SLG5NT1593V
SLG5NT1593V
    DIALOGSEMICONDUCTOR(戴乐格)
    UFDFN4
    IC PWR SWITCH P-CHAN 1:1 4STDFN
SLG5NT1593V 数据手册
SLG5NT1593V Ultra-small 28.5 mΩ 1.0 A GreenFET 3 Load Switch with Discharge General Description Pin Configuration ON 1 Features VIN 2 • One 1.0 A MOSFET • Ultra Low Quiescent Current • Low RDSON • 28.5 mΩ @ 5.0 V • 36.4 mΩ @ 3.3 V • 44.3 mΩ @ 2.5 V • 60.8 mΩ @ 1.8 V • 77.6 mΩ @ 1.5 V • VIN = 1.5 V to 5.5 V • Integrated Discharge Resistor • Pb-Free / Halogen-Free / RoHS compliant • STDFN 4L, 1.0 x 1.0 x 0.55 mm SLG5NT1593V The SLG5NT1593V is designed for load switching applications with ultra low quiescent current. The part comes with one 28.5 mΩ 1.0 A rated P-channel MOSFET controlled by a single ON control pin. The product is packaged in an ultra-small 1.0 x 1.0 mm package. 4 GND 3 VOUT 4-pin STDFN (Top View) Block Diagram VOUT VIN 1.0 A ON Silego Technology, Inc. 000-005NT1593-10 Fixed Slew Rate Control Rev 1.0 Revised September 23, 2014 SLG5NT1593V Pin Description Pin # Pin Name Type Pin Description 1 ON Input Turns on MOSFET. 2 VIN MOSFET 3 VOUT MOSFET 4 GND GND Power MOSFET input Power MOSFET output Ground Ordering Information Part Number Type Production Flow SLG5NT1593V STDFN 4L Industrial, -40 °C to 85 °C SLG5NT1593VTR STDFN 4L (Tape and Reel) Industrial, -40 °C to 85 °C 000-005NT1593-10 Page 2 of 9 SLG5NT1593V Absolute Maximum Ratings Parameter VDD TS ESDHBM WDIS Description Conditions Min. Typ. Max. Unit -- -- 6 V -65 -- 140 °C 2000 -- -- V -- -- 0.5 W -- -- 1.5 A Power Supply Storage Temperature ESD Protection Human Body Model Package Power Dissipation MOSFET IDSPK Peak Current from Drain to Source For no more than 1 ms with 1% duty cycle Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics TA = -40 °C to 85 °C (unless otherwise stated) Parameter VIN IDD Description Power Supply Voltage Power Supply Current (PIN 2) Conditions -40 °C to 85 °C Min. -- 5.5 V -- 0.02 0.1 μA when ON = VIN, No load -- 0.05 0.5 μA 0.05 1 μA Leakage Measured from Pin2 to Pin3 when OFF, VIN = 5.5 V -- ON Pin Input Leakage RDSON IDS TON_Delay TTotal_ON Static Drain to Source ON Resistance @ TA 85°C Operating Current ON pin Delay Time Total Turn On Time 000-005NT1593-10 Unit 1.5 IDS_LKG Static Drain to Source ON Resistance @ TA 25°C Max. when OFF, VIN = 5.5 V ION_LKG RDSON Typ. -- -- 0.1 μA @ 5.5 V -- 28.5 32.0 mΩ @ 3.3 V -- 36.4 40.0 mΩ @ 2.5 V -- 44.3 49.0 mΩ @ 1.8 V -- 60.8 65.0 mΩ @ 1.5 V -- 77.6 82.0 mΩ @ 5.5 V -- 34.0 36.0 mΩ @ 3.3 V -- 43.8 46.0 mΩ @ 2.5 V -- 53.3 56.0 mΩ @ 1.8 V -- 72.2 76.0 mΩ @ 1.5 V -- 90.7 94.0 mΩ VIN = 1.5 V to 5.5 V -- -- 1.0 A 50% ON to Ramp Begin VIN = 5 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 12.0 15.0 18.5 