IS31LT3172-GRLS4-TR
IS31LT3172-GRLS4-TR
    LUMISSIL
    ESOP-8
    IC LED DRVR LINEAR 200MA 8SOP
IS31LT3172-GRLS4-TR 数据手册
IS31LT3172/73 10-TO-200MA CONSTANT-CURRENT LED DRIVER July 2016 GENERAL DESCRIPTION FEATURES The IS31LT3172 and IS31LT3173 are adjustable linear current devices with excellent temperature stability. A single resistor is all that is required to set the operating current from 10mA to 200mA. The devices can operate from an input voltage from 2.5V to 42V with a minimal voltage headroom of 1V (typical). Designed with a low dropout voltage; the device can drive LED strings close to the supply voltage without switch capacitors or inductors.  The IS31LT3172/73 simplifies designs by providing a stable current without the additional requirement of input or output capacitors, inductors, FETs or diodes. The complete constant current driver requires only a current set resistor and a small PCB area making designs both efficient and cost effective.   The EN Pin (3) of the IS31LT3172 can be tied to VBAT or BCM PWM signal for high side dimming. The EN Pin (3) of the IS31LT3173 can function as the PWM signal input used for low side dimming.  As a current sink it is ideal for LED lighting applications or current limiter for power supplies. The device is provided in a lead (Pb) free, SOP-8-EP package.   Low-side current sink - Current preset to 10mA - Adjustable from 10mA to 200mA with external resistor selection Wide input voltage range from - 2.5V to 42V (IS31LT3173) - 5V to 42V (IS31LT3172) with a low dropout of typical 1V Up to 10kHz PWM input (IS31LT3173 only) Protection features: - 0.26%/K negative temperature coefficient at high temp for thermal protection Up to 1.8W power dissipation in a small SOP-8EP package RoHS compliant (Pb-free) package APPLICATIONS     Architectural LED lighting Channel letters for advertising, LED strips for decorative lighting Retail lighting in fridge, freezer case and vending machines Emergency lighting (e.g. steps lighting, exit way sign etc.) TYPICAL APPLICATION CIRCUIT Figure 1 Typical Application Circuit Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016      1  IS31LT3172/73 PIN CONFIGURATION Package Pin Configuration (Top View) SOP-8-EP PIN DESCRIPTION No. Pin Description 1, 2 OUT Current sink. 3 EN Enable pin (PWM input IS31LT3173 only). 4 REXT Optional current adjust. 5 GND Ground. 6~8 NC Floating or connect to GND. Thermal Pad Connect to GND. Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016      2  IS31LT3172/73 ORDERING INFORMATION Industrial Range: -40°C to +125°C Order Part No. Package QTY/Reel IS31LT3172-GRLS4-TR IS31LT3173-GRLS4-TR SOP-8-EP, Lead-free 2500 Copyright  ©  2016  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use  in such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Integrated Silicon Solution, Inc is adequately protected under the circumstances  Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016      3  IS31LT3172/73 ABSOLUTE MAXIMUM RATINGS (Note 1) Maximum enable voltage, VEN(MAX) only for IS31LT3172-GRLS4-TR VEN(MAX) only for IS31LT3173-GRLS4-TR Maximum output current, IOUT(MAX) Maximum output voltage, VOUT(MAX) Reverse voltage between all terminals, VR Power dissipation, PD(MAX) (Note 2) Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA ESD (HBM) IS31LT3172-GRLS4-TR ESD (HBM) IS31LT3173-GRLS4-TR ESD (CDM) 45V 6V 200mA 45V 0.5V 1.8W +150°C -65°C ~ +150°C -40°C ~ +125°C ±2kV ±1.5kV ±500V Note 1: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Note 