IS32LT3175N-GRLA3-TR 数据手册
IS32LT3175N/P
SINGLE CHANNEL LINEAR LED DRIVER WITH FADE IN/OUT AND PWM DIMMING
July 2016
GENERAL DESCRIPTION
FEATURES
The IS32LT3175 is a single channel linear
programmable current regulator capable of up to
150mA. It integrates a debounce and latch circuit on
the channel enable pin (EN) to facilitate the use of a
low cost momentary contact switch. The PWM pin can
be interfaced to a logic level “courtesy light” signal to
directly drive the LED channel. The IS32LT3175P
accepts a positive polarity PWM signal while the
IS32LT3175N accepts a negative polarity PWM signal.
The device operates as a stand-alone LED driver
configurable with external resistors; no microcontroller
is required. A single external resistor programs the
current level, while two separate resistors
independently program the fade in and fade out ramp
rate for the channel.
The device integrates a 63 steps fade in and fade out
algorithm (Gamma correction) which causes the output
LED current to gradually ramp up to the full source
value after the EN pin is pulsed. The same controller
causes the LED current to gradually ramp down to
zero if the EN pin is pulsed while the output channel is
ON. The fade ramp can be interrupted mid-cycle
before completion of the ramp cycle. The EN pin will
accept either a momentary contact switch or logic level
signal pulsed low.
The IS32LT3175 is targeted at the automotive market
with end applications to include map and dome lighting
as well as exterior accent lighting. For 12V automotive
applications the low dropout driver can support 1 to 3
LEDs (VF = 3.2V) per channel. It is offered in a small
thermally enhanced SOP-8-EP package.
Operating voltage 5V to 42V
Single channel current source
- Programmable current via a single external
resistor
- Configurable from 20mA to 150mA
Momentary contact button EN input
- Input is debounced and latched
- Higher priority than PWM input
- Gamma corrected Fade In/Out algorithm
- Pull down resistors set independent fade IN and
OUT ramp time
PWM input pin driven by external PWM source
- PWM directly drives the current source
- IS32LT3175P – Positive polarity
- IS32LT3175N – Negative polarity
Fault Protection:
- OUT pin shorted to GND
- ISET pin shorted to GND
- Over temperature
SOP-8-EP package
Automotive Grade:
- IS32LT3175P – AEC-Q100
- IS32LT3175N – AEC-Q100
Operating temperature range from -40°C ~ +125°C
APPLICATIONS
Automotive Interior:
- Map/Dome light
- Puddle lamp in doors
- Glove box
- Vanity mirror
TYPICAL APPLICATION CIRCUIT
Figure 1
Typical Application Circuit
Note: The resistor RPWM is a fixed value. Please don’t change it. CPWM is optional. Add it for robust electromagnetic susceptibility.
Lumissil Microsystems – www.lumissil.com
Rev.A, 07/19/2016
1
IS32LT3175N/P
PIN CONFIGURATION
Package
Pin Configuration (Top view)
SOP-8-EP
PIN DESCRIPTION
No.
Pin
Description
1
EN
Internally debounced input pin for control of LED current. A
negative going pulse on this pin will toggle the state of the OUT
current. The pin condition is constantly monitored after the
debounce time period.
2
ISET
Output current setting for channel. Connect a resistor between
this pin and GND to set the maximum output current.
3
TSET_UP
Timing control for the Fade In feature. Connect a resistor
between this pin and GND to set the Fade In time. Connect this
pin directly to ground to disable the fade function for instant ON.
4
TSET_DN
Timing control for the Fade Out feature. Connect a resistor
between this pin and GND to set the Fade Out time. Connect
this pin directly to ground to disable the fade function for instant
OFF.
5
GND
Ground pin for the device.
6
OUT
Output current source channel.
7
VCC
Power supply input pin. A capacitor on this pin will help maintain
EN latch status during low voltage conditions.
PWM
PWM (or BCM) signal via a 10kΩ to drive OUT pin. Pin
condition is ignored if EN pin has latched and activated OUT
pin. IS32LT3175P positive polarity, IS32LT3175N negative
polarity.
Thermal Pad
Connect to GND.
8
Rev.A, 07/19/2016
2
IS32LT3175N/P
ORDERING INFORMATION
Automotive Range: -40°C to +125°C
Order Part No.
Package
QTY/Reel
IS32LT3175P-GRLA3-TR
SOP-8-EP, Lead-free
2500
Copyright © 2016 Lumissil Microsystems. All rights reserved. Lumissil Microsystems reserves the right to make changes to this specification and its
products at any time without notice. Lumissil Microsystems assumes no liability arising out of the application or use of any information, products or
services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and
before placing orders for products.
Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can
reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in
such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:
a.) the risk of injury or damage has been minimized;
b.) the user assume all such risks; and
c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances
Rev.A, 07/19/2016
3
IS32LT3175N/P
ABSOLUTE MAXIMUM RATINGS
VCC, OUT, PWM
EN, ISET, TSET_UP, TSET_DN
Ambient operating temperature, TA=TJ
Maximum continuous junction temperature, TJ(MAX)
Storage temperature range, TSTG
Maximum power dissipation, PDMAX
ESD (HBM)
ESD (CDM)
-0.3V ~ +45V
-0.3V ~ +7.0V
-40°C ~ +125°C
150°C
-55°C ~ +150°C
1.96W
±2kV
±750V
Note: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings
only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the
specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
THERMAL CHARACTERISTICS
Characteristic
Test Conditions
Value
Package Thermal Resistance
(Junction to Ambient), θJA
On 4-layer PCB based on JEDEC standard
at 1W, TA=25°C
50.98°C/W
(Junction to Pad), θJP
2.24°C/W
ELECTRICAL CHARACTERISTICS
TJ = -40°C ~ +125°C, VCC=12V, refer to each condition description. Typical values are at TJ = 25°C.
Symbol
Parameter
VCC
Supply voltage range
VDO
Minimum dropout
voltage
Condition
tON
Quiescent supply
current
Startup time
IOUT_LIM Output limit current
IOUT
EOUT
Output current
(Note 3)
Absolute current
accuracy (Note 3)
Typ.
5
Max. Unit
42
V
VCC –VOUT, IOUT= -150mA (Note 1)
900
mV
VCC –VOUT, IOUT= -100mA (Note 2)
700
mV
1
mA
PWM pin floating. EN disables the output.
ICC
Min.
0.1
RISET=15kΩ, EN enable the output, PWM floating,
OUT floating
2.3
3.8
mA
VCC=4.2V, EN enable the output. VPWM=4V for
IS32LT3175P and VPWM=GND for IS32LT3175N.
0.25
0.6
mA
400
μs
VCC> 6V to IOUT
IS32LT3175N-GRLA3-TR 价格&库存
很抱歉,暂时无法提供与“IS32LT3175N-GRLA3-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+12.451511+1.55740
- 10+9.0709010+1.13457
- 25+8.2163025+1.02767
- 100+7.28456100+0.91113
- 250+6.83868250+0.85537
- 500+6.57036500+0.82181
- 1000+6.349421000+0.79417
- 国内价格 香港价格
- 2500+6.116112500+0.76499