μs 50% ON to Ramp Begin VIN = 3.3 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 17.0 22.0 30.0 μs 50% ON to Ramp Begin VIN = 1.5 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 44.0 55.0 76.0 μs 50% ON to 90% VOUT VIN = 5 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 114 122 134 μs 50% ON to 90% VOUT VIN = 3.3 V, VOUT_Cap = 0.1 μF, RL = 10Ω 146 156 176 μs 50% ON to 90% VOUT VIN = 1.5 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 292 332 399 μs Page 3 of 9 SLG5NT1593V TA = -40 °C to 85 °C (unless otherwise stated) Parameter TRISE Description Rise Time Conditions Min. Typ. Max. Unit 10% VOUT to 90% VOUT VIN = 5.0 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 92 97 107 μs 10% VOUT to 90% VOUT VIN = 3.3 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 116 120 131 μs 10% VOUT to 90% VOUT VIN = 1.5 V, VOUT_Cap = 0.1 μF, RL = 10 Ω 228 253 296 μs VIN = 1.5 V to 5.5 V, VOUT = 0.4 V Input Bias 65 80 400 Ω RDIS Discharge Resistance ON_VIH Initial Turn On Voltage 0.85 -- VIN V ON_VIL Low Input Voltage on ON pin -0.3 0 0.3 V 6.2 6.5 7.0 μs TDelay_OFF OFF Delay Time 000-005NT1593-10 50% ON to VOUT Fall, VIN = 5 V, RL =10 Ω Page 4 of 9 SLG5NT1593V VIN vs. Max IDS, Safe Operation Area Safe Operation Area VIN vs. Max IDS 8 7 6 5 VIN 4 SOA Boundary 3 2 1 0 0 0.5 1 1.5 2 Max IDS 000-005NT1593-10 Page 5 of 9 SLG5NT1593V TTotal_ON, TON_Delay and Slew Rate Measurement ON 50% ON 50% ON TOFF_DELAY 90% VOUT VOUT 90% VOUT TON_DELAY 10% VOUT 10% VOUT TRISE TFALL TTotal_ON SLG5NT1593V Layout Suggestion 800 Recommended Land Pattern 210 Unit: μm 410 810 190 Exposed Pad 200 1800 000-005NT1593-10 Page 6 of 9 SLG5NT1593V Package Top Marking System Definition Pin 1 Identifier 000-005NT1593-10 XX Serial Number Page 7 of 9 SLG5NT1593V Package Drawing and Dimensions 4 Lead STDFN Package 1.0 x 1.0 mm 000-005NT1593-10 Page 8 of 9 SLG5NT1593V Tape and Reel Specifications Max Units Leader (min) Nominal Reel & Package # of Package Size Hub Size Length Type Pins per Reel per Box Pockets [mm] [mm] [mm] STDFN 4L Green 4 1.0 x 1.0 x 0.55 8000 8000 178 / 60 200 400 Trailer (min) Pockets Length [mm] Tape Width [mm] 200 400 8 Part Pitch [mm] 2 Carrier Tape Drawing and Dimensions Pocket BTM Pocket BTM Package Length Width Type STDFN 4L Green Pocket Depth Index Hole Pitch Pocket Pitch Index Hole Diameter Index Hole Index Hole to Tape to Pocket Tape Width Edge Center A0 B0 K0 P0 P1 D0 E F W 1.16 1.16 0.63 4 2 1.5 1.75 3.5 8 Refer to EIA-481 specification Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 0.55 mm3 (nominal). More information can be found at www.jedec.org. 000-005NT1593-10 Page 9 of 9
SLG5NT1593V 价格&库存
很抱歉,暂时无法提供与“SLG5NT1593V”相匹配的价格&库存,您可以联系我们找货
