TC58BYG0S3HBAI6
TC58BYG0S3HBAI6
    KIOXIA(铠侠)
    VFBGA67
    1 GBIT CMOS NAND E2PROM
TC58BYG0S3HBAI6 数据手册
TC58BYG0S3HBAI6 MOS DIGITAL INTEGRATED CIRCUIT SILICON GATE CMOS 1 GBIT (128M  8 BIT) CMOS NAND E2PROM DESCRIPTION The TC58BYG0S3HBAI6 is a single 1.8V 1Gbit (1,107,296,256 bits) NAND Electrically Erasable and Programmable Read-Only Memory (NAND E2PROM) organized as (2048  64) bytes  64 pages  1024 blocks. The device has a 2112-byte static register which allows program and read data to be transferred between the register and the memory cell array in 2112-bytes increments. The Erase operation is implemented in a single block unit (128 Kbytes  4 Kbytes: 2112 bytes  64 pages). The TC58BYG0S3HBAI6 is a serial-type memory device which utilizes the I/O pins for both address and data input/output as well as for command inputs. The Erase and Program operations are automatically executed, making the device most suitable for applications such as solid-state file storage, voice recording, image file memory for still cameras and other systems which require high-density non-volatile memory data storage. The TC58BYG0S3HBAI6 has ECC logic on the chip and 8bit read errors for each 528Bytes can be corrected internally. FEATURES  Organization Memory cell array Register Page size Block size  Modes Read, Reset, Auto Page Program, Auto Block Erase, Status Read, Page Copy, ECC Status Read  Mode control Serial input/output Command control  Number of valid blocks Min 1004 blocks Max 1024 blocks x8 2112  64K  8 2112  8 2112 bytes (128K  4K) bytes  Power supply VCC  1.7V to 1.95V  Access time Cell array to register Read Cycle Time 40 s typ. 25 ns min (CL=30pF)  Program/Erase time Auto Page Program Auto Block Erase 330 s/page typ. 3.5 ms/block typ.  Operating current Read (25 ns cycle) Program (avg.) Erase (avg.) Standby 30 mA max 30 mA max 30 mA max 50 A max  Package P-VFBGA67-0608-0.80-001 (Weight: 0.095 g typ.)  8bit ECC for each 528Bytes is implemented on a chip. © 2012-2019 KIOXIA Corporation 1 2019-10-01C TC58BYG0S3HBAI6 PIN ASSIGNMENT (TOP VIEW) 1 A 2 3 NC NC 4 -------- B NC WP ALE 5 6 7 8 NC NC NC -------- -------- -------- VSS CE WE RY/BY NC NC -------- C NC NC RE CLE NC NC NC D NC NC NC NC NC NC E NC NC NC NC NC NC F NC NC NC NC NC NC G NC I/O1 NC NC NC VCC H NC NC I/O2 NC VCC I/O6 I/O8 NC J NC VSS I/O3 I/O4 I/O5 I/O7 VSS NC K NC NC NC NC NC NC PIN NAMES I/O1 to I/O8 I/O port -------- CE Chip enable -------- WE Write enable -------- RE Read enable CLE Command latch enable ALE Address latch enable -------- WP Write protect -------- © 2012-2019 KIOXIA Corporation RY / BY Ready/Busy VCC Power supply VSS Ground NC No Connection 2 2019-10-01C TC58BYG0S3HBAI6 BLOCK DIAGRAM ECC Logic Data register 1 VCC VSS Status register Address register I/O1 to Column buffer I/O Control circuit Column decoder I/O8 Command register Data register 0 Sense amp Row address buffer decoder CE CLE ALE Logic control -------- WE Control circuit -------- RE -------- WP Row address decoder -------- Memory cell array -------- RY / BY -------- RY / BY HV generator ABSOLUTE MAXIMUM RATINGS SYMBOL RATING VALUE UNIT VCC Power Supply Voltage 0.6 to 2.5 V VIN Input Voltage 0.6 to 2.5 V VI/O Input /Output Voltage 0.6 to VCC  0.3 ( 2.5 V) V PD Power Dissipation 0.3 W TSTG Storage Temperature 55 to 125 °C TOPR Operating Temperature -40 to 85 °C Note: Avoid locations where the device may be exposed to water (wet, rain, dew condensation, etc.) CAPACITANCE *(Ta  25°C, f  1 MHz) SYMBOL PARAMETER CONDITION MIN MAX UNIT CIN Input VIN  0 V  10 pF COUT Output VOUT  0 V  10 pF * This parameter is periodically