IS31FL3743A-QULS4-TR
    LUMISSIL
    UFQFN40
    IC LED DRIVER LIN DIM
IS31FL3743A-QULS4-TR 数据手册
IS31FL3743A 18 × 11 DOTS MATRIX LED DRIVER August 2018 GENERAL DESCRIPTION FEATURES The IS31FL3743A is a general purpose 18×n (n=1~11) LED Matrix programmed via 1MHz I2C compatible interface. Each LED can be dimmed individually with 8-bit PWM data and 8-bit DC scaling data which allowing 256 steps of linear PWM dimming and 256 steps of DC current adjustable level.              Additionally each LED open and short state can be detected, IS31FL3743A store the open or short information in Open-Short Registers. The Open-Short Registers allowing MCU to read out via I2C compatible interface, inform MCU whether there are LEDs open or short and the locations of open or short LEDs. The IS31FL3743A operates from 2.7V to 5.5V and features a very low shutdown and operational current. IS31FL3743A is available in UQFN-40 (5mm×5mm) package. It operates from 2.7V to 5.5V over the temperature range of -40°C to +125°C. Supply voltage range: 2.7V to 5.5V 18 current sinks Support 18×n (n=1~11) LED matrix configurations Individual 256 PWM control steps Individual 256 DC current steps Global 256 DC current steps SDB rising edge reset I2C module Programmable H/L logic: 1.4V/0.4V, 2.4V/0.6V 24kHz PWM frequency 1MHz I2C-compatible interface State lookup registers Individual open and short error detect function 180 degree phase delay operation to reduce power noise De-Ghost Cascade for synchronization of chips UQFN-40 (5mm×5mm) package    APPLICATIONS    Hand-held devices for LED display Gaming device (Keyboard, Mouse etc.) LED in white goods application TYPICAL APPLICATION CIRCUIT 5V 5 1 F 22 1 F PVCC SW11 0.1 F SW10 VCC 11 40 SW1 SW2 SW3 SW4 SW5 SW6 SW7 SW8 SW9 SW10 SW11 0.1 F 51R CS18 VIO/MCU 2k SW2 2k 28 27 Micro Controller 26 SW1 SDA SCL CS18 29 24 RISET 10k 25 23 6 20R CS17 20R CS16 IS31FL3743A SDB 0.1 F 100k 30 4 CS17 12 13 SYNC 51R CS3 20R CS2 ISET 20R ADDR 2 CS2 ADDR 1 CS1 38 CS1 39 GND Figure 1 Typical Application Circuit: 66 RGBs Note 1: For the mobile applications the IC should be placed far away from the mobile antenna in order to prevent the EMI. Note 2: PVCC and VCC should use same power supply to avoid the additional ISD, it is OK to use PVCC=VCC=5V and VIO=3.3V. Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 1 IS31FL3743A TYPICAL APPLICATION CIRCUIT (CONTINUED)  5V 5 1 F 22 1 F PVCC SW11 0.1 F SW10 VCC 11 40 SW1 SW2 SW3 SW4 SW5 SW6 SW7 SW8 SW9 SW10 SW11 0.1 F 20R CS18 VIO/MCU 2k SW2 2k 28 27 Micro Controller 26 SW1 SDA SCL CS18 29 24 RISET 10k 25 23 20R CS17 6 20R CS16 IS31FL3743A SDB 0.1 F 100k 30 4 CS17 12 13 SYNC 20R CS3 20R CS2 ISET 20R ADDR 2 CS2 ADDR 1 CS1 38 CS1 39 GND Figure 2 Typical Application Circuit: 198 Mono Color LEDs VCC VIO 2k ADDR1 ADDR2 ADDR2 SDA ADDR1 SCL ADDR2 ADDR1 ADDR2 2k SDA Micro Controller ADDR1 SCL SDB SDA SDA SDA SDA SDA SDA SDA SCL SCL SCL SCL SCL SCL SCL SDB SDB SDB SDB SDB SDB SDB 100k SYNC SYNC Master SYNC SYNC Slave 1 SYNC VCC SYNC Slave 2 SYNC VCC SYNC VCC ADDR2 ADDR2 ADDR1 ADDR1 VCC ADDR2 SDA ADDR2 ADDR1 SCL ADDR1 SDA SDA SDA SDA SDA SDA SDA SDA SCL SCL SCL SCL SCL SCL SCL SCL SDB SDB SDB SDB SDB SDB SDB SDB Slave 4 Slave 5 Slave 3 Slave 6 Slave 7 Figure 3 Typical Application Circuit (Eight Parts Synchronization-Work) Note 3: The 20R and 50R between LED and IC is only for thermal reduction, for mono red LED, if PVCC=VCC=3.3V, don’t need these resistors. Note 4: One part is configured as master mode, all the other 7 parts configured as slave mode. Work as master mode or slave mode specified by Configuration Register (SYNC bits, register 25h, Page 2). Master part output master clock, and all the other parts which work as slave input this master clock. Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 2 IS31FL3743A PIN CONFIGURATION 40 SW10 39 CS1 38 CS2 37 CS3 36 CS4 35 CS5 34 CS6 33 CS7 32 CS8 31 CS9 CS18 12 CS17 13 CS16 14 CS15 15 PGND 16 CS14 17 CS13 18 CS12 19 CS11 20 Pin Configuration (Top View) SW11 11 Package UQFN-40   PIN DESCRIPTION No. Pin Description 1~4 SW8,SW6,SW4,SW2 Power SW. 5 PVCC Power for current source SW. 6~11 SW1,SW3,SW5, SW7,SW9,SW11 Power SW. 12~15 CS18~CS15 Current sink pin for LED matrix. 16 PGND Power GND. 17~21 CS14~CS10 Current sink pin for LED matrix. 22 VCC Analog and digital circuits. 23 GND Analog GND. 24 ADDR2 I2C address select pin 2. 25 ADDR1 I2C address select pin 1. 26 SDB Shutdown pin. 27 SCL I2C compatible serial clock. 28 SDA I2C compatible serial data. 29 ISET Set the maximum IOUT current. 30 SYNC Synchronization. 31~39 CS9~CS1 Current sink pin for LED matrix. 40 SW10 Power SW. Thermal Pad Connect to GND. Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 3 IS31FL3743A ORDERING INFORMATION Industrial Range: -40°C to +125°C Order Part No. Package QTY/Reel IS31FL3743A-QULS4-TR UQFN-40, Lead-free 2500 Copyright  ©  2018  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use  in such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances  Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 4 IS31FL3743A ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at any input pin Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA=TJ Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA ESD (HBM) ESD (CDM) -0.3V ~+6.0V -0.3V ~ VCC+0.3V +150°C -65°C ~+150°C -40°C ~ +125°C 41.6°C/W ±7kV ±1kV Note 5: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS The following specifications apply for VCC = 3.6V, TA= 25°C, unless otherwise noted. Symbol Parameter VCC Supply voltage ICC Quiescent power supply current Conditions Min. Typ. 2.7 VSDB=VCC, all LEDs off 1.8 VSDB=0V 1.3 1.3 ISD Shutdown current VSDB= VCC, Configuration Register written “0000 0000 IOUT Maximum constant current of CSx RISET=10kΩ, GCC=0xFF SL=0xFF ILED Average current on each LED ILED = IOUT(PEAK)/Duty(11.275) RISET=10kΩ, GCC=0xFF SL=0xFF 3.03 Current switch headroom voltage SWx ISWITCH=612mA RISET=10kΩ, GCC=0xFF, SL=0xFF 550 Current sink headroom voltage CSx ISINK=34mA, RISET=10kΩ, GCC=0xFF, SL=0xFF 450 VHR tSCAN Period of scanning tNOL1 tNOL2 32.09 34.5 Max. Unit 5.5 V mA μA 36.91 mA mA mV 33 µs Non-overlap blanking time during scan, the SWx and CSy are all off during this time 0.83 µs Delay total time for CS1 to CS 18, during this time, the SWx is on but CSx is not all turned on 0.3 µs Logic Electrical Characteristics (SDA, SCL, ADDRx, SDB) VIL Logic “0” input voltage VCC=2.7V~5.5V, LGC=0 VIH Logic “1” input voltage VCC=2.7V~5.5V, LGC=0 Input schmitt trigger hysteresis VCC=3.6V, LGC=0 VIL Logic “0” input voltage VCC=2.7V~5.5V, LGC=1 VIH Logic “1” input voltage VCC=2.7V~5.5V, LGC=1 Input schmitt trigger hysteresis VCC=3.6V, LGC=1 IIL Logic “0” input current IIH Logic “1” input current VHYS VHYS Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 0.4 1.4 V V 0.2 V 0.6 2.4 V V 0.2 V SDB=L, VINPUT = L (Note 6) 5 nA SDB=L, VINPUT = H (Note 6) 5 nA 5 IS31FL3743A DIGITAL INPUT I2C SWITCHING CHARACTERISTICS (NOTE 6) Fast Mode Symbol Parameter Min. Typ. Max. fSCL Serial-clock frequency tBUF Fast Mode Plus Min. Typ. Max. Units - 400 - 1000 kHz Bus free time between a STOP and a START condition 1.3 - 0.5 - μs tHD, STA Hold time (repeated) START condition 0.6 - 0.26 - μs tSU, STA Repeated START condition setup time 0.6 - 0.26 - μs tSU, STO STOP condition setup time 0.6 - 0.26 - μs tHD, DAT Data hold time - - - - μs tSU, DAT Data setup time 100 - 50 - ns tLOW SCL clock low period 1.3 - 0.5 - μs tHIGH SCL clock high period 0.7 - 0.26 - μs tR Rise time of both SDA and SCL signals, receiving - 300 - 120 ns tF Fall time of both SDA and SCL signals, receiving - 