TH58BVG2S3HBAI4
TH58BVG2S3HBAI4
    KIOXIA(铠侠)
    VFBGA63
    4 GBIT CMOS NAND E²PROM
TH58BVG2S3HBAI4 数据手册
TH58BVG2S3HBAI4 TOSHIBA MOS DIGITAL INTEGRATED CIRCUIT SILICON GATE CMOS 4 GBIT (512M 2 8 BIT) CMOS NAND E PROM DESCRIPTION The TH58BVG2S3HBAI4 is a single 3.3V 4 Gbit (4,429,185,024 bits) NAND Electrically Erasable and Programmable Read-Only Memory (NAND E2PROM) organized as (2048 64) bytes 64 pages 4096 blocks. The device has a 2112-byte static register which allows program and read data to be transferred between the register and the memory cell array in 2112-bytes increments. The Erase operation is implemented in a single block unit (128 Kbytes 4 Kbytes: 2112 bytes 64 pages). The TH58BVG2S3HBAI4 is a serial-type memory device which utilizes the I/O pins for both address and data input/output as well as for command inputs. The Erase and Program operations are automatically executed making the device most suitable for applications such as solid-state file storage, voice recording, image file memory for still cameras and other systems which require high-density non-volatile memory data storage. The TH58BVG2S3HBAI4 has ECC logic on the chip and 8bit read errors for each 528Bytes can be corrected internally. FEATURES Organization Memory cell array Register Page size Block size x8 2112 128K 8 x 2 2112 8 2112 bytes (128K 4K) bytes Modes Read, Reset, Auto Page Program, Auto Block Erase, Status Read, Page Copy, Multi Page Read, Multi Page Program, Multi Block Erase, ECC Status Read Mode control Serial input/output Command control Number of valid blocks Min 4016 blocks Max 4096 blocks Power supply VCC 2.7V to 3.6V Access time Cell array to register 40 s typ. (Single Page Read) / 55us typ. (Multi Page Read) Serial Read Cycle 25 ns min (CL=50pF) Program/Erase time Auto Page Program Auto Block Erase 330 s/page typ. 2.5 ms/block typ. Operating current Read (25 ns cycle) Program (avg.) Erase (avg.) Standby 30 mA max. 30 mA max 30 mA max 100 A max Package P-TFBGA63-0911-0.80CZ (Weight: 0.154 g typ.) 8bit ECC for each 528Byte is implemented on the chip. 1 2014-03-15C TH58BVG2S3HBAI4 PIN ASSIGNMENT (TOP VIEW) 1 2 A NC NC B NC 3 C 4 ALE D NC E NC F 5 6 7 8 9 10 NC NC NC NC VSS CLE NC NC NC NC NC NC NC NC NC NC NC NC NC NC G NC NC NC NC NC NC H NC I/O1 NC NC NC VCC J NC I/O2 NC VCC I/O6 I/O8 K VSS I/O3 I/O4 I/O5 I/O7 VSS L NC NC NC NC M NC NC NC NC PIN NAMES I/O1 to I/O8 I/O port Chip enable Write enable Read enable CLE Command latch enable ALE Address latch enable Write protect Ready/Busy VCC Power supply VSS Ground NC No Connection 2 2014-03-15C TH58BVG2S3HBAI4 BLOCK DIAGRAM ECC Logic Data register 1 VCC VSS Status register Address register I/O1 Column buffer I/O Control circuit to Column decoder I/O8 Command register Data register 0 Sense amp CLE ALE Logic control Control circuit Memory cell array HV generator ABSOLUTE MAXIMUM RATINGS SYMBOL RATING VALUE UNIT VCC Power Supply Voltage 0.6 to 4.6 V VIN Input Voltage 0.6 to 4.6 V VI/O Input /Output Voltage PD Power Dissipation 0.3 W TSOLDER Soldering Temperature (10 s) 260 °C TSTG Storage Temperature 55 to 150 °C TOPR Operating Temperature -40 to 85 °C CAPACITANCE *(Ta SYMB0L 0.6 to VCC 25°C, f V 1 MHz) PARAMETER CONDITION CIN Input VIN COUT Output VOUT * 0.3 ( 4.6 V) 0V 0V MIN MAX UNIT 20 pF 20 pF This parameter is periodically sampled and is not tested for every device. 3 2014-03-15C TH58BVG2S3HBAI4 VALID BLOCKS SYMBOL NVB PARAMETER MIN Number of Valid Blocks NOTE: TYP. 4016 MAX UNIT 4096 Blocks The device occasionally contains unusable blocks. Refer to Application Note (13) toward the end of this document. The first block (Block 0) is guaranteed to be a valid block at the time of shipment. The specification for the minimum number of valid blocks is applicable over lifetime The number of valid blocks is on the basis of single plane operations, and this may be decreased with two plane operations. RECOMMENDED DC OPERATING CONDITIONS SYMBOL PARAMETER MIN VCC Power Supply Voltage VIH High Level input Voltage Vcc x 0.8 VIL Low Level Input Voltage 0.3* TYP. 2.7 MAX UNIT 3.6 V VCC 0.3 V Vcc x 0.2 V 2 V (pulse width lower than 20 ns) * DC CHARACTERISTICS (Ta SYMBOL -40 to 85 , VCC PARAMETER 2.7 to 3.6V) CONDITION MIN TYP. UNIT 20 A 20 A 30 mA IIL Input Leakage Current VIN ILO Output Leakage Current VOUT ICCO1 Serial Read Current ICCO2 Programming Current 30 mA ICCO3 Erasing Current 30 mA ICCS Standby Current 100 A VOH High Level Output Voltage IOH VOL Low Level Output Voltage IOL 0.1 mA Output current of pin VOL 0.2 V IOL ( ) 0 V to VCC MAX 0 V to VCC VIL, IOUT VCC 0 mA, tcycle 0.2 V, 0.1 mA 25 ns 0 V/VCC, Vcc V 0.2 0.2 4 4 V mA 2014-03-15C TH58BVG2S3HBAI4 AC CHARACTERISTICS AND RECOMMENDED OPERATING CONDITIONS (Ta -40 to 85 , VCC 2.7 to 3.6V) SYMBOL PARAMETER MIN MAX UNIT tCLS CLE Setup Time 12 ns tCLH CLE Hold Time 5 ns 20 ns tCS tCH Setup Time 5 ns tWP Write Pulse Width Hold Time 12 ns tALS ALE Setup Time 12 ns tALH ALE Hold Time 5 ns tDS Data Setup Time 12 ns tDH Data Hold Time 5 ns tWC Write Cycle Time 25 ns tWH High Hold Time 10 ns tWW High to Low 100 ns tRR Ready to Falling Edge 20 ns tRW Ready to Falling Edge 20 ns tRP Read Pulse Width 12 ns tRC Read Cycle Time 25 ns tREA Access Time 20 ns tCEA Access Time 25 ns tCLR CLE Low to Low tAR ALE Low to Low 10 ns 10 ns tRHOH High to Output Hold Time 25 ns tRLOH Low to Output Hold Time 5 ns tRHZ High to Output High Impedance 60 ns tCHZ High to Output High Impedance 20 ns tCSD High to ALE or CLE Don t Care 0 ns tREH High Hold Time 10 ns 0 ns 30 ns 30 ns 60 ns tIR Output-High-impedance-to- tRHW High to tWHC High to tWHR High to tWB High to Busy tRST Falling Edge Low Low Low Device Reset Time (Ready/Read/Program/Erase) 100 ns 5/5/10/500 s *1: tCLS and tALS can not be shorter than tWP *2: tCS should be longer than tWP + 8ns. 5 2014-03-15C TH58BVG2S3HBAI4 AC TEST CONDITIONS CONDITION PARAMETER VCC: 2.7 to 3.6V Input level Vcc-0.2V, 0.2V Input pulse rise and fall time 3 ns Input comparison level Vcc / 2 Output data comparison level Vcc / 2 Output load Note: CL (50 pF) Busy to ready time depends on the pull-up resistor tied to the (Refer to Application Note (9) toward the end of this document.) 