sampled and is not tested for every device. © 2012-2019 KIOXIA Corporation 3 2019-10-01C TC58BYG0S3HBAI6 VALID BLOCKS SYMBOL NVB NOTE: PARAMETER Number of Valid Blocks MIN TYP. MAX UNIT 1004  1024 Blocks The device occasionally contains unusable blocks. Refer to Application Note (13) toward the end of this document. The first block (Block 0) is guaranteed to be a valid block at the time of shipment. The specification for the minimum number of valid blocks is applicable over lifetime. DC OPERATING CONDITIONS SYMBOL PARAMETER MIN TYP. MAX UNIT 1.7  1.95 V VCC Power Supply Voltage VIH High Level Input Voltage VCC x 0.8  VCC  0.3 V VIL Low Level Input Voltage 0.3*  VCC x 0.2 V 2 V (pulse width lower than 20 ns) * DC CHARACTERISTICS (Ta  -40 to 85°C, VCC  1.7 to 1.95V) SYMBOL PARAMETER CONDITION MIN TYP. MAX UNIT IIL Input Leakage Current VIN  0 V to VCC   10 A ILO Output Leakage Current VOUT  0 V to VCC   10 A --------   30 mA    30 mA    30 mA   50 A VCC – 0.2   V   0.2 V  4  mA ICCO1 Serial Read Current ICCO2 Programming Current ICCO3 Erasing Current CE  VIL, IOUT  0 mA, tRC  25 ns -------- -------- ICCS Standby Current CE  VCC  0.2 V, WP  0 V/VCC VOH High Level Output Voltage IOH  0.1 mA VOL Low Level Output Voltage IOL  0.1 mA IOL -------(RY / BY) Output Current of RY / BY pin VOL  0.2 V © 2012-2019 KIOXIA Corporation -------- 4 2019-10-01C TC58BYG0S3HBAI6 AC CHARACTERISTICS AND OPERATING CONDITIONS (Ta  -40 to 85°C, VCC  1.7 to 1.95V) SYMBOL PARAMETER MIN MAX UNIT tCLS CLE Setup Time 12  ns tCLH CLE Hold Time 5  ns 20  ns -------- tCS CE Setup Time -------- tCH CE Hold Time 5  ns tWP Write Pulse Width 12  ns tALS ALE Setup Time 12  ns tALH ALE Hold Time 5  ns tDS Data Setup Time 12  ns tDH Data Hold Time 5  ns tWC Write Cycle Time 25  ns 10  ns 100  ns 20  ns -------- tWH WE High Hold Time -------- tWW -------- WP High to WE Low -------- tRR Ready to RE Falling Edge -------- tRW Ready to WE Falling Edge 20  ns tRP Read Pulse Width 12  ns tRC Read Cycle Time 25  ns --------  20 ns  25 ns 10  ns 10  ns 25  ns 5  ns  60 ns  20 ns 0  ns 10  ns 0  ns 30  ns 30  ns WE High to RE Low 60  ns -------- tREA RE Access Time -------- tCEA CE Access Time -------- tCLR CLE Low to RE Low -------- tAR ALE Low to RE Low -------- tRHOH RE High to Output Hold Time -------- tRLOH RE Low to Output Hold Time -------- tRHZ RE High to Output High Impedance -------- tCHZ CE High to Output High Impedance -------- tCSD CE High to ALE or CLE Don’t Care -------- tREH RE High Hold Time -------- tIR Output-High-Impedance-to-RE Falling Edge -------- tRHW -------- RE High to WE Low -------- tWHC WE High to CE Low -------- tWHR -------- -------- tWB WE High to Busy  100 ns tRST Device Reset Time (Ready/Read/Program/Erase)  5/5/10/500 s *1: tCLS and tALS cannot be shorter than tWP. *2: tCS should be longer than tWP + 8ns. © 2012-2019 KIOXIA Corporation 5 2019-10-01C TC58BYG0S3HBAI6 AC TEST CONDITIONS CONDITION PARAMETER VCC: 1.7 to 1.95 Input level VCC-0.2V, 0.2V Input pulse rise and fall time 3 ns Input comparison level VCC / 2 Output data comparison level VCC / 2 CL (30 pF)  1 TTL Output load -------- Note: Busy to ready time depends on the pull-up resistor tied to the RY / BY pin. (Refer to Application Note (9) toward the end of this document) PROGRAMMING / ERASING / READING CHARACTERISTICS (Ta  -40 to 85°C, VCC  1.7 to 1.95V) SYMBOL PARAMETER MIN TYP. MAX UNIT s tPROG Average Programming Time  330 700 N Number of Partial Program Cycles in the Same Page   4 tBERASE Block Erasing Time  3.5 10 ms tR Memory Cell Array to Starting Address  40 120 s NOTES (1) (1) Refer to Application Note (12) toward the end of this document. Data Output When tREH is long, output buffers are disabled by /RE=High, and the hold time of data output depends on tRHOH (25ns MIN). Under this condition, the waveforms look like Normal Serial Read Mode. When tREH is short, output buffers are not disabled by /RE=High, and the hold time of data output depends on tRLOH (5ns MIN). Under this condition, output buffers are disabled by the rising edge of CLE, ALE, /CE or the falling edge of /WE, and waveforms look like Extended Data Output Mode. © 2012-2019 KIOXIA Corporation 6 2019-10-01C TC58BYG0S3HBAI6 TIMING DIAGRAMS Latch Timing Diagram for Command/Address/Data CLE ALE -------CE Setup Time Hold Time -------- WE tDS tDH I/O : VIH or VIL Command Input Cycle Timing Diagram CLE tCLS tCS tCLH tCH -------- CE tWP -------- WE tALS tALH ALE tDS tDH I/O : VIH or VIL © 2012-2019 KIOXIA Corporation 7 2019-10-01C TC58BYG0S3HBAI6 Address Input Cycle Timing Diagram tCLS tCLH CLE tCH tCS tWC tCH tCS -------- CE tWP tWH tWP tWH tWP tWH tWP -------- WE tALS tALH ALE tDS tDH tDS CA0 to 7 I/O tDH tDS CA8 to 11 tDH tDS PA0 to 7 tDH PA8 to 15 : VIH or VIL Data Input Cycle Timing Diagram tCLS tCLH CLE tCH tCS tCS tCH -------- CE tALS tALH tWC ALE tWP tWH tWP tWP -------- WE tDS I/O © 2012-2019 KIOXIA Corporation tDH tDS DIN0 tDH DIN1 8 tDS tDH DIN2111 2019-10-01C TC58BYG0S3HBAI6 Serial Read Cycle Timing Diagram tRC -------- CE tRP tREH tRP tCHZ tRP -------- RE tRHZ tRHOH tREA tREA tRHZ tRHZ tRHOH tREA tCEA tRHOH tCEA I/O tRR -------- RY / BY : VIH or VIL Status Read Cycle Timing Diagram tCLR CLE tCLS tCLH tCS -------- CE tWP tCH tCEA -------- WE tCHZ tWHC tWHR -------- RE tRHOH tDS tDH tIR tREA 70h* I/O tRHZ Status output -------- RY / BY : VIH or VIL * 70h represents the hexadecimal number © 2012-2019 KIOXIA Corporation 9 2019-10-01C TC58BYG0S3HBAI6 ECC Status Read Cycle Timing Diagram tCLR CLE tCLS tCLH tCS -------- CE tWP tCH tCEA -------- WE tWHC tWHR -------- RE tDS tDH tIR tREA I/O 7Ah* tREA tREA tREA Status output Status output Status output Status output Sector1 Sector2 Sector3 Sector4 -------- RY / BY : VIH or VIL * ECC Status output should be read for all 4 sector information -------** 7Ah command can be input to the device from [after RY / BY returns to High] to [before Dout or Next command input]. © 2012-2019 KIOXIA Corporation 10 2019-10-01C TC58BYG0S3HBAI6 Read Cycle Timing Diagram tCLR CLE tCLS tCLH tCS tCLS tCH tCLR tCLH tCS tCH -------- CE tWC -------- WE tALH tALS tALH tALS ALE tR -------- tRC tWB RE tDS tDH I/O tDS tDH tDS tDH tDS tDH tDS tDH CA0 to 7 00h CA8 to 11 PA0 to 7 tDS tDH PA8 to 15 tRR 70h 30h tREA status output DOUT N 00h DOUT N1 Data out from Col. Add. N Col. Add. N -------- RY / BY -------- Read Cycle Timing Diagram: When Interrupted by CE tCLR CLE tCLS tCLH tCS tCH tCLS tCS tCLR tCLH tCH -------- CE tCSD tWC -------- WE tALH tALS tALH tALS ALE tR -------- tCHZ tWB RE tDS tDH I/O tRC 00h tDS tDH tDS tDH tDS tDH tDS tDH CA0 to 7 CA8 to 11 PA0 to 7 PA8 to 15 tDS tDH tRR 30h 70h tREA status output 00h DOUT N tRHZ tRHOH DOUT N1 Data out from Col. Add. N Col. Add. N -------- RY / BY © 2012-2019 KIOXIA Corporation 11 2019-10-01C TC58BYG0S3HBAI6 Column Address Change in Read Cycle Timing Diagram (1/2) tCLR CLE tCLS tCLH tCS tCLR tCLS tCLH tCH tCH tCS -------- CE tWC -------- WE tALH tALS tALH tALS ALE tRC tR -------- tWB RE tDS tDH tDS tDH tDS tDH tDS tDH tDS tDH tDS tDH 00h CA0 to 7 CA8 to 11 PA0 to 7 PA8 to 15 30h tREA I/O Column address A Page address P 70h Status Output 00h DOUT DOUT A+1 A DOUT A +N Page address P -------- RY / BY Data out from Column