IS31FL3216A-QFLS3-TR
    LUMISSIL
    WFQFN28
    16通道LED驱动器
IS31FL3216A-QFLS3-TR 数据手册
IS31FL3216A 16 CHANNELS LED DRIVER July 2017 GENERAL DESCRIPTION FEATURES The IS31FL3216A is a fun light LED controller with an audio modulation mode. It can store data of 8 frames with internal RAM to play small animations automatically.   IS31FL3216A can sample the input signal to modulate the intensity of LEDs, or control 8 frames playing by internal ADC block. The LED current of each channel can be set in 256 steps by adjusting the PWM duty cycle through an I2C interface. 8 channels can be used as GPIO ports. IS31FL3216A is available in QFN-28 (4mm × 4mm). It operates from 2.7V to 5.5V over the temperature range of -40°C to +105°C. APPLICATIONS   Mobile phones and other hand-held devices for LED display LED in home appliances              2.7V to 5.5V supply I2C interface, automatic address increment function Internal RAM Modulate LED brightness with 256 steps PWM PWM frequency up to 26kHz Each channel can be controlled independently Auto Frame Play Mode with 8 frames 8 frames memory for animations Audio Frame Mode with 8 frames 8 of 16 outputs not used as LED drivers can be used as GPIO ports 8 levels of maximum intensity control 8kV HBM ESD Over-temperature protection -40°C to +105°C temperature range QFN-28 (4mm × 4mm) package TYPICAL APPLICATION CIRCUIT Figure 1 Typical Application Circuit Note: The IC should be placed far away from the mobile antenna in order to prevent the EMI. Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 1 IS31FL3216A VBattery VBattery 1 F 26 OUT1 VCC OUT2 0.1 F OUT3 VDD 4.7k 4.7k OUT4 4.7k OUT5 24 23 Micro Controller 21 22 OUT6 SDA OUT7 SCL OUT8 INTB SDB OUT9 IS31FL3216A OUT10 100k OUT11 OUT12 0.22 F 2 Audio In 28 27 100k 0.1 F 25 7, 16 IN OUT13 OUT14 R_EXT OUT15 C_FILT OUT16 AD GND VBattery VBattery 3 4 25 5 1 F VCC OUT1 AD OUT2 OUT3 0.1 F 6 OUT4 8 OUT5 9 24 10 23 11 21 12 22 13 OUT6 SDA OUT7 SCL OUT8 INTB SDB 14 OUT9 IS31FL3216A OUT10 OUT11 15 OUT12 0.22 F 17 2 Audio In 18 IN OUT13 OUT14 19 28 20 27 100k CLK 26 1 0.1 F 7 16 OUT15 R_EXT OUT16 C_FILT GND CLK 3 4 5 6 8 9 10 11 12 13 14 15 17 18 19 20 1 0 Figure 2 Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 Typical Application Circuit (Cascade Mode) 2 IS31FL3216A PIN CONFIGURATION Package Pin Configuration (Top View) QFN-28 PIN DESCRIPTION No. Pin Description 1 CLK Clock for chip cascade. 2 IN Audio signal input. 3~6 OUT1 ~ OUT4 Output channel. 7,16 GND Ground. 8 ~ 11 OUT5 ~ OUT8 Output channel. 12 ~ 15 OUT9 ~ OUT12 Output channel. Also can be configured as GPIO port. 17 ~ 20 OUT13 ~ OUT16 Output channel. Also can be configured as GPIO port. 21 INTB Interrupt output, active low. 22 SDB Shutdown, pull to GND in the shutdown mode. 23 SCL Serial clock input. 24 SDA Serial data input. 25 AD I2C address pin. 26 VCC Power supply. 27 C_FILT Filter capacitor for audio control. 28 R_EXT External resistor to regulate the output current. Thermal Pad Connect to GND. Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 3 IS31FL3216A ORDERING INFORMATION Industrial Range: -40°C to +105°C Order Part No. Package QTY/Reel IS31FL3216A-QFLS3-TR QFN-28, Lead-free 2500 Copyright  ©  2017  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 4 IS31FL3216A ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at any input pin Current in GND terminal Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA=TJ Thermal resistance, θJA ESD (HBM) ESD (CDM) -0.3V ~ +6.0V -0.3V ~ VCC+0.3V 1A +150°C -65°C ~ +150°C -40°C ~ +105°C 51.4°C /W ±8kV ±1kV Note: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS TA = 25°C, VCC = 2.7V ~ 5.5V, unless otherwise noted. Typical values are TA = 25°C, VCC = 3.6V. Symbol Parameter Condition VCC Supply voltage ICC Quiescent power supply current VSDB = VCC ISD Shutdown current VSDB = 0V or software shutdown Min. Typ. 2.7 Max. Unit 5.5 V 5.2 mA 1 μA PWM Control