1 TTL pin. PROGRAMMING / ERASING / READING CHARACTERISTICS (Ta -40 to 85 , VCC 2.7 to 3.6V) SYMBOL PARAMETER MIN TYP. MAX UNIT Average Programming Time (Single Page) 330 700 s Average Programming Time (Multi Page) 350 700 s tDCBSYW1 Busy Time in Multi Page Program(following 11h) 0.5 1 s N Number of Partial Program Cycles in the Same Page tBERASE Block Erasing Time 2.5 5 Memory Cell Array to Starting Address (Sigle Page) 40 120 Memory Cell Array to Starting Address (Multi Page) 55 200 NOTES tPROG tR 4 (1) ms s (1) Refer to Application Note (12) toward the end of this document. Data Output When tREH is long, output buffers are disabled by /RE=High, and the hold time of data output depend on tRHOH (25ns MIN). On this condition, waveforms look like normal serial read mode. When tREH is short, output buffers are not disabled by /RE=High, and the hold time of data output depend on tRLOH (5ns MIN). On this condition, output buffers are disabled by the rising edge of CLE,ALE,/CE or falling edge of /WE, and waveforms look like Extended Data Output Mode. 6 2014-03-15C TH58BVG2S3HBAI4 TIMING DIAGRAMS Latch Timing Diagram for Command/Address/Data CLE ALE Setup Time Hold Time tDS tDH I/O : VIH or VIL Command Input Cycle Timing Diagram CLE tCLS tCS tCLH tCH tWP tALS tALH ALE tDS tDH I/O : VIH or VIL 7 2014-03-15C TH58BVG2S3HBAI4 Address Input Cycle Timing Diagram tCLS tCLH CLE tCH tCS tWP tCS tWH tWP tWC tWH tWP tWC tWH tWP tCH tWH tWP tALS tALH ALE tDS I/O tDH tDS CA0 to 7 tDS tDH CA8 to 11 tDH tDS PA0 to 7 tDH PA8 to 15 tDS tDH PA16 to 17 : VIH or VIL Data Input Cycle Timing Diagram tCLS tCLH CLE tCH tCS tCS tCH tALS tALH tWC ALE tWP tWH tDS tWP tDH tDS DIN0 I/O tWP tDH DIN1 tDS tDH DIN2111 . 8 2014-03-15C TH58BVG2S3HBAI4 Serial Read Cycle Timing Diagram tRC tRP tREA tREH tRHZ tRHOH tRP tCHZ tRP tRHZ tRHZ tRHOH tREA tREA tCEA tRHOH tCEA I/O tRR : VIH or VIL Status Read Cycle Timing Diagram tCLR CLE tCLS tCLH tCS tWP tCH tCEA tCHZ tWHC tWHR tDS tDH tRHOH tIR tREA I/O tRHZ Status output 70h/71h* : VIH or VIL *: 70h/71h represents the hexadecimal number 9 2014-03-15C TH58BVG2S3HBAI4 ECC Status Read Cycle Timing Diagram tCLR CLE tCLS tCLH tCS tWP tCH tCEA tWHC tWHR tDS tDH tIR tREA I/O 7Ah* tREA tREA tREA Status output Status output Status output Status output Sector1 Sector2 Sector3 Sector4 : VIH or VIL *: ECC Status output should be read for all 4 sector information. **: 7Ah command can be inputted to the device from [ after RY/BY returns to High ] to [before Dout or Next command input]. 10 2014-03-15C TH58BVG2S3HBAI4 Read Cycle Timing Diagram tCLR CLE tCLS tCLH tCS tCLS tCH tCLR tCLH tCS tCH tWC tALH tALS tALH tALS ALE tRC tR tWB tDS tDH I/O tDS tDH tDS tDH tDS tDH tDS tDH tDS tDH CA0 to 7 00h CA8 to 11 PA0 to 7 PA8 to 15 tDS tDH PA16 to 17 tREA 70h 30h tREA status output 00h DOUT N Data out from Col. Add. N Col. Add. N Read Cycle Timing Diagram: When Interrupted by tCLR tCLR CLE tCLS tCLH tCS tCH tCLS tCS tCLH tCH tWC tALH tCSD tALS tALH tALS ALE tR tRC tWB tDS tDH I/O 00h tDS tDH tDS tDH tDS tDH tDS tDH tDS tDH CA0 to 7 CA8 to 11 PA0 to 7 PA8 to 15 PA16 to 17 Col. Add. N tDS tDH 30h tCHZ tRHZ tREA tREA 70h tRHOH status output 00h DOUT N DOUT N+1 Col. Add. N 11 2014-03-15C TH58BVG2S3HBAI4 Column Address Change in Read Cycle Timing Diagram (1/2) tCLR tCLR CLE tCLS tCLH tCS tCLS tCLH tCH tCH tCS tWC tALH tALS tALH tALS ALE tR tRC tWB I/O tDS tDH tDS tDH tDS tDH tDS tDH tDS tDH tDS tDH tDS tDH 00h CA0 to 7 CA8 to 11 PA0 to 7 PA8 to 15 PA16 to 17 30h tREA 70h Status Output 00h DOUT DOUT A A 1 DOUT A N Page address P Page address P Column address A 1 Continues to 1 12 of next page 2014-03-15C TH58BVG2S3HBAI4 Column Address Change in Read Cycle Timing Diagram (2/2) tCLR CLE tCLS tCLH tCS tCH tCLS tCS tRHW tCLH tCH tWC tCEA tALH tALS tALH tALS ALE tWHR tDS tDH tDS tDH tDS tDH tDS tDH tRC tREA tIR DOUT A N I/O 05h CA0 to 7 CA8 to 11 E0h Column address B DOUT B DOUT B 1 DOUT B Page address P Column address B 1 Continues from 1 of previous page 13 2014-03-15C TH58BVG2S3HBAI4 Data Output Timing Diagram CLE tCLS tCLH tCS tCH tALH ALE tRC tRP tCHZ tREH tREA tCEA Dout tRR tRHZ tREA tRLOH tREA I/O tRP tRP tDS tDH tRLOH Dout tRHOH Dout Command tRHOH 14 2014-03-15C TH58BVG2S3HBAI4 Auto-Program Operation Timing Diagram tCLS CLE tCLS tCLH tCS tCS tCH tALH tALH tALS tPROG tWB tALS tRW ALE I/O tDS tDS tDS tDH tDS tDH 80h CA0 to 7 tDH tDH CA8 to 11 PA0 to 7 PA8 PA16 to 15 to 17 DINN DIN N+1 DINM* 10h 70h Status output Column address N : Do not input data while data is being output. : VIH or VIL *) M: up to 2111 15 2014-03-15C TH58BVG2S3HBAI4 Multi-Page Program Operation Timing Diagram (1/2) tCLS CLE tCLS tCLH tCS tCS tCH tALH tALH tALS tDCBSYW1 tWB tALS ALE I/O tDS tDS tDH tDS tDH 80h CA0 to 7 tDS tDH CA8 to 11 PA0 to 7 PA8 to 15 PA16 to 17 DINN tDH DIN N+1 Page Address M District-0 11h 81h CA0 to 7 DIN2111 : Do not input data while data is being output. : VIH or VIL 1 Continues to 1 of next page 16 2014-03-15C TH58BVG2S3HBAI4 Multi-Page Program Operation Timing Diagram (2/2) tCLS CLE tCLS tCLH tCS tCS tCH tALH tALH tALS tPROG tWB tALS ALE tDS tDH 81h CA0 to 7 I/O tDS tDS tDS tDH tDH tDH CA8 to 11 PA0 PA8 PA16 to 7 to 15 to 17 Page Address M District-1 DINN DIN N+1 10h 71h DIN2111 : Do not input data while data is being output. : VIH or VIL 1 Continues from 1 of previous page 17 2014-03-15C Status output TH58BVG2S3HBAI4 Auto Block Erase Timing Diagram CLE tCLS tCLH tCS tCLS tALH tALS tWB tBERASE ALE tDS tDH I/O 60h Auto Block Erase Setup command : VIH or VIL PA0 to 7 PA8 to 15 PA16 to 17 D0h Erase Start command Status output 70h Busy Status Read command : Do not input data while data is being output. 18 2014-03-15C TH58BVG2S3HBAI4 Multi Block Erase Timing Diagram CLE tCLS tCLH tCS tCLS tALH tALS tWB tBERASE ALE tDS tDH I/O 60h PA0 to 7 PA8 to 15 PA16 to 17 Auto Block Erase Setup command D0h Erase Start command 71h Busy Status output Status Read command Repeat 2 times (District-0,1) : VIH or VIL : Do not input data while data is being output. 