IS31LT3353
40V/1A BUCK LED DRIVER WITH INTERNAL SWITCH
May 2015
GENERAL DESCRIPTION
FEATURES
The IS31LT3353 is a continuous mode inductive
step-down converter, designed for driving a single
LED or multiple series connected LEDs efficiently
from a voltage source higher than the LED voltage.
The chip operates from an input supply between 6V
and 40V and provides an externally adjustable output
current of up to 1A.
The IS31LT3353 includes an integrated output
switch and a high-side output current sensing circuit,
which uses an external resistor to set the nominal
average output current.
The output current can be dynamically adjusted by
adding either a digital PWM or analog voltage level
signal to the ADJ pin. A PWM signal will provide a
gated output current while a voltage signal will
generate a continuously linear output current.
Applying a voltage less than 0.2V to the ADJ pin
turns the output off and switches the chip into a low
current standby state.
The chip is assembled in SOT23-5 and SOT89-5
packages. It operates from 6V to 40V over the
temperature range of -40°C to +125°C.
Up to 1A output current
High efficiency (up to 97% )
Wide input voltage range: 6V to 40V
Internal 40V power switch
Simple low parts count
Typical 3% output current accuracy
Single pin on/off and brightness control using
DC voltage or PWM
Up to 1MHz switching frequency
Inherent LED open-circuit/short-circuit
protection
Thermal shutdown protection circuitry
Up to 1200: 1 dimming rate
APPLICATIONS
LED MR16, MR11 spot light
LED street light
PAR light
Industrial lighting
Refrigeration lights
Other LED lighting
TYPICAL APPLICATION CIRCUIT
Figure 1
Typical Application Circuit
Note: The capacitor, C2, can’t be removed. And it should be placed as close as possible to the VIN and GND pins, otherwise the operation
might be abnormal.
Lumissil Microsystems – www.lumissil.com
Rev. B, 05/20/2015
1
IS31LT3353
PIN CONFIGURATION
Package
Pin Configuration
SOT23-5
SOT89-5
LX
1
GND
2
ADJ
3
5
VIN
Thermal Pad
4
ISENSE
PIN DESCRIPTION
No.
Pin
Description
1
LX
Drain of power switch.
2
GND
SOT23-5 SOT89-5
3
4
5
Ground (0V).
Multi-function On/Off and brightness control pin:
* Leave floating for normal operation.(VADJ = VREF = 1.2V
giving nominal average output current IOUT_NOM =0.1/RS)
* Drive to voltage below 0.2V to turn off output current.
* Drive with DC voltage (0.3V
IS31LT3353-STLS4-TR 价格&库存
很抱歉,暂时无法提供与“IS31LT3353-STLS4-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.793541+0.88245
- 10+4.8152110+0.62547
- 25+4.3248325+0.56178
- 100+3.78700100+0.49192
- 250+3.53128250+0.45870
- 500+3.37711500+0.43867
- 1000+3.250111000+0.42218
- 国内价格 香港价格
- 3000+3.093273000+0.40180
- 6000+3.016516000+0.39183
- 9000+2.978079000+0.38684
- 15000+2.9354515000+0.38130
- 21000+2.9105621000+0.37807
- 30000+2.8866230000+0.37496
