NJM2606AM-TE2
NJM2606AM-TE2
    NJR(新日本无线)
    DMP8_5X5MM
    IC DC MOTOR CTLR BIPO LV 8DMP
NJM2606AM-TE2 数据手册
NJM2606 / 2606A LOW VOLTAGE DC MOTOR CONTROLLER ■ GENERAL DESCRIPTION The NJM2606/06A are integrated circuits with wide operating supply voltage range for DC motor speed control. Especially, the NJM2606A is suited for the applications requiring low staturation output voltage. ■ FEATURES ● Operating Voltage (1.8V to 8V) ● Internal Low Saturation Voltage Output Transistor ● Package Outline DIP8, DMP8 ● Bipolar Technology ■ PACKAGE OUTLINE NJM2606D NJM2606AD NJM2606M NJM2606AM ■ PIN CONFIGURATION NJM2606D NJM2606AD NJM2606M NJM2606AM ■ BLOCK DIAGRAM Ver.2003-12-09 -1- NJM2606 / 2606A ■ ABSOLUTE MAXIMUM RATINGS PARAMETER (Ta=25°C) SYMBOL RATINGS + UNIT Supply Voltage V 10 V Peak-to-peak Output Current IOP Power Dissipation PD Operating Temperature Range Topr -20 to 75 °C Storage Temperature Range Tstg -40 to 125 °C 700 (DIP) (DMP8) mA 500 300 mW mW (note)At SW ON. (3 sec. at motor locked or 100msec at duty factor less than 0.1%) (Ta=25°C, V+=3V, IM=100mA) ■ ELECTRICAL CHARACTERISTICS MIN. TYP. MAX. UNIT Operating Current Output Saturation Voltage NJM2606 NJM2606A Reference Voltage vs. Operating Voltage vs. Output Current vs. Ambient Temperature Current Ratio vs. Operating Voltage PARAMETER ICC - 2.4 6.0 mA VOSAT VOSAT VREF ∆VRSV ∆VROC ∆VRT K ∆KSV 0.18 45 - 0.18 0.13 0.20 0.7 2.7 0.04 50 0.6 0.3 0.18 0.22 8.0 9.0 55 3.0 V V V mV mV mV / °C vs. Output Current vs. Ambient Temperature ∆KOC ∆KTC - 1.0 1.0 4.0 - -2- SYMBOL TEST CONDITION + V =1.8V to 8.0V IM=20mA to 200mA Ta= -20°C to +75°C IM=50mA to 150mA + V =1.8V to 8.0V IM=50mA to 150mA IM=(20 to 50)mA to (170 to 200)mA Ta= -20°C to +75°C IM=50mA to 150mA 1 / °C Ver.2003-12-09 NJM2606 / 2606A ■ TYPICAL CHARACTERISTICS Reference Voltage vs. Operating Voltage Reference Voltage vs. Motor Current Reference Voltage vs. Temperature Operating Current vs. Operating Voltage Output Staturation Voltage vs. Motor Current Current Ratio vs. Operating Voltage Ver.2003-12-09 -3- NJM2606 / 2606A ■ TYPICAL CHARACTERISTICS Current Ratio vs. Motor Current Current Ratio vs. Temperature Rotation vs. Torque -4- Ver.2003-12-09 NJM2606 / 2606A ■ TYPICAL APPLICATION The voltage applied at the motor is set as VM, which brings the following formula. I +I VM = (R1 + R 2 + R 3 ) Iref + R1・ M ref K Now that, Iref = Vref / R 2 so that, (Iref ≒100µA setting is appropriate) VM = Vref R R (R1 + 1 + R 2 + R 3 ) + 1 IM Λ Λ (1) R2 K K On the other hand, the voltage applied at the motor itself will be as in the following. VM = E O + RM・IM Λ Λ ( 2) Through (1), (2), and then leading to stabilize the control system. R RM・IM > 1 ・IM K ∴ R1 < K・RM Λ Λ (3) Taking in consideration of deviations, R1(MAX ) < K (MIN)・RM(MIN) with the condition. Items required checking in regard to the temperature coefficient IC items 1. Reference voltage : Temperature coefficient of Vref. 2. Current Ratio : Temperature coefficient of K *1 External component items 3. Temperature coefficient of R1, R2 and R3 The relation among these 3 parts takes the very important roll. 4. Temperature coefficient of motor internal resistance 5. Temperature coefficient of motor generative voltage 6. Temperature coefficient ratio of R1 and RM Count up from 3.4. Ver.2003-12-09 [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. -5-
NJM2606AM-TE2 价格&库存
很抱歉,暂时无法提供与“NJM2606AM-TE2”相匹配的价格&库存,您可以联系我们找货