19 2014-03-15C TH58BVG2S3HBAI4 20 2014-03-15C TH58BVG2S3HBAI4 ID Read Operation Timing Diagram tCLS CLE tCLS tCS tCS tCH tCEA tCH tALH tALH tALS tAR ALE tDH tDS I/O tREA tREA tREA tREA tREA 90h 00h 98h DCh See Table 5 See Table 5 See Table 5 ID Read command Address 00 Maker code Device code 3rd Data 4th Data 5th Data : VIH or VIL 21 2014-03-15C TH58BVG2S3HBAI4 PIN FUNCTIONS The device is a serial access memory which utilizes time-sharing input of address information. Command Latch Enable: CLE The CLE input signal is used to control loading of the operation mode command into the internal command register. The command is latched into the command register from the I/O port on the rising edge of the signal while CLE is High. Address Latch Enable: ALE The ALE signal is used to control loading address information into the internal address register. Address information is latched into the address register from the I/O port on the rising edge of while ALE is High. Chip Enable: The device goes into a low-power Standby mode when signal is ignored when device is in Busy state ( operation, and will not enter Standby mode even if the goes High during the device is in Ready state. The L), such as during a Program or Erase or Read input goes High. Write Enable: The signal is used to control the acquisition of data from the I/O port. Read Enable: The signal controls serial data output. Data is available t REA after the falling edge of . The internal column address counter is also incremented (Address = Address + l) on this falling edge. I/O Port: I/O1 to 8 The I/O1 to 8 pins are used as a port for transferring address, command and input/output data to and from the device. Write Protect: The signal is used to protect the device from accidental programming or erasing. The internal voltage regulator is reset when is Low. This signal is usually used for protecting the data during the power-on/off sequence when input signals are invalid. Ready/Busy: The output signal is used to indicate the operating condition of the device. The signal is in Busy state ( = L) during the Program, Erase and Read operations and will return to Ready state ( = H) after completion of the operation. The output buffer for this signal is an open drain and has to be pulled-up to Vccq with an appropriate resister. 22 2014-03-15C TH58BVG2S3HBAI4 Schematic Cell Layout and Address Assignment The Program operation works on page units while the Erase operation works on block units. I/O1 Data Cache 2048 64 Page Buffer 2048 64 I/O8 A page consists of 2112 bytes in which 2048 bytes are used for main memory storage and 64 bytes are for redundancy or for other uses. 1 page 2112bytes 1 block 2112 bytes 64 pages (128K 4K) bytes Capacity 2112 bytes 64pages 4096 blocks 64 Pages 1 block 262144 pages 4096 blocks An address is read in via the I/O port over five consecutive clock cycles, as shown in Table 1. 8I/O 2112 Table 1. Addressing I/O8 I/O7 I/O6 I/O5 I/O4 I/O3 I/O2 I/O1 CA7 CA6 CA5 CA4 CA3 CA2 CA1 CA0 L L L L CA11 CA10 CA9 CA8 Third cycle PA7 PA6 PA5 PA4 PA3 PA2 PA1 PA0 Fourth cycle PA15 PA14 PA13 PA12 PA11 PA10 PA9 PA8 L L L L L L PA17 PA16 First cycle Second cycle Fifth cycle 23 CA0 to CA11: Column address PA0 to PA17: Page address PA6 to PA17: Block address PA0 to PA5: NAND address in block 2014-03-15C TH58BVG2S3HBAI4 Operation Mode: Logic and Command Tables The operation modes such as Program, Erase, Read and Reset are controlled by command operations shown in Table 3. Address input, command input and data input/output are controlled by the CLE, ALE, , , and signals, as shown in Table 2. Table 2. Logic Table *1 CLE ALE Command Input H L L H * Data Input L L L H H Address input L H L H * Serial Data Output L L L H During Program (Busy) * * * * * H During Erase (Busy) * * * * * H * * H * * * * * L H (*2) H (*2) * Program, Erase Inhibit * * * * * L Standby * * H * * 0 V/VCC * During Read (Busy) H: VIH, L: VIL, *: VIH or VIL *1: Refer to Application Note (10) toward the end of this document regarding the signal when Program or Erase Inhibit is low during read busy, and must be held High to avoid unintended command/address input to the device or *2: If read to device. Reset or Status Read command can be input during Read Busy. 24 2014-03-15C TH58BVG2S3HBAI4 Table 3. Command table (HEX) First Set Second Set Serial Data Input 80 Read 00 30 Column Address Change in Serial Data Output 05 E0 Auto Page Program 80 10 Column Address Change in Serial Data Input 85 80 11 81 10 Read for Copy-Back without Data Out 00 35 Copy-Back Program without Data Out 85 10 Auto Block Erase 60 D0 ID Read 90 Status Read 70 Status Read for Multi-Page Program or Multi Block Erase 71 ECC Status Read 7A Reset FF Acceptable while Busy Multi Page Program HEX data bit assignment (Example) Serial Data Input: 80h 1 0 0 0 0 0 0 8 7 6 5 4 3 2 I/O1 0 Table 4. Read mode operation states CLE ALE Output select L L L H Output Deselect L L L H I/O1 to I/O8 Power L Data output Active H High impedance Active H: VIH, L: VIL 25 2014-03-15C TH58BVG2S3HBAI4 DEVICE OPERATION Read Mode Read mode is set when the "00h" and 30h commands are issued to the Command register. Between the two commands, a start address for the Read mode needs to be issued. After initial power on sequence, 00h command is latched into the internal command register. Therefore read operation after power on sequence is executed by the setting of only five address cycles and 30h command. Refer to the figures below for the sequence and the block diagram (Refer to the detailed timing chart.). CLE ALE Column Address M I/O Busy Page Address N 00h 30h tR 70h Status 00h M A data transfer operation from the cell array to the Data in the Cache via Page Buffer starts on the rising edge of 30h command input cycle (after the address information has been latched). The device will be in the Busy state during this transfer period. After the transfer period, the device returns to Ready state. clock Serial data can be output synchronously with the from the start address designated in the address input cycle. m Page Buffer Select page N Cell array 2111 I/O1 to 8: m M+2 Page Address N Start-address input Data Cache M+1 M Random Column Address Change in Read Cycle CLE ALE Busy t R Col. M I/O 30h 00h Col. M Page N M M 1 M 2 M 3 Page N Start from Col. M Start-address input M 70h Status 00h E0h 05h Col. M M M 1 M 2 M 3 M 4 Page N Start from Col. M During the serial data output from the register, the column address can be changed by inputting a new column address using the 05h and E0h commands. The data is read out in serial starting at the new column address. Random Column Address Change operation can be done multiple times within the same page. M Select page N 26 2014-03-15C TH58BVG2S3HBAI4 Multi Page Read Operation The device has a Multi Page