300 - 120 ns Note 6: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 6 IS31FL3743A FUNCTIONAL BLOCK DIAGRAM Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 7 IS31FL3743A DETAILED DESCRIPTION   I2C INTERFACE IS31FL3743A uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. The IS31FL3743A has a 7-bit slave address (A7:A1), followed by the R/W bit, A0. Set A0 to “0” for a write command and set A0 to “1” for a read command. The value of bits A1 and A2 are decided by the connection of the ADDRx pin. Table 1 Slave Address: ADDR2 ADDR1 A7:A5 A4:A3 A2:A1 A0 The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. After the last bit of the chip address is sent, the master checks for the IS31FL3743A’s acknowledge. The master releases the SDA line high (through a pull-up resistor). Then the master sends an SCL pulse. If the IS31FL3743A has received the address correctly, then it holds the SDA line low during the SCL pulse. If the SDA line is not low, then the master should send a “STOP” signal (discussed later) and abort the transfer. Following acknowledge of IS31FL3743A, the register address byte is sent, most significant bit first. IS31FL3743A must generate another acknowledge indicating that the register address has been received. GND GND 00 00 GND SCL 00 01 GND SDA 00 10 GND VCC 00 11 SCL GND 01 00 SCL SCL 01 01 SCL SDA 01 10 SCL VCC 01 11 SDA GND 10 00 SDA SCL 10 01 ADDRESS AUTO INCREMENT SDA SDA 10 10 SDA VCC 10 11 VCC GND 11 00 VCC SCL 11 01 VCC SDA 11 10 VCC VCC 11 11 To write multiple bytes of data into IS31FL3743A, load the address of the data register that the first data byte is intended for. During the IS31FL3743A acknowledge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS31FL3743A will be placed in the new address, and so on. The auto increment of the address will continue as long as data continues to be written to IS31FL3743A (Figure 7). 010 Then 8-bit of data byte are sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, the IS31FL3743A must generate another acknowledge to indicate that the data was received. 0/1 ADDR1/2 connected to GND, (A2:A1)/(A4:A3)=00; ADDR1/2 connected to VCC, (A2:A1)/(A4:A3)=11; ADDR1/2 connected to SCL, (A2:A1)/(A4:A3)=01; ADDR1/2 connected to SDA, (A2:A1)/(A4:A3)=10; The SCL line is uni-directional. The SDA line is bidirectional (open-collector) with a pull-up resistor (typically 400kHz I2C with 4.7kΩ, 1MHz I2C with 2kΩ). The maximum clock frequency specified by the I2C standard is 1MHz. In this discussion, the master is the microcontroller and the slave is the IS31FL3743A. The timing diagram for the I2C is shown in Figure 4. The SDA is latched in on the stable high level of the SCL. When there is no interface activity, the SDA line should be held high. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. The start signal will alert all devices attached to the I2C bus to check the incoming address against their own chip address. Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high. READING OPERATION Most of the registers can be read. To read the FCh, FEh, after I2C start condition, the bus master must send the IS31FL3743A device ____ address with the R/W bit set to “0”, followed by the register address (FEh or F1h) which determines which register is accessed. Then restart I2C, the bus master should send the IS31FL3743A device address with ____ the R/W bit set to “1”. Data from the register defined by the command byte is then sent from the IS31FL3743A to the master (Figure 8). To read the registers of Page 0 thru Page 3, the FDh should write with 00h before follow the Figure 8 sequence to read the data. That means, when you want to read registers of Page 0, the FDh should point to Page 0 first and you can read the Page 0 data. 8 IS31FL3743A Figure 4 I2C Interface Timing Figure 5 I2C Bit