IS31FL3199-QFLS2-TR
IS31FL3199-QFLS2-TR
    LUMISSIL
    VFQFN20
    IC LED DRIVER LIN DIM 40MA 20QFN
IS31FL3199-QFLS2-TR 数据手册
IS31FL3199 9-CHANNEL LIGHT EFFECT LED DRIVER October 2018 GENERAL DESCRIPTION FEATURES IS31FL3199 is a 9-channel light effect LED driver which features two-dimensional auto breathing mode and an audio modulated display mode. It has One Shot Programming mode and PWM Control mode for RGB lighting effects. The maximum output current can be adjusted in 8 levels (5mA~40mA).   In PWM Control mode, the PWM duty cycle of each output can be independently programmed and controlled in 256 steps to simplify color mixing. In One Shot Programming mode, the timing characteristics for output current - current rising, holding, falling and off time, can be adjusted individually so that each output can independently maintain a pre-established pattern achieving mixing color breathing or a single color breathing without requiring any additional interface activity, thus saving valuable system resources. The IS31FL3199 includes an audio modulated display mode, wherein the brightness of LED can be modulated by audio signal. There is a cascade pin for the synchronization of two chips.         2.7V to 5.5V supply voltage I2C interface, automatic address increment function Three groups RGB, single color LED breathing system-free pre-established pattern 9 independently controlled automatic and semiautomatic breathing system-free pre-established pattern 9 independently controlled outputs of 256 PWM steps 8 levels programmable output current Audio mode with AGC function Cascade for the synchronization of chips Over-temperature protection QFN-20 (3mm × 3mm) package APPLICATIONS   Mobile phones and other hand-held devices for LED display LED in home appliances IS31FL3199 is available in QFN-20 (3mm × 3mm). It operates from 2.7V to 5.5V over the temperature range of -40°C to +85°C. TYPICAL APPLICATION CIRCUIT Figure 1 Typical Application Circuit Note 1: IC should be placed far away from the antenna in order to prevent the EMI. Note 2: The VIH of I2C bus (VDD as above) should be smaller than VCC. And if VIH is lower than 3.0V, it is recommended add a level shift circuit to avoid extra shutdown current. Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 1 IS31FL3199 Figure 2 Typical Application Circuit (Cascade Mode) Note 3: One system should contain only one clock master, all slave parts should be configured as slave mode before the master is configured as master mode. Work as master mode or slave mode specified by Configuration Register-2 (CM bit, register 04h). Master part output master clock, and all the other parts which work as slave input this master clock. Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 2 IS31FL3199 PIN CONFIGURATION Package Pin Configuration (Top View) QFN-20 PIN DESCRIPTION No. Pin Description 1 VCC Power supply. 2 C_FILT Filter capacitor for audio control. 3~6 OUT1~OUT4 Current source outputs. 7 GND Ground. 8~12 OUT5~OUT9 Current source outputs. 13 SDB Shutdown the chip when pulled to low. 14 I_AUD Audio current input or output for cascade. 15 R_EXT Input terminal used to connect an external resistor. The value must be about 100kΩ. 16 AD I2C address setting. 17 IN Audio input. 18 SCL I2C serial clock. 19 SDA I2C serial data. 20 CLK/V_BM CLK input or output for cascade. When breathing mark function enable, this pin is V_BM pin. Thermal Pad Connect to GND. Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 3 IS31FL3199 ORDERING INFORMATION Industrial Range: -40°C to +85°C Order Part No. Package QTY/Reel IS31FL3199-QFLS2-TR QFN-20, Lead-free 2500 Copyright  ©  2018  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 4 IS31FL3199 ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at any OUTx pins Voltage at any input pin GND terminal current Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA =TJ Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA ESD (HBM) ESD (CDM) -0.3V ~ +6.0V -0.3V ~ VCC+0.3V -0.3V ~ VCC+0.3V 400mA 150°C -65°C ~ +150°C -40°C ~ +85°C 58.1°C/W ±2kV ±1kV Note 4: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS TA = -40°C ~ +85°C, unless otherwise noted. Typical value are TA = 25°C, VCC = 5V. Symbol Parameter Condition Min. Typ. VCC Supply voltage ICC Quiescent power supply current VSDB = VCC 3 ISD Shutdown current VSDB = 0V 1 VSDB = VCC, software shutdown 2 IOUT VHR Output current 2.7 PWM Control Mode, VDS = 0.4V PWM Register(07h~0Fh) = 0xFF Max. Unit 5.5 V mA μA 20 (Note 5) Audio Mode, Gain = 12dB VIN = 0.8VP-P, 1kHz square wave mA 18 (Note 5) Current sink headroom voltage IOUT = 20mA 400 mV Logic Electrical Characteristics (SDA, SCL, SDB, AD) VIL Logic “0” input voltage VCC= 2.7V~5.5V VIH Logic “1” input voltage VCC= 2.7V~5.5V IIL Logic “0” input current SSD= “0”, VINPUT= 0V (Note 6) IIH Logic “1” input current SSD= “0”, VINPUT= VCC (Note 6) Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 0.4 1.4 V V 5 5 nA nA 5 IS31FL3199 DIGITAL INPUT SWITCHING CHARACTERISTICS (Note 6) Symbol Parameter Condition Standard Mode Min. Typ. Fast Mode Max. Min. Typ. 100 Max. fSCL Serial-Clock frequency tBUF Bus free time between a STOP and a START condition 4.7 1.3 μs tHD, STA Hold time (repeated) START condition 4.0 0.6 μs tSU, STA Repeated START condition setup time 4.7 0.6 μs tSU, STO STOP condition setup time 4.0 0.6 μs tHD, DAT Data hold time (Note 7) 0 tSU, DAT Data setup time (Note 8) 250 100 ns tLOW SCL clock low period 4.7 1.3 μs tHIGH SCL clock high period 4.0 0.7 μs 3.45 400 Unit 0 0.9 kHz μs tR Rise time of both SDA and SCL signals, receiving (Note 9) 1000 20+0.1Cb 300 ns tF Fall time of both SDA and SCL signals, receiving (Note 9) 300 20+0.1Cb 300 ns Note 5: The average current of each channel is IOUT. Note 6: Guaranteed by design. Note 7: The minimum tHD, DAT measured start from VIL(max) of SCL signal. The maximum tHD,DAT has only to be met if the device does not stretch the LOW period (tLOW) of the SCL signal. VIL(max) Note 8: A Fast-mode I2C-bus device can be used in a Standard-mode I2C-bus system, but the requirement tSU,DAT≥ 250ns must then be met. This will automatically be the case if the device does not stretch the LOW period of the SCL signal. If such a device does stretch the LOW period of the SCL signal, it must output the next data bit to the SDA line tR max + tSU,DAT = 1000 + 250 = 1250ns (according to the Standard-mode I2C-bus specification) before the SCL line is released. Note 9: Cb= total capacitance of one bus line in pF. ISINK ≤ 6mA. tR and tF measured between 0.3 × VCC and 0.7 × VCC. Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 6 IS31FL3199 DETAILED DESCRIPTION The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. I2C INTERFACE The IS31FL3199 uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. The IS31FL3199 has a 7-bit slave address (A7:A1), followed by the R/W bit, A0. Since IS31FL3199 only supports write operations, A0 must always be “0”. The value of bits A1 and A2 are decided by the connection of the AD pin. After the last bit of the chip address is sent, the master checks for the IS31FL3199’s acknowledge. The master releases the SDA line high (through a pull-up resistor). Then the master sends an SCL pulse. If the IS31FL3199 has received the address correctly, then it holds the SDA line low during the SCL pulse. If the SDA line is not low, then the master should send a “STOP” signal (discussed later) and abort the transfer. The complete slave address is: Table 1 Slave Address (Write Only): Bit A7:A3 A2:A1 A0 Value 11001 AD 0 Following acknowledge of IS31FL3199, the