Read operation. The sequence of command and address input is shown below. Same page address (PA0 to PA5) within each district has to be selected. Command input (3 cycle) 60 Address input (3 cycle) 60 Page Address PA0 to PA17 (District 0) A 0 Address input 30 Page Address PA0 to PA17 (District 1) Command input (5 cycle) 00 Address input 70 I/O1 1 Fail tR A (2 cycle) 05 Column + Page Address CA0 to CA11, PA0 to PA17 (District 0) Address input E0 Column Address CA0 to CA11 (District 0) Data output B (District 0) B A B A Pass Command input (5 cycle) 00 Address input 05 Column + Page Address CA0 to CA11, PA0 to PA17 (District 1) Address input E0 Column Address CA0 to CA11 (District 1) Data output (District 1) B District 0 District 1 Reading Selected page Selected page The data transfer operation from the cell array to the Data Cache via Page Buffer starts on the rising in the 30h command input cycle (after the 2 Districts address information has been edge of latched). The device will be in the Busy state during this transfer period. After the transfer period, the device returns to Ready state. Serial data can be output synchronously clock from the start address designated in the address input cycle. with the ECC Status command can be used only for Single Page Read. It is not supported for Multi Page Read operation. 27 2014-03-15C TH58BVG2S3HBAI4 Internal addressing in relation with the Districts To use Multi Page Read operation, the internal addressing should be considered in relation with the District. The device consists from 2 Districts. Each District consists of 1024 erase blocks. The allocation rule is follows. (a) District 0: Block 0, Block 2, Block 4, Block 6,···, Block 2046 (b) District 1: Block 1, Block 3, Block 5, Block 7,···, Block 2047 (c) District 0: Block 2048, Block 2050, Block 2052,···, Block 4094 (d) District 1: Block 2049, Block 2051, Block 2053,···, Block 4095 Combination of (a) and (b) or (c) and (d) can only be selected. Address input restriction for the Multi Page Read operation There are following restrictions in using Multi Page Read; (Restriction) Maximum one block should be selected from each District. Same page address (PA0 to PA5) within two districts has to be selected. For example; (60) [District 0, Page Address 0x00000] (60) [District 1, Page Address 0x00040] (30) (60) [District 0, Page Address 0x00001] (60) [District 1, Page Address 0x00041] (30) (Acceptance) There is no order limitation of the District for the address input. For example, following operation is accepted; (60) [District 0] (60) [District 1] (30) (60) [District 1] (60) [District 0] (30) It requires no mutual address relation between the selected blocks from each District. Operating restriction during the Multi Page Read operation Make sure is held to High level when Multi Page Read operation is performed 28 2014-03-15C TH58BVG2S3HBAI4 ECC & Sector definition for ECC Internal ECC logic generates Error Correction Code during busy time in program operation. The ECC logic manages 9bit error detection and 8bit error correction in each 528Bytes of main data and spare data. A section of main field (512Bytes) and spare field (16Bytes) are paired for ECC. During read, the device executes ECC of itself. Once read operation is executed, Read Status Command (70h) can be issued to check the read status. The read status remains until other valid commands are executed. To use ECC function, below limitation must be considered. - A sector is the minimum unit for program operation and the number of program per page must not exceed 4. 2KByte Page Assignment 1 st 2 nd 3 rd 4 th 1 st 2 nd 3 rd 4 th Main Main Main Main Spare Spare Spare Spare 512B 512B 512B 512B 16B 16B 16B 16B Note) The Internal ECC manages all data of Main area and Spare area Definition of 528Byte Sector Sector Column Address (Byte) Main Field Spare Field 1 st Sector 0 ~ 511 2,048 ~ 2,063 2 nd Sector 512 ~ 1,023 2,064 ~ 2,079 3 rd Sector 1,024 ~ 1,535 2,080 ~ 2,095 4 th Sector 1,536 ~ 2,047 2,096 ~ 2,111 29 2014-03-15C TH58BVG2S3HBAI4 Auto Page Program Operation The device carries out an Automatic Page Program operation when it receives a "10h" Program command after the address and data have been input. The sequence of command, address and data input is shown below. (Refer to the detailed timing chart.) CLE ALE Din Din Din 80h I/O Col. M Page P Din 70h 10h Status Out Data Data input Program The data is transferred (programmed) from the Data Cache via the Page Buffer to the selected page on the rising edge of following input of the 10h command. After programming, the programmed data is transferred back to the Page Buffer to be automatically verified by the device. If the programming does not succeed, the Program/Verify operation is repeated by the device until success is achieved or until the maximum loop number set in the device is reached. Read& verification Selected page Random Column Address Change in Auto Page Program Operation The column address can be changed by the 85h command during the data input sequence of the Auto Page Program operation. Two address input cycles after the 85h command are recognized as a new column address for the data input. After the new data is input to the new column address, the 10h command initiates the actual data program into the selected page automatically. The Random Column Address Change operation can be repeated multiple times within the same page. 80h Din Col. M Din Din Din 85h Din Col. M Page N Col. M Din Din Din 10h 70h Status Busy Col. M Data input Program Reading & verification Selected page 30 2014-03-15C TH58BVG2S3HBAI4 Multi Page Program The device has a Multi Page Program, which enables even higher speed program operation compared to Auto Page Program. The sequence of command, address and data input is shown below. (Refer to the detailed timing chart.) Although two planes are programmed simultaneously, pass/fail is not available for each page by 70h command when the program operation completes. Status bit of I/O 1 is set to 1 when any of the pages fails. Limitation in addressing with Multi Page Program is shown below. Multi Page Program tPROG tDCBSYW1 I/O1~8 0 80h Address & Data Input CA0~CA11 PA0~PA5 PA6 PA7~PA17 81h 11h Address & Data Input Note : Valid : Valid : District0 : Valid CA0~CA11 PA0~PA5 PA6 PA7~PA17 10h : Valid : Valid : District1 : Valid 70h/71h Pass I/O1 1 Fail NOTE: Any command between 11h and 81h is prohibited except 70h and FFh. 80h 11h 81h 10h Data Input Plane 0 (1024 Block) Plane 1 (1024 Block) Block 0 Block 1 Block 2 Block 3 Block 2044 Block 2045 Block 2046 Block 2047 The 71h command Status description is as below. STATUS OUTPUT I/O1 Chip Status : Pass/Fail Pass: 0 Fail: 1 I/O2 District 0 Chip Status : Pass/Fail Pass: 0 Fail: 1 I/O3 District 1 Chip Status : Pass/Fail Pass: 0 Fail: 1 I/O4 Not Used Invalid I/O5 Not Used Invalid I/O6 Ready/Busy Ready: 1 Busy: 0 I/O7 Ready/Busy Ready: 1 Busy: 0 I/O8 Write Protect Protect: 0 I/O1 describes Pass/Fail condition of district 0 and 1(OR data of I/O2 and I/O3). If one of the districts fails during multi page program operation, it shows Fail . I/O2 to 3 shows the Pass/Fail condition of each district.. Not Protect: 1 31 2014-03-15C TH58BVG2S3HBAI4 Internal addressing in relation with the Districts To use Multi Page Program operation, the internal addressing should be considered in relation with the District. The device consists of 2 Districts. Each District consists from 1024 erase blocks. The allocation rule is follows. (a) District 0: Block 0, Block 2, Block 4, Block 6,···, Block 2046 (b) District 1: Block 1, Block 3, Block 5, Block 7,···, Block 2047 (c) District 0: Block 2048, Block 2050, Block 2052,···, Block 4094 (d) District 1: Block 2049, Block 2051, Block 2053,···, Block 4095 Combination of (a) and (b) or (c) and (d) can only be selected. Address input restriction for the Multi Page Program operation There are following restrictions in using Multi Page Program; (Restriction) Maximum one block should be selected from each District. Same page address (PA0 to PA5) within two districts has to be selected. For example; (80) [District 0, Page Address 0x00000] (11) (81) [District 1, Page Address 0x00040] (10) (80) [District 0, Page Address 0x00001] (11) (81) [District 1, Page Address 0x00041] (10) (Acceptance) There is no order limitation of the District for the address input. For example, following operation is accepted; (80) [District 0] (11) (81) [District 1] (10) (80) [District 1] (11) (81) [District 0] (10) It requires no mutual address relation between the selected blocks from each District. Operating restriction during the Multi Page Program operation (Restriction) The operation has to be terminated with 10h command. Once the operation is started, no commands other than the commands shown in the timing diagram is allowed to be input except for Status Read command and reset command. 32 2014-03-15C TH58BVG2S3HBAI4 Auto Block Erase The Auto Block Erase operation starts on the rising edge of after the Erase Start command D0h which follows the Erase Setup command 60h . This two-cycle process for Erase operations acts as an extra layer of protection from accidental erasure of data due to external noise. The device automatically executes the Erase and Verify operations. 60 D0 Block Address input: 3 cycles 70 Status Read command Erase Start command I/O Pass Fail Busy Multi Block Erase The Multi Block Erase operation starts by selecting two block addresses before D0h command as in below diagram. The device automatically executes the Erase and Verify operations and the result can be monitored by checking the status by 71h status read command. For details on 71h status read command, refer to section Multi Page Program . 60 Block Address input: 3 cycles District 0 60 D0 71 Status Read command Block Address Erase Start input: 3 cycles command District 1 I/O Pass Fail Busy Internal addressing in relation with the Districts To use Multi Block Erase operation, the internal addressing should be considered in relation with the District. The device consists from 2 Districts. Each District consists from 1024 erase blocks. The allocation rule is follows. (a) District 0: Block 0, Block 2, Block 4, Block 6,···, Block 2046 (b) District 1: Block 1, Block 3, Block 5, Block 7,···, Block 2047 (c) District 0: Block 2048, Block 2050, Block 2052,···, Block 4094 (d) District 1: Block 2049, Block 2051, Block 2053,···, Block 4095 Combination of (a) and (b) or (c) and (d) can only be selected. Address input restriction for the Multi Block Erase There are following restrictions in using Multi Block Erase. (Restriction) Maximum one block should be selected from each District. For example; (60) [District 0] (60) [District 1] (D0) (Acceptance) There is no order limitation of the District for the address input. For example, following operation is accepted; (60) [District 1] (60) [District 0] (D0) It requires no mutual address relation between the selected blocks from each District. Make sure to terminate the operation with D0h command. If the operation needs to be terminated before D0h command input, input the FFh reset command to terminate the operation. 33 2014-03-15C TH58BVG2S3HBAI4 READ FOR COPY-BACK WITH DATA OUTPUT TIMING GUIDE Copy-Back operation is a sequence execution of Read for Copy-Back and of copy-back program with the destination page address. A read operation with 35h command and the address of source page moves the whole 2112 bytes data into the internal data buffer. Bit errors are checked by sequential reading the data or by reading the status in read after read busy time(tR) to check if uncorrectable error occurs. In the case where there is no bit error or no uncorrectable error, the data don t need to be reloaded. Therefore Copy-Back program operation is initiated by issuing Page-Copy Data-Input command (85h) with destination page address. Actual programming operation begins after Program Confirm command (10h) is issued. Once the program process starts, the Read Status Register command (70h) may be entered to read the status register. The system controller can detect the completion of a program cycle by monitoring the output, or the Status Bit (I/O7) of the Status Register. When the Copy-Back Program is complete, the Write Status Bit (I/O1) may be checked. The command register remains in Read Status command mode until another valid command is written to the command register. During copy-Back program, data modification is possible using random data input command (85h) as shown below. Page Copy-Back Program Operation tR tPROG 0 I/Ox 00h Add.(5Cycle ) 35h 70h Col. Add.1,2 & Page Add.1,2,3 0 I/O1 1 Data Output 00h 85h Pass Add.