Transfer Figure 6 I2C Writing to IS31FL3743A (Typical) Figure 7 I2C Writing to IS31FL3743A (Automatic Address Increment) Figure 8 I2C Reading from IS31FL3743A Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 9 IS31FL3743A Table 2 Command Register Definition Address Name Function Table R/W Default FEh Command Register Write Lock To unlock Command Register 4 R/W 0000 0000 FDh Command Register Available Page 0 to Page 2 Registers 3 W xxxx xxxx FCh ID Register For read the product ID only Read result is the slave address - R Slave Address   REGISTER CONTROL   Table 3 FDh Command Register Data Function 0000 0000 Point to Page 0 (PG0, PWM Register is available) 0000 0001 Point to Page 1 (PG1, White balance Scaling Register is available) 0000 0010 Point to Page 2 (PG2, Function Register is available) Others Reserved Note: FDh is locked when power up, need to unlock this register before write command to it. See Table 4 for detail. The Command Register should be configured first after writing in the slave address to choose the available register. Then write data in the choosing register. Power up default state is “0000 0000”. For example, when write “0000 0001” in the Command Register (FDh), the data which writing after will be stored in the White balance Scaling Register. Write new data can configure other registers. Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 10 IS31FL3743A Table 4 FEh Command Register Write Lock (Read/Write) Bit D7:D0 Name CRWL Default 0000 0000 (FDh write disable) To select the PG0~PG2, need to unlock this register first, with the purpose to avoid mis-operation of this register. When FEh is written with 0xC5, FDh is allowed to modify once, after the FDh is modified the FEh will reset to be 0x00 at once. Table 5 Register Definition Address Name Function Table R/W Default Set PWM for each LED 6 R/W 0000 0000 Set Scaling for each LED 7 R/W 0000 0000 PG0 (0x00): PWM Register 01h~C6h PWM Register PG1 (0x01): LED Scaling 01h~C6h Scaling Register PG2 (0x02): Function Register 00h Configuration Register Configure the operation mode 9 R/W 0000 0000 01h Global Current Control Register Set the global current 10 R/W 0000 0000 02h Pull Down/Up Resistor Selection Register Set the pull down resistor for SWx and pull up resistor for CSy 11 R/W 0011 0011 03h~23h Open/Short Register Store the open or short information 12 R 0000 0000 24h Temperature Status Store the temperature point of the IC 13 R/W 0000 0000 25h Spread Spectrum Register Spread spectrum function enable 14 R/W 0000 0000 2Fh Reset Register Reset all register to POR state - W 0000 0000   Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 11 IS31FL3743A Page 0 (PG0, FDh= 0x00): PWM Register PWM PWM PWM PWM PWM PWM Figure 9 PWM Register Table 6 PG0: 01h ~ C6h PWM Register Bit D7:D0 Name PWM Default 0000 0000 Duty  PWM  I OUT ( PEAK )  Duty 256 PWM  (1) 7  D [n ]  2 (2) IOUT is the output current of CSy (y=1~18), Each dot has a byte to modulate the PWM duty in 256 steps. The value of the PWM Registers decides the average current of each LED noted ILED. ILED computed by Formula (1): I LED  33s 1 1   33s  0.83s  0.3s 11 11.377 n n 0 IOUT( PEAK)  343 GCC SL   RISET 256 256 (3) GCC is the Global Current Control register (PG2, 01h) value, SL is the Scaling Register value as Table 9 and RISET is the external resistor of ISET pin. D[n] stands for the individual bit value, 1 or 0, in location n. For example: if D7:D0=1011 0101 (0xB5, 181), GCC=1111 1111, RISET=10kΩ, SL=1111 1111: 343 255 255 1 181 I LED      10 k  256 256 11 . 377 256 Where Duty is the duty cycle of SWx, see SCANING TIMING section for more information. Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 12 IS31FL3743A Page 1 (PG1, FDh= 0x01): Scaling Register T01 T02 SW1 T03 SW2 T04 SW3 T05 SW4 T06 SW5 T07 T08 SW7 SW6 T09 SW8 T10 T11 SW10 SW11 SW9 PWM PWM PWM CS18 12 24 36 48 5A 6C 7E 90 A2 B4 C6 CS17 11 23 35 47 59 6B 7D 8F A1 B3 C5 CS16 10 22 34 46 58 6A 7C 8E A0 B2 C4 PVCC PAGE 1 Y X PWM PWM PWM CS03 CS02 CS01 03 15 27 39 4B 5D 6F 81 93 A5 B7 02 14 26 38 4A 5C 6E 80 92 A4 B6 01 13 25 37 49 6D 7F 91 A3 B5 5B Figure 10 Scaling Register IOUT is the output current of CSy (y=1~18), GCC is the Global Current Control Register (PG2, 01h) value and RISET is the external resistor of ISET pin. D[n] stands for the individual bit value, 1 or 0, in location n. Table 7 PG1: 01h ~ C6h Scaling Register Bit D7:D0 Name SL Default 0000 0000 Scaling register control the DC output current of each dot. Each dot has a byte to modulate the scaling in 256 steps. The value of the Scaling Register decides the peak current of each LED noted IOUT(PEAK). 343 GCC SL   RISET 256 256 SL  SL  (3) 7  D[n]  2 n  127 n0 I OUT  IOUT(PEAK) computed by Formula (3): IOUT( PEAK)  For example: if RISET=10kΩ, GCC=1111 1111, SL=0111 1111: 343 255 127    16 . 8 mA 10 k  256 256 I LED  16 .8 mA  1 PWM  11 .377 256 7  D[n]  2 n n0 Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 13 IS31FL3743A Table 8 Page 2 (PG2, FDh= 0x02): Function Register Register Name Function Table R/W Default 00h Configuration Register Configure the operation mode 10 R/W 0000 0000 01h Global Current Control Register Set the global current 11 R/W 0000 0000 02h Pull Down/Up Resistor Selection Register Set the pull down resistor for SWx and pull up resistor for CSy 12 R/W 0011 0011 03h~23h Open/Short Register Store the open or short information 13 R 0000 0000 24h Temperature Status Store the temperature point of the IC 14 R/W 0000 0000 25h Spread Spectrum Register Spread spectrum function enable 15 R/W 0000 0000 2Fh Reset Register Reset all register to POR state - W 0000 0000 Table 9 00h Configuration Register Bit D7:D4 D3 D2:D1 D0 Name SWS LGC OSDE SSD Default 0000 0 00 0 The Configuration Register sets operating mode of IS31FL3743A. When OSDE set to “01”, open detection will be trigger once, the user could trigger open detection again by set OSDE from “00” to “01”. Before set OSDE, the GCC should set to 0x0F, please check OPEN/SHORT DETECT FUNCTION section for more information. When SSD is “0”, IS31FL3743A works in software shutdown mode and to normal operate the SSD bit should set to “1”. SWS control the duty cycle of the SW, default mode is 1/11. SSD 0 1 0111 1000 1001 1010 Others SW1~SW4, 1/4, SW5~SW11 no-active SW1~SW3, 1/3, SW4~SW11 no-active SW1~SW2, 1/2, SW3~SW11 no-active All CSx work as current sinks only, no scan Not allowed Table 10 01h Global Current Control Register Bit D7:D0 Name GCC Default 0000 0000 The Global Current Control Register modulates all CSy (x=1~18) DC current which is noted as IOUT in 256 steps. IOUT is computed by the Formula (3): IOUT( PEAK)  Software Shutdown Control Software shutdown Normal operation LGC 0 1 H/L Logic 1.4V/0.4V 2.4V/0.6V OSDE 00/11 01 10 Open Detection Enable Disable open/short detection Enable open detection Enable short detection SWS 0000 0001 0010 0011 0100 0101 0110 SWx Setting SW1~SW11, 1/11 SW1~SW10, 1/10, SW11 no-active SW1~SW9, 1/9, SW10~SW11 no-active SW1~SW8, 1/8, SW9~SW11 no-active SW1~SW7, 1/7, SW8~SW11 no-active SW1~SW6, 1/6, SW7~SW11 no-active SW1~SW5, 1/5, SW6~SW11 no-active Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 343 GCC SL   RISET 256 256 GCC  (3) 7  D[ n ]  2 n n0 Where D[n] stands for the individual bit value, 1 or 0, in location n. Table 11 02h Pull Down/Up Resistor Selection Register Bit D7 D6:D4 D3 D2:D0 Name PHC SWPDR - CSPUR Default 0 011 0 011 Set pull down resistor for SWx and pull up resistor for CSy. Please check DE-GHOST FUNCTION section for more information. PHC 0 1 Phase choice 0 degree phase delay 180 degree phase delay 