2: Detail information please refer to package thermal de-rating curve on Page 14. THERMAL CHARACTERISTICS Symbol Parameter Package Thermal Resistance (Junction to Ambient), RθJA Condition On 4-layer PCB based on JEDEC standard at 1W, TA=25°C 55.4°C/W Package Thermal Resistance (Junction to Pad), RθJP 2.24°C/W ELECTRICAL CHARACTERISTICS “●” This symbol in the table means these parameters are for IS31LT3172-GRLS4-TR. “○” This symbol in the table means these parameters are for IS31LT3173-GRLS4-TR. Test condition is TA = TJ = 25°C, unless otherwise specified. (Note 3) Symbol Parameter VBD_OUT OUT pin breakdown voltage IEN Enable current RINT Internal resistor Output current IOUT Output current Range (Note 4, 5) Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016  Condition Min. VEN= 0V Typ. 42 Unit V VEN= 24V ● 0.35 VEN= 3.3V ○ 0.35 IRINT = 10mA VOUT = 1.4V, VEN = 24V, REXT OPEN VOUT = 1.4V, VEN = 3.3V, REXT OPEN Max. mA 106 Ω ● 9 10 11 ○ 9 10 11 VOUT > 2.0V, VEN = 24V, REXT = 10Ω ● 105 118 130 VOUT > 2.0V, VEN = 3.3V, REXT = 10Ω ○ 105 118 130 VOUT > 2.0V, VEN = 24V ● 10 mA mA 200 mA VOUT > 2.0V, VEN = 3.3V   ○ 10 200   4  IS31LT3172/73 DC CHARACTERISTICS WITH STABILIZED LED LOAD “●” This symbol in the table means these parameters are for IS31LT3172-GRLS4-TR. “○” This symbol in the table means these parameters are for IS31LT3173-GRLS4-TR. Test condition is TA = TJ = 25°C, unless otherwise specified. (Note 3) Symbol Parameter VS Sufficient supply voltage on EN pin VHR Lowest sufficient headroom voltage on OUT pin Output current change versus ambient temp change ∆IOUT/IOUT (Note 4) Output current change versus Vout Condition Min. Typ. Max. ● 5 42 ○ 2.5 5.5 IOUT = 100mA 1 VOUT > 2.0V, VEN = 24V, REXT = 10Ω ● -0.26 VOUT > 2.0V, VEN = 3.3V, REXT = 10Ω ○ -0.26 VOUT > 2.0V, VEN = 24V, REXT = 10Ω ● 1.9 VOUT > 2.0V, VEN = 3.3V, REXT = 10Ω ○ 1.2 Unit V V %/K %/V 1.9 Note 3: Production testing of the device is performed at 25°C. Functional operation of the device and parameters specified over -40°C to +125°C temperature range, are guaranteed by design and characterization. Note 4: Guaranteed by design. Note 5: The maximum output current is dependent on the PCB board design, air flow, ambient temperature and power dissipation in the device. Please refer to the package thermal de-rating curve on Page 14 for more detail information. Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016      5  IS31LT3172/73 FUNCTIONAL BLOCK DIAGRAM IS31LT3172 IS31LT3173 Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016      6  IS31LT3172/73 TYPICAL PERFORMANCE CHARACTERISTICS IS31LT3172 80 12.5 VEN = 42V REXT = 20Ω VEN = 42V REXT Open TA = 25°C TA = 85°C Output Current (mA) Output Current (mA) 15 10 TA = 125°C 7.5 TA = -40°C 5 TA = 125°C TA = 25°C 60 TA = 85°C TA = -40°C 40 20 2.5 0 0.5 2 3.5 5 6.5 8 9.5 11 12.5 0 0.5 14 2 3.5 5 8 9.5 11 12.5 14 Output Voltage (V) Output Voltage (V) Figure 3 IOUT vs. VOUT Figure 2 IOUT vs. VOUT 200 200 VEN = 42V REXT = 10Ω VEN = 42V REXT = 7.5Ω 180 150 TA = 25°C TA = 85°C 100 Output Current (mA) Output Current (mA) 6.5 TA = 125°C TA = -40°C 50 TA = 85°C TA = 25°C 160 140 TA = 125°C 120 TA = -40°C 100 80 60 40 20 0 0.5 2 3.5 5 6.5 8 9.5 11 12.5 0 0.5 14 2 3.5 5 TA = 85°C 250 TA = 25°C Output Current (mA) Output Current (mA) 11 12.5 14 300 VEN = 3.3V REXT = 5.6Ω 200 TA = -40°C TA = 125°C 150 100 VEN = 42V TA = 25°C 250 3.5 5 6.5 8 9.5 11 12.5 REXT = 7.5Ω 150 REXT = 10Ω 100 REXT = 20Ω 0 REXT Open 0 2 4 