IS31FL3743B-QULS4-TR
    LUMISSIL
    UFQFN40
IS31FL3743B-QULS4-TR 数据手册
IS31FL3743B 18×11 DOTS MATRIX LED DRIVER WITH 12MHZ SPI May 2019 GENERAL DESCRIPTION FEATURES The IS31FL3743B is a general purpose 18×n (n=1~11) LED Matrix programmed via 12MHz SPI interface. Each LED can be dimmed individually with 8-bit PWM data and 8-bit DC scaling data which allowing 256 steps of linear PWM dimming and 256 steps of DC current adjustable level.             Additionally each LED open state can be detected, IS31FL3743B store the open information in OpenRegisters. The Open Registers allowing MCU to read out via SPI, inform MCU whether there are LEDs open or short LEDs. The IS31FL3743B operates from 2.7V to 5.5V and features a very low shutdown and operational current. IS31FL3743B is available in UQFN-40 (5mm×5mm) package. It operates from 2.7V to 5.5V over the temperature range of -40°C to +125°C. Supply voltage range: 2.7V to 5.5V 18 current sinks (Maximum) Support 18×n (n=1~11) LED matrix configurations Individual 256 PWM control steps Individual 256 DC current steps Global 256 DC current steps SDB rising edge reset SPI module 29kHz PWM frequency 12MHz SPI interface State lookup registers Individual open and short error detect function 180 degree phase delay operation to reduce power noise De-ghost Cascade for synchronization of chips UQFN-40 (5mm×5mm) package    APPLICATIONS    Hand-held devices for LED display Gaming device (Keyboard, Mouse etc.) LED in white goods application TYPICAL APPLICATION CIRCUIT 5V 1 F 0.1 F 5 5V 1 F 22 PVCC VCC SW11 SW10 11 40 SW1 SW2 SW3 SW4 SW5 SW6 SW7 SW8 SW9 SW10 SW11 0.1 F 51R 28 27 25 Micro Controller 24 26 MOSI SCK SW2 SW1 MISO SDB CS18 20R 6 CS17 20R CS16 CS IS31FL3743B CS18 CS17 100k 4 12 13 51R CS3 0.1 F 20R 30 29 10k 23 CS2 SYNC ISET GND CS2 CS1 PGND 38 39 20R CS1 16 Figure 1 Typical Application Circuit: 66 RGBs Note 1: For the mobile applications the IC should be placed far away from the mobile antenna in order to prevent the EMI. Note 2: PVCC and VCC should use same power supply to avoid the additional ISD, it is OK to use PVCC=VCC=5V and VIO=3.3V. Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 1 IS31FL3743B TYPICAL APPLICATION CIRCUIT (CONTINUED) 5V 1 F 0.1 F 5 5V 1 F 22 PVCC VCC SW11 SW10 11 40 SW1 SW2 SW3 SW4 SW5 SW6 SW7 SW8 SW9 SW10 SW11 0.1 F 20R 28 27 25 Micro Controller 24 26 MOSI SCK SW2 SW1 20R 6 MISO SDB CS17 20R CS16 CS IS31FL3743B CS18 CS17 100k 4 CS18 12 13 20R CS3 0.1 F 20R 30 29 CS2 SYNC ISET CS2 CS1 38 39 20R CS1 10k 23 GND PGND 16 Figure 2 Typical Application Circuit: 198 Mono Color LEDs Figure 2 Typical Application Circuit (Eight Parts Synchronization-Work) Note 3: The 20R between LED and IC is only for thermal reduction, for mono red LED, if PVCC=VCC=3.3V, don’t need these resistors. Note 4: One part is configured as master mode, all the other 7 parts configured as slave mode (slaves should be configured as slave before master set as master). Work as master mode or slave mode specified by Configuration Register (SYNC bits, register 25h, Page 2). Master part output master clock, and all the other parts which work as slave input this master clock. Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 2 IS31FL3743B PIN CONFIGURATION Package Pin Configuration (Top View) UQFN-40 PIN DESCRIPTION No. Pin Description 1~4 SW8,SW6,SW4,SW2 Power SW. 5 PVCC Power for current source SW. 6~11 SW1,SW3,SW5, SW7,SW9,SW11 Power SW. 12~15 CS18~CS15 Current sink pin for LED matrix. 16 PGND Power GND. 17~21 CS14~CS10 Current sink pin for LED matrix. 22 VCC Analog and digital circuits. 23 GND Analog GND. 24 MISO MISO of SPI. 25 CS CS of SPI. 26 SDB Shutdown pin. 27 SCK SPI clock. 28 MOSI SPI input data. 29 ISET Set the maximum IOUT current. 30 SYNC Synchronization. 