14 IS31FL3743A SWPDR SWx Pull down Resistor Selection Bit 000 No pull down resistor 001 0.5kΩ only in SWx off time 010 1.0kΩ only in SWx off time 011 2.0kΩ only in SWx off time 100 1.0kΩ all the time 101 2.0kΩ all the time 110 4.0kΩ all the time 111 8.0kΩ all the time CSPUR CSy Pull up Resistor Selection Bit 000 No pull up resistor 001 0.5kΩ only in CSx off time 010 1.0kΩ only in CSx off time 011 2.0kΩ only in CSx off time 100 1.0kΩ all the time 101 2.0kΩ all the time 110 4.0kΩ all the time 111 8.0kΩ all the time Table 12 Open/Short Register (Read Only) 03h~23h Open/Short Information Bit D7:D6 D5:D0 Name - CS18:CS13, CS12:CS07,CS06:CS01 Default 00 00 0000 When OSDE (PG2, 00h) is set to “01”, open detection will be trigger once, and the open information will be stored at 03h~23h. When OSDE (PG2, 00h) set to “10”, short detection will be trigger once, and the short information will be stored at 03h~23h. Before set OSDE, the GCC should set to 0x0F, please check OPEN/SHORT DETECT FUNCTION section for more information. Figure 11 Open/Short Register Table 13 24h Temperature Status Bit D7:D4 D3:D2 D1:D0 Name - TS TROF Default 0000 00 00 TS store the temperature point of the IC. If the IC temperature reaches the temperature point the IC will trigger the thermal roll off and will decrease the current as TROF set percentage. Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 TROF 00 01 10 11 percentage of output current 100% 75% 55% 30% TS 00 01 10 11 Temperature Point, Thermal roll off start point 140°C 120°C 100°C 90°C 15 IS31FL3743A Table 14 25h Spread Spectrum Register Bit D7:D6 D4 D3:D2 D1:D0 Name SYNC SSP RNG CLT Default 00 0 00 00 When SYNC bits are set to “11”, the IS31FL3745 is configured as the master clock source and the SYNC pin will generate a clock signal distributed to the clock slave devices. To be configured as a clock slave device and accept an external clock input the slave device’s SYNC bits must be set to “10’”. When SSP enable, the spread spectrum function will be enabled and the RNG & CLT bits will adjust the range and cycle time of spread spectrum function. SYNC 0x 10 11 Enable of SYNC function Disable SYNC function, 30kOhm pull-low Slave, clock input Master, clock output Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 SSP 0 1 Spread spectrum function enable Disable Enable RNG 00 01 10 11 Spread spectrum range ±5% ±15% ±24% ±34% CLT 00 01 10 11 Spread spectrum cycle time 1980μs 1200μs 820μs 660μs 2Fh Reset Register Once user writes the Reset Register with 0xAE, IS31FL3743A will reset all the IS31FL3743A registers to their default value. On initial power-up, the IS31FL3743A registers are reset to their default values for a blank display. 16 IS31FL3743A APPLICATION INFORMATION I OUT  343 GCC SL   RISET 256 256 Figure 12 Scanning Timing SCANING TIMING As shown in Figure 12 above, the SW1~SW11 is turned on by serial, LED is driven 11 by 11 within the SWx (x=1~11) on time (SWx, x=1~11 is source and it is high when LED on) , including the non-overlap blanking time during scan, the duty cycle of SWx (active high, x=1~11) is: Duty  33s 1 1   33s  0.83s  0.3s  11 11.377 (2) Where 33μs is tSCAN, the period of scanning and 0.83μs is tNOL, the non-overlap time and 0.3μs is the CSx delay time. PWM CONTROL After setting the IOUT and GCC, the brightness of each LEDs (LED average current (ILED)) can be modulated with 256 steps by PWM Register, as described in Formula (1). I LED  PWM  I OUT ( PEAK )  Duty (1) 256 Where PWM is PWM Registers (PG0, 00h~B3h /PG1, 01h~C6h) data showing in Table 7. For example, in Figure 1, if RISET= 10kΩ, PWM= 255, and GCC= 255, Scaling= 255, then Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 I OUT ( PEAK )  343 255 255    34 mA 10 k 256 256 I LED  34 mA  1 PWM  11.377 256 Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. GAMMA