MM3220H15NRH
MM3220H15NRH
    NMBTECHNOLOGIESCORPORATION
    SOT23-6
    IC, TWO CELL, BATTERY PROTECTION
MM3220H15NRH 数据手册
2cell Li-ion/Li-polymer battery protection IC 2cell Li-ion/Li-polymer battery protection IC  MM3220 Series Description The MM3220 series are protection IC using high voltage CMOS process for overcharge, overdischarge and overcurrent protection of the rechargeable Lithium-ion or Lithium-polymer battery. The overcharge, overdischarge, discharging overcurrent, short, charging , and overcurrent(optional) of the rechargeable one-cell Lithium-ion or Lithium-polymer battery can be detected. Each of these IC composed of four voltage detectors, short detection circuit, reference voltage sources, oscillator, counter circuit and logical circuits. Features ・Accuracy and selectable range of detection/release voltage Range Accuracy Overcharge detection voltage 4.0V to 4.5V ±20mV Ta= 25degC ±25mV Ta= -5 to 60degC Overcharge release voltage 3.9V to 4.5V ±30mV Ta= 25degC Overdischarge detection voltage 2.0V to 3.0V ±35mV Ta= 25degC Overdischarge release voltage 2.0V to 3.5V ±100mV Ta= 25degC Discharging overcurrent detection voltage 1 +50mV to +300mV ±10mV Ta= 25degC Discharging overcurrent detection voltage 2 ※1 +50mV to +700mV ±20% Ta= 25degC Charging overcurrent detection voltage ※1 -50mV to -300mV ±20mV Ta= 25degC Short detection voltage 0.9V fixed ±100mV Ta= 25degC ±300mV ※2 Ta= 25degC ・Current consumption Normal mode Typ. 4.0uA, Max. 8.0uA Stand-by mode Max. 0.1uA Applications ・Lithium-ion rechargeable battery pack ・Lithium polymer rechargeable battery pack Package type ・SOT-26A 2.90 × 2.80 × 1.15 [mm] ※1 Optional function ※2 When the discharging overcurrent detection voltage 2 function having 1 Absolute maximum ratings Parameter Supply voltage Rating Symbol Unit VDD VSS-0.3 to 12 V COUT terminal VCOUT VDD-28 to VDD+0.3 V DOUT terminal VDOUT -0.3 to VDD+0.3 V Operating ambient temperature Topr -40 to +85 degC Storage temperature Tstg -55 to +125 degC Electrical characteristics Unless otherwise specified, Topr=+25℃ Parameter Symbol Conditions Min. Typ. Max. unit 1.5 - 12.0 V - - 1.2 V INPUT/OUTPUT VOLTAGE Operating input voltage VDD1 Minimum operating voltage for 0V charging Vst VDD-VSS VDD-V- COUT pin Nch ON voltage Vol1 Iol=30uA, VDD=9.0V - 0.4 0.5 V COUT pin Pch ON voltage Voh1 Ioh=-30uA, VDD=7.0V 6.5 6.8 - V DOUT pin Nch ON voltage Vol2 Iol=30uA, VDD=3.8V - 0.2 0.5 V DOUT pin Pch ON voltage Voh2 Ioh=-30uA, VDD=7.0V 6.5 6.8 - V - 4.0 8.0 uA - - 0.1 uA -300 - 300 nA CURRENT CONSUMPTION Current consumption IDD Vcell=3.5V, V-=0V Current consumption at stand-by IS Vcell=1.9V, V-=3.8V DOUT pin Pch ON voltage IBL Vcell=3.5V, V-=0V DETECTION/RELEASE VOLTAGE Overcharge detection voltage Vdet1 Overcharge release voltage Vrel1 Overdischarge detection voltage Vdet2 Overdischarge release voltage Vrel2 Ta=+25℃ Typ-0.020 Ta=-5~+60℃ Typ-0.025 Vdet1≠Vrel1 Typ-0.030 Vrel1 Typ+0.030 V Typ-0.035 Vdet2 Typ+0.035 V Typ-0.10 Vrel2 Typ+0.100 V Typ-0.010 Vdet3-1 Typ+0.010 V V Vdet2≠Vrel2 Vdet1 Typ+0.020 Typ+0.025 V Discharging overcurrent detection voltage 1 Vdet3-1 Discharging overcurrent detection voltage 2 ※1 Vdet3-2 Typ-20% Charging overcurrent detection voltage ※1 Vdet4 Typ-0.020 Vdet4 Typ+0.020 V Short detection voltage Vshort 0.8 0.9 1.0 V Vdet3-2 Typ+20% DETECTION DELAY TIME Overcharge detection delay time tVdet1 tVdet1 s Overdischarge detection delay time tVdet2 tVdet2 ms Discharging overcurrent detection delay time 1 tVdet3-1 Discharging overcurrent detection delay time 2 ※1 tVdet3-2 Charging overcurrent detection delay time ※1 tVdet4 Short detection delay time tshort Typ*0.8 tVdet3-1 Typ*1.2 tVdet3-2 ms tVdet4 280 400 ms ms 560 us ※1 Optional function 2 Package and pin configuration SOT-26A 6 1 5 2 Package dimensions Function Pin No. Symbol 1 DOUT Output of overdischarge detection. 2 COUT Output of overcharge detection. 3 V- 4 3 Input terminal connected to charger negative voltage. 4 VBL Input terminal of the low side cell. 5 VDD Input terminal of the high side cell. Supply terminal. 