address A 1 Continues from 1 of next page © 2012-2019 KIOXIA Corporation 12 2019-10-01C TC58BYG0S3HBAI6 Column Address Change in Read Cycle Timing Diagram (2/2) tCLR CLE tCLS tCLH tCS tCH tCLS tCLH tCS tCH -------- CE tRHW tCEA tWC -------- WE tALH tALS tALH tALS ALE tWHR tRC -------- RE tDS tDH tDS tDH tDS tDH tDS tDH tREA tIR DOUT AN I/O 05h CA0 to 7 CA8 to 11 E0h DOUT B DOUT B1 DOUT B  N’ Page address P Column address B -------- RY / BY Data out from Column address B 1 Continues from 1 © 2012-2019 KIOXIA Corporation of previous page 13 2019-10-01C TC58BYG0S3HBAI6 Data Output Timing Diagram CLE tCLS tCLH tCS tCH -------- CE -------- WE tALH ALE tRC tRP tCHZ tREH tRP tRP tRHZ -------- RE tREA tCEA Dout tRR tDS tDH tRLOH tRLOH tREA I/O tREA Dout tRHOH Dout Command tRHOH -------- RY / BY © 2012-2019 KIOXIA Corporation 14 2019-10-01C TC58BYG0S3HBAI6 Auto-Program Operation Timing Diagram tCLS CLE tCLS tCLH tCS tCS -------- CE tCH -------- WE tALH tALH tALS tPROG tWB tALS tRW ALE -------- RE I/O tDS tDS tDS tDH tDS tDH 80h CA0 to 7 tDH tDH CA8 to 11 PA0 to 7 PA8 to 15 DIN N+1 DINN DINM* 10h 70h Status output Column address N -------- RY / BY : Do not input data while data is being output. : VIH or VIL * © 2012-2019 KIOXIA Corporation M: up to 2111 15 2019-10-01C TC58BYG0S3HBAI6 Auto Block Erase Timing Diagram CLE tCLS tCLH tCS tCLS -------- CE -------- WE tALS tALH tWB tBERASE ALE -------- RE tDS tDH I/O -------- RY / BY 60h PA0 to 7 Auto Block Erase Setup command : VIH or VIL © 2012-2019 KIOXIA Corporation PA8 to 15 D0h Erase Start command 70h Busy Status output Status Read command : Do not input data while data is being output. 16 2019-10-01C © 2012-2019 KIOXIA Corporation 17 RY/BY I/Ox RE ALE WE CE CLE 00h tWC Column Address Row Address Col Col Row Row 35h Add1 Add2 Add1 Add2 tWB t 70h I/O 00h Data1 I/O1=0 Successful Read I/O1=1 Error in Read Busy tR Copy Back Program with Random Data Input DataN Column Address Row Address Col Col Row Row Add1 Add2 Add1 Add2 Copy Back Program Data Input Command 85h Data1 DataN 10h tWB 70h tWHR I/O I/O1=0 Successful Program I/O1=1 Error in Program Busy Status Read command tPROG TC58BYG0S3HBAI6 2019-10-01C TC58BYG0S3HBAI6 ID Read Operation Timing Diagram tCLS CLE tCLS tCS tCS tCH tCEA -------- CE tCH -------- WE tALH tALH tALS tAR ALE -------- RE tDH tDS I/O tREA tREA tREA tREA tREA 90h 00h 98h A1h See Table 5 See Table 5 ID Read command Address 00 Maker code Device code 3rd Data 4th Data See Table 5 5th Data : VIH or VIL © 2012-2019 KIOXIA Corporation 18 2019-10-01C TC58BYG0S3HBAI6 PIN FUNCTIONS The device is a serial access memory which utilizes time-sharing input of address information. Command Latch Enable: CLE The CLE input signal is used to control loading of the operation mode command into the internal command register. The command is latched into the command register from the I/O port on the rising edge of the WE signal while CLE is High. -------- Address Latch Enable: ALE The ALE signal is used to control loading address information into the internal address register. Address information is latched into the address register from the I/O port on the rising edge of WE while ALE is High. -------- -------- Chip Enable: CE The device goes into a low-power Standby mode when CE goes High while the device is in Ready state. The CE signal is ignored when the device is in Busy state (RY / BY  L), such as during a Program, Erase or Read operation, and will not enter Standby mode even if the CE input goes High. -------- -------- -------- -------- -------- Write Enable: WE The WE signal is used to control the acquisition of