31~39 CS9~CS1 Current sink pin for LED matrix. 40 SW10 Power SW. Thermal Pad Need to connect to GND. Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 3 IS31FL3743B ORDERING INFORMATION Industrial Range: -40°C to +125°C Order Part No. Package QTY/Reel IS31FL3743B-QULS4-TR UQFN-40, Lead-free 2500 Copyright  ©  2019  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use  in such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances  Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 4 IS31FL3743B ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at any input pin Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA=TJ Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA ESD (HBM) ESD (CDM) -0.3V ~+6.0V -0.3V ~ VCC+0.3V +150°C -65°C ~+150°C -40°C ~ +125°C 41.6°C/W ±7kV ±1kV Note 6: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS The following specifications apply for VCC = 3.6V, TA = 25°C, unless otherwise noted. Symbol Parameter Conditions Min. Typ. VCC Supply voltage ICC Quiescent power supply current ISD Shutdown current IOUT Maximum constant current of CSx RISET=10kΩ, GCC=0xFF, SL=0xFF ILED Average current on each LED ILED = IOUT(PEAK)/Duty(1/11.377) RISET=10kΩ, GCC=0xFF, SL=0xFF 3.03 Current switch headroom voltage SWx ISWITCH=612mA RISET=10kΩ, GCC=0xFF, SL=0xFF 550 Current sink headroom voltage CSx ISINK=34mA, RISET=10kΩ, GCC=0xFF, SL=0xFF 450 VHR tSCAN Period of scanning tNOL1 Non-overlap blanking time during scan, the SWx and CSy are all off during this time tNOL2 Delay total time for CS1 to CS 18, during this time, the SWx is on but CSx is not all turned on 2.7 VSDB=VCC, all LEDs off 1.8 VSDB=0V 1.3 VSDB= VCC, Configuration Register written “0000 0000 1.3 32.09 34.5 Max. Unit 5.5 V mA μA 36.91 mA mA mV (Note 7) 33 µs 0.83 µs 0.3 µs Logic Electrical Characteristics (SCK, MISO, MOSI, CS, SDB, SYNC) VIL Logic “0” input voltage VCC=2.7V~5.5V VIH Logic “1” input voltage VCC=2.7V~5.5V VOH H level MISO pin output voltage IOH= -8mA VOL L level MISO pin output voltage IOL= 8mA VHYS Input Schmitt trigger hysteresis VCC=3.6V IIL Logic “0” input current IIH Logic “1” input current Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 0.6 2.4 VCC0.4V 0 V V VCC V 0.4 V 0.2 V SDB=L, VINPUT = L (Note 7) 5 nA SDB=L, VINPUT = H (Note 7) 5 nA 5 IS31FL3743B DIGITAL INPUT SPI SWITCHING CHARACTERISTICS (NOTE 7) Symbol fC Parameter Clock frequency Min. Typ. Max. Units 12 MHz tSLCH CS active set-up time 34 tSHCH CS not active set-up time 17 ns tSHSL CS detect time 167 ns tCHSH CS active hold time 34 ns tCHSL CS not active hold time 17 ns tCH Clock high time 34 ns tCL Clock low time 34 ns tCLCH Clock rise time 9 ns tCHCL Clock fall time 9 ns tDVCH Data in set-up time 7 ns tCHDX Data in hold time 9 ns tSHQZ Output disable time 34 ns tCLQV Clock low to output valid 39 ns tCLQX Output hold time tQLQH Output rise time 17 ns tQLQH Output fall time 17 ns ns 0 ns Note 7: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 6 IS31FL3743B FUNCTIONAL BLOCK DIAGRAM Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 7 IS31FL3743B DETAILED DESCRIPTION SPI INTERFACE ADDRESS AUTO INCREMENT IS31FL3743B uses a SPI protocol to control the chip’s function with four wires: CS, SCK, MOSI and MISO. SPI transfer starts form CS pin from high to low controlled by Master (Microcontroller), and IS31FL3743B latches data when clock rising. To write multiple bytes of data into IS31FL3743B, load the address of the data register that the first data byte is intended for. During the 8th rising edge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS31FL3743B will be placed in the new address, and so on. The auto increment of the address will continue as long as data continues to be written to IS31FL3743B (Figure 7). SPI