(5Cycle ) 10h 70h Col. Add.1,2 & Page Add.1,2,3 Fail I/O1 Pass 1 Fail NOTE: 1. Copy-Back Program operation is allowed only within the same district. Page Copy-Back Program Operation with Random Data Input tR A 0 I/Ox 00h Add.(5Cycles) 35h 70h I/O1 Col. Add.1,2 & Page Add.1,2,3 Source Address 1 00h Data Output Fail tPROG A I/Ox A A Pass 85h Add.(5Cycles) Data Col. Add.1,2 & Page Add.1,2,3 Destination Address 85h Add.(2Cycles) Data 10h 70h Col. Add.1,2 There is no limitation for the number of repetition 34 2014-03-15C TH58BVG2S3HBAI4 ID Read The device contains ID codes which can be used to identify the device type, the manufacturer, and features of the device. The ID codes can be read out under the following timing conditions: CLE tCEA tAR ALE tREA I/O 90h 00h 98h DCh See table 5 See table 5 See table 5 ID Read command Address 00 Maker code Device code 3rd Data 4th Data 5th Data Table 5. Code table Description I/O8 I/O7 I/O6 I/O5 I/O4 I/O3 I/O2 I/O1 Hex Data 1st Data Maker Code 1 0 0 1 1 0 0 0 98h 2nd Data Device Code 1 1 0 1 1 1 0 0 DCh 3rd Data Chip Number, Cell Type 1 0 0 1 0 0 0 1 91h 4th Data Page Size, Block Size 0 0 0 1 0 1 0 1 15h 5th Data Plane Number 1 1 1 1 0 1 1 0 F6h 3rd Data Description Internal Chip Number Cell Type I/O8 I/O7 I/O6 I/O5 I/O4 I/O3 1 2 4 8 2 level cell 4 level cell 8 level cell 16 level cell 0 0 1 1 Reserved 1 35 0 0 I/O2 I/O1 0 0 1 1 0 1 0 1 0 1 0 1 1 2014-03-15C TH58BVG2S3HBAI4 4th Data Description Page Size (without redundant area) 1 KB 2 KB 4 KB 8 KB Block Size (without redundant area) 64 KB 128 KB 256 KB 512 KB I/O Width I/O8 I/O7 I/O6 0 0 1 1 x8 x16 I/O5 I/O4 I/O3 I/O2 I/O1 0 0 1 1 0 1 0 1 I/O2 I/O1 1 0 0 1 0 1 0 1 Reserved 0 0 1 I/O4 I/O3 0 0 1 1 0 1 0 1 5th Data Description Plane Number ECC engine on chip I/O8 I/O7 I/O6 I/O5 1 Plane 2 Plane 4 Plane 8 Plane With ECC engine 1 Reserved 1 36 1 1 2014-03-15C TH58BVG2S3HBAI4 Status Read The device automatically implements the execution and verification of the Program and Erase operations. The Status Read function is used to monitor the Ready/Busy status of the device, determine the result (pass /fail) of a Program or Erase operation, and determine whether the device is in Protect mode. The device status is output via the I/O port using after a 70h command input. The Status Read can also be used during a Read operation to find out the Ready/Busy status. The resulting information is outlined in Table 6. Table 6. Status output table Definition Page Program Block Erase Read Pass/Fail Pass/Fail Pass/Fail(Uncorrectable) I/O1 Chip Status Pass: 0 I/O2 Not Used Invalid Invalid Invalid I/O3 Not Used 0 0 0 0 0 Normal or uncorrectable / Recommended to rewrite 0 0 0 Ready/Busy Ready/Busy Ready/Busy Ready/Busy Ready/Busy Ready/Busy Write Protect Write Protect Write Protect Fail: 1 Chip Read Status I/O4 Normal or uncorrectable: 0 Recommended to rewrite : 1 I/O5 Not Used I/O6 Ready/Busy Ready: 1 Busy: 0 I/O7 Ready/Busy Ready: 1 Busy: 0 I/O8 Write Protect Not Protected :1 Protected: 0 The Pass/Fail status on I/O1 is only valid during a Program/Erase operation when the device is in the Ready state. 37 2014-03-15C TH58BVG2S3HBAI4 ECC Status Read The ECC Status Read function is used to monitor the Error Correction Status. 24nm BENAND can correct up to 8bit errors. ECC can be performed on the NAND Flash main and spare areas. The ECC Status Read function can also show the number of errors in a sector as a result of an ECC check in during a read operation. 8 7 6 Sector Information 5 4 3 2 I/O1 ECC Status ECC Status I/O4 to I/O1 ECC Status 0000 No Error 0001 1bit error(Correctable) 0010 2bit error(Correctable) 0011 3bit error(Correctable) 0100 4bit error(Correctable) 0101 5bit error(Correctable) 0110 6bit error(Correctable) 0111 7bit error(Correctable) 1000 8bit error(Correctable) 1111 Uncorrectable Error I/O8 to I/O5 Sector Information 0000 1st Sector (Main and Spare area) 0001 2nd Sector (Main and Spare area) 0010 3rd Sector (Main and Spare area) 0011 4th Sector (Main and Spare area) Other Reserved Sector Information 38 2014-03-15C TH58BVG2S3HBAI4 Reset The Reset mode stops all operations. For example, in case of a Program or Erase operation, the internally generated voltage is discharged to 0 volt and the device enters the Wait state. Reset during a Page Copy may not just stop the most recent page program but it may also stop the previous program to a page depending on when the FF reset is input. The response to a FFh Reset command input during the various device operations is as follows: When a Reset (FFh) command is input during programming 80 10 FF 00 Internal VPP tRST (max 10 s) 39 2014-03-15C TH58BVG2S3HBAI4 When a Reset (FFh) command is input during erasing D0 FF 00 Internal erase voltage tRST (max 500 s) When a Reset (FFh) command is input during Read operation 00 30 FF 00 tRST (max 5 s) When a Reset (FFh) command is input during Ready FF 00 tRST (max 5 s) When a Status Read command (70h) is input after a Reset FF 70 I/O status: Pass/Fail Pass : Ready/Busy Ready When two or more Reset commands are input in succession 10 The second FF (1) (2) (3) FF FF FF command is invalid, but the third 40 FF command is valid. 2014-03-15C TH58BVG2S3HBAI4 APPLICATION NOTES AND COMMENTS (1) Power-on/off sequence: The timing sequence shown in the figure below is necessary for the power-on/off sequence. The device internal initialization starts after the power supply reaches an appropriate level in the power on sequence. During the initialization the device Ready/Busy signal indicates the Busy state as shown in the figure below. In this time period, the acceptable commands are FFh or 70h. The signal is useful for protecting against data corruption at power-on/off. 2.7 V 2.5 V 0 V , 1ms VCC 2.7 V 2.5 V 0.5 V 0.5 V Don t care Don t care , CLE, ALE Don t care VIH VIL VIL 1.2 ms max Operation 100 s max 100 s max Invalid Invalid 1.2 ms max Invalid Ready/Busy (2) Power-on Reset The following sequence is necessary because some input signals may not be stable at power-on. Power on FF Reset (3) Prohibition of unspecified commands The operation commands are listed in Table 3. Input of a command other than those specified in Table 3 is prohibited. Stored data may be corrupted if an unknown command is entered during the command cycle. (4) Restriction of commands while in the Busy state During the Busy state, do not input any command except 70h,71h and FFh. 41 2014-03-15C TH58BVG2S3HBAI4 (5) Acceptable commands after Serial Input command 80h Once the Serial Input command 80h has been input, do not input any command other than the Column Address Change in Serial Data Input command 85h , Auto Program command 10h , Multi Page Program command 11h or the Reset command FFh . 