register address byte is sent, most significant bit first. IS31FL3199 must generate another acknowledge indicating that the register address has been received. AD connected to GND, AD = 00; AD connected to VCC, AD = 11; AD connected to SCL, AD = 01; AD connected to SDA, AD = 10; Then 8-bit of data byte are sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, the IS31FL3199 must generate another acknowledge to indicate that the data was received. The SCL line is uni-directional. The SDA line is bi-directional (open-collector) with a pull-up resistor (typically 4.7kΩ). The maximum clock frequency specified by the I2C standard is 400kHz. In this discussion, the master is the microcontroller and the slave is the IS31FL3199. The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high. ADDRESS AUTO INCREMENT To write multiple bytes of data into IS31FL3199, load the address of the data register that the first data byte is intended for. During the IS31FL3199 acknowledge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS31FL3199 will be placed in the new address, and so on (Figure 6). The timing diagram for the I2C is shown in Figure 3. The SDA is latched in on the stable high level of the SCL. When there is no interface activity, the SDA line should be held high. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. The start signal will alert all devices attached to the I2C bus to check the incoming address against their own chip address. SDA tSU,DAT tLOW SCL tHD,DAT S tHIGH tSU,STA tHD,STA R tSU,STO tBUF P tHD,STA tR tF Start Condition Restart Condition Figure 3 Figure 4 Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 Stop Condition Start Condition Interface Timing Bit Transfer 7 IS31FL3199 Figure 5 Figure 6 Writing to IS31FL3199(Typical) Writing to IS31FL3199(Automatic Address Increment) REGISTERS DEFINITIONS Table 2 Register Function Address Name Function Table Default 00h Shutdown Register Set software shutdown mode 3 0000 0000 01h LED Control Register 1 OUT1~ OUT6 enable bit 4 0111 0111 02h LED Control Register 2 OUT7~ OUT9 enable bit 5 0000 0111 03h Configuration Register 1 Set operation mode 6 04h Configuration Register 2 Set output current and audio input gain 7 05h Ramping Mode Register Set the ramping function mode 8 06h Breathing Mark Register Set the breathing mark function 9 PWM Register 9 channels PWM duty cycle data registers 10 Data Update Register Load PWM Registers and LED Control Registers’ data 11h ~ 19h T0 Register Set the T0 time 11 1Ah ~ 1Ch T1~T3 Register Set the T1~T3 time 12 1Dh ~ 25h T4 Register Set the T4 time 13 26h Time Update Register Load time registers’ data - FFh Reset Register Reset all registers to default value - 07h ~ 0Fh 10h Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 - 0000 0000 xxxx xxxx 0000 0000 xxxx xxxx 8 IS31FL3199 AGCM 0 1 Table 3 00h Shutdown Register Bit D7:D1 D0 Name - SSD Default 0000 000 0 Table 7 04h Configuration Register 2 The Shutdown Register sets software shutdown mode of IS31FL3199. SSD 0 1 AGC Mode Selection Mode1 (Fast Modulation) Mode2 (Slow Modulation) Software Shutdown Enable Software shutdown mode Normal operation Bit D7 D6:D4 D3 D2:D0 Name CM CS - AGS Default 0 000 0 000 The Configuration Register 2 stores the intensity control settings for all of the LEDs and the control mode. Table 4 01h LED Control Register 1(OUT1~OUT6) Bit D7 D6:D4 D3 D2:D0 Name - OUT6:OUT4 - OUT3:OUT1 Default 0 111 0 111 Table 5 02h LED Control Register 2(OUT7~OUT9) Bit D7:D3 D2:D0 Name - OUT9:OUT7 Default 0000 0 111 The LED Control Registers store the on or off state of each channel LED. OUTx 0 1 LED State LED off LED on Table 6 03h Configuration Register 1 Bit D7 D6:D4 D3 D2 D1 D0 Name - RGB3:1 - AE AGCE AGCM Default 0 000 0 0 0 0 The Configuration Register 1 sets operation