data format is 8-bit length. The first command byte composite of 1-bit R/W bit, 3-bit chip ID bit and 4-bit page bit. The command byte must be sent first, and is followed by register address byte then the register data. If the R/W bit is “0”, it will be write operation and Master (Micro-controller) can write the register data into the register. The maximum SCK IS31FL3743B is 12MHz. frequency supported Table 1 SPI Command Byte Name R/W ID bit Page No. Bit D7 D6:D4 D3:D0 Value 0: Write 1: Read 101 0x00: Point to Page 0 0x01: Point to Page 1 0x02: Point to Page 2 in READING OPERATION Page 0~Page 2 registers can be read by SPI. To read the registers of Page 0 thru Page 2, The D7 of the Command Byte need to be set to “1” and select the page number. If read one register, as shown in Figure 8, read the MISO data after sending the command byte and register address. If read more registers, as shown in Figure 9, the register address will auto increase during the 8th rising edge of receiving the last bit of the previous register data. Figure 4 SPI Input Timing Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 8 IS31FL3743B Figure 5 SPI Input Timing Figure 6 SPI writing to IS31FL3743B (Typical) Figure 7 SPI writing to IS31FL3743B (Automatic address increment) Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 9 IS31FL3743B Figure 8 SPI Reading From IS31FL3743B (Typical) Figure 9 SPI Reading From IS31FL3743B (Automatic Address Increment) Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 10 IS31FL3743B Table 2 Register Definition Address Name Function Table R/W Default Set PWM for each LED 3 W 0000 0000 Set Scaling for each LED 4 W 0000 0000 PG0 (0x50): PWM Register 01h~C6h PWM Register PG1 (0x51): LED Scaling 01h~C6h Scaling Register PG2 (0x52): Function Register 00h Configuration Register Configure the operation mode 6 W 0000 0000 01h Global Current Control Register Set the global current 7 W 0000 0000 02h Pull Down/Up Resistor Selection Register Set the pull down resistor for SWx and pull up resistor for CSy 8 W 0011 0011 Open Register Store the open information 9 R 0000 0000 24h Temperature Status Store the temperature point of the IC 10 W 0000 0000 25h Spread Spectrum Register Spread spectrum function enable 11 W 0000 0000 2Fh Reset Register Reset all register to POR state - W 0000 0000 03h~23h Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 11 IS31FL3743B Page 0 (PG0, Page No. = 0x50): PWM Register Figure 10 PWM Register Table 3 PG0: 01h ~ C6h PWM Register Bit D7:D0 Name PWM Default 0000 0000 Duty  PWM  I OUT ( PEAK )  Duty 256 PWM  (1) 7  D [n ]  2 (2) IOUT is the output current of CSy (y=1~18), Each dot has a byte to modulate the PWM duty in 256 steps. The value of the PWM Registers decides the average current of each LED noted ILED. ILED computed by Formula (1): I LED  33s 1 1   33s  0.83s  0.3s 11 11.377 n n 0 Where Duty is the duty cycle of SWx, see SCANING TIMING section for more information. Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 I OUT( PEAK)  343 GCC SL   RISET 256 256 (3) GCC is the Global Current Control register (PG2, 01h) value, SL is the Scaling Register value as Table 9 and RISET is the external resistor of ISET pin. D[n] stands for the individual bit value, 1 or 0, in location n. For example: if D7:D0=1011 0101 (0xB5, 181), GCC=1111 1111, RISET=10kΩ, SL=1111 1111: I LED  343 255 255 1 181     10 k  256 256 11 . 377 256 12 IS31FL3743B Page 1 (PG1, Page No.