.68 0.66 0.71 0.94 0.95 0.93 0.99 0.85 0.97 1.12 1.05 1.05 1.23 1.12 1.10 1.14 1.36 1.32 1.27 1.18 1.12 1.06 1.23 1.21 1.32 1.25 0.065 0.065 0.042 0.042 0.042 0.042 0.042 0.042 0.042 0.082 0.082 0.082 0.065 0.053 0.053 0.053 0.053 0.053 0.082 0.065 0.053 0.053 0.053 0.053 0.053 0.082 0.065 0.053 0.053 0.053 0.053 0.053 EUROPE Basingstoke, UK 01256 812812 AUSTRALIA Queenstown, Australia 61-8-8240-2244 CANADA www.hammondmfg.com Guelph, Ontario (519) 822-2960 St. Laurent, Quebec (514) 343-9010 53 Cheektowaga, NY (716) 630-7030 USA ©
1539M14
物料型号:文档列出了多个型号的电感器,包括1537系列和1539系列。
器件简介:这些电感器具有大的铁氧体核心,用于扩展饱和点,优化频率范围在0.01-2 MHz之间。1537系列的电感器采用1.5英寸长的引线,而EMI/RFI电感器则有1英寸长的镀锡引线。
引脚分配:1537系列电感器的引线长度为1.5英寸,EMI/RFI电感器的引线长度为1英寸。
参数特性:表格中列出了不同型号电感器的电感值、品质因数Q、直流电阻、最大直流电流、线圈直径和引线直径。
功能详解:EMI/RFI电感器适用于滤波或能量存储电感器,其电感值在1kHz频率和0A直流电流下测量,典型电感变化小于额定电流的两倍时的5%。
应用信息:这些电感器适用于需要高电流和高饱和通量密度的应用场合。
封装信息:文档提供了不同型号电感器的最大尺寸和典型尺寸。
1539M14 价格&库存
很抱歉,暂时无法提供与“1539M14”相匹配的价格&库存,您可以联系我们找货