mode. RGBx 0 1 RGB Mode Selection PWM Control Mode One Shot Programming Mode AE 0 1 Audio Modulate Enable Disable Enable AGCE 0 1 AGC Function Enable Enable Disable Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 CM 0 1 Control Mode Master Slave CS 000 001 010 011 100 101 110 111 Current Setting 20mA 15mA 10mA 5mA 40mA 35mA 30mA 25mA AGS 000 001 010 011 100 101 110 111 Audio Gain Selection Gain= 0dB Gain= 3dB Gain= 6dB Gain= 9dB Gain= 12dB Gain= 15dB Gain= 18dB Gain= 21dB Table 8 05h Ramping Mode Register Bit D7 D6:D4 D3 D2:D0 Name - RM(RGB3:1) - HT(RGB3:1) Default 0 000 0 000 The Ramping Mode Register sets the ramping function. RM 0 1 Ramping Mode Enable Disable Enable HT 0 1 Hold Time Selection Breathing Hold on T2 Breathing Hold on T4 9 IS31FL3199 Table 11 11h~19h T0 Register (OUT1~OUT9) Table 9 06h Breathing Mark Register Bit D7:D5 D4 D3:D0 Bit D7:D6 D5:D4 D3:D0 Name - BME CSS Name - B A Default 000 0 0000 Default 00 00 0000 The Breathing Mark Register sets the breathing mark function (Detail information refers to Page 11). BME 0 1 Breathing Mark Enable Disable Enable The T0 Registers set the T0 time in One Shot Programming Mode. T0 = τ×A×2B A = 0~15, B = 0~3 and τ = 260ms (Typ.) For example, the max T0 is 260ms×15×23 = 31.2s Table 12 1Ah~1Ch T1~T3 Register (RGB1~RGB3) CSS 0000 0001 0010 0011 0100 0101 0110 0111 1000 Others Channel Selection OUT1 OUT2 OUT3 OUT4 OUT5 OUT6 OUT7 OUT8 OUT9 Not available D7 D6:D4 D3 D2:D0 Name DT B - A Default 0 000 0 000 The T1~T3 Registers set the T1~T3 time in One Shot Programming Mode. Double Time T3 =T1 T3 = 2T1 DT 0 1 Table 10 07h~0Fh PWM Register(OUT1~OUT9) Bit D7:D0 Name PWM Default 0000 0000 The PWM Registers can modulate RGB light with 256 different items. The value of PWM Registers decide the average output current of OUT1~OUT9. The average output current may be computed using the Formula (1): I OUT Bit I MAX 7    D[n]  2 n 256 n0 (1) Where “n” indicates the bit location in the respective PWM register. For example: D7:D0 = 10110101, IOUT = IMAX (20+22+24+25+27)/256 IMAX is set by Configuration Register2 (04h). If A = 0~4, T1 = T3 = τ×2A, τ = 260ms (Typ.) If A = 5~6, the breathing function disable. If A = 7, T1= T3 = 0.1ms If B = 1~7, T2 = τ×2B-1, τ = 260ms (Typ.) If B = 0, T2 = 0s. For example, the max T1&T3 is 260ms×24 = 4.16s The max T2 is 260ms×26 = 16.64s Table 13 1Dh~25h T4 Register (OUT1~OUT9) Bit D7:D6 D5:D4 D3:D0 Name - B A Default 00 00 0000 The T4 Registers set the T4 time in One Shot Programming Mode. T4 = τ×A×2B A = 0~15, B = 0~3 and τ = 260ms (Typ.) For example, the max T4 is 260ms×15×23 = 31.2s 10h Data Update Register The data sent to the PWM Registers and the LED Control Registers will be stored in temporary registers. A write operation of “0000 0000” data to the Data Update Register is required to update the registers (01h~02h, 07h~0Fh). Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 26h Time Update Register The data sent to the time registers (11h~25h) will be stored in temporary registers. A write operation of “0000 0000” data to the Time Update Register is required to update the registers (11h~25h). 10 IS31FL3199 FFh Reset Register Once user writes “0000 0000” data to the Reset Register, IS31FL3199 will reset all registers to default value. On initial power-up, the IS31FL3199 registers are reset to their default values for a blank display. Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 11 IS31FL3199 FUNCTIONAL BLOCK DIAGRAM Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 12 IS31FL3199 TYPICAL APPLICATION GENERAL DESCRIPTION IS31FL3199 is a 9-channel LED driver with two-dimensional auto breathing and PWM Control mode. It can drive nine LEDs or three groups RGB. POWER ON SEQUENCE IS31FL3199 provides a power-on reset feature that is controlled by VBAT (voltage at pin1) supply voltage. When the VBAT exceeds 2.0V (POR_H, Typ.), the internal circuit starts to work. The reset signal will be generated to perform a power-on reset (POR_H) operation, which will reset all control circuits and configuration registers until the internal power voltage become stable. Before SDB pull high, the I2C operation is allowed. The SDB rising edge will reset the I2C bus. RGB BREATHING CONTROL WITH AUTO COLOR CHANGING By setting the RGBx bits of the Configuration Register1 (03h) to “1”, the IS31FL3199 will operate in One Shot Programming mode. In this mode each group RGB can be modulated breathing cycle independently by T0~T4. The full cycle is T1 to T4 (Figure 8). Setting different T0~T4 can achieve RGB breathing with auto color changing. The maximum intensity of each RGB can be adjusted independently by the PWM Registers (07h~0Fh). Note, if IS31FL3199 operates in the One Shot Programming mode and then enters into the shutdown mode, an 8-bit data write operation to the Time Update Register is required to restart the LED breathing effect after the IC is re-enabled. Figure 8 Breathing Timing RGB AUTO BREATHING CONTROL WITH COLOR SETTING Figure 7 SDB Pin Sequence Note 1: I2C operation is allowed when SDB is low. Note 2: There should be no I2C operation 10µs before and after SDB rinsing edge. In some case, like a mouse, when plug-out and quickly plug-in back the USB power, the LED will flash for a very short time. The reason is the power is not lower than the POR_L voltage point 1.92V (Typ.), and the device still stores the previous setting data, if user pull-up the SDB high when power up, following with the initial operation, the LED will be ON between SDB rising edge and PWM initial effective, to avoid this, as above figure, a writing to 00h is recommended to shutdown the chip before pull-high the SDB pin. PWM CONTROL By setting the RGBx bits of the Configuration Register1 (03h) to “0”, the IS31FL3199 will operate in PWM Control mode. The PWM Registers (07h~0Fh) can modulate LED brightness of 9 channels with 256 steps. For example, if the data in PWM Register is “0000 0100”, then the PWM is the fourth step. Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 IS31FL3199 can pre-establish pattern achieving mixing color breathing. There are three groups RGB. Each RGB consists of three channels. Every channel has an 8-bit PWM data register. The color can be set by the PWM data register. For example, there are three PWM data: 20h, 80h, C8h, so the three data will determine a kind of color. After setting the color, T0~T4 time register will be set to control the LED breathing panel. And T0~T4 time should be same for one RGB or the pre-established color will change. SEMIAUTOMATIC BREATHING By setting the RGBx bits of the Configuration Register1 (03h) to “1” and the RM bit of the Ramping Mode Register (05h) to “1”, the ramping function is enabled. HT is the time select bit. When HT bit is set to “0”, T2 will be held forever, and the LED will remain at the programmed maximum intensity. When HT bit is set to “1”, T3 will continue and T4 will be held, causing the LED to complete one breathing cycle and then remain off. AUDIO MODULATE DISPLAY MODE WITH AGC FUNCTION In audio modulate display mode the output current can be modulated by the audio input signal. An AGC automatically adjusts the audio input gain to improve the dynamic range of the LED current modulation, thus improving the visual effect. When the input signal is 13 IS31FL3199 large such that the amplifier output begins to clip, the gain goes down. If the input signal is small, the gain increases, adjusting the output to provide a good dynamic response to the input signal. master. There are two pins (CLK, I_AUD) for synchronization of chips. CLK pin