= 0x51): Scaling Register T01 T02 SW1 T03 SW2 T04 SW3 T05 SW4 T06 SW5 T07 T08 SW7 SW6 T10 T09 SW8 T11 SW10 SW11 SW9 CS18 12 24 36 48 5A 6C 7E 90 A2 B4 C6 CS17 11 23 35 47 59 6B 7D 8F A1 B3 C5 CS16 10 22 34 46 58 6A 7C 8E A0 B2 C4 PVCC PAGE 1 Y X CS3 CS2 CS1 03 15 27 39 4B 5D 6F 81 93 A5 B7 02 14 26 38 4A 5C 6E 80 92 A4 B6 01 13 25 37 49 6D 7F 91 A3 B5 5B Figure 11 Scaling Register IOUT is the output current of CSy (y=1~18), GCC is the Global Current Control Register (PG2, 01h) value and RISET is the external resistor of ISET pin. D[n] stands for the individual bit value, 1 or 0, in location n. Table 4 PG1: 01h ~ C6h Scaling Register Bit D7:D0 Name SL Default 0000 0000 Scaling register control the DC output current of each dot. Each dot has a byte to modulate the scaling in 256 steps. For example: if RISET=10kΩ, GCC=1111 1111, SL=0111 1111: SL  The value of the Scaling Register decides the peak current of each LED noted IOUT(PEAK). I OUT( PEAK)  343 GCC SL   RISET 256 256 SL  (3) n  127 n0 I OUT  IOUT(PEAK) computed by Formula (3): 7  D[n]  2 343 255 127    16 . 8 mA 10 k  256 256 I LED  16 .8 mA  1 PWM  11 .377 256 7  D[n]  2 n n0 Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 13 IS31FL3743B Table 5 Page 2 (PG2, Page No. = 0x52): Function Register Register Name Function Table R/W Default 00h Configuration Register Configure the operation mode 10 W 0000 0000 01h Global Current Control Register Set the global current 11 W 0000 0000 02h Pull Down/Up Resistor Selection Register Set the pull down resistor for SWx and pull up resistor for CSy 12 W 0011 0011 03h~23h Open/short Register Store the open/short information 13 R 0000 0000 24h Temperature Status Store the temperature point of the IC 14 W 0000 0000 25h Spread Spectrum Register Spread spectrum function enable 15 W 0000 0000 2Fh Reset Register Reset all register to POR state - W 0000 0000 Table 6 00h Configuration Register Bit D7:D4 D3 D2:D1 D0 Name SWS - OSDE SSD Default 0000 1 00 0 The Configuration Register sets operating mode of IS31FL3743B. Note the D3 need to be configured as “1”. When OSDE set to “01”, open detection will be trigger once, the user could trigger open detection again by set OSDE from “00” to “01”. Before set OSDE, the GCC should set to 0x0F, please check OPEN/SHORT DETECT FUNCTION section for more information. When SSD is “0”, IS31FL3743B works in software shutdown mode and to normal operate the SSD bit should set to “1”. SWS control the duty cycle of the SW, default mode is 1/11. SSD 0 1 Software Shutdown Control Software shutdown Normal operation OSDE 00/11 01 10 Open Detection Enable Disable open/short detection Enable open detection Enable short detection SWS 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 SWx Setting SW1~SW11, 1/11 SW1~SW10, 1/10, SW11 no-active SW1~SW9, 1/9, SW10~SW11 no-active SW1~SW8, 1/8, SW9~SW11 no-active SW1~SW7, 1/7, SW8~SW11 no-active SW1~SW6, 1/6, SW7~SW11 no-active SW1~SW5, 1/5, SW6~SW11 no-active SW1~SW4, 1/4, SW5~SW11 no-active SW1~SW3, 1/3, SW4~SW11 no-active SW1~SW2, 1/2, SW3~SW11 no-active Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 1010 All CSx work as current sinks only, no scan Others Not allowed Table 7 01h Global Current Control Register Bit D7:D0 Name GCC Default 0000 0000 The Global Current Control Register modulates all CSy (x=1~18) DC current which is noted as IOUT in 256 steps. IOUT is computed by the Formula (3): I OUT( PEAK)  343 GCC SL   RISET 256 256 GCC  (3) 7  D[ n ]  2 n n0 Where D[n] stands for the individual bit value, 1 or 0, in location n. Table 8 02h Pull Down/Up Resistor Selection Register Bit D7 D6:D4 D3 D2:D0 Name PHC SWPDR - CSPUR Default 0 011 0 011 Set pull down resistor for SWx and pull up resistor for CSy. Please check DE-GHOST FUNCTION section for more information. PHC 0 1 Phase choice 0 degree phase delay 180 degree phase delay 14 IS31FL3743B SWPDR SWx Pull down Resistor Selection Bit 000 No pull down resistor 001 0.5kΩ only in SWx off time 010 1.0kΩ only in SWx off time 011 2.0kΩ only in SWx off time 100 1.0kΩ all the time 101 2.0kΩ all