NDL16PFJ-8KET TR
NDL16PFJ-8KET TR
    INSIGNIS
    VFBGA96
NDL16PFJ-8KET TR 数据手册
1Gb (x16) - DDR3 Synchronous DRAM (2133) Preliminary Datasheet 64M x 16 bit DDR3 Synchronous DRAM (2133) Overview The 1Gb Double-Data-Rate-3 (DDR3) SDRAM is double data rate architecture to achieve high speed transfer rates of up to 2133 Mb/sec/pin for general applications. It is internally configured as an eight bank DRAM. The 1Gb chip is organized as 8Mbit x 16 I/Os x 8 bank devices. The chip is designed to comply with all DDR3 DRAM key features and all of the control and address inputs are synchronized with a pair of externally supplied differential clocks and inputs are latched at the cross point of differential clocks (CK rising and CK# falling). All I/Os are synchronized with differential DQS pair in a source synchronous fashion. These devices operate with a single +1.5V -/+0.075V power supply and are available in BGA packages. Features ⚫ JEDEC ⚫ Power Standard Compliant supplies: VDD & VDDQ = +1.5V ±0.075V ⚫ Operating temperature range: - Industrial (IT): TC = -40~95°C ⚫ Supports JEDEC clock jitter specification ⚫ Fully synchronous operation ⚫ Fast clock rate: 1066MHz ⚫ Differential Clock, CK & CK# ⚫ Bidirectional differential data strobe - DQS & DQS# ⚫8 internal banks for concurrent operation ⚫ 8n-bit prefetch architecture ⚫ Pipelined internal architecture ⚫ Precharge & active power down ⚫ Programmable ⚫ Additive Latency (AL): 0, CL-1, CL-2 ⚫ Programmable ⚫ Burst Mode & Extended Mode registers Burst lengths: 4, 8 type: Sequential / Interleave ⚫ Output Driver Impedance Control ⚫ Average refresh period - 8192 cycles/64ms (7.8us at -40°C ≦ TC ≦ +85°C) - 8192 cycles/32ms (3.9us at +85°C ≦ TC ≦ +95°C) ⚫ Write ⚫ ZQ Leveling Calibration ⚫ Dynamic ⚫ RoHS ⚫ Auto ODT (Rtt_Nom & Rtt_WR) compliant Refresh and Self Refresh ⚫ 96-ball 8 x 13 x 1.0mm FBGA package - Pb and Halogen Free DISCLAIMER: All product, product specifications, and data are subject to change without notice to improve reliability, function or design, or otherwise. The information provided herein is correct to the best of Insignis Technology Corporation’s knowledge. No liability for any errors, facts or opinions is accepted. Customers must satisfy themselves as to the suitability of this product for their application. No responsibility for any loss as a result of any person placing reliance on any material contained herein will be accepted. NDT16PFJ2133v3.5-1Gb(x16)20200824 1Gb (x16) DDR3 Synchronous DRAM (2133) 64Mx16 –NDT16PFJ How to Order Function Density DDR3 1Gb IO Width x16 Pkg Pkg Size Type FBGA 8x13 (x1.0) Speed & Latency 2133-14-14-14 Visit: http://insignis-tech.com/how-to-buy NDT16PFJ2133v3.5-1Gb(x16)20200824 2 Option* INSIGNIS PART NUMBER: Industrial Temp NDT16PFJ-5GIT 1Gb (x16) DDR3 Synchronous DRAM (2133) 64Mx16 –NDT16PFJ Table 1. Speed Grade Information Speed Grade Clock Frequency CAS Latency tRCD (ns) tRP (ns) DDR3-2133 1066MHz 14 13.09 13.09 Figure 1. Ball Assignment (FBGA Top View) 1 2 3 A VDDQ DQ13 B VSSQ C … 7 8 9 DQ15 DQ12 VDDQ VSS VDD VSS UDQS#. DQ14 VSSQ VDDQ DQ11 DQ9 UDQS DQ10 VDDQ D VSSQ VDDQ UDM DQ8 VSSQ VDD E VSS VSSQ DQ0 LDM VSSQ VDDQ F VDDQ DQ2 LDQS DQ1 DQ3 VSSQ G VSSQ DQ6 LDQS# VDD VSS VSSQ H VREFDQ VDDQ DQ4 DQ7 DQ5 