RM10F1540CT
RM10F1540CT
    CAL-CHIP
    贴片电阻 0805 154Ω ±1% 1/8W ±100ppm/℃
RM10F1540CT 数据手册
THICK FILM CHIP RESISTOR - RM SERIES FEATURES APPLICATIONS - Small size and light weight - Highly reliable multilayer electrode construction - Compatible with all soldering process - Telecommunication Equipments - Radio and Tape Recorders, TV Tuners - Digital Cameras, Watches, Pocket Calculators - Computers, Instruments - Medical and Military Equipment DERATIVE CURVE SCOPE 100 RM04 RM06 RM10 RM12 RM14 RM20 RM25 RM28 RM43 RM45 80 Applies to all sizes of rectangular-type fixed chip resistors with Ruthenium base as material. 60 CONSTRUCTION 40 RM01 RM02 20 0 0 20 40 60 80 100 120 140 160 AMBIENT TEMPERATURE (C°) 3 DIMENSIONS 4 5 SIZE 6 9 8 7 L (INCH) 1 2 (MM) W (MM) T D1 (MM) D2 (MM) (MM) WEIGHT (G) (1000PCS) RM01 01005 0.40±0.02 0.20±0.02 0.13±0.02 0.10±0.03 0.10±0.03 0.037 RM02 0201 0.60±0.03 0.30±0.03 0.23±0.03 0.15±0.05 0.15±0.05 0.150 Alumina Substrate 4 Edge Electrode (NiCr) 7 Resistor Layer RM04 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 2 Bottom Electrode (Ag) 5 Barrier Layer (Ni) 8 Primary Overcoat (glass) RM06 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 1 3 Top Elctrode (Ag-pd) 6 External Electrode (Sn) 9 Secondary Overcoat (Epoxy) RM10 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 RM12 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 RM14 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 RM18 1812 4.50±0.20 3.20±0.20 0.55±0.20 0.55±0.20 0.50±0.20 18.126 RM20 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 RM20 2010 5.00±0.10 2.50±0.15 1.10±0.10 0.60±0.25 0.50±0.20 35.325 ULTRA HIGH POWER RM25 2512 6.34±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 RM25 ULTRA HIGH POWER 2512 6.35±0.10 3.20±0.15 1.10±0.10 0.60±0.25 1.80±0.20 45.328 RM28 2817 7.10±0.20 4.20±0.20 1.10±0.10 0.60±0.20 1.80±0.20 43.258 4320 11.00±0.30 5.00±0.25 1.10±0.10 0.80±0.20 2.40±0.20 48.698 4527 11.60±0.30 6.85±0.25 1.10±0.10 1.10±0.20 2.50±0.20 53.987 ULTRA HIGH POWER RM-43 ULTRA HIGH POWER RM45 ULTRA HIGH POWER PART NUMBERING GUIDE RM 06 J 100 CT -H TYPE DIMENSIONS RESISTANCE TOLERANCE NOMINAL RESISTANCE PACKAGING FUNCTION CODE RM SERIES 01: 01005 02: 0201 04: 0402 06: 0603 10: 0805 12: 1206 14: 1210 18: 1812 20: 2010 25: 2512 28: 2817 43: 4320 45: 4527 B: ±0.1% C: ±0.25% D: ±0.5% F: ±1% J: ±5% 5% - 3 Digit: 1st 2 are significant, 3rd is multiplier (10x), “R” indicates decimal on value
RM10F1540CT
物料型号: RM系列 - 厚膜芯片电阻
器件简介: - 适用于电信设备、小型和轻便设备如收音机、磁带录音机、电视调谐器、数码相机、手表、袖珍计算器、计算机、仪器、医疗和军事设备。 - 高度可靠的多层电极结构,兼容所有焊接工艺。
引脚分配: - 包括边缘电极(NiCr)、电阻层、底电极(Ag)、阻挡层(Ni)、主要涂层(玻璃)、顶电极(Ag-pd)、次要涂层(环氧树脂)和外部电极(Sn)。
参数特性: - 提供了不同尺寸的电阻参数,例如RM01、RM02、RM04等,包括尺寸、宽度、厚度、孔径、重量等。
功能详解: - 包括电阻范围、温度系数(TCR)、功率额定值、额定电流、最大工作电压、最大过载电压等详细电气规格。
应用信息: - 适用于需要高精度和可靠性的应用场景。
封装信息: - 提供了不同尺寸的封装信息,如01005、0201、0402等,以及它们的具体尺寸和重量。
RM10F1540CT 价格&库存
很抱歉,暂时无法提供与“RM10F1540CT”相匹配的价格&库存,您可以联系我们找货
RM10F1540CT
  • 1+0.883841+0.11457
  • 10+0.2821910+0.03658
  • 25+0.2078625+0.02695
  • 50+0.1674050+0.02170
  • 100+0.13652100+0.01770
  • 250+0.10709250+0.01388
  • 500+0.09018500+0.01169
  • 1000+0.076881000+0.00997
库存:5000
RM10F1540CT
  • 1+0.885351+0.11476
  • 10+0.2826710+0.03664
  • 25+0.2082225+0.02699
  • 50+0.1676950+0.02174
  • 100+0.13675100+0.01773
  • 250+0.10727250+0.01391
  • 500+0.09033500+0.01171
  • 1000+0.077011000+0.00999
库存:5000
