TH58NVG2S3HTA00
TH58NVG2S3HTA00
    KIOXIA(铠侠)
    TFSOP48
    24nm工艺,3.3V供电,8位/512B页面大小,工作温度范围0°C至70°C,48TSOP12x20封装。
TH58NVG2S3HTA00 数据手册
CPU Bad Block Management Wear levelling Garbage Collection NAND I/F CPU Host CPU Bad Block Management Wear levelling Garbage Collection ECC Host Host  MMC I/F NAND I/F Bad Block Management Wear levelling Garbage Collection ECC Built in ECC VALID FROM JULY TO SEPTEMBER 2013 Item Name Design rule Page Size Vcc Vccq ECC level Operation Temperature Package TC58NVG0S3HTAI0 TC58NVG0S3HBAI4 TC58NYG0S3HBAI4 TC58NVG1S3HTAI0 TC58NVG1S3HBAI4 TC58NYG1S3HBAI4 TC58NVG2S0HTA00 TH58NVG2S3HTAI0 TC58NVG3S0FTAI0 TC58NYG3S0FBAID TH58NVG4S0FTAK0 TH58NYG4S0FBAID TC58NVG5H2HTAI0 TH58NVG6H2HTAK0 TH58NVG7H2HTAK0 24nm 24nm 24nm 24nm 24nm 24nm 24nm 24nm 32nm 32nm 32nm 32nm 24nm 24nm 24nm (2048+128)x8 bit (2048+128)x8 bit (2048+128)x8 bit (2048+128)x8 bit (2048+128)x8 bit (2048+128)x8 bit (4096+256)x8 bit (2048+128)x8 bit (4096+232)x8 bit (4096+232)x8 bit (4096+232)x8 bit (4096+232)x8 bit (8192+1024)x8 bit (8192+1024)x8 bit (8192+1024)x8 bit 3.3V 3.3V 1.8V 3.3V 3.3V 1.8V 3.3V 3.3V 3.3V 1.8V 3.3V 1.8V 3.3V 3.3V 3.3V 3.3V 3.3V 1.8V 3.3V 3.3V 1.8V 3.3V 3.3V 3.3V 1.8V 3.3V 1.8V 3.3V 3.3V 3.3V 8bit/512B 8bit/512B 8bit/512B 8bit/512B 8bit/512B 8bit/512B 8bit/512B 8bit/512B 4bit/512B 4bit/512B 4bit/512B 4bit/512B 24bit/1024B 24bit/1024B 24bit/1024B -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 85°C 0°C to 70°C -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 70°C -40°C to 70°C -40°C to 70°C 48TSOP 12x20 63BGA 9x11 63BGA 9x11 48TSOP 12x20 63BGA 9x11 63BGA 9x11 48TSOP 12x20 48TSOP 12x20 48TSOP 12x20 63BGA 10x11 48TSOP 12x20 63BGA 10x11 48TSOP 12x20 48TSOP 12x20 48TSOP 12x20 BENAND™ - SLC NAND with build in ECC TC58BVG0S3HTAI0 24nm 1Gbit TC58BVG0S3HBAI4 24nm TC58BYG0S3HBAI4 24nm TC58BVG1S3HTAI0 24nm 2Gbit TC58BVG1S3HBAI4 24nm TC58BYG1S3HBAI4 24nm TH58BVG2S3HTAI0 24nm 4Gbit TC58BVG2S0HTAI0 24nm TH58BYG2S3HBAI4 24nm TC58BYG2S0HBAI4 24nm (2048+64)x8 bit (2048+64)x8 bit (2048+64)x8 bit (2048+64)x8 bit (2048+64)x8 bit (2048+64)x8 bit (2048+64)x8 bit (4096+128) x 8 bit (2048+64)x8 bit (4096+128)x 8 bit 3.3V 3.3V 1.8V 3.3V 3.3V 1.8V 3.3V 3.3V 1.8V 1.8V 3.3V 3.3V 1.8V 3.3V 3.3V 1.8V 3.3V 3.3V 1.8V 1.8V internal ECC internal ECC internal ECC internal ECC internal ECC internal ECC internal ECC internal ECC internal ECC internal ECC -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 85°C -40°C to 85°C 48TSOP 12x20 63BGA 9x11 63BGA 9x11 48TSOP 12x20 63BGA 9x11 63BGA 9x11 48TSOP 12x20 48TSOP 12x20 63BGA 9x11 63BGA 9x11 - 3.3V 3.3V 3.3V 3.3V 3.3V 1.8V, 3.3V 1.8V, 3.3V 1.8V, 3.3V 1.8V, 3.3V 1.8V, 3.3V internal ECC internal ECC internal ECC internal ECC internal ECC -25°C to 85°C -25°C to 85°C -25°C