can synchronize the breathing and I_AUD pin can synchronize the audio current. The AGC can be disabled and the audio gain can be set by programming Configuration Register 1 (03h). SHUTDOWN MODE BREATHING MARK FUNCTION By setting the BME bit of the Breathing Mark Register (06h) to “1”, the breathing mark function is enabled. The CLK/V_BM pin is used as V_BM. If the BME bit sets to “0”, the breathing mark function disabled. The CLK/V_BM pin is used as CLK. V_BM is an output pin. The breathing mark function is useful as a signal to notify the MCU when to update the color data. At the end of time period T1, V_BM will induce a falling edge and hold logic low, so the new data can be sent by MCU at this time. At the end of T3, V_BM will induce a rising edge and the MCU can send an update command to update all data simultaneously (Figure 9). The marking channel (OUT1~OUT9) is selected by the CSS bits of the Breathing Mark Register (06h). When IS31FL3199 operates as slave, the breathing mark function is unavailable. Shutdown mode can either be used as a means of reducing power consumption or generating a flashing display (repeatedly entering and leaving shutdown mode). During shutdown mode all registers retain their data and can be accessed via the I2C bus interface. The only difference between Software and Hardware shutdown mode is the current consumption. Software Shutdown By setting SSD bit of the Shutdown Register (00h) to “0”, the IS31FL3199 will operate in software shutdown mode, wherein it consumes only 2μA (Typ.) current. When the IS31FL3199 is in software shutdown mode, all current sources are switched off. Hardware Shutdown The chip enters hardware shutdown mode when the SDB pin is pulled low, wherein it consumes only 1μA (Typ.) current. When the IS31FL3199 is in hardware shutdown mode, all current sources are switched off. Register Access During Shutdown Figure 9 V_BM Signal CASCADE FOR SYNCHRONIZATION OF CHIPS All registers are accessible (read or write) while the IS31FL3199 is in either Software or Hardware shutdown. SDB turn on time is about 200µs, do not send I2C commands during a rising edge of the SDB pin as data will be corrupted. Data transfers during SDB falling edge, low or high steady state are permitted. Operating in the cascade mode can make two chips synchronize. By setting the CM bit of Configuration Register 2 (04h) to “0”, IS31FL3199 operates as a Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 14 IS31FL3199 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 10 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 15 IS31FL3199 PACKAGE INFORMATION QFN-20 Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 16 IS31FL3199 RECOMMENDED LAND PATTERN QFN-20 Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. user’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 17 IS31FL3199 REVISION HISTORY Revision Detail Information Date A Initial release 2011.12.26 B Add ESD(HBM/CDM) value 2013.12.25 C 1. Update θJA value 2. Update IIH/IIL test condition 3. VIH, VIL condition revise to VCC= 2.7V~5.5V 4. Add STANDARD MODE in DIGITAL INPUT SWITCHING CHARACTERISTICS 5. Add function block diagram 6. Add POWER ON SEQUENCE section in APPLICATION INFORMATION 7. Update POD 8. Add land pattern 2018.10.15 Lumissil Microsystems – www.lumissil.com Rev. C, 10/15/2018 18
IS31FL3199-QFLS2-TR 价格&库存
很抱歉,暂时无法提供与“IS31FL3199-QFLS2-TR”相匹配的价格&库存,您可以联系我们找货
IS31FL3199-QFLS2-TR
  • 2500+4.373242500+0.56757
  • 5000+4.266495000+0.55372
  • 7500+4.213017500+0.54678
  • 12500+4.1537912500+0.53909
  • 17500+4.1191717500+0.53460
库存:9983
IS31FL3199-QFLS2-TR
  • 1+9.177511+1.19108
  • 10+6.6099410+0.85785
  • 25+5.9692325+0.77470
  • 100+5.26053100+0.68272
  • 250+4.92214250+0.63881
  • 500+4.71812500+0.61233
  • 1000+4.590681000+0.59579
库存:9983
