IS31FL3726-ZLS2
IS31FL3726-ZLS2
    LUMISSIL
    TSSOP24
    IC LED DVR 16BIT COLOR 24TSSOP
IS31FL3726-ZLS2 数据手册
IS31FL3726 16-BIT COLOR LED DRIVER WITH PWM CONTROL June 2013 GENERAL DESCRIPTION The IS31FL3726 is comprised of constant-current drivers designed for color LEDs. The output current value can be set using an external resistor. The output current value can be adjusted from 5mA to 60mA through the external resistor. As a result, all outputs will have virtually the same current levels. This driver incorporates 16-bit constant t-current outputs, a 16-bit shift register, a 16-bit latch and a 16-bit AND-gate circuit. These drivers have been designed using the CMOS process. Output voltage ≥0.4V APPLICATIONAS    FEATURES  Output current capability and number of outputs: 60mA × 16 outputs  Constant current range: 5mA to 60mA  Application output voltage: ≥0.4V  For anode-common LEDs  Power supply voltage range, VDD = 3.3V to 5.5V  Serial and parallel data transfer rate: 20MHz (Max. cascade connection)  Operating temperature range, TA = −40°C ~ +85°C  Package: QFN-24 and TSSOP-24  Current accuracy (All output on) Current Accuracy Between Bits Between ICs ±4% ±20% Output Current 5mA ~ 60mA Cellular phones MP3/MP4/CD/minidiskplayers Toys BLOCK DIAGRAM Figure 1 Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 Block Diagram 1 IS31FL3726 TYPICAL APPLICATION CIRCUIT LDO 3.3V Vbat VDD 0.1uF O1 O2 MICROCONTROLLER O3 . .. .. . SERIAL-IN ENABLE LATCH O14 O15 GND REXT CLOCK O16 R1=2kohm(tpy.) Figure 2 Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 Typical Application Figure 2 IS31FL3726 PIN CONFIGURATION 19 OUT11 20 OUT12 21 OUT13 22 OUT14 23 OUT15 Pin Configuration (Top View) 24 ENABLE Package SERIAL-OUT 1 17 OUT9 CLOCK 6 13 OUT5 OUT4 12 14 OUT6 OUT3 11 SERIAL-IN 5 OUT2 10 15 OUT7 OUT1 9 16 OUT8 OUT0 8 VDD 3 GND 4 LATCH 7 QFN-24 18 OUT10 R-EXT 2 TSSOP-24 Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 3 IS31FL3726 PIN DESCRIPTION No. Pin Description 22 SERIAL-OUT Output terminal for serial data input on SERIAL-IN terminal. 2 23 R-EXT Input terminal used to connect an external resistor. This regulated the output current. 3 24 VDD Supply voltage terminal. 4 1 GND GND terminal for control logic. 5 2 SERIAL-IN Input terminal for serial data for data shift register. 6 3 CLOCK Input terminal for clock for data shift on rising edge. 7 4 ———————— 8 ~ 23 5~20 —————— 21 ————————— QFN TSSOP 1 ———————— LATCH ——————— OUT0 ~OUT15 Input terminal for data strobe When the L A T C H input is driven High, data is not latched. When it is pulled Low ,data is latched. Constant-current output terminals. Input terminal for output enable. —————— 24 ENABLE Thermal Pad ——————— All outputs (OUT0 to OUT15) are turned off, when ————————— the ENABLE terminal is driven High .And are turned on, when the terminal is driven Low. Connect to GND. Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 4 IS31FL3726 ORDERING INFORMATION Industrial Range: -40°C to +85°C Order Part No. Package QTY/Reel IS31FL3726-QFLS2-TR IS31FL3726-ZLS2-TR IS31FL3726-ZLS2 QFN-24, Lead-free 2500/Reel 2500/Reel 62/Tube TSSOP-24, Lead-free Copyright © 2013 Integrated Silicon Solution, Inc. All rights reserved. ISSI reserves the right to make changes to this specification and its products at any  time without notice. ISSI assumes no liability arising out of the application or use of any information, products or services described herein. Customers are  advised to obtain the latest version of this device specification before relying on any published information and before placing orders for products.  