W83391TG TR
W83391TG TR
    NUVOTON(新唐)
    SOIC14
    有刷直流电机驱动芯片 12.6V
W83391TG TR 数据手册
Nuvoton DC Fan Pre-Driver W83391TG W83391TG W83391TG Data Sheet Revision History VERSION NO PAGES DATES VERSION 1. N.A Sep/04 0.5 N.A. All versions before 0.5 are for internal use and W83391DG/TG/QG are Pb-free package. 2. N.A Jan/06 0.51 N.A Remove W83391DS/DG 3. N.A Jan./06 0.52 N.A Remove W83391QS/QG 4 All Jan./06 0.53 N.A Update the datasheet with new template 5 3 Nov./08 0.54 N.A Modify application application note. 6 1&9 Apr./10 0.55 N.A Update the package information ON WEB -I- MAIN CONTENTS circuit and add Publication Date: Apr., 2010 Revision 0.55 W83391TG Table of Contents1. GENERAL DESCRIPTION ......................................................................................................... 1 2. FEATURES ................................................................................................................................. 1 3. APPLICATIONS .......................................................................................................................... 1 4. PIN CONFIGURATION AND DESCRIPTION ............................................................................ 2 5. APPLICATION CIRCUIT ............................................................................................................. 3 6. INTERNAL BLOCK DIAGRAM ................................................................................................... 4 7. ABSOLUTE MAXIMUM RATINGS ............................................................................................. 5 8. RECOMMENDED OPERATING CONDITIONS ......................................................................... 6 9. ELECTRICAL CHARACTERISTICS ........................................................................................... 6 10. PACKAGE DIMENSION ............................................................................................................. 7 11. ORDERING INFORMATION ...................................................................................................... 9 12. TOP MARKING SPECIFICATION .............................................................................................. 9 -II- Publication Date: Apr., 2010 Revision 0.55 W83391TG 1. GENERAL DESCRIPTION The W83391TG is a DC Fan Pre-Driver which was integrated charge pump to drive external Nchannel MOSFET instead of P-channel MOSFET/ PNP transistor. The W83391TG provides 3 channels Fan Control and easily couples with Super I/O or hardware monitor to perform the control of DC Fans. W83391TG is available in a SOP-14 Pb Free and Halogen Free package. 2. FEATURES z Provides 3 channels Fan Control z Integrated Charge Pump and Can Support Up to 24V Gate Voltage for Driving External Nchannel MOSFET z Pairing with Nuvoton Series Super I/O and Hardware Monitoring IC for DC Fan Voltage Regulation z External Resistors for Output Voltage Scale Adjustment z Provides Pb-free and Halogen Free SOP-14 Package 3. APPLICATIONS z Motherboard, IPC relative Applications z Projector and other DC Fan Control Applications -1- Publication Date: Apr., 2010 Revision 0.55 W83391TG 4. PIN CONFIGURATION AND DESCRIPTION FAN1_IN 1 14 FAN1_DRV FAN2_IN 2 13 FAN1_SEN VCC12 3 12 FAN2_DRV C1 4 11 FAN2_SEN C2 5 10 FAN3_DRV CHRPMP 6 9 FAN3_SEN GND 7 8 FAN3_IN W83391TG W83391TG (Top View) PIN SYMBOL FUNCTION 1 FAN1_IN DC FAN1 Voltage Input Ranging from 0V~8V 2 FAN2_IN DC FAN2 Voltage Input Ranging from 0V~8V 3 VCC12 4 C1 5 C2 6 CHRPMP 7 GND 8 FAN3_IN 9 FAN3_SEN Voltage FB Sensing Pin for 3rd Fan Voltage Regulation 10 FAN3_DRV Voltage Driving Pin for 3rd Fan Voltage Regulation 11 FAN2_SEN Voltage FB Sensing Pin for 2nd Fan Voltage Regulation 12 FAN2_DRV Voltage Driving Pin for 2nd Fan Voltage Regulation 13 FAN1_SEN Voltage FB Sensing Pin for 1st Fan Voltage Regulation 14 FAN1_DRV Voltage Driving Pin for 1st Fan Voltage Regulation 12Vcc Input. Charge Pump Pins. To insure the