6 8 10 12 14 Output Voltage (V) Output Voltage (V) Figure 7 IOUT vs. VOUT Figure 6 IOUT vs. VOUT Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016  14 REXT = 5.6Ω 200 50 50 2 9.5 Figure 5 IOUT vs. VOUT Figure 4 IOUT vs. VOUT 0 0.5 8 Output Voltage (V) Output Voltage (V) 300 6.5     7  IS31LT3172/73 250 Output Current (mA) 20 VEN = 5V fPWM = 100Hz@1% Duty Cycle TA = 25°C VOUT = 2V REXT Open REXT = 5.6Ω 200 REXT = 7.5Ω 150 REXT = 10Ω 100 REXT= 20Ω 16 12 8 TA = 125°C TA = -40°C REXT Open 0 2 4 6 8 10 12 0 14 5 15 25 Output Voltage (V) 42 35 VEN (V) Figure 8 IOUT vs. VOUT Figure 9 IOUT vs. VEN 80 150 VOUT = 2V REXT = 20Ω TA = 85°C VOUT = 2V REXT = 10Ω TA = 25°C Output Current (mA) Output Current (mA) TA = 85°C TA = 25°C 4 50 0 Output Current (mA) 300 60 TA = 125°C TA = -40°C 40 TA = 85°C TA = 125°C 120 TA = 25°C TA = -40°C 90 60 20 30 0 5 15 25 35 0 42 5 15 25 VEN (V) 42 VEN (V) Figure 10 IOUT vs. VEN Figure 11 IOUT vs. VEN 200 300 VOUT = 2V REXT = 7.5Ω TA = 85°C 150 TA = 25°C 125 VOUT = 2V REXT = 5.6Ω TA = 125°C Output Current (mA) 175 Output Current (mA) 35 TA = -40°C 100 75 250 200 TA = 85°C TA = 125°C TA = 25°C 150 TA = -40°C 100 50 50 25 0 5 15 25 35 42 2.5 3 3.5 4 4.5 5 VEN (V) VEN (V) Figure 13 IOUT vs. VEN Figure 12 IOUT vs. VEN Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016  0     8  IS31LT3172/73 250 VOUT = 2V TA = 25°C VEN = 42V VOUT = 2V 250 REXT = 5.6Ω 200 REXT = 7.5Ω 150 REXT = 10Ω 100 REXT = 20Ω 200 150 100 50 50 0 Output Current (mA) Output Current (mA) 300 REXT Open 5 10 15 20 25 30 40 42 35 0 1 10 100 1000 REXT (Ω) VEN (V) Figure 15 IOUT vs. REXT Figure 14 IOUT vs. VEN 500 IOUT = 0A REXT Open Supply Current (µA) 400 TA = -40°C TA = 25°C 300 TA = 85°C 200 TA = 125°C 100 0 0 5 10 15 20 25 30 40 42 35 VEN (V) Figure 16 IEN vs. VEN Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016      9  IS31LT3172/73 IS31LT3173 80 VEN = 3.3V REXT = 20Ω VEN = 3.3V REXT Open 25 Output Current (mA) Output Current (mA) 30 20 15 TA = 25°C TA = 85°C 10 0 0.5 2 3.5 5 60 TA = 125°C TA = -40°C 40 20 TA = 125°C 5 TA = -40°C 6.5 8 9.5 11 12.5 0 0.5 14 2 3.5 5 8 9.5 11 12.5 14 Figure 18 IOUT vs. VOUT Figure 17 IOUT vs. VOUT 180 150 TA = 25°C TA = 85°C 100 TA = 125°C TA = -40°C VEN = 3.3V REXT = 7.5Ω 160 Output Current (mA) VEN = 3.3V REXT = 10Ω 6.5 Output Voltage (V) Output Voltage (V) Output Current (mA) TA = 25°C TA = 85°C 50 TA = 25°C TA = 85°C 140 120 TA = 125°C TA = -40°C 100 80 60 40 20 0 0.5 2 3.5 5 6.5 8 9.5 11 12.5 0 0.5 14 2 3.5 5 Output Voltage (V) TA = 25°C 200 TA = 125°C TA = -40°C 100 2 12.5 14 3.5 5 6.5 8 9.5 11 12.5 Output Voltage (V) REXT = 7.5Ω REXT = 10Ω 150 100 REXT = 20Ω 0 REXT Open 0 2 4 6 8 10 12 14 Output Voltage (V) Figure 21 IOUT vs. VOUT Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016  14 REXT = 5.6Ω 200 50 50 0.5 VEN = 3.3V TA = 25°C 250 250 0 11 300 VEN = 3.3V REXT = 5.6Ω TA = 85°C 150 9.5 Figure 20 IOUT vs. VOUT Output Current (mA) Output Current (mA) 300 8 Output Voltage (V) Figure 19 IOUT vs. VOUT 350 6.5 Figure 22 IOUT vs. VOUT     10  IS31LT3172/73 20 VEN = 5V fPWM = 100Hz@1% Duty Cycle TA = 25°C 250 VOUT = 2V REXT Open REXT = 5.6Ω 200 REXT = 7.5Ω 150 REXT = 10Ω 100 REXT= 20Ω 16 12 8 TA = -40°C TA = 125°C REXT Open 0 2 4 6 8 10 12 0 14 2.5 3 3.5 4 4.5 5 VEN (V) Output Voltage (V) Figure 24 IOUT vs. VEN Figure 23 IOUT vs. VOUT 150 80 VOUT = 2V REXT = 20Ω TA = 85°C VOUT = 2V REXT = 10Ω TA = 25°C Output Current (mA) Output Current (mA) TA = 85°C TA = 25°C 4 50 0 Output Current (mA) Output