CORRECTION In order to perform a better visual LED breathing effect we recommend using a gamma corrected PWM value to set the LED intensity. This results in a reduced number of steps for the LED intensity setting, but causes the change in intensity to appear more linear to the human eye. Gamma correction, also known as gamma compression or encoding, is used to encode linear luminance to match the non-linear characteristics of display. Since the IS31FL3743A can modulate the brightness of the LEDs with 256 steps, a gamma correction function can be applied when computing each subsequent LED intensity setting such that the changes in brightness matches the human eye's brightness curve. 17 IS31FL3743A 256 Table 15 32 Gamma Steps with 256 PWM Steps C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 4 6 10 13 18 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 22 28 33 39 46 53 61 69 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 78 86 96 106 116 126 138 149 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 161 173 186 199 212 226 240 255 256 224 192 PWM Data C(0) 160 128 96 64 32 224 0 0 8 16 PWM Data 192 32 40 48 56 64 Intensity Steps 160 Figure 14 Gamma Correction (64 Steps) 128 Note: The data of 32 gamma steps is the standard value and the data of 64 gamma steps is the recommended value. 96 OPERATING MODE 64 32 0 0 4 8 12 16 20 24 28 32 Intensity Steps Figure 13 Gamma Correction (32 Steps) Choosing more gamma steps provides for a more continuous looking breathing effect. This is useful for very long breathing cycles. The recommended configuration is defined by the breath cycle T. When T=1s, choose 32 gamma steps, when T=2s, choose 64 gamma steps. The user must decide the final number of gamma steps not only by the LED itself, but also based on the visual performance of the finished product. Table 16 64 Gamma Steps with 256 PWM Steps C(0) 24 C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 3 4 5 6 7 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 8 10 12 14 16 18 20 22 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 24 26 29 32 35 38 41 44 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 47 50 53 57 61 65 69 73 C(32) C(33) C(34) C(35) C(36) C(37) C(38) C(39) 77 81 85 89 94 99 104 109 C(40) C(41) C(42) C(43) C(44) C(45) C(46) C(47) 114 119 124 129 134 140 146 152 C(48) C(49) C(50) C(51) C(52) C(53) C(54) C(55) 158 164 170 176 182 188 195 202 C(56) C(57) C(58) C(59) C(60) C(61) C(62) C(63) 209 216 223 230 237 244 251 255 Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 IS31FL3743Acan only operate in PWM Mode. The brightness of each LED can be modulated with 256 steps by PWM registers. For example, if the data in PWM Register is “0000 0100”, then the PWM is the fourth step. Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. OPEN/SHORT DETECT FUNCTION IS31FL3743A has open and short detect bit for each LED. By setting the OSD bits of the Configuration Register (PG2, 00h) from “00” to “01” or ’10’, the LED Open/short Register will start to store the open/short information and after at least 2 scanning cycles and the MCU can get the open/short information by reading the 03h~23h, for those dots are turned off via LED On/Off Registers (PG0, 00h~17h), the open/short data will not get refreshed when setting the OSD bit of the Configuration Register. The two configurations need to set before setting the OSD bits: 1 2 0x0F≤GCC≤0x40, 02h=0x00 0x01≤GCC≤0x40, 02h=0x30 Where GCC is the Global Current Control Register (PG2, 01h) and both case 1 or two can get the correct open and short information. 02h is the Pull Down/UP Resistor Selection Register and 0x30 is to enable the SWx pull-up function. The detect action is one-off event and each time before reading out the open/short information, the OSD bit of the Configuration Register (PG3, 00h) need to be set from “0” to “1” (clear before set operation). 