NSEC00K004-IT
NSEC00K004-IT
    INSIGNIS
    LBGA100
NSEC00K004-IT 数据手册
NSEC Series (MLC) – Product Brief Embedded Multimedia Card (eMMC 5.0 HS400) NSEC Series Embedded Multimedia Card (eMMC) (MLC) Overview Insignis Technology Corporation eMMC products follow the JEDEC eMMC 5.0 standard. It is an ideal universal storage solution for many electronic devices, including embedded, automotive and industrial electronic applications requiring high quality, wide temperature operation and high reliability. eMMC encloses the MLC NAND and eMMC controller inside as one JEDEC standard package, providing a standard interface to the host. The eMMC controller directly manages NAND flash, including ECC, wear-leveling, IOPS optimization and read sensing. Features • • • • • • • • • • • • • • • Packaged NAND flash memory with eMMC 5.0 interface Compliant with eMMC Specification Ver. 4.4, 4.41, 4.5, 5.0 Bus mode o High-speed eMMC protocol o Clock frequency: 0-200MHz. o Ten-wire bus (clock, 1 bit command, 8 bit data bus) and a hardware reset. Supports three different data bus widths: 1 bit (default), 4 bits, 8 bits o Data transfer rate: up to 52Mbyte/s (using 8 parallel data lines at 52 MHz) o Single data rate: up to 200Mbyte/s @ 200MHz o Dual data rate: up to 400Mbyte/s @ 200MHz Operating voltage range: o VCCQ = 1.8 V/3.3 V o VCC = 3.3 V Error free memory access o Internal error correction code (ECC) to protect data communication o Internal enhanced data management algorithm o Solid protection of sudden power failure safe-update operations for data content Security o Support secure bad block erase commands o Enhanced write protection with permanent and partial protection options Quality o RoHS compliant Supports Field Firmware Update (FFU) Enhanced Device Lifetime Support Pre EOL information Optimal Size Supports Production State Awareness Supports Power Off Notification for Sleep Supports HS400 • • Also available in p-SLC mode Temperature range o Operation: 100ball eMMC ▪ Automotive (AT): -40℃ to 105℃ ▪ Industrial (IT): -40℃ to 85℃ ▪ Extended Test (ET): -25℃ to 85℃ 153ball eMMC ▪ Automotive (AT) - MLC only: -40℃ to 105℃ ▪ Automotive (AT) - pSLC only -40℃ to 85℃ ▪ Industrial (IT) - MLC and pSLC: -40℃ to 85℃ o Storage: 100ball eMMC ▪ Automotive (AT): -40℃ to 105℃ ▪ Industrial (IT)/Extended Test (ET): -40℃ to 85℃ 153ball eMMC ▪ Automotive (AT) - MLC only: -40℃ to 125℃ ▪ Automotive (AT) - pSLC only: -40℃ to 85℃ ▪ Industrial (IT) - MLC and pSLC: -40℃ to 85℃ • Component weight: o One unit of 4Gb eMMC 100 ball: 0.54g o One unit of 4Gb eMMC 153 ball: 0.37g • JEDEC Standard Package with a 0.5mm pitch. DISCLAIMER: All product, product specifications, and data are subject to change without notice to improve reliability, function or design, or otherwise. The information provided herein is correct to the best of Insignis Technology Corporation’s knowledge. No liability for any errors, facts or opinions is accepted. Customers must satisfy themselves as to the suitability of this product for their application. No responsibility for any loss as a result of any person placing reliance on any material contained herein will be accepted. NSECxxKv3.0-eMMCbriefMLC-20191030 Insignis Embedded Multimedia Card (eMMC) NSEC Series (MLC) How to Order BGA100 Package Operating voltage Package NAND Option Extended Test MLC Industrial Temperature Automotive Temperature VCC=3.3V, VCCQ=1.8V/3.3V BGA100 Extended Test pSLC Industrial Temperature Automotive Temperature Usable Capacity 4GB 8GB 16GB 32GB 64GB 4GB 8GB 16GB 32GB 64GB 4GB 8GB 16GB 32GB 64GB 2GB 4GB 8GB 16GB 32GB 2GB 4GB 8GB 16GB 32GB 2GB 4GB 8GB 16GB 32GB Insignis Part Number NSEC00K004-ET NSEC00K008-ET NSEC00K016-ET NSEC00K032-ET NSEC00K064-ET NSEC00K004-IT NSEC00K008-IT NSEC00K016-IT NSEC00K032-IT NSEC00K064-IT NSEC00K004-AT NSEC00K008-AT NSEC00K016-AT NSEC00K032-AT NSEC00K064-AT NSEC00K002-ETJ NSEC00K004-ETJ NSEC00K008-ETJ NSEC00K016-ETJ NSEC00K032-ETJ NSEC00K002-ITJ NSEC00K004-ITJ NSEC00K008-ITJ NSEC00K016-ITJ NSEC00K032-ITJ NSEC00K002-ATJ NSEC00K004-ATJ NSEC00K008-ATJ NSEC00K016-ATJ NSEC00K032-ATJ Visit: http://insignis-tech.com/how-to-buy Engineering Specifications are available upon request by emailing info@insignis-tech.com NSECxxKv3.0-eMMCbriefMLC-20191030 2 Insignis Embedded Multimedia Card (eMMC) NSEC Series (MLC) FBGA153 Package Operating voltage Package NAND Option Industrial Temperature MLC Automotive Temperature VCC=3.3V, VCCQ=1.8V/3.3V FBGA153* Industrial Temperature pSLC Automotive Temperature Usable Capacity 4GB 8GB 16GB 4GB 8GB 16GB 2GB 4GB 8GB 2GB 4GB 8GB NEW Insignis Part Number NSEC53K004-IT NSEC53K008-IT NSEC53K016-IT NSEC53K004-AT NSEC53K008-AT NSEC53K016-AT NSEC53K002-ITJ NSEC53K004-ITJ NSEC53K008-ITJ NSEC53K002-ATJ NSEC53K004-ATJ NSEC53K008-ATJ * Only customers who have previously qualified the 153ball MLC 32GB/64GB and 153ball pSLC 16GB/32GB parts can still order these parts. Customers who have not already qualified these parts can order our 3D TLC eMMC as a replacement for these higher capacity MLC/pSLC offerings. Visit: http://insignis-tech.com/how-to-buy Engineering Specifications are available upon request by emailing info@insignis-tech.com NSECxxKv3.0-eMMCbriefMLC-20191030 3
NSEC00K004-IT 价格&库存
很抱歉,暂时无法提供与“NSEC00K004-IT”相匹配的价格&库存,您可以联系我们找货