Current (mA) 300 60 TA = 125°C TA = -40°C 40 TA = 85°C TA = 125°C 120 TA = 25°C TA = -40°C 90 60 20 30 0 2.5 3 3.5 4 4.5 0 5 2.5 3 3.5 300 200 VOUT = 2V REXT = 5.6Ω TA = 85°C Output Current (mA) Output Current (mA) TA = 125°C 150 TA = 25°C 125 5 Figure 26 IOUT vs. VEN Figure 25 IOUT vs. VEN VOUT = 2V REXT = 7.5Ω 4.5 VEN (V) VEN (V) 175 4 TA = -40°C 100 75 TA = 85°C 250 TA = 125°C TA = 25°C 200 TA = -40°C 150 100 50 50 25 0 2.5 3 3.5 4 4.5 5 2.5 3 3.5 4 4.5 5 VEN (V) VEN (V) Figure 28 IOUT vs. VEN Figure 27 IOUT vs. VEN Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016  0     11  IS31LT3172/73 250 VOUT = 2V TA = 25°C 250 VEN = 3.3V VOUT = 2V REXT = 5.6Ω Output Current (mA) Output Current (mA) 300 200 REXT = 7.5Ω 150 REXT = 10Ω 100 REXT = 20Ω 150 100 50 50 0 200 REXT Open 2.5 3 3.5 4 4.5 5 0 1 10 100 REXT (Ω) VEN (V) Figure 30 IOUT vs. REXT Figure 29 IOUT vs. VEN 500 VOUT = 3V, 3 LEDs VEN = 5V, 100Hz, 50% Duty Cycle REXT = 10Ω TJ = -40°C IOUT = 0A REXT Open Supply Current (µA) 400 TA = -40°C TA = 25°C 300 VEN 2V/Div 200 TA = 85°C TA = 125°C 100 IOUT 50mA/Div 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 VEN (V) Time (400ns/Div) Figure 31 IEN vs. VEN Figure 32 VEN vs. IOUT Delay and Rising Edge VOUT = 3V, 3 LEDs VEN = 5V, 100Hz, 50% Duty Cycle REXT = 10Ω TJ = 25°C VOUT = 3V, 3 LEDs VEN = 5V, 100Hz, 50% Duty Cycle REXT = 10Ω TJ = 125°C VEN 2V/Div VEN 2V/Div IOUT 50mA/Div IOUT 50mA/Div Time (200ns/Div) Time (400ns/Div) Figure 33 VEN vs. IOUT Delay and Rising Edge Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016  Figure 34 VEN vs. IOUT Delay and Rising Edge     12  IS31LT3172/73 VOUT = 3V, 3 LEDs VEN = 5V, 100Hz, 50% Duty Cycle REXT = 10Ω TJ = -40°C VOUT = 3V, 3 LEDs VEN = 5V, 100Hz, 50% Duty Cycle REXT = 10Ω TJ = 25°C VEN 2V/Div VEN 2V/Div IOUT 50mA/Div IOUT 50mA/Div Time (100ns/Div) Time (100ns/Div) Figure 35 VEN vs. IOUT Delay and Falling Edge Figure 36 VEN vs. IOUT Delay and Falling Edge VOUT = 3V, 3 LEDs VEN = 5V, 100Hz, 50% Duty Cycle REXT = 10Ω TJ = 125°C VEN 2V/Div IOUT 50mA/Div Time (100ns/Div) Figure 37 VEN vs. IOUT Delay and Falling Edge Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016      13  IS31LT3172/73 APPLICATIONS INFORMATION IS31LT3172/73 provides an easy constant current source solution for LED lighting applications. It uses an external resistor to adjust the LED current from 10mA to 200mA. The LED current can be determined by the external resistor REXT as Equation (1): REXT  10mA  106 I SET  10mA (1) Where ISET is in mA. Paralleling a low tolerance resistor REXT with the internal resistor RINT will improve the overall accuracy of the current sense resistance. The resulting output current will vary slightly lower due to the negative temperature coefficient (NTC) resulting from the self heating of the IS31LT3172/73. HIGH INPUT VOLTAGE APPLICATION When driving a long string of LEDs whose total forward voltage drop exceeds the IS31LT3172 VBD_OUT limit of 42V, it is possible to stack several LEDs (such as 2 LEDs) between the EN pin and the OUT pins, and so the voltage on the EN pin is higher than 5V. The remaining string of LEDs can then be placed between power supply +VS and EN pin, (Figure 38). The number of LEDs required to stack at EN pin will depend on the LED’s forward voltage drop (VF) and the +VS value. implements a negative (NTC) of -0.26%/K. temperature coefficient When operating the chip at high ambient temperatures, or when driving maximum load current, care must be taken to avoid