80 FF Address input If a command other than 85h , 10h , 11h or FFh is input, the Program operation is not performed and the device operation is set to the mode which the input command specifies. 80 XX Mode specified by the command. 10 Programming cannot be executed. Command other than 85h , 10h , 11h or FFh (6) Addressing for program operation Within a block, the pages must be programmed consecutively from the LSB (least significant bit) page of the block to MSB (most significant bit) page of the block. Random page address programming is prohibited. From the LSB page to MSB page DATA IN: Data (1) Ex.) Random page program (Prohibition) Data (64) DATA IN: Data (1) Data register Data (64) Data register Page 0 Page 1 Page 2 (1) (2) (3) Page 0 Page 1 Page 2 (2) (32) (3) Page 31 (32) Page 31 (1) Page 63 (64) Page 63 (64) 42 2014-03-15C TH58BVG2S3HBAI4 (7) Status Read during a Read operation 00 Command 00 30 [A] 70 Address N Status Read command input Status output Status Read . The device status can be read out by inputting the Status Read command 70h in Read mode. Once the device has been set to Status Read mode by a 70h command, the device will not return to Read mode unless the Read command 00h is inputted during [A]. If the Read command 00h is inputted during [A], Status Read mode is reset, and the device returns to Read mode. In this case, data output starts automatically from address N and address input is unnecessary (8) Auto programming failure 80 10 70 Fail I/O 80 Address Data M input 10 Address Data N input 80 If the programming result for page address M is Fail, do not try to program the page to address N in another block without the data input sequence. Because the previous input data has been lost, the same input sequence of 80h command, address and data is necessary. 10 M N (9) : termination for the Ready/Busy pin ( ) A pull-up resistor needs to be used for termination because the circuit. VCC VCC Ready buffer consists of an open drain VCC R Busy Device tr tf CL VSS 1.5 tr This data may vary from device to device. We recommend that you use this data as a reference when selecting a resistor value. 1.0 0.5 s tf s 1 K 3.3 V 25°C 50 pF 15 ns 10 ns tr s 0 VCC Ta CL tf 5 ns 2 K 3 K 4 K R 43 2014-03-15C TH58BVG2S3HBAI4 (10) Note regarding the signal The Erase and Program operations are automatically reset when enabled and disabled as follows: goes Low. The operations are Enable Programming DIN 80 10 tWW (100 ns MIN) Disable Programming DIN 80 10 tWW (100 ns MIN) Enable Erasing DIN 60 D0 tWW (100 ns MIN) Disable Erasing DIN 60 D0 tWW (100 ns MIN) 44 2014-03-15C TH58BVG2S3HBAI4 (11) When six address cycles are input Although the device may read in a sixth address, it is ignored inside the chip. Read operation CLE ALE I/O 00h 30h Ignored Address input Program operation CLE ALE I/O 80h Ignored Address input 45 Data input 2014-03-15C TH58BVG2S3HBAI4 (12) Several programming cycles on the same page (Partial Page Program) Each segment can be programmed individually as follows: 1st programming 2nd programming All 1 s Data Pattern 2 All 1 s 4th programming Result All 1 s Data Pattern 1 Data Pattern 1 Data Pattern 2 46 All 1 s Data Pattern 4 Data Pattern 4 2014-03-15C TH58BVG2S3HBAI4 (13) Invalid blocks (bad blocks) The device occasionally contains unusable blocks. Therefore, the following issues must be recognized: Bad Block Bad Block Please do not perform an erase operation to bad blocks. It may be impossible to recover the bad block information if the information is erased. Check if the device has any bad blocks after installation into the system. Refer to the test flow for bad block detection. Bad blocks which are detected by the test flow must be managed as unusable blocks by the system. A bad block does not affect the performance of good blocks because it is isolated from the bit lines by select gates. The number of valid blocks over the device lifetime is as follows: MIN Valid (Good) Block Number 4016 TYP. MAX UNIT 4096 Block Bad Block Test Flow Regarding invalid blocks, bad block mark is in whole pages. Please read one column of any page in each block. If the data of the column is 00 (Hex), define the block as a bad block Start Block No 1 Fail Read Check Pass Block No. Block No. No 1 Entry Bad Block *1 Last Block Yes End *1: No erase operation is allowed to detected bad blocks 47 2014-03-15C TH58BVG2S3HBAI4 (14) Failure phenomena for Program and Erase operations The device may fail during a Program or Erase operation. The following possible failure modes should be considered when implementing a highly reliable system. FAILURE MODE DETECTION AND COUNTERMEASURE SEQUENCE Block Erase Failure Status Read after Erase Page Programming Failure Status Read after Program Read 9bit Failure(uncorrectable error) Uncorrectable ECC error Block Replacement Block Replacement ECC: Error Correction Code. 8 bit correction per 528Bytes is executed in a device. Block Replacement Program Error occurs Buffer memory Block A When an error happens in Block A, try to reprogram the data into another Block (Block B) by loading from an external buffer. Then, prevent further system accesses to Block A ( by creating a bad block table or by using another appropriate scheme). Block B Erase When an error occurs during an Erase operation, prevent future accesses to this bad block (again by creating a table within the system or by using another appropriate scheme). (15) Do not turn off the power before write/erase operation is complete. Avoid using the device when the battery is low. Power shortage and/or power failure before write/erase operation is complete will cause loss of data and/or damage to data. (16) The number of valid blocks is on the basis of single plane operations, and this may be decreased with two plane operations. 