the time 110 4.0kΩ all the time 111 8.0kΩ all the time CSPUR CSy Pull up Resistor Selection Bit 000 No pull up resistor 001 0.5kΩ only in CSx off time 010 1.0kΩ only in CSx off time 011 2.0kΩ only in CSx off time 100 1.0kΩ all the time 101 2.0kΩ all the time 110 4.0kΩ all the time 111 8.0kΩ all the time Table 9 Open Register (Read Only) 03h~23h Open Information Bit D7:D6 D5:D0 Name - CS18:CS13, CS12:CS07,CS06:CS01 Default 00 00 0000 When OSDE (PG2, 00h) is set to “01”, open detection will be trigger once, and the open information will be stored at 03h~23h. When OSDE (PG2, 00h) set to “10”, short detection will be trigger once, and the short information will be stored at 03h~23h. Before set OSDE, the GCC should set to 0x0F, please check OPEN/SHORT DETECT FUNCTION section for more information. Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 Figure 12 Open Register Table 10 24h Temperature Status Bit D7:D4 D3:D2 D1:D0 Name - TS TROF Default 0000 00 00 TS store the temperature point of the IC. If the IC temperature reaches the temperature point the IC will trigger the thermal roll off and will decrease the current as TROF set percentage. TROF 00 01 10 11 percentage of output current 100% 75% 55% 30% TS 00 01 10 11 Temperature Point, Thermal roll off start point 140D 120D 100D 90D 15 IS31FL3743B Table 11 25h Spread Spectrum Register Bit D7:D6 D4 D3:D2 D1:D0 Name SYNC SSP RNG CLT Default 00 0 00 00 When SYNC bits are set to “11”, the IS31FL3745 is configured as the master clock source and the SYNC pin will generate a clock signal distributed to the clock slave devices. To be configured as a clock slave device and accept an external clock input the slave device’s SYNC bits must be set to “10”. When SSP enable, the spread spectrum function will be enabled and the RNG & CLT bits will adjust the range and cycle time of spread spectrum function. SYNC 0x 10 11 Enable of SYNC function Disable SYNC function, 30kOhm pull-low Slave, clock input Master, clock output Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 SSP 0 1 Spread spectrum function enable Disable Enable RNG 00 01 10 11 Spread spectrum range ±5% ±15% ±24% ±34% CLT 00 01 10 11 Spread spectrum cycle time 1980μs 1200μs 820μs 660μs 2Fh Reset Register Once user writes the Reset Register with 0xAE, IS31FL3743B will reset all the IS31FL3743B registers to their default value. On initial power-up, the IS31FL3743B registers are reset to their default values for a blank display. 16 IS31FL3743B APPLICATION INFORMATION I OUT  343 GCC SL   R ISET 256 256 Figure 13 Scanning Timing SCANING TIMING As shown in Figure above, the SW1~SW11 is turned on by serial, LED is driven 11 by 11 within the SWx (x=1~11) on time (SWx, x=1~11 is source and it is high when LED on) , including the non-overlap blanking time during scan, the duty cycle of SWx (active high, x=1~11) is: Duty  33s 1 1   (2) 33s  0.83s  0.3s 11 11.377 Where 33μs is tSCAN, the period of scanning and 0.83μs is tNOL, the non-overlap time and 0.3μs is the CSx delay time. PWM CONTROL After setting the IOUT and GCC, the brightness of each LEDs (LED average current (ILED)) can be modulated with 256 steps by PWM Register, as described in Formula (1). I LED  PWM  I OUT ( PEAK )  Duty (1) 256 Where PWM is PWM Registers (PG0, 00h~B3h /PG1, 01h~C6h) data showing in Table 7. 