VDDQ J NC VSS RAS# CK VSS NC K ODT VDD CAS# CK# VDD CKE L NC CS# WE# A10/AP ZQ NC M VSS BA0 BA2 NC VREFCA VSS N VDD A3 A0 A12/BC# BA1 VDD P VSS A5 A2 A1 A4 VSS R VDD A7 A9 A11 A6 VDD T VSS RESET# NC NC A8 VSS NDT16PFJ2133v3.5-1Gb(x16)20200824 3 1Gb (x16) DDR3 Synchronous DRAM (2133) 64Mx16 –NDT16PFJ Figure 2. Block Diagram CK CK# CKE Row Decoder DLL CLOCK BUFFER 8M x 16 CELL ARRAY (BANK #0) Column Decoder CS# RAS# CAS# WE# 8M x 16 CELL ARRAY (BANK #1) Column Decoder Row Decoder COMMAND DECODER CONTROL SIGNAL GENERATOR Row Decoder RESET# 8M x 16 CELL ARRAY (BANK #2) A10/AP A12/BC# COLUMN COUNTER Row Decoder Column Decoder MODE REGISTER 8M x 16 CELL ARRAY (BANK #3) Column Decoder A0 A9 A11 BA0 BA1 BA2 Row Decoder ~ ADDRESS BUFFER 8M x 16 CELL ARRAY (BANK #4) REFRESH COUNTER ZQCL ZQCS ZQ CAL Row Decoder Column Decoder 8M x 16 CELL ARRAY (BANK #5) Column Decoder RZQ LDQS LDQS# UDQS UDQS# Row Decoder VSSQ DATA STROBE BUFFER 8M x 16 CELL ARRAY (BANK #6) Column Decoder DQ Buffer DQ0 Row Decoder ~ DQ15 8M x 16 CELL ARRAY (BANK #7) Column Decoder ODT NDT16PFJ2133v3.5-1Gb(x16)20200824 LDM UDM 4 1Gb (x16) DDR3 Synchronous DRAM (2133) 64Mx16 –NDT16PFJ Figure 3. State Diagram This simplified State Diagram is intended to provide an overview of the possible state transitions and the commands to control them. In particular, situations involving more than one bank, the enabling or disabling of on-die termination, and some other events are not captured in full detail. MRS,MPR, Write Leveling Self Refresh E Initialization from any RESET state ZQCL ZQ Calibration MRS X Reset Procedure SR Power On SR Power applied ZQCL,ZQCS Idle Refreshing REF PD E PD ACT X ACT = Active PRE = Precharge Active Power Down Precharge Power Down Activating PREA = Precharge All PD X MRS = Mode Register Set PD E REF = Refresh RESET = Start RESET Procedure Bank Activating Read = RD, RDS4, RDS8 Read A = RDA, RDAS4, RDAS8 WRITE RE AD WR ITE A Write A = WRA, WRAS4, WRAS8 TE RI W Write = WR, WRS4, WRS8 READ ZQCL = ZQ Calibration Long ZQCS = ZQ Calibration Short READ Writing A AD RE PDE = Enter Power-down PDX = Exit Power-down SRE = Self-Refresh entry SRX = Self-Refresh exit WRITE A MPR = Multi-Purpose Register READ A A ITE WR RE AD A PR E ,P RE A Automatic Sequence Command Sequence PRE, PREA EA PR E, PR Writing Precharging NDT16PFJ2133v3.5-1Gb(x16)20200824 Reading WRITE 5 Reading 1Gb (x16) DDR3 Synchronous DRAM (2133) 64Mx16 –NDT16PFJ Ball Descriptions Table 2. Ball Details Symbol Type Description CK, CK# Input Differential Clock: CK and CK# are driven by the system clock. All SDRAM input signals are sampled on the crossing of positive edge of CK and negative edge of CK#. Output (Read) data is referenced to the crossings of CK and CK# (both directions of crossing). CKE Input Clock Enable: CKE activates (HIGH) and deactivates (LOW) the CK signal. If CKE goes LOW synchronously with clock, the internal clock is suspended from the next clock cycle and the state of output and burst address is frozen as long as the CKE remains LOW. When all banks are in the idle state, deactivating the clock controls the entry to the Power Down and Self Refresh modes. BA0-BA2 Input Bank Address: BA0-BA2 define to which bank the BankActivate, Read, Write, or Bank