18 IS31FL3743A DE-GHOST FUNCTION Hardware Shutdown The “ghost” term is used to describe the behavior of an LED that should be OFF but instead glows dimly when another LED is turned ON. A ghosting effect typically can occur when multiplexing LEDs. In matrix architecture any parasitic capacitance found in the constant-current outputs or the PCB traces to the LEDs may provide sufficient current to dimly light an LED to create a ghosting effect. The chip enters hardware shutdown when the SDB pin is pulled low. All analog circuits are disabled during hardware shutdown, typical the current consume is 1.3μA. To prevent this LED ghost effect, the IS31FL3743A has integrated Pull down resistors for each SWx (x=1~11) and Pull up resistors for each CSy (y=1~18). Select the right SWx Pull down resistor (PG2, 02h) and CSy Pull up resistor (PG2, 02h) which eliminates the ghost LED for a particular matrix layout configuration. Typically, selecting the 2kΩ will be sufficient to eliminate the LED ghost phenomenon. The SWx Pull down resistors and CSy Pull up resistors are active only when the CSy/SWx output working the OFF state and therefore no power is lost through these resistors. SHUTDOWN MODE Shutdown mode can be used as a means of reducing power consumption. During shutdown mode all registers retain their data. Software Shutdown By setting SSD bit of the Configuration Register (PG2, 00h) to “0”, the IS31FL3743A will operate in software shutdown mode. When the IS31FL3743A is in software shutdown, all current sources are switched off, so that the matrix is blanked. All registers can be operated. Typical current consume is 1.3μA. Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 The chip releases hardware shutdown when the SDB pin is pulled high. During hardware shutdown state Function Register can be operated. If VCC has risk drop below 1.75V but above 0.1V during SDB pulled low, please re-initialize all Function Registers before SDB pulled high. LAYOUT As described in external resistor (RISET), the chip consumes lots of power. Please consider below factors when layout the PCB. 1. The VCC (PVCC, AVCC) capacitors need to close to the chip and the ground side should well connected to the GND of the chip. 2. RISET should be close to the chip and the ground side should well connect to the GND of the chip. 3. The thermal pad should connect to ground pins and the PCB should have the thermal pad too, usually this pad should have 16 or 25 via thru the PCB to other side’s ground area to help radiate the heat. About the thermal pad size, please refer to the land pattern of each package. 4. The CSy pins maximum current is 34mA (RISET=10kΩ), and the SWx pins maximum current is larger, the width of the trace, SWx should have wider trace then CSy. 19 IS31FL3743A CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 15 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 20 IS31FL3743A PACKAGE INFORMATION UQFN-40 Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 21 IS31FL3743A RECOMMENDED LAND PATTERN UQFN-40 Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. User’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 22 IS31FL3743A REVISION HISTORY Revision A Detail Information Initial release Lumissil Microsystems – www.lumissil.com Rev. A, 08/06/2018 Date 2018.08.06 23
IS31FL3743A-QULS4-TR 价格&库存
很抱歉,暂时无法提供与“IS31FL3743A-QULS4-TR”相匹配的价格&库存,您可以联系我们找货
  • 2500+10.667752500+1.33496
  • 5000+10.446075000+1.30722
  • 7500+10.335087500+1.29333
库存:3688
  • 1+20.698271+2.59017
  • 10+15.3188510+1.91700
  • 25+13.9801525+1.74947
  • 100+12.50919100+1.56540
  • 250+11.80706250+1.47753
  • 500+11.38390500+1.42458
  • 1000+11.035491000+1.38098
库存:3688