Mode, VDS=0.6V PWM duty cycle=0xFF, 03h=0x70 21 (Note 1) Audio Frame Mode, VDS=0.6V VIN = 3Vp-p, 1kHz square wave Audio gain=0dB 18 (Note 1) mA IOUT Average output current VHR Current sink headroom voltage I = 20mA (when use as GPIO output ports) OUT 400 mV fPWM PWM frequency of output 26 kHz Logic Electrical Characteristics (SDB, SDA, SCL, AD, INTB) VIL Logic “0” input voltage VCC = 2.7V VIH Logic “1” input voltage VCC = 5.5V IIL Logic “0” input current VIN = 0V (Note 2,3) 5 nA IIH Logic “1” input current VIN = VCC (Note 2,3) 5 nA Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 0.4 1.4 V V 5 IS31FL3216A DIGITAL INPUT SWITCHING CHARACTERISTICS (Note 3) Symbol Parameter Condition Min. Typ. Max. Unit 400 kHz fSCL Serial-Clock frequency tBUF Bus free time between a STOP and a START condition 1.3 μs tHD, STA Hold time (repeated) START condition 0.6 μs tSU, STA Repeated START condition setup time 0.6 μs tSU, STO STOP condition setup time 0.6 μs tHD, DAT Data hold time tSU, DAT Data setup time 100 ns tLOW SCL clock low period 1.3 μs tHIGH SCL clock high period 0.7 μs 0.9 μs tR Rise time of both SDA and SCL signals, receiving (Note 4) 20+0.1Cb 300 ns tF Fall time of both SDA and SCL signals, receiving (Note 4) 20+0.1Cb 300 ns Note 1: The average output current of each channel is IOUT. Note 2: All LEDs are on. Note 3: Guaranteed by design. Note 4: Cb = total capacitance of one bus line in pF. ISINK≤ 6mA. tR and tF measured between 0.3×VCC and 0.7×VCC. Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 6 IS31FL3216A DETAILED DESCRIPTION I2C INTERFACE The IS31FL3216A uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. The IS31FL3216A has a 7-bit slave address (A7:A1), followed by the R/W bit, A0. Set A0 to “0” for a write command and set A0 to “1” for a read command. The value of bits A1 and A2 are decided by the connection of the AD pin. The complete slave address is: Table 1 Slave Address Bit A7:A3 A2:A1 A0 Value 11101 AD 1/0 AD connected to GND, AD = 00; AD connected to VCC, AD = 11; AD connected to SCL, AD = 01; AD connected to SDA, AD = 10; Following acknowledge of IS31FL3216A, the register address byte is sent, most significant bit first. IS31FL3216A must generate another acknowledge indicating that the register address has been received. Then 8-bit of data byte are sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, the IS31FL3216A must generate another acknowledge to indicate that the data was received. The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high. ADDRESS AUTO INCREMENT The SCL line is uni-directional. The SDA line is bi-directional (open-collector) with a pull-up resistor (typically 4.7kΩ). The maximum clock frequency specified by the I2C standard is 400kHz. In this discussion, the master is the microcontroller and the slave is the IS31FL3216A. The timing diagram for the I2C is shown in Figure 3. The SDA is latched in on the stable high level of the SCL. When there is no interface activity, the SDA line should be held high. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. The start signal will alert all devices attached to the I2C bus to check the incoming address against their own chip address. The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. After the last bit of the chip address is sent, the master checks for the IS31FL3216A’s acknowledge. The master releases the SDA line high (through a pull-up Figure 3 Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 resistor). Then the master sends an SCL pulse. If the IS31FL3216A has received the address correctly, then it holds the SDA line low during the SCL pulse. If the SDA line is not low, then the master should send a “STOP” signal (discussed later) and abort the transfer. To write multiple bytes of data into IS31FL3216A, load the address of the data register that the first data byte is intended for. During the IS31FL3216A