Precharge command is being applied. A0-A12 Input Address Inputs: A0-A12 is sampled during row address (A0-A12) for Active commands and the column address (A0-A9) for Read/Write commands to select one location out of the memory array in the respective bank. (A10/AP and A12/BC# have additional functions). The address inputs also provide the op-code during Mode Register Set commands. A10/AP Input Auto-Precharge: A10 is sampled during Read/Write commands to determine whether Autoprecharge should be performed to the accessed bank after the Read/Write operation. (HIGH: Autoprecharge; LOW: no Autoprecharge). A10 is sampled during a Precharge command to determine whether the Precharge applies to one bank (A10 LOW) or all banks (A10 HIGH). A12/BC# Input Burst Chop: A12/BC# is sampled during Read and Write commands to determine if burst chop (on the fly) will be performed. (HIGH - no burst chop; LOW - burst chopped). CS# Input Chip Select: CS# enables (sampled LOW) and disables (sampled HIGH) the command decoder. All commands are masked when CS# is sampled HIGH. It is considered part of the command code. RAS# Input Row Address Strobe: The RAS# signal defines the operation commands in conjunction with the CAS# and WE# signals and is latched at the crossing of positive edges of CK and negative edge of CK#. When RAS# and CS# are asserted "LOW" and CAS# is asserted "HIGH" either the BankActivate command or the Precharge command is selected by the WE# signal. When the WE# is asserted "HIGH" the BankActivate command is selected and the bank designated by BA is turned on to the active state. When the WE# is asserted "LOW" the Precharge command is selected and the bank designated by BA is switched to the idle state after the precharge operation. CAS# Input Column Address Strobe: The CAS# signal defines the operation commands in conjunction with the RAS# and WE# signals and is latched at the crossing of positive edges of CK and negative edge of CK#. When RAS# is held "HIGH" and CS# is asserted "LOW" the column access is started by asserting CAS# "LOW". Then, the Read or Write command is selected by asserting WE# “HIGH" or “LOW". WE# Input Write Enable: The WE# signal defines the operation commands in conjunction with the RAS# and CAS# signals and is latched at the crossing of positive edges of CK and negative edge of CK#. The WE# input is used to select the BankActivate or Precharge command and Read or Write command. LDQS, LDQS# UDQS UDQS# Input / Output Bidirectional Data Strobe: Specifies timing for Input and Output data. Read Data Strobe is edge triggered. Write Data Strobe provides a setup and hold time for data and DQM. LDQS is for DQ0~7, UDQS is for DQ8~15. The data strobes LDOS and UDQS are paired with LDQS# and UDQS# to provide differential pair signaling to the system during both reads and writes. LDM, UDM Input Data Input Mask: Input data is masked when DM is sampled HIGH during a write cycle. LDM masks DQ0-DQ7, UDM masks DQ8-DQ15. NDT16PFJ2133v3.5-1Gb(x16)20200824 6 1Gb (x16) DDR3 Synchronous DRAM (2133) 64Mx16 –NDT16PFJ DQ0-DQ15 Input / Output Data I/O: The DQ0-DQ15 input and output data are synchronized with positive and negative edges of DQS and DQS#. TheI/Os are byte-maskable during Writes. ODT