IS31LT3352-V1GRLS2-TR 数据手册
IS31LT3352
40V LED DRIVER WITH TEMPERATURE COMPENSATION
September 2011
GENERAL DESCRIPTION
FEATURES
The IS31LT3352 is a continuous mode inductive
step-down converter, designed for driving a single
LED or multiple series connected LEDs efficiently
from a voltage source higher than the required LED
voltage. The chip operates from an input supply
between 6V and 40V and provides an externally
adjustable output current of up to 750mA. Depending
upon supply voltage and external components, this
can provide up to 30 watts of output power.
The IS31LT3352 includes an integrated output
switch and a high-side output current sensing circuit,
which uses an external resistor to set the nominal
average output current. The IS31LT3352 integrates
temperature compensation function in order to
maintain LEDs’ stable and reliable operation. The
IS31LT3352 measures the thermistance mounted
close to LEDs. When ambient temperature near
LEDs goes too high and the Negative Temperature
Coefficient thermistors reach the value of threshold
resistance connected at RTH pin, output current starts
to reduce automatically. After the ambient
temperature falls down to a safe temperature,the
current will return to the set value.
Simple low parts count
Internal 40V power switch
Wide input voltage range: 6V to 40V
Up to 750mA output current
High efficiency (up to 95% )
1200:1 dimming ratio
Typical 5% output current accuracy
Single pin on/off and brightness control using
DC voltage or PWM
Up to 1MHz switching frequency
Inherent open-circuit LED protection
Thermal shutdown to protect IC itself
Temperature compensation to protect LEDs
APPLICATIONS
Low voltage halogen replacement LEDs
Automotive lighting
Low voltage industrial lighting
LED back-up lighting
Illuminated sign
The IS31LT3352 can be connected as LED drivers’
chain with the same temperature compensation
percentage. In this chain, every IS31LT3352’s ADJO
output pin drives next stage’s IS31LT3352 ADJI input
pin with temperature compensation information. So,
only one thermistor is needed in the whole
IS31LT3352 system.
TYPICAL APPLICATION CIRCUIT
Figure 1
Lumissil Microsystems – www.lumissil.com
Rev. A, 09/01/2011
Typical Application Circuit
1
IS31LT3352
SYSTEM APPLICATION
Note:
Each IS31LT3352 can driver up to three slave chips in the next stages, and it is recommend no more than three stages are used for the current
coherence, therefore, up to thirteen IS31LT3352s are allowed in one system
Rev. A, 09/01/2011
2
IS31LT3352
PIN CONFIGURATION
Package
Pin Configuration
SOP-8
PIN DESCRIPTION
No.
Pin
Description
1
VIN
Input voltage (6V to 40V). Decouple to ground with 1μF or
higher X7R ceramic capacitor close to device
2
ISENSE
Connect resistor RS from this pin to VIN to define nominal
average output current IOUTnom =0.1/RS
3
RTH
The pin set the starting temperature of temperature
compensation by connecting an external resistor.
4
RNTC
5
ADJO
6
ADJI
7
GND
The output currents reduction slope set pin by connecting an
external thermistor in temperature compensation mode.
LED drivers chain application pin.
* When R3(NTC)>R2,VADJO=VADJI
* When R3(NTC)
IS31LT3352-V1GRLS2-TR 价格&库存
很抱歉,暂时无法提供与“IS31LT3352-V1GRLS2-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9.495311+1.18824
- 10+6.8174210+0.85313
- 25+6.1551025+0.77025
- 100+5.42780100+0.67924
- 国内价格 香港价格
- 2500+4.386842500+0.54897
- 5000+4.068295000+0.50911
- 7500+3.993037500+0.49969