48 2014-03-15C TH58BVG2S3HBAI4 Package Dimensions Weight: 0.154 g (typ.) 49 2014-03-15C TH58BVG2S3HBAI4 Revision History Date 2013-02-15 2014-03-15 Rev. 0.10 1.00 Description Preliminary version Deleted TENTATIVE notation. Clarification for the Package Weight. 50 2014-03-15C TH58BVG2S3HBAI4 RESTRICTIONS ON PRODUCT USE Toshiba Corporation, and its subsidiaries and affiliates (collectively "TOSHIBA"), reserve the right to make changes to the information in this document, and related hardware, software and systems (collectively "Product") without notice. This document and any information herein may not be reproduced without prior written permission from TOSHIBA. Even with TOSHIBA's written permission, reproduction is permissible only if reproduction is without alteration/omission. Though TOSHIBA works continually to improve Product's quality and reliability, Product can malfunction or fail. Customers are responsible for complying with safety standards and for providing adequate designs and safeguards for their hardware, software and systems which minimize risk and avoid situations in which a malfunction or failure of Product could cause loss of human life, bodily injury or damage to property, including data loss or corruption. Before customers use the Product, create designs including the Product, or incorporate the Product into their own applications, customers must also refer to and comply with (a) the latest versions of all relevant TOSHIBA information, including without limitation, this document, the specifications, the data sheets and application notes for Product and the precautions and conditions set forth in the "TOSHIBA Semiconductor Reliability Handbook" and (b) the instructions for the application with which the Product will be used with or for. Customers are solely responsible for all aspects of their own product design or applications, including but not limited to (a) determining the appropriateness of the use of this Product in such design or applications; (b) evaluating and determining the applicability of any information contained in this document, or in charts, diagrams, programs, algorithms, sample application circuits, or any other referenced documents; and (c) validating all operating parameters for such designs and applications. TOSHIBA ASSUMES NO LIABILITY FOR CUSTOMERS' PRODUCT DESIGN OR APPLICATIONS. PRODUCT IS NEITHER INTENDED NOR WARRANTED FOR USE IN EQUIPMENTS OR SYSTEMS THAT REQUIRE EXTRAORDINARILY HIGH LEVELS OF QUALITY AND/OR RELIABILITY, AND/OR A MALFUNCTION OR FAILURE OF WHICH MAY CAUSE LOSS OF HUMAN LIFE, BODILY INJURY, SERIOUS PROPERTY DAMAGE AND/OR SERIOUS PUBLIC IMPACT ("UNINTENDED USE"). Except for specific applications as expressly stated in this document, Unintended Use includes, without limitation, equipment used in nuclear facilities, equipment used in the aerospace industry, medical equipment, equipment used for automobiles, trains, ships and other transportation, traffic signaling equipment, equipment used to control combustions or explosions, safety devices, elevators and escalators, devices related to electric power, and equipment used in finance-related fields. IF YOU USE PRODUCT FOR UNINTENDED USE, TOSHIBA ASSUMES NO LIABILITY FOR PRODUCT. For details, please contact your TOSHIBA sales representative. Do not disassemble, analyze, reverse-engineer, alter, modify, translate or copy Product, whether in whole or in part. Product shall not be used for or incorporated into any products or systems whose manufacture, use, or sale is prohibited under any applicable laws or regulations. The information contained herein is presented only as guidance for Product use. No responsibility is assumed by TOSHIBA for any infringement of patents or any other intellectual property rights of third parties that may result from the use of Product. No license to any intellectual property right is granted by this document, whether express or implied, by estoppel or otherwise. ABSENT A WRITTEN SIGNED AGREEMENT, EXCEPT AS PROVIDED IN THE RELEVANT TERMS AND CONDITIONS OF SALE FOR PRODUCT, AND TO THE MAXIMUM EXTENT ALLOWABLE BY LAW, TOSHIBA (1) ASSUMES NO LIABILITY WHATSOEVER, INCLUDING WITHOUT LIMITATION, INDIRECT, CONSEQUENTIAL, SPECIAL, OR INCIDENTAL DAMAGES OR LOSS, INCLUDING WITHOUT LIMITATION, LOSS OF PROFITS, LOSS OF OPPORTUNITIES, BUSINESS INTERRUPTION AND LOSS OF DATA, AND (2) DISCLAIMS ANY AND ALL EXPRESS OR IMPLIED WARRANTIES AND CONDITIONS RELATED TO SALE, USE OF PRODUCT, OR INFORMATION, INCLUDING WARRANTIES OR CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, ACCURACY OF INFORMATION, OR NONINFRINGEMENT. Do not use or otherwise make available Product or related software or technology for any military purposes, including without limitation, for the design, development, use, stockpiling or manufacturing of nuclear, chemical, or biological weapons or missile technology products (mass destruction weapons). Product and related software and technology may be controlled under the applicable export laws and regulations including, without limitation, the Japanese Foreign Exchange and Foreign Trade Law and the U.S. Export Administration Regulations. Export and re-export of Product or related software or technology are strictly prohibited except in compliance with all applicable export laws and regulations. Please contact your TOSHIBA sales representative for details as to environmental matters such as the RoHS compatibility of Product. Please use Product in compliance with all applicable laws and regulations that regulate the inclusion or use of controlled substances, including without limitation, the EU RoHS Directive. TOSHIBA ASSUMES NO LIABILITY FOR DAMAGES OR LOSSES OCCURRING AS A RESULT OF NONCOMPLIANCE WITH APPLICABLE LAWS AND REGULATIONS. 51 2014-03-15C
TH58BVG2S3HBAI4
物料型号:TH58BVG2S3HBAI4
器件简介: - 这是一款由东芝生产的单3.3V供电的4Gbit(4,429,185,024位)NAND型电可擦可编程只读存储器(NAND E2PROM)。 - 该设备采用串行接口,利用I/O引脚进行地址和数据的输入/输出以及命令输入。 - 适用于固态文件存储、声音记录、静态相机图像文件存储等需要高密度非易失性存储的应用。
引脚分配: - 该芯片共有63个引脚,其中包括8个I/O端口(I/O1至I/O8),用于数据传输。 - 其他引脚包括芯片使能(CE)、写使能(WE)、读使能(RE)、命令锁存器使能(CLE)、地址锁存器使能(ALE)、写保护(WP)、就绪/忙(RY/BY)等控制引脚。
参数特性: - 存储组织:2112x128Kx8x2,具有2048字节的静态寄存器。 - 页面大小:2112字节,块大小:(128K + 4K)字节。 - 电源电压:VCC 2.7V至3.6V。 - 读、写、擦除操作的典型电流均为30mA。 - 待机电流:100μA。
功能详解: - 支持多种操作模式,包括读、重置、自动页编程、自动块擦除、状态读出、页复制、多页读、多页编程、多块擦除、ECC状态读出等。 - 具有内部ECC逻辑,能够对528字节的数据进行8位的错误校正。
应用信息: - 适用于需要高密度非易失性数据存储的系统,如固态文件存储、声音记录、静态相机图像文件存储等。
封装信息: - 封装类型:P-TFBGA63-0911-0.80CZ,重量约为0.154克。