6 VSS VSS terminal. Connected to ground. Unit:mm SOT-26A 3 Typical application circuit R1 , C1 , R2 , C2 stabilize a supply voltage ripple. However, R1 is enlarged, the detection voltage shifts by voltage when current consumption flows into R1. Please decide it after confirming the characteristic. Moreover, adjust the value of C1 , C2 to 0.01uF or more to do the stability operation, please. R1 and R3 resistors are current limit resistance if a charger is connected reversibly or a high-voltage charger that exceeds the absolute maximum rating is connected. R1 and R3 may cause a power consumption will be over rating of power dissipation, therefore the `R1+R3` should be more than 1kohm. Moreover, if R3 is too enlarged, the charger connection release cannot be occasionally done after the overdischarge is detected, so adjust the value of R3 to 10kohm or less, please. In the state of overdischarge, The current flows through overdischarge pull-up resistance built into between VDD terminal and V- terminal when the charger is connected. As a result, current that flows into VDD terminal increases. When current increases, the voltage is generated in R1. And hysteresis might be caused. Please use it after confirming the characteristic. C3 and C4 capacitors have effect that the system stability about voltage ripple or imported noise. After check characteristics, decide that these capacitors should be inserted or not, where should be inserted, and capacitance value, please. 4 Lineup tVdet3-1 tVdet3-2 - -0.200V 1.00s 128.0ms 12.0ms SOT26A × ○ 4.250V 4.050V 2.800V 3.000V 0.100V - -0.100V 1.00s 128.0ms SOT26A ○ × 4.300V 4.100V 2.000V 2.000V 0.100V 0.200V - 1.00s 12.0ms C03NRH SOT26A ○ × 4.300V 4.100V 2.000V 2.000V 0.100V 0.200V - 1.00s C08NRH SOT26A ○ × 4.300V 4.100V 2.000V 2.000V 0.065V 0.200V - D01NRH SOT26A × × 4.250V 4.100V 3.000V 3.000V 0.200V - - D05NRH SOT26A × × 4.250V 4.100V 2.500V 2.500V 0.150V - F01NRH SOT26A × 4.225V 4.075V 2.550V 2.550V 0.200V - G01NRH SOT26A × ○ 4.290V 4.050V 3.000V 3.200V 0.200V G06NRH SOT26A × ○ 4.250V 4.100V 2.500V 3.000V 0.150V G07NRH SOT26A H01NRH SOT26A H02NRH※2 H03NRH ※1 SOT26A AA2NRH C02NRH Charging overcurrent detection delay time Discharging overcurrent detection delay time 2 Discharging overcurrent detection delay time 1 tVdet2 × ○ 4.250V 4.050V 2.800V 3.000V 0.200V AA1NRH Vrel2 Vdet3-1 Vdet3-2 Vdet4 tVdet1 Overdischarge detection delay time Overcharge detection delay time Charging overcurrent detection voltage Vdet2 Detection delay time Discharging overcurrent detection voltage 2 Vrel1 Discharging overcurrent detection voltage 1 Overdischarge detection voltage Vdet1 Overdischarge release voltage Overcharge release voltage Detection / Release voltage Overcharge detection voltage Charging overcurrent detection Two stage overcurrent detecting function Product name (MM3220) Package Option tVdet4 - 8.0ms 12.0ms - 8.0ms 48.0ms 4.0ms - 12.0ms 256.0ms 2.5ms - 1.00s 12.0ms 256.0ms 0.5ms - 1.15s 144.0ms 9.0ms - - - 1.15s 144.0ms 9.0ms - - - 1.15s 144.0ms 9.0ms - - - -0.200V 1.00s 128.0ms 12.0ms - 8.0ms - -0.100V 1.00s 12.0ms 256.0ms - 8.0ms × ○ 4.400V 4.250V 2.500V 3.000V 0.150V - -0.100V 1.00s 12.0ms 256.0ms - 8.0ms × ○ 4.225V 4.075V 3.000V 3.000V 0.200V - -0.200V 1.15s 144.0ms 9.0ms - 8.0ms SOT26A × ○ 4.300V 4.150V 2.400V 2.400V 0.200V - -0.200V 1.15s 144.0ms 9.0ms - 8.0ms SOT26A × ○ 4.250V 4.100V 3.200V 3.200V 0.200V - -0.200V 1.15s 144.0ms 9.0ms - 8.0ms H04NRH※2 SOT26A × ○ 4.230V 4.080V 2.400V 2.400V 0.200V - -0.200V 1.15s 144.0ms 9.0ms - 8.0ms H06NRH※2 SOT26A × ○ 4.230V 4.080V 2.865V 2.865V 0.200V - -0.200V 1.15s 144.0ms 9.0ms - 8.0ms H09NRH※2 SOT26A × ○ 4.225V 4.150V 2.600V 2.600V 0.250V - -0.200V 1.15s 1.15s 9.0ms - 8.0ms H10NRH※2 SOT26A × ○ 4.250V 4.175V 2.600V 2.600V 0.250V - -0.200V 1.15s 1.15s 9.0ms - 8.0ms H11NRH SOT26A × ○ 4.300V 4.150V 2.300V 2.300V 0.150V - -0.150V 1.00s 96.0ms 20.0ms - 8.0ms H13NRH SOT26A × ○ 4.250V 4.050V 2.400V 2.400V 0.200V - -0.200V 1.00s 128.0ms 12.0ms - 8.0ms H15NRH※2 SOT26A × ○ 4.280V 4.130V 2.800V 2.800V 0.150V - -0.150V 1.00s 128.0ms 9.0ms - 8.0ms H16NRH SOT26A × ○ 4.250V 4.100V 3.000V 3.000V 0.200V - -0.200V 1.00s 128.0ms 8.0ms - 8.0ms J01NRH※2 SOT26A × ○ 4.275V 4.275V 2.500V 2.500V 0.085V - -0.060V 0.25s 20.0ms 6.0ms - 16.0ms JA1NRH SOT26A × ○ 4.250V 4.250V 2.800V 2.800V 0.100V - -0.100V 1.00s 96.0ms 10.0ms - 6.0ms × K01NRH SOT26A ○ ○ 4.300V 4.100V 2.000V 2.000V 0.125V 0.300V -0.090V 1.15s 144.0ms 12.0ms 0.5ms 8.0ms M01NRH※2 SOT26A × ○ 4.280V 4.080V 2.000V 2.000V 0.200V - -0.100V 1.00s 128.0ms 12.0ms - 8.0ms M04NRH※2 SOT26A × ○ 4.280V 4.080V 2.600V 2.600V 0.135V - -0.085V 1.00s 128.0ms 12.0ms - 8.0ms MB1NRH※2 SOT26A × ○ 4.425V 4.225V 2.800V 2.800V 0.150V - -0.100V 1.00s 128.0ms 8.0ms - 8.0ms MC1NRH※2 SOT26A × ○ 4.300V 4.100V 2.300V 2.300V 0.090V - -0.090V 1.00s 12.0ms 48.0ms - 16.0ms N01NRH SOT26A × × 4.250V 4.100V 2.500V 3.000V 0.150V - - 1.15s 144.0ms 9.0ms - - U01NRH※4 SOT26A × 4.250V 4.100V 2.500V 3.000V 0.150V - - 1.15s 512.0ms 288.0ms - - Z01NRH※3 SOT26A ○ × 4.300V 4.100V 2.000V 2.000V 0.100V 0.180V - 1.00s 12.0ms 256.0ms 2.5ms ※1 Optional functions × ○ : Provided. × - : Not provided. ※2 0V Charge Disabled ※3 The charging overcurrent function cannot be added to the Z01 rank. ※4 Overdischarge release method: voltage release 5 NOTES 【Safety Precautions】 ・ Though Mitsumi Electric Co., Ltd. (hereinafter referred to as "Mitsumi") works continually to improve our product's quality and reliability, semiconductor products may generally malfunction or fail. Customers are responsible for complying with safety standards and for providing adequate designs and safeguards for their hardware, software and systems which minimize risk and avoid situations in which a malfunction or failure of this product could cause loss of human life, bodily injury, or damage to property, including data loss or corruption. Before customers use this product, create designs including this product, or incorporate this product into their own applications, customers must also refer to and comply with (a) the latest versions or all of our relevant information, including without limitation, product specifications, data sheets and application notes for this product and (b) the user’s manual, handling instructions or all relevant information for any products which is to be used, or combined with this products. Customers are solely responsible for all aspects of their own product design or applications, including but not limited to (a) determining the appropriateness of the use of this product in such design or applications; (b) evaluating and determining the applicability of any information contained in this document, or in charts, diagrams, programs, algorithms, sample application circuits, or any other referenced documents; and (c) validating all operating parameters for such designs and applications. Mitsumi assumes no liability for customers’ product design or applications. ・ This product is intended for applying to computers, OA units, communication units, instrumentation units, machine tools, industrial robots, AV units, household electrical appliances, and other general electronic units. 【Precautions for Product Liability Act】 ・ No responsibility is assumed by us for any consequence resulting from any wrong or improper use or operation, etc. of this product. 【ATTENTION】 ・ This product is designed and manufactured with the intention of normal use in general electronics. No special circumstance as described below is considered for the use of it when it is designed. With this reason, any use and storage under the circumstances below may affect the performance of this product. Prior confirmation of performance and reliability is requested to customers. Environment with strong static electricity or electromagnetic wave Environment with high temperature or high humidity where dew condensation may occur ・ This product is not designed to withstand radioactivity, and must avoid using in a radioactive environment. ・ This specification is written in Japanese and English. The English text is faithfully translated into the Japanese. However, if any question arises, Japanese text shall prevail. 6
MM3220H15NRH 价格&库存
很抱歉,暂时无法提供与“MM3220H15NRH”相匹配的价格&库存,您可以联系我们找货