Integrated Silicon Solution, Inc. does not recommend the use of any of its products in life support applications where the failure or malfunction of the  product can reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not  authorized for use in such applications unless Integrated Silicon Solution, Inc. receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Integrated Silicon Solution, Inc is adequately protected under the circumstances Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 5 IS31FL3726 n=0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 H CLOCK L H SERIAL-IN L H L LATCH H ENABLE L ON OUT0 OFF ON OFF OUT1 ON OUT2 OFF ON OFF OUT15 H SERIAL-OUT L Timing Dagram Figure 3 Warning: Latch circuit is leveled-latch circuit. Be careful because it is not triggered-latch circuit. ———————— ———————— Note : The latches circuit holds data by pulling the L A T C H terminal Low. And, when L A T C H terminal is a High level, latch circuit ————————— —————— ——————— doesn’t hold data, and it passes from the input to the output. When E N A B L E terminal is a Low level, output terminal O U T 0 to O U T 1 5 ————————— respond to the data, and on and off does. And, when E N A B L E terminal is a High level, it offs with the output terminal regardless of the data. Truth Table CLOCK ————— ———————— ————————— ENABLE SERIAL-IN H L L —————— —————— ——————— OUT0 …OUT7 … OUT15 SERIAL-OUT Dn Dn …Dn-7 …Dn-15 Dn-15 L Dn+1 No change Dn-14 H L Dn+2 Dn+2 …Dn-5 …Dn-13 Dn-13 X L Dn+3 Dn+2 …Dn-5 …Dn-13 Dn-13 X H Dn+3 OFF Dn-13 LATCH ————— ————— ————— Note : OUT0 to OUT15 =On when Dn = H; OUT0 to OUT15 =Off when Dn = L. In order to ensure that the level of the power supply voltage is correct, an external resistor must be connected between R-EXT and GND. ____________ __________ Warning: The following conditions, ENABLE =0, LATCH =1, SERIAL-IN=1, cannot be configured at the same time when power on, or IS31FL3726 will be abnormal. Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 6 IS31FL3726 ABSOLUTE MAXIMUM RATINGS Supply voltage, VDD Voltage at any input pin Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA -0.3V ~ +6.0V -0.3V ~ VDD+0.2V 150°C -65°C ~ +150°C −40°C ~ +85°C Note: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. RECOMMENDED OPERATING CONDITION TA = 25°C, unless otherwise specified. Symbol VOUT fCLK twLAT twCLK twENA tSETUP1 tHOLD tSETUP2 Characteristic Condition Min. Output voltage Clock frequency (Note 1) Cascade connected ———————— L A T C H pulse width CLOCK pulse width ————————— ENABLE pulse width (Note 1,2) Typ. Max. Unit 0.7 4 V 20 MHz 50 ns 25 ns Upper IOUT = 20mA 20 Lower IOUT = 20mA 20 µs Set-up time for CLOCK terminal 10 ns Hold time for CLOCK terminal 10 ns 50 ns ———————— Set-up time for L A T C H terminal Note 1: Guaranteed by design. ————————— Note 2: When the pulse of the Low level is input to the E N A B L E terminal held in the High level. Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 7 IS31FL3726 ELECTRICAL CHARACTERISTICS TA = 25°C, VDD = 3.3V ~ 5.5V, unless otherwise specified. Symbol VDD Characteristic Supply voltage IOUT1 Output current IOZ VIH VIL Output current between bits error Output leakage current input voltage SOUT terminal voltage VOH %/VDD R(Up) R(Down) IDD(OFF)2 IDD(ON)1 Unit 5.5 V 15 18.7 22 15 18.9 22 ±3 ±4 % 1 uA VOUT≥0.4V, All outputs on REXT = 1kΩ mA REXT = 1kΩ VOUT = 5.0V 1.4 0.4 IOL = 1.0mA, VDD = 3.3V 0.3 IOL = 1.0mA, VDD = 5V 0.3 IOH = -1.0mA, VDD = 3.3V Output current supply voltage regulation When VDD is