acknowledge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS31FL3216A will be placed in the new address, and so on. The auto increment of the address will continue as long as data continues to be written to IS31FL3216A (Figure 6). READING PORT REGISTERS To read the device data, the bus master must first send ____ the IS31FL3216A address with the R/W bit set to “0”, followed by the command byte, which determines which register is accessed. After a restart, the bus master must then send the IS31FL3216A address with ____ the R/W bit set to “1”. Data from the register defined by the command byte is then sent from the IS31FL3216A to the master (Figure 7). Interface timing 7 IS31FL3216A Figure 4 Figure 5 Figure 6 Bit transfer Writing to IS31FL3216A (Typical) Writing to IS31FL3216A (Automatic Address Increment) Figure 7 Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 Reading from IS31FL3216A 8 IS31FL3216A REGISTER DEFINITION Table 2 Register Function Address 00h Name Configuration Register 01h LED Control Register 02h Function Table R/W Default Set the operating mode of IS31FL3216A 3 W 1000 0000 OUT9~OUT16 enable bit 4 W OUT1~OUT8 enable bit 5 W 1111 1111 03h Lighting Effect Register Set the output current and the audio gain 6 W 04h Channel Configuration Register Set the operating mode of OUT9~OUT16 7 W 05h GPIO Configuration Register Set the operating mode of OUT9~OUT16 as the GPIO port 8 W 06h Output Port Register Set the logic level of OUT9~OUT16 as the output port 9 W 07h Interrupt Control Register Set the interrupt function of OUT9~OUT16 10 W 08h State Register Store the state of OUT9~OUT16 as the input port 11 R 09h ADC Sample Rate Register Set the ADC sample rate of the input signal 12 W 10h~1Fh PWM Register Set the PWM duty cycle data 13 W 20h~AFh Frame Register Store the data of 8 frames 14 W - - W xxxx xxxx B0h Update Register Load PWM Register data B6h Frame Delay Register Set the delay time between each frame 15 W B7h Frame Start Register Set the start frame in Auto Frame Play Mode 16 W Table 3 00h Configuration Register xxxx xxxx 0000 0000 0000 0000 Table 4 01h LED Control Register (OUT9~OUT16) Bit D7 D6:D5 D4 D3:D0 Bit D7:D0 Name SSD MODE AE - Name OUT16:OUT9 Default 1 00 0 0000 Default 1111 1111 The Configuration Register sets the operating mode of IS31FL3216A. SSD 0 1 Software Shutdown Enable Normal operation Software shutdown mode MODE 00 01 10 11 Operation Mode Selection PWM Control Mode Auto Frame Play Mode Audio Frame Mode Not available AE 0 1 Audio Modulated Enable Output current is set by register Output current is modulated by audio signal Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 0000 0000 Table 5 02h LED Control Register (OUT1~OUT8) Bit D7:D0 Name OUT8:OUT1 Default 1111 1111 The LED Control Registers store the on or off state of each channel. OUTx 0 1 LED State LED off LED on 9 IS31FL3216A Table 6 03h Lighting Effect Register Bit D7 D6:D4 D3 D2:D0 Name CM CS AGCE AGS Default 0 000 0 000 The Lighting Effect Register sets the output current and the audio gain. Table 8 05h GPIO Configuration Register (OUT9~OUT16) Bit D7:D0 Name OUT16:OUT9 Default 0000 0000 Set the state of OUT9~OUT16 as the GPIO port. CM 0 1 Chip Cascade Mode Master Mode Slave Mode OUTx 0 1 CS 000 001 010 011 100 101 110 111 Output Current Selection ILED × 1.0 ILED × 0.75 ILED × 0.5 ILED × 0.25 ILED × 2.0 ILED × 1.75 ILED × 1.5 ILED × 1.25 Table 9 06h Output Configuration Register (OUT9~OUT16) The ILED is set by the resistor REXT. Please refer to Page 14 for detail information. GPIO Configuration Output port Input port Bit D7:D0 Name OUT16:OUT9 Default 0000 0000 Set the logic level of OUT9~OUT16 as the output port. Output State Output low Output high OUTx 0 1 Table 10 07h Interrupt Control Register (OUT9~OUT16) AGCE 0 1 AGC Enable Enable Disable AGS 000 001 010 011 100 101 110 111 Audio Gain Selection 0dB 3dB 6dB 9dB 12dB 15dB 18dB 21dB Bit D7:D0 Name OUT16:OUT9 Default 0000 