343 255 255    34 mA 10 k  256 256 1 PWM  34 mA   11.377 256 I OUT ( PEAK )  I LED Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. GAMMA CORRECTION In order to perform a better visual LED breathing effect we recommend using a gamma corrected PWM value to set the LED intensity. This results in a reduced number of steps for the LED intensity setting, but causes the change in intensity to appear more linear to the human eye. Gamma correction, also known as gamma compression or encoding, is used to encode linear luminance to match the non-linear characteristics of display. Since the IS31FL3743B can modulate the brightness of the LEDs with 256 steps, a gamma correction function can be applied when computing each subsequent LED intensity setting such that the changes in brightness matches the human eye's brightness curve. For example, in Figure 1, if RISET= 10kΩ, PWM= 255, and GCC= 255, Scaling= 255, then Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 17 IS31FL3743B 256 Table 12 32 Gamma Steps with 256 PWM Steps C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 4 6 10 13 18 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 22 28 33 39 46 53 61 69 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 78 86 96 106 116 126 138 149 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 161 173 186 199 212 226 240 255 256 224 192 PWM Data C(0) 160 128 96 64 32 224 0 0 8 16 PWM Data 192 32 40 48 56 64 Intensity Steps 160 Figure 15 Gamma Correction (64 Steps) 128 Note: The data of 32 gamma steps is the standard value and the data of 64 gamma steps is the recommended value. 96 OPERATING MODE 64 32 0 0 4 8 12 16 20 24 28 32 Intensity Steps Figure 14 Gamma Correction (32 Steps) Choosing more gamma steps provides for a more continuous looking breathing effect. This is useful for very long breathing cycles. The recommended configuration is defined by the breath cycle T. When T=1s, choose 32 gamma steps, when T=2s, choose 64 gamma steps. The user must decide the final number of gamma steps not only by the LED itself, but also based on the visual performance of the finished product. Table 13 64 Gamma Steps with 256 PWM Steps C(0) 24 C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 3 4 5 6 7 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 8 10 12 14 16 18 20 22 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 24 26 29 32 35 38 41 44 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 47 50 53 57 61 65 69 73 C(32) C(33) C(34) C(35) C(36) C(37) C(38) C(39) 77 81 85 89 94 99 104 109 C(40) C(41) C(42) C(43) C(44) C(45) C(46) C(47) 114 119 124 129 134 140 146 152 C(48) C(49) C(50) C(51) C(52) C(53) C(54) C(55) 158 164 170 176 182 188 195 202 C(56) C(57) C(58) C(59) C(60) C(61) C(62) C(63) 209 216 223 230 237 244 251 255 Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 IS31FL3743B can only operate in PWM Mode. The brightness of each LED can be modulated with 256 steps by PWM registers. For example, if the data in PWM Register is “0000 0100”, then the PWM is the fourth step. Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. OPEN/SHORT DETECT FUNCTION IS31FL3743B has open and short detect bit for each LED. By setting the OSD bits of the Configuration Register (PG2, 00h) from “00” to “01” or ’10’, the LED Open/short Register will start to store the open/short information and after at least 2 scanning cycles and the MCU can get the open/short information by reading the 03h~23h, for those dots are turned off via LED On/Off Registers (PG0, 00h~17h), the open/short data will not get refreshed when setting the OSD bit of the Configuration Register. The two configurations need to set before setting the OSD bits: 1 2 0x0F≤GCC≤0x40, 02h=0x00 0x01≤GCC≤0x40, 02h=0x30 Where GCC is the Global Current Control Register (PG2, 01h) and both case 1 or two can get the correct open and short information. 02h is the Pull Down/UP Resistor Selection Register and 0x30 is to enable the SWx pull-up function. The detect action is one-off event and each time before reading out the open/short information, the OSD bit of the Configuration Register (PG3, 00h) need to be set from “0” to “1” (clear before set operation). 