data from the I/O port. -------- -------- Read Enable: RE The RE signal controls serial data output. Data is available tREA after the falling edge of RE. The internal column address counter is also incremented (Address = Address + 1) on this falling edge. -------- -------- I/O Port: I/O1 to 8 The I/O1 to 8 pins are used as a port for transferring address, command and input/output data to and from the device. -------- Write Protect: WP The WP signal is used to protect the device from accidental programming or erasing. The internal voltage regulator is reset when WP is Low. This signal is usually used to protect the data during the power-on/off sequence when input signals are invalid. -------- -------- -- -- - --- Ready/Busy: RY / BY The RY / BY output signal is used to indicate the operating condition of the device. The RY / BY signal is in Busy state (RY / BY = L) during the Program, Erase and Read operations and will return to Ready state (RY / BY = H) after completion of the operation. The output buffer for this signal is an open drain and has to be pulled up to VCC with an appropriate resistor. -------- -------- -------- -------- © 2012-2019 KIOXIA Corporation 19 2019-10-01C TC58BYG0S3HBAI6 Schematic Cell Layout and Address Assignment The Program operation works on page units while the Erase operation works on block units. I/O1 Data Cache 2048 64 Page Buffer 2048 64 I/O8 A page consists of 2112 bytes in which 2048 bytes are used for main memory storage and 64 bytes are for redundancy or for other uses. 1 page  2112 bytes 1 block  2112 bytes  64 pages  (128K  4K) bytes Capacity  2112 bytes  64 pages  1024 blocks 64 Pages1 block 65536 pages 1024 blocks An address is read in via the I/O port over four consecutive clock cycles, as shown in Table 1. 8I/O 2112 Table 1. Addressing I/O8 I/O7 I/O6 I/O5 I/O4 I/O3 I/O2 I/O1 CA7 CA6 CA5 CA4 CA3 CA2 CA1 CA0 L L L L CA11 CA10 CA9 CA8 Third cycle PA7 PA6 PA5 PA4 PA3 PA2 PA1 PA0 Fourth cycle PA15 PA14 PA13 PA12 PA11 PA10 PA9 PA8 First cycle Second cycle © 2012-2019 KIOXIA Corporation 20 CA0 to CA11: Column address PA0 to PA5: Page address in block PA6 to PA15: Block address 2019-10-01C TC58BYG0S3HBAI6 Operation Mode: Logic and Command Tables The operation modes such as Program, Erase, Read and Reset are controlled by command operations shown in Table 3. Address input, command input and data input/output are controlled by the CLE, ALE, CE, WE, RE, and WP signals, as shown in Table 2. -------- -------- -------- -------- Table 2. Logic Table -------- -------- -------- CLE ALE CE WE RE WP*1 -------- Command Input H L L H * Data Input L L L H H Address Input L H L H * Serial Data Output L L L H During Program (Busy) * * * * * H During Erase (Busy) * * * * * H * * H * * * * * L H (*2) H (*2) * Program, Erase Inhibit * * * * * L Standby * * H * * 0 V/VCC * During Read (Busy) H: VIH, L: VIL, *: VIH or VIL -------*1: When the WP signal goes Low, Program or Erase operation is inhibited (Refer to Application Note (10) toward the end of this document). ---------------------*2: If CE is Low during Read Busy, WE and RE must be held High to avoid unintended command/address input to the device or read to the device. Reset or Status Read command can be input during Read Busy. © 2012-2019 KIOXIA Corporation 21 2019-10-01C TC58BYG0S3HBAI6 Table 3. Command table (HEX) First Set Second Set Serial Data Input 80  Read 00 30 Column Address Change in Serial Data Output 05 E0 Auto Page Program 80 10 Column Address Change in Serial Data Input 85  Read for Copy-Back 00 35 Copy-Back Program 85 10 Auto Block Erase 60 D0 ID Read 90  Status Read 