Input On Die Termination: ODT (registered HIGH) enables termination resistance internal to the DDR3 SDRAM. When enabled, ODT is applied to each DQ, DQS, DQS#. The ODT pin will be ignored if Mode-registers, MR1and MR2, are programmed to disable RTT. RESET# Input Active Low Asynchronous Reset: Reset is active when RESET# is LOW, and inactive when RESET# is HIGH. RESET# must be HIGH during normal operation. RESET# is a CMOS rail to rail signal with DC high and low at 80% and 20% of VDD. VDD Supply Power Supply: +1.5V +/-0.075V. VSS Supply Ground VDDQ Supply DQ Power: +1.5V +/-0.075V. VSSQ Supply DQ Ground VREFCA Supply Reference voltage for CA VREFDQ Supply Reference voltage for DQ ZQ Supply Reference pin for ZQ calibration. NC - No Connect: These pins should be left unconnected. NDT16PFJ2133v3.5-1Gb(x16)20200824 7 1Gb (x16) DDR3 Synchronous DRAM (2133) 64Mx16 –NDT16PFJ Operation Mode Truth Table The following tables provide a quick reference of available DDR3 SDRAM commands, including CKE power-down modes and bank-to-bank commands. Table 3. Truth Table (Note (1), (2)) Command BankActivate State CKEn-1(3) CKEn DM BA0-2 A10/AP A0-9, 11 A12/BC# CS# RAS# CAS# WE# Idle(4) H H X V Single Bank Precharge Any H H X V L V All Banks Precharge Any H H X V H Write (Fixed BL8 or BC4) Active(4) H H X V Write (BC4, on the fly) Active(4) H H X Write (BL8, on the fly) Active(4) H H Active(4) H Active(4) L L H H V L L H L V V L L H L L V V L H L L V L V L L H L L X V L V H L H L L H X V H V V L H L L H H X V H V L L H L L Active(4) H H X V H V H L H L L Read (Fixed BL8 or BC4) Active(4) H H X V L V V L H L H Read (BC4, on the fly) Active(4) H H X V L V L L H L H Read (BL8, on the fly) Active(4) H H X V L V H L H L H Active(4) H H X V H V V L H L H Active(4) H H X V H V L L H L H Active(4) H H X V H V H L H L H (Extended) Mode Register Set Idle H H X V L L L L No-Operation Any H H X V V V V L H H H Device Deselect Any H H X X X X X H X X X Refresh Idle H H X V V V V L L L H SelfRefresh Entry Idle H L X V V V V L L L H SelfRefresh Exit Idle L H X X X X X H X X X V V V V L H H H Power Down Mode Entry Idle H L X X X X X H X X X V V V V L H H H Power Down Mode Exit Any L H X X X X X H X X X V V V V L H H H Data Input Mask Disable Active H X L X X X X X X X X Data Input Mask Enable(5) Active H X H X X X X X X X X ZQ Calibration Long Idle H H X X H X X L H H L ZQ Calibration Short Idle X L H H L Write with Autoprecharge (Fixed BL8 or BC4) Write with Autoprecharge (BC4, on the fly) Write with Autoprecharge (BL8, on the fly) Read with Autoprecharge (Fixed BL8 or BC4) Read with Autoprecharge (BC4, on the fly) Read with Autoprecharge (BL8, on the fly) Row address OP code H H X X L X Note 1: V=Valid data, X=Don't Care, L=Low level, H=High level Note 2: CKEn signal is input level when commands are provided. Note 3: CKEn-1 signal is input level one clock cycle before the commands are provided. Note 4: These are states of bank designated by BA signal. Note 5: LDM and UDM can be enabled respectively. NDT16PFJ2133v3.5-1Gb(x16)20200824 8 1Gb (x16) DDR3 Synchronous DRAM (2133) 64Mx16 –NDT16PFJ Functional Description The DDR3 SDRAM is a high-speed dynamic random access memory internally configured as an eight-bank DRAM. The