exceeding the package power dissipation limits. Exceeding the package dissipation will cause the device to enter thermal protection mode. The maximum package power dissipation can be calculated using the following Equation (2): PD ( MAX )  TJ ( MAX )  TA (2)  JA Where TJ(MAX) is the maximum junction temperature, TA is the ambient temperature, and θJA is the junction to ambient thermal resistance; a metric for the relative thermal performance of a package. The recommended maximum operating junction temperature, TJ(MAX), is 125°C and so the maximum ambient temperature is determined by the package parameter; θJA. The θJA for the IS31LT3172/73 SOP8-EP package is 55.4°C/W. Therefore the maximum power dissipation at TA = 25°C is: PD ( MAX )  125C  25C  1.8W 55.4C / W The actual power dissipation PD is: PD  VOUT  I OUT  VEN  I EN (3) To ensure the performance, the die temperature (TJ) of the IS31LT3172/73 should not exceed 125°C. The graph below gives details for the package power derating. 2.5 Figure 38 High Input Voltage Application Circuit Note: when operating the IS31LT3172 at voltages exceeding the device operating limits, care needs to be taken to keep the EN pin and OUT pin voltage below 42V. 2 1.5 1 0.5 0 -40 THERMAL PROTECTION AND DISSIPATION The IS31LT3172/73 implements thermal foldback protection to reduce the LED current when the package’s thermal dissipation is exceeded and prevent “thermal runaway”. The thermal foldback Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016  Power Dissipation (W) SOP-8-EP   -25 -10 5 20 35 50 65 80 95 110 125 Temperature (°C) Figure 39 PD vs. TA (SOP-8-EP)   14  IS31LT3172/73 The thermal resistance is achieved by mounting the IS31LT3172/73 on a standard FR4 double-sided printed circuit board (PCB) with a copper area of a few square inches on each side of the board under the IS31LT3172/73. Multiple thermal vias, as shown in Figure 40, help to conduct the heat from the exposed pad of the IS31LT3172/73 to the copper on each side of the board. The thermal resistance can be reduced by using a metal substrate or by adding a heatsink. Figure 40 Board Via Layout For Thermal Dissipation Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016      15  IS31LT3172/73 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak 150°C Temperature min (Tsmin) 200°C Temperature max (Tsmax) 60-120 seconds Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) 217°C Time at liquidous (tL) 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified Max 30 seconds classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 41 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016      16  IS31LT3172/73 PACKAGE INFORMATION SOP-8-EP Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016      17  IS31LT3172/73 RECOMMENDED LAND PATTERN Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. user’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016      18  IS31LT3172/73 REVISION HISTORY Revision Detail Information Date A Initial release 2016.03.01 B Update EC table 2016.05.04 C Add Package Thermal Resistance (Junction to Pad), RθJP in THERMAL CHARACTERISTICS 2016.07.01 Lumissil Microsystems – www.lumissil.com Rev. C, 07/01/2016      19
IS31LT3172-GRLS4-TR 价格&库存
很抱歉,暂时无法提供与“IS31LT3172-GRLS4-TR”相匹配的价格&库存,您可以联系我们找货
IS31LT3172-GRLS4-TR
  • 1+4.747661+0.59412
  • 10+3.3500310+0.41922
  • 25+2.9898525+0.37415
  • 100+2.60118100+0.32551
  • 250+2.41497250+0.30221
  • 500+2.30310500+0.28821
  • 1000+2.210721000+0.27665
库存:1981