output voltage achieve to 24V. Power Ground. DC FAN3 Voltage Input Ranging from 0V~8V -2- Publication Date: Apr., 2010 Revision 0.55 W83391TG 5. APPLICATION CIRCUIT 1 VCC12 Q1 N DGS C1 Reserv ed FROM FAN2_OUT 3 2 FROM FAN1_OUT R1 10K TO FAN1 0.1U C4 0.1U 1 2 3 4 5 6 C6 7 FAN1_IN FAN1_DRV FAN2_IN FAN1_SEN VCC12 FAN2_DRV C1 FAN2_SEN C2 FAN3_DRV CHRPMP FAN3_SEN GND FAN3_IN 14 12 C5 Reserv ed 10 8 470u Q2 N DGS 2 11 9 C2 VCC12 13 R3 10K TO FAN2 R4 6.49K W83391TG C7 470u VCC12 1 0.1U R2 6.49K 1 C3 U1 3 VCC12 FROM FAN3_OUT Q3 N DGS 2 3 C8 Reserv ed R5 10K TO FAN3 R6 6.49K C9 470u Note. z PCB Layout Guide The critical IC components (decoupling capacitors, charge pump capacitors, FB resistor dividers) are located next to the IC (or directly under it), with short traces to the IC pins. z Reserved Component Footprints For most situations, no external compensation is required for the linear output. As long as the output capacitor is large (>100µF) and so is its ESR (>20mΩ), then it should be stable for loads as low as 10mA up to at least 4A. If a smaller value of capacitance and/or ESR is desired, then special considerations may be required to add external compensation capacitors and next to external power MOSFET. -3- Publication Date: Apr., 2010 Revision 0.55 W83391TG 6. INTERNAL BLOCK DIAGRAM C1 C2 CHRPMP Charge Pump FAN1_IN FAN2_IN FAN3_IN + _ + _ + _ 24V FAN1_DRV 24V FAN1_SEN FAN2_DRV 24V FAN2_SEN FAN3_DRV FAN3_SEN -4- Publication Date: Apr., 2010 Revision 0.55 W83391TG 7. ABSOLUTE MAXIMUM RATINGS ITEM SYMBOL RATING UNIT VCC12 Input Voltage VCC12 -0.3 to 15 V FANX_IN Input Voltage FANX_IN -0.3 to 15 V Operating Temperature Range T opt 0 to 70 ℃ Human Body Mode ±2 kV Machine Mode ±200 V Latch-Up ±100 mA Electrostatic discharge protection Note: Stresses beyond those listed under "Absolute Maximum Ratings" may cause permanent damage to the device and exposure to absolute maximum rating conditions for extended periods may affect device reliability. -5- Publication Date: Apr., 2010 Revision 0.55 W83391TG 8. RECOMMENDED OPERATING CONDITIONS ITEM DESCRIPTION MIN MAX UNIT VCC12 Input Voltage VCC12 Supply Voltage 11.4 12.6 V FANX_IN Input Voltage FANX_IN DC Fan1, 2, 3 Input Voltage 0 8 V 9. ELECTRICAL CHARACTERISTICS Vcc12=12V ± 5 %, TA = 0°C to +70°C PARAMETER SYMBOL MIN TYP MAX UNITS Input Offset Voltage V IOffset 2 5 50 mV Input Voltage Range FANX_IN 0 - 8 V - 45 - uA 1.5 - 24 V - 180 - KHz 22.8 23.2 24 V TEST CONDITIONS FAN#_IN Input FAN#_DRV Output Output Drive Current Output Voltage Range C OUT = 10nF Charge Pump Charge Pump Frequency Charge Pump Voltage -6- Publication Date: Apr., 2010 Revision 0.55 W83391TG 10. PACKAGE DIMENSION z W83391TG (14pin SOP, 150mil) 8 14 c E HE L 7 1 D 0.25 O A Y SEATING PLANE e GAUGE PLANE A1 b Control demensions are in milmeters . SYMBOL A A1 b c E D e HE Y L θ DIMENSION IN MM MAX. MIN. 1.35 1.75 0.10 0.25 0.51 0.33 0.19 0.25 3.80 4.00 8.75 8.55 1.27 BSC 6.20 5.80 0.10 0.40 1.27 0 8 DIMENSION IN INCH MIN. MAX. 0.053 0.069 0.010 0.004 0.013 0.020 0.008 0.010 0.150 0.157 0.344 0.337 0.050 BSC 0.228 0.016 0 -7- 0.244 0.004 0.050 8 Publication Date: Apr., 2010 Revision 0.55 W83391TG z Taping Specification 14 Pin SOP Package -8- Publication Date: Apr., 2010 Revision 0.55 W83391TG 11. ORDERING INFORMATION PART NUMBER SUPPLIED AS W83391TG T Shape: 2,500 units/T&R PACKAGE TYPE PRODUCTION FLOW 14-pin SOP Commercial, (Green package) 0℃ TO +70℃ 12. TOP MARKING SPECIFICATION W83391TG 212345678 601XY Left line: Winbond/Nuvoton logo 1st line: W83391TG – the part number 2nd line: Chip lot number 3rd line: Tracking code 649 X Y 601: packages assembled in Year 06’, week 01 X: Assembly house ID Y: The IC version -9- Publication Date: Apr., 2010 Revision 0.55 W83391TG Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Further more, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. -10- Publication Date: Apr., 2010 Revision 0.55
W83391TG TR 价格&库存
很抱歉,暂时无法提供与“W83391TG TR”相匹配的价格&库存,您可以联系我们找货