DDR3 SDRAM uses an 8n prefetch architecture to achieve high speed operation. The 8n Prefetch architecture is combined with an interface designed to transfer two data words per clock cycle at the I/O pins. A single read or write operation for the DDR3 SDRAM consists of a single 8n-bit wide, four clock data transfer at the internal DRAM core and two corresponding n-bit wide, one-half clock cycle data transfers at the I/O pins. Read and write operation to the DDR3 SDRAM are burst oriented, start at a selected location, and continue for a burst length of eight or a ‘chopped’ burst of four in a programmed sequence. Operation begins with the registration of an Active command, which is then followed by a Read or Write command. The address bits registered coincident with the Active command are used to select the bank and row to be activated (BA0-BA2 select the bank; A0-A11 select the row). The address bit registered coincident with the Read or Write command are used to select the starting column location for the burst operation, determine if the auto precharge command is to be issued (via A10), and select BC4 or BL8 mode ‘on the fly’ (via A12) if enabled in the mode register. Prior to normal operation, the DDR3 SDRAM must be powered up and initialized in a predefined manner. The following sections provide detailed information covering device reset and initialization, register definition, command descriptions and device operation. Figure 4. Reset and Initialization Sequence at Power-on Ramping Ta Tb Tc Td Te Tf Tg Th Ti Tj Tk CK# CK VDD VDDQ tCKSRX T=200μs T=500μs RESET# Tmin=10ns tIS CKE tDLLK tIS COMMAND Note 1 BA tXPR tMRD tMRD tMRD tMOD MRS MRS MRS MRS MR2 MR3 MR1 MR0 tZQinit ZQCL Note 1 VALID tIS ODT VALID tIS Static LOW in case RTT_Nom is enabled at time Tg, otherwise static HIGH or LOW VALID RTT NOTE 1. From time point "Td" until "Tk " NOP or DES commands must be applied between MRS and ZQCL commands. TIME BREAK NDT16PFJ2133v3.5-1Gb(x16)20200824 9 Don't Care 1Gb (x16) DDR3 Synchronous DRAM (2133) 64Mx16 –NDT16PFJ Power-up and Initialization The Following sequence is required for POWER UP and Initialization 1. Apply power (RESET# is recommended to be maintained below 0.2 x VDD, all other inputs may be undefined). RESET# needs to be maintained for minimum 200us with stable power. CKE is pulled “Low” anytime before RESET# being de-asserted (min. time 10ns). The power voltage ramp time between 300mV to VDDmin must be no greater than 200ms; and during the ramp, VDD>VDDQ and (VDD-VDDQ)
NDL16PFJ-8KET TR
物料型号: NDT16PFJ2133v3.5-1Gb(x16)20200824
器件简介: - 1Gb (x16) DDR3 Synchronous DRAM (2133) 64Mx16 - 用于一般应用的高速传输率,最高可达2133 Mb/sec/pin - 8Mbit x 16 I/Os x 8 bank设备内部配置 - 符合所有DDR3 DRAM关键特性
引脚分配: - 96-ball 8 x 13 x 1.0mm FBGA封装,无铅和无卤素
参数特性: - JEDEC标准兼容 - 电源电压: VDD & VDDQ = +1.5V ±0.075V - 工作温度范围: 工业级(IT): TC = -40~95°C - 支持JEDEC时钟抖动规范 - 完全同步操作 - 快速时钟频率: 1066MHz - 差分时钟CK & CK# - 8个内部银行同时操作 - 8n位预取架构 - 流水线内部架构
功能详解: - 预充电和活动功耗降低 - 可编程模式和扩展模式寄存器 - 可编程的延迟(AL): 0, CL-1, CL-2 - 可编程突发长度: 4, 8 - 突发类型: 连续/交错 - 输出驱动器阻抗控制 - 自动刷新和自刷新 - 写入均衡 - ZQ校准 - 动态ODT (Rtt_Nom & Rtt_WR)
应用信息: - 适用于需要高速数据传输和同步操作的应用
封装信息: - 96-ball 8 x 13 x 1.0mm FBGA封装,无铅和无卤素
NDL16PFJ-8KET TR 价格&库存
很抱歉,暂时无法提供与“NDL16PFJ-8KET TR”相匹配的价格&库存,您可以联系我们找货
