560L104YTT
560L104YTT
    ATC
    贴片电容(MLCC) 0402 100nF -20~+25% 16V
560L104YTT 数据手册
A T C 5 6 0 L S E R I E S U B C TM C A P A C I T O R S ATC 560L Series UBC Ultra-Broadband Capacitor TM Features: • EIA 0402 Case Size • Capacitance: 100 nF • Operating Frequency: 16 KHz (-3 dB roll-off) to 40+ GHz* • Insertion Loss: < 0.6 dB typical • Orientation Insensitive • One Piece Construction • Voltage Rating: 16 WVDC** • RoHS Compliant Terminations • Gold Terminations Available ATC’s new 560L Ultra-Broadband Capacitor is manufactured with highest quality materials to provide reliable and repeatable Ultra-Broadband performance from 16 KHz through 40+ GHz. It exhibits ultra-low insertion loss, flat frequency response and excellent return loss, and is ideal for D.C. Blocking, Coupling, Bypassing and Feedback applications requiring Ultra-Broadband performance. The 560L is a one-piece orientation-insensitive 0402 SMT package, fully compatible with high speed automated pick-and-place manufacturing. It is designed to meet the most stringent requirements of Ultra-Broadband applications. Advantages: Applications: • Ultra-Broadband Performance • Optoelectronics/ High Speed Data • Ultra-Low Insertion Loss • Transimpedance amplifiers • Flat Frequency Response • ROSA/TOSA† • Excellent Return Loss • SONET†† • Unit-to-Unit Performance Repeatability • Broadband Test Equipment • Rugged Ceramic Construction • Broadband Microwave/ millimeter-wave * 25 °C, no bias applied ** Operating Temperture dependent 0 -0.2 -10 -0.4 -20 Magnitude (dB) -0.6 Magnitude (dB) †† Synchronous Optical Network ATC 560L Series Return Loss (S11) ATC 560L Series Insertion Loss (S21) 0 -0.8 -1 -1.2 -1.4 -1.6 (Typical) -1.8 -2 †R  eceive and Transmit Optical Sub-Assembly 0 5 10 15 20 25 30 -30 -40 -50 (Typical) -60 35 40 -70 0 5 10 15 20 25 30 35 40 Frequency (GHz) Frequency (GHz) ATC 560L Data Sheet Test Condition Description ATC testing to 40 GHz performed on 10-mil-thick Rogers RO4350 microstrip board, with the device under test subtending a 24 mil gap in a 22-mil-wide center trace (nominal 50-ohm characteristic impedance). ATC # 001-1141 Rev. B; 1/18 A T C 5 6 0 L S E R I E S U B C TM C A P A C I T O R S Mechanical Dimensions Electrical Specifications: • Capacitance: 100 nF • Rated Voltage: 16 WVDC from -55°C to +85°C 10 WVDC from -55°C to +125°C 0.020 in. ± 0.004 in. (0.508 mm ± 0.1 mm) 0.040 in. ± 0.004 in. (1.016 mm ± 0.1 mm) • Dielectric Withstanding Voltage (DWV): 250% of rated WVDC for 5 secs. • Operating Temperature Range: -55°C to +125°C • Temperature Coefficient of Capacitance (TCC):  ±15% (-55°C to +85°C) ±22% (>85°C to +125°C) 0.012 in. typ. (0.305 typ.) 0.024 in. max. (0.610 mm max.) • Insulation Resistance: 1010 Ω min. @ +25°C @ rated WVDC 109 Ω min. @ +125°C @ rated WVDC ATC PART NUMBER CODE ATC 560 L 104 Y T T Series Case Size: (0402) Capacitance Code: First 2 significant digits for capacitance R=Decimal Point Capacitance Tolerance Y = +25%, -20% *500, 1000, 4000 pieces on 7” reel Tape and Reel (standard)* Termination Code T = Tin Plated over Nickel Barrier (Standard) CA = Gold Plated over Nickel Barrier The above part number refers to a 560 Series (case size L) 100 nF capacitor, Y tolerance (+25%, -20%), with T termination (Tin Plated over Nickel Barrier), tape and reel packaging. ATC accepts orders for our parts using designations with or without the “ATC” prefix. Both methods of defining the part number are equivalent, i.e., part numbers referenced with the “ATC” prefix are interchangeable to parts referenced without the “ATC” prefix. Customers are free to use either in specifying or procuring parts from American Technical Ceramics. For additional information and catalogs contact your ATC representative or call direct at (+1-631) 622-4700. Consult factory for additional performance data. Sales of ATC products are subject to the terms and conditions contained in American Technical Ceramics Corp. Terms and Conditions of Sale (ATC document #001-992 Rev. A 10/03). Copies of these terms and conditions will be provided upon request. They may also be viewed on ATC’s website at www.atceramics. com/productfinder/default.asp. Click on the link for Terms and Conditions of Sale. ATC has made every effort to have this information as accurate as possible. However, no responsibility is assumed by ATC for its use, nor for any infringements of rights of third parties which may result from its use. ATC reserves the right to revise the content or modify its product line without prior notice. © 2009 American Technical Ceramics Corp. All Rights Reserved. ATC # 001-1141 Rev. B; 1/18
560L104YTT 价格&库存
很抱歉,暂时无法提供与“560L104YTT”相匹配的价格&库存,您可以联系我们找货