to 85°C -25°C to 85°C -25°C to 85°C Density SLC NAND 1Gbit 2Gbit 4Gbit 8Gbit 16Gbit 32Gbit 64Gbit 128Gbit e MMC™ 4GBytes 8GByte 16GByte 32GByte 64GByte THGBM5G5A1JBAIR THGBMBG6D1KBAIL THGBMBG7D2KBAIL THGBMBG8D4KBAIR THGBMBG9D8KBAIG 19nm A19nm A19nm A19nm A19nm 153FBGA 153FBGA 153FBGA 153FBGA 153FBGA 11.5x13 11.5x13 11.5x13 11.5x13 11.5x13 www.toshiba-components.com VALID FROM JULY TO SEPTEMBER 2013 Speed class Density Item Name Design Rule Bit/Cell Operation Temperature 4GB 8GB 16GB 32GB 8GB 16GB 32GB 64GB SD-C04GET2(RZCLH) SD-C08G2T2(RZCKH) SD-C16G2T2(PZCKH) SD-C32G2T2(PZCKP) SD-C08G2T2(22GKP) SD-C16G2T2(2ZGKP) SD-C32G2T2(2ZGKP) SD-C64G2T2(2ZGKY) 19nm 19nm 19nm 19nm 19nm 19nm 19nm 19nm 3b/c 3b/c 3b/c 3b/c 2b/c 3b/c 3b/c 3b/c -25°C to 85°C -25°C to 85°C -25°C to 85°C -25°C to 85°C -25°C to 85°C -25°C to 85°C -25°C to 85°C -25°C to 85°C 4GB 8GB 16GB 32GB 8GB 16GB 32GB 64GB SD-K04G2B8(PZCFN) SD-K08G2B8(PZCFN) SD-K16G2B8(P1CFN) SD-K32G2B8(P1CFN) SD-K08G2B8(22GFN) SD-K16G2B8(2ZGFN) SD-K32G2B8(2ZGFN) SD-K64G2B8(21GFN) 19nm 19nm 19nm 19nm 19nm 19nm 19nm 19nm 3b/c 3b/c 3b/c 3b/c 2b/c 3b/c 3b/c 3b/c -25°C to 85°C -25°C to 85°C -25°C to 85°C -25°C to 85°C -25°C to 85°C -25°C to 85°C -25°C to 85°C -25°C to 85°C 8GB 16GB THNSW008GAA-B(xxx) THNSW016GAA-B(QB8) 19nm 19nm 2b/c 2b/c -25°C to 85°C -25°C to 85°C microSD Cards cl4 cl10 U1 SD Cards cl4 cl10 U1 FlashAirTM SD Cards cl10 Note: The microSD and SD Card line up will change to A19nm generation within Q4 2013 FlashAir™ is a standard SDHC™ memory card class 10, which offers you 8 and 16GB of high quality memory. But FlashAir™ is more than a standard memory card. It offers embedded Wireless LAN and creates it’s own access point, accessible from other Wireless LAN enabled devices. Industrial or consumer products which have an SD Card slot can now transmit any kind of data stored on a FlashAir™ SD card. Log files, firmware updates, configuration settings, pictures, templates and even more types of data can now be easily transmitted and accessed remotely. • • • • No special software or driver required WPA2 Secured Access Point Easy access to Data via integrated HTML Server Compatible with Windows, Android, iOS, etc. www.toshiba-components.com
TH58NVG2S3HTA00
1. 物料型号:文档列出了不同容量和特性的存储产品型号,如TC58NVG0S3HTAI0、TC58BVGOS3HTAI0和THGBM5G5A1JBAIR等。
2. 器件简介:介绍了各种存储产品,包括SLC NAND、BENAND™(带有内置ECC的SLC NAND)、e·MMC™和SD/microSD卡。
3. 引脚分配:对于SLC NAND和e·MMC™产品,文档列出了不同的封装类型,如48TSOP12x20和63BGA 9x11等。
4. 参数特性:包括设计规则、页面大小、供电电压(Vcc和Vccq)、ECC级别、操作温度范围和封装类型。
5. 功能详解:文档强调了BENAND™产品内置的ECC(错误校正码)功能,以及FlashAir™ SD卡的无线LAN功能,允许通过自己的接入点进行数据传输。
6. 应用信息:FlashAir™ SD卡的应用包括工业或消费产品的日志文件、固件更新、配置设置、图片、模板等数据的远程传输和访问。
7. 封装信息:提供了不同产品的封装信息,包括尺寸和类型。
TH58NVG2S3HTA00 价格&库存
很抱歉,暂时无法提供与“TH58NVG2S3HTA00”相匹配的价格&库存,您可以联系我们找货