18 IS31FL3743B DE-GHOST FUNCTION Hardware Shutdown The “ghost” term is used to describe the behavior of an LED that should be OFF but instead glows dimly when another LED is turned ON. A ghosting effect typically can occur when multiplexing LEDs. In matrix architecture any parasitic capacitance found in the constant-current outputs or the PCB traces to the LEDs may provide sufficient current to dimly light an LED to create a ghosting effect. The chip enters hardware shutdown when the SDB pin is pulled low. All analog circuits are disabled during hardware shutdown, typical the current consume is 1.3μA. To prevent this LED ghost effect, the IS31FL3743B has integrated Pull down resistors for each SWx (x=1~11) and Pull up resistors for each CSy (y=1~18). Select the right SWx Pull down resistor (PG2, 02h) and CSy Pull up resistor (PG2, 02h) which eliminates the ghost LED for a particular matrix layout configuration. Typically, selecting the 2kΩ will be sufficient to eliminate the LED ghost phenomenon. The SWx Pull down resistors and CSy Pull up resistors are active only when the CSy/SWx output working the OFF state and therefore no power is lost through these resistors. SHUTDOWN MODE Shutdown mode can be used as a means of reducing power consumption. During shutdown mode all registers retain their data. Software Shutdown By setting SSD bit of the Configuration Register (PG2, 00h) to “0”, the IS31FL3743B will operate in software shutdown mode. When the IS31FL3743B is in software shutdown, all current sources are switched off, so that the matrix is blanked. All registers can be operated. Typical current consume is 1.3μA. Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 The chip releases hardware shutdown when the SDB pin is pulled high. During hardware shutdown state Function Register can be operated. If VCC has risk drop below 1.75V but above 0.1V during SDB pulled low, please re-initialize all Function Registers before SDB pulled high. LAYOUT As described in external resistor (RISET), the chip consumes lots of power. Please consider below factors when layout the PCB. 1. The VCC (PVCC, AVCC) capacitors need to close to the chip and the ground side should well connected to the GND of the chip. 2. RISET should be close to the chip and the ground side should well connect to the GND of the chip. 3. The thermal pad should connect to ground pins and the PCB should have the thermal pad too, usually this pad should have 16 or 25 via thru the PCB to other side’s ground area to help radiate the heat. About the thermal pad size, please refer to the land pattern of each package. 4. The CSy pins maximum current is 34mA (RISET=10kΩ), and the SWx pins maximum current is larger, the width of the trace, SWx should have wider trace then CSy. 19 IS31FL3743B CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 16 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 20 IS31FL3743B PACKAGE INFORMATION UQFN-40 Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 21 IS31FL3743B RECOMMENDED LAND PATTERN Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. User’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 22 IS31FL3743B REVISION HISTORY Revision Detail Information Date 0A Initial release 2018.04.18 0B Add VOH and VOL in ELECTRICAL CHARACTERISTICS table 2018.09.20 A Update to final version 2019.05.13 Lumissil Microsystems – www.lumissil.com Rev. A, 05/13/2019 23
IS31FL3743B-QULS4-TR 价格&库存
很抱歉,暂时无法提供与“IS31FL3743B-QULS4-TR”相匹配的价格&库存,您可以联系我们找货
  • 1+20.804331+2.60344
  • 10+15.3973410+1.92682
  • 25+14.0517825+1.75843
  • 100+12.57328100+1.57342
  • 250+11.86756250+1.48510
  • 500+11.44223500+1.43188
  • 1000+11.092041000+1.38805
库存:2667
  • 2500+10.722412500+1.34180
  • 5000+10.499595000+1.31392
  • 7500+10.388047500+1.29996
库存:2667