changed 3.3V to 5.5V Pull-up resistor ————————— Pull-down resistor ———————— Supply current Max. VOUT = 0.4V VDD = 3.3V IOH = -1.0mA, VDD = 5V IDD(OFF)1 Typ. 3.3 Input voltage VOL Min. Normal operation VOUT = 0.4V VDD = 5.5V IOUT2 △IOUT1 Condition ENABLE terminal L A T C H terminal VOUT = 5V REXT = OPEN 3 V 4.7 -1 250 500 % 750 kΩ 1 VOUT = 5V All outputs off REXT = 1kΩ 4.5 VOUT = 0.7V All outputs on REXT = 1kΩ 5 Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 V mA 8 IS31FL3726 SWITCHING CHARACTERISTICS TA = 25°C, unless otherwise specified. Symbol Characteristic Condition —————— Typ. Max. 80 200 ————————— 80 200 ———————— 2000 CLK-OUTn , L A T C H = “H” tpLH1 ————————— ENABLE = “L” tpLH2 ———————— tpLH3 ————————— —————— tpLH Min. —————— L A T C H –OUTn , ENABLE = “L” Propagation delay tpHL1 ENABLE -OUTn , L A T C H = “H” CLK-SERIAL OUT —————— 3 5 ns ———————— CLK-OUTn , L A T C H = “H” ————————— ENABLE = “L” 160 250 tpHL2 ———————— —————— L A T C H -OUTn , ENABLE = “L” ————————— 160 250 tpHL3 ————————— —————— ———————— 200 350 tpLH Unit ———————— ENABLE -OUTn , L A T C H = “H” CLK-SERIAL OUT 4 6 tor Output rise time 10%~90% of voltage waveform 30 150 200 ns tof Output fall time 90%~10% of voltage waveform 150 200 250 ns tr Maximum CLOCK rise time 5 us tf Maximum CLOCK fall time 5 us When not on PCB (Note) Conditions: (Refer to test circuit.) Topr = 25°C, VDD=VIH =3.3V and 5V, VOUT = 0.7V, VIL =0V, REXT =1000Ω, VL =3.0V, RL=60Ω, CL=10.5pF Note: 1. If the device is connected in a cascade and tr/tf for the waveform is large, it may not be possible to achieve the timing required for data transfer. Please consider the timings carefully. 2. Delay between outputs. The IS31FL3726 has graduated delay circuits between outputs. The fixed delay time is 5ns (typical), OUT1 has 5ns delay, OUT2 has 10 ns delay, etc. This delay prevents large inrush currents, which reduce power supply bypass capacitor requirements when ——————— the outputs turn on. The delay works during switch on and switch off of each output channel. LEDs that have not turned on before ENABLE is ——————— low will still turn on and off at the determined delayed time regardless of the state of ENABLE. Therefore, every LED will be illuminated for the ——————— amount of time ENABLE is pulled high. Figure 4 Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 Test Diagram 9 IS31FL3726 TIMING WAVEFORM 1.CLOCK, SERIAL-IN,SERIAL-OUT ———————— —————————— —————— 2. CLOCK, SERIAL-IN, L A T C H , E N A B L E , OUTn —————— 3. OUTn Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 10 IS31FL3726 TYPICAL OPERATING CHARACTERISTICS ADJUSTING OUTPUT CURRENT The output current of each channel is set by an external resistor Rext, the relationship between Iout and Rext is: Iout = (VR-ext/Rext)×52 the VR-ext is 0.36V in the IS31FL3726,so we can count the Iout as : Iout = 0.36×52/Rext. As show in the figure below: 50 -40°C 45 25°C 85°C LED current(mA) 40 35 30 25 20 15 10 400 600 800 1000 1200 1400 1600 Rset(Ω) Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 11 IS31FL3726 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 5 Classification Profile Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 12 IS31FL3726 PACKAGE INFORMATION QFN-24 Note: All dimensions in millimeters unless otherwise stated. Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 13 IS31FL3726 TSSOP-24 Note: All dimensions in millimeters unless otherwise stated. Integrated Silicon Solution, Inc. — www.issi.com Rev.B, 06/18/2013 14
IS31FL3726-ZLS2 价格&库存
很抱歉,暂时无法提供与“IS31FL3726-ZLS2”相匹配的价格&库存,您可以联系我们找货
