EMMC04G-MK27-A01C
EMMC04G-MK27-A01C
    KINGSTON(金士顿)
    BGA153_11.5X13MM
EMMC04G-MK27-A01C 数据手册
KINGSTON.COM/EMMC eMMC — the perfect storage solution for mobile and embedded applications. Overview Kingston® eMMC™ Flash memory follows the JEDEC eMMC 5.1 standard and encloses the NAND Flash and eMMC controller inside one JEDEC standard package to provide a standard interface to the host CPU. The eMMC controller directs the Flash management, including ECC, wear-leveling, lOPS optimization and read sensing, significantly reducing the storage management burden on the host CPU. A universal storage solution, Kingston eMMC is ideal for many electronic devices, including: smartphones, tablet PCs, eBook readers, electronic learning products, smart TVs, set-top boxes, smart home appliances and many wearable devices. Beyond its use in consumer products, eMMC is being rapidly adopted in many other embedded applications, such as Single Board Computers (SBC), robotics, medical devices, networking and building control devices because of its compact size, low-power consumption and numerous enhanced features. With the rapid growth of the IoT market, eMMC is finding its way to newer applications. Key Benefits • Simplifies system design and reduces time to market. The standard interface makes fast-changing NAND technology invisible to the host and the host processor doesn’t have to keep changing its software to accommodate every NAND technology change and variation. This helps to significantly reduce the design-in complexity and shorten the qualification cycle. • Helps to improve whole system performance. The eMMC controller frees up the host processor’s valuable resources from NAND management so the host processor can use its processing power on other tasks. • Provides a cost-effective solution. As opposed to SLC NAND, eMMC uses MLC NAND so it makes higher capacity storage in embedded applications much more affordable and enables today’s embedded designs to meet increasing demands for storage. eMMC Part Numbers and Specifications Key Features Part Number Capacity eMMC Standard Package NAND EMMC04G-M627 4GB 5.0/5.1 (HS400) 11.5x13x1.0 EMMC04G-MK27 4GB 5.0/5.1 (HS400) EMMC04G-M657 4GB 5.0/5.1 (HS400) EMMC08G-ML36 8GB 5.1 (HS400) JEDEC Standard Features eMMC 5.0 eMMC 5.1 Boot Operation √ √ MLC Partitioning √ √ 11.5x13x0.8 MLC Sleep Mode √ √ 9.0x7.5x0.8 MLC Replay Protected Memory Block √ √ MLC Secure Trim/Secure Erase √ √ √ √ 11.5x13x0.8 EMMC16G-TB29 16GB 5.1 (HS400) 11.5x13x0.8 3D TLC Hardware Reset EMMC32G-TX29 32GB 5.1 (HS400) 11.5x13x0.8 3D TLC Reliable Write √ √ 3D TLC Background Operation √ √ High Priority Interrupt √ √ DDR Interface √ √ Discard/Sanitize CMD √ √ Packed Commands, Context IDs √ √ Power OFF Notification √ √ Data Tag √ √ Device Health Report √ √ Field FW Update √ √ Production State Awareness √ EMMC64G-TX29 EMMC128-TX29 64GB 128GB 5.1 (HS400) 5.1 (HS400) 11.5x13x0.8 11.5x13x1.0 3D TLC For more information, please visit kingston.com/emmc CMD Queuing THIS DOCUMENT SUBJECT TO CHANGE WITHOUT NOTICE. ©2021 Kingston Technology Corporation, 17600 Newhope Street, Fountain Valley, CA 92708 USA. All rights reserved. All trademarks and registered trademarks are the property of their respective owners. Printed in the USA MKF-625.5US √ √
EMMC04G-MK27-A01C 价格&库存
很抱歉,暂时无法提供与“EMMC04G-MK27-A01C”相匹配的价格&库存,您可以联系我们找货