0000 Set the interrupt function of OUT9~OUT16 as the input port. Interrupt Function Enable Enable Disable OUTx 0 1 Table 7 04h Channel Configuration Register (OUT9~OUT16) Table 11 08h State Register (OUT9~OUT16) Bit D7:D0 Bit D7:D0 Name OUT16:OUT9 Name OUT16:OUT9 Default xxxx xxxx Default 0000 0000 Configure the operating mode of OUT9~OUT16. If any port is set as GPIO, the Lighting Effect Register will be unavailable for the port. OUTx 0 1 Store the input state of OUT9~OUT16 as the input port (Write only). The INTB pin will be pulled high until the MCU reads the data of State Register. Channel Configuration LED output GPIO port Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 10 IS31FL3216A Table 12 09h ADC Sample Rate Register Bit D7:D0 Name SR Default 0000 0000 The value of ADC Sample Rate Register decides the sample rate of ADC for Audio Frame Mode. The sample rate could be computed using the Formula (1): 7 SR  100kHz /  D[n]  2 n (1) n 0 Where “n” indicates the bit location in the respective ADC Sample Rate Register. For example: D7:D0 = 10110100 SR = 100kHz/(22+24+25+27) = 556Hz Table 13 10h~1Fh PWM Register (OUT16~OUT1) Bit D7:D0 Name PWM Default 0000 0000 The PWM Registers adjusts LED luminous intensity in 256 steps. The value of a channel’s PWM Register decides the average output current for each output, OUT1~OUT16. The average output current may be computed using the Formula (2): I OUT  I MAX 7   D[n]  2 n 256 n0 (2) Where “n” indicates the bit location in the respective PWM Registers. For example: D7:D0 = 10110101 IOUT = IMAX (20+22+24+25+27)/256 IMAX is set by the CS bit of Lighting Effect Register (03h). Table 14 20h~AFh Frame Register Address List Frame LED Control Register PWM Register Frame 1 20h ~ 21h 22h ~ 31h Frame 2 32h ~ 33h 34h ~ 43h Frame 3 44h ~ 45h 46h ~ 55h Frame 4 56h ~ 57h 58h ~ 67h Frame 5 68h ~ 69h 6Ah ~ 79h Frame 6 7Ah ~ 7Bh 7Ch ~ 8Bh Frame 7 8Ch ~ 8Dh 8Eh ~ 9Dh Frame 8 9Eh ~ 9Fh A0h ~ AFh Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 Frame Registers store the data of 8 frames. Each frame is controlled by two LED Control Registers and sixteen PWM Registers. The detail about the LED Control Register is shown in Table 4, 5 and the PWM Register is shown in Table 13. B0h Update Register The data sent to the PWM Register will be stored in temporary registers. A write operation of “0000 0000” to the Update Register is required to update the registers. Table 15 B6h Frame Delay Register Bit D7:D5 D4:D0 Name FDT - Default 000 00000 Set the delay time between each frame in Auto Frame Play Mode. Frame Delay Time 4.87ms 9.5ms 19ms 38ms 76ms 152ms 304ms 608ms FDT 000 001 010 011 100 101 110 111 Table 16 B7h Frame Start Register Bit D7:D5 D4:D0 Name FS - Default 000 00000 Set the start frame in Auto Frame Play Mode. FS 000 001 010 011 100 101 110 111 Frame Start Frame 1 Frame 2 Frame 3 Frame 4 Frame 5 Frame 6 Frame 7 Frame 8 For example, if FS bit sets to “011”, it plays from the fourth frame to the eighth frame then cycled back to the first frame. 11 IS31FL3216A FUNCTIONAL BLOCK DIAGRAM C_FILT VCC IN Current Control Block ADC I2C Interface Configuration Register SYNC Decoder CLK R_EXT SCL SDA AD Frame Control Frame Data Registers OUT1 ~ OUT8 SDB Shutdown Control PWM Registers INTB OUT9 ~ OUT16 GPIO Port Registers INT BIAS PWM Counter Band-gap Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 OSC GND 12 IS31FL3216A APPLICATION INFORMATION PWM CONTROL By setting the MODE bit of the Configuration Register (00h) to “00”, IS31FL3216A operates in PWM Control Mode. The LED brightness of 16 channels can be modulated with 256 steps by PWM Registers. For example, if the data in PWM Register is “0000 0100”, then the PWM is the fourth step. Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. GAMMA CORRECTION In order to perform a better visual LED breathing effect we recommend using a gamma corrected PWM value to set the LED intensity. This results in a reduced number of steps for the LED intensity setting, but causes the change in intensity to appear more linear to the human eye. Gamma correction, also known as gamma compression or encoding, is used to encode linear luminance to match the non-linear characteristics of display. Since the IS31FL3216A can modulate the brightness of the LEDs with 256 steps, a gamma correction function can be applied when computing each subsequent LED intensity setting such that the changes in brightness matches the human eye's brightness curve. Table 17 32 Gamma Steps With 256 PWM Steps Choosing more gamma steps provides for a more continuous looking breathing effect. This is useful for very long breathing cycles. The recommended configuration is defined by the breath cycle T. When T=1s, choose 32 gamma steps, when T=2s, choose 64 gamma steps. The user must decide the final number of gamma steps not only by the LED itself, but also based on the visual performance of the finished product. Table 18 64 Gamma Steps With 256 PWM Steps C(0) C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 3 4 5 6 7 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 8 10 12 14 16 18 20 22 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 24 26 29 32 35 38 41 44 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 47 50 53 57 61 65 69 73 C(32) C(33) C(34) C(35) C(36) C(37) C(38) C(39) 77 81 85 89 94 99 104 109 C(40) C(41) C(42) C(43) C(44) C(45) C(46) C(47) 114 119 124 129 134 140 146 152 C(48) C(49) C(50) C(51) C(52) C(53) C(54) C(55) 158 164 170 176 182 188 195 202 C(56) C(57) C(58) C(59) C(60) C(61) C(62) C(63) 209 216 223 230 237 244 251 255 C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 4 6 10 13 18 256 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 224 22 28 33 39 46 53 61 69 192 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 78 86 96 106 116 126 138 149 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 161 173 186 199 212 226 240 255 256 PWM Data C(0) 160 128 96 64 32 224 0 0 8 PWM Data 192 16 24 32 40 48 56 64 Intensity Steps 160 Figure 9 128 Gamma Correction (64 Steps) Note, the data of 32 gamma steps is the standard value and the data of 64 gamma steps is the recommended value. 96 64 32 0 0 4 8 12 16 20 24 28 32 Intensity Steps Figure 8 Gamma Correction (32 Steps) Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 13 IS31FL3216A AUTO FRAME PLAY MODE AUDIO FRAME MODE By setting the MODE bit of the Configuration Register (00h) to “10”, the IS31FL3216A operates in Audio Frame Mode. It stores data of 8 frames and the 8 frames playing follow the input signal. 09h register is used to set the ADC sample rate for the input signal to control frames playing. It plays the first frame when the value is the smallest and plays the eighth frame when the value is the biggest (See Table 14). AUDIO MODULATED MODE AND GAIN SETTING By setting the AE bit of the Configuration Register (00h) to “1”, IS31FL3216A operates in Audio Modulated Mode. The intensity of LEDs is adjusted by the input signal. The audio input gain can be set by the Lighting Effect Register (03h). CHANNEL MODE SETTING IS31FL3216A has 16 channels for LEDs output. OUT9~OUT16 also can be set as GPIO ports. By setting the OUTx bit of the Channel Configuration Register (04h) to “1”, the corresponding channel will be used as GPIO port. When the OUTx is set to “0”, the corresponding channel will be used as LED output. CASCADE FOR SYNCHRONIZATION OF CHIPS Operating in the cascade mode can make two chips synchronize. By setting the CM bit of the Lighting Effect Register (03h) to “0”, IS31FL3216A operates as a master. The CLK pin offers the output clock signal. When the CM bit sets to “1”, IS31FL3216A operates as a slave. The CLK pin as a clock input pin. If there is only one chip to use, setting CM bit to “0” and the CLK pin should be floating. INTERRUPT FUNCTION When OUT9~OUT16 configure as input port and the interrupt function enabled, the INTB pin is available. If any input port of OUT9~OUT16 has state changing, the INTB pin will be pulled low. The MCU can get the information via reading the State Register (08h). The INTB will be back to high until the MCU reading the State Register (08h). REXT The output current of each LED channel can be adjusted by the external resistor on pin 28, REXT, as described in Formula (3). Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 1 .2  1400 REXT [k] (3) For example, in Figure 1, REXT = 100kΩ, So I LED  1 .2  1400  16.8mA 100 The recommended minimum value of REXT is 100kΩ. Smaller REXT values will result in a per channel current whose total will exceed the absolute maximum package current rating causing thermal damage to the device. The ILED defines the IMAX value which is set by the CS bit of Lighting Effect Register (03h). And the average output current of each output, IOUT, is calculated by the IMAX and PWM Register as Formula (2) in Table 13. PWM FREQUENCY The IS31FL3216A output channels operate with a default PWM frequency of 26kHz. Because all the OUTx channels are synchronized, the DC supply will experience large instantaneous current surges when the OUTx channels turn ON. These current surges will generate an AC ripple on the power supply which cause stress to the decoupling capacitors. When the AC ripple is applied to a monolithic ceramic capacitor chip (MLCC) it will expand and contract causing the PCB to flex and generate audible hum in the range of between 20Hz to 20kHz. To avoid this hum, there are many countermeasures, such as selecting the capacitor type and value which will not cause the PCB to flex and contract. Figure 10 below shows the variation of output PWM frequency across supply voltage and temperature. 40 Output PWM Frequency (kHz) By setting the MODE bit of the Configuration Register (00h) to “01”, the IS31FL3216A operates in Auto Frame Play Mode. It stores data of 8 frames and automatically plays in order. Customers can configure the delay time between each two frames and the first playing frame by setting the Frame Delay Register (B6h) and the Frame Start Register (B7h). I LED [mA]  125°C 30 85°C 25°C 20 -40°C 10 2.5 3 3.5 4 4.5 5 5.5 VCC (V) Figure 10 VCC vs. Output PWM Frequency SHUTDOWN MODE Shutdown mode can either be used as a means of reducing power. During shutdown mode all registers 14 IS31FL3216A retain their data and OUT9~OUT16 still can be available as GPIO port. Software Shutdown By setting SSD bit of the Configuration Register (00h) to “1”, the IS31FL3216A will operate in software shutdown mode, wherein they consume only 1μA (Typ.) current. When the IS31FL3216A is in software shutdown mode, all current sources are switched off. Hardware Shutdown The chip enters hardware shutdown mode when the SDB pin is pulled low. Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 15 IS31FL3216A CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 11 Classification profile Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 16 IS31FL3216A PACKAGE INFORMATION QFN-28 Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 17 IS31FL3216A RECOMMENDED LAND PATTERN Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. user’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 18 IS31FL3216A REVISION HISTORY Revision A Detail Information Initial release Lumissil Microsystems – www.lumissil.com Rev. A, 07/03/2017 Date 2017.07.03 19
IS31FL3216A-QFLS3-TR 价格&库存
很抱歉,暂时无法提供与“IS31FL3216A-QFLS3-TR”相匹配的价格&库存,您可以联系我们找货
  • 2500+5.248112500+0.67893
  • 5000+5.124095000+0.66288
  • 7500+5.062027500+0.65485
  • 12500+4.9931812500+0.64595
  • 17500+4.9529717500+0.64075
库存:51019
  • 1+10.855671+1.40435
  • 10+7.8476810+1.01522
  • 25+7.1004825+0.91856
  • 100+6.27793100+0.81215
  • 250+5.88567250+0.76141
  • 500+5.64877500+0.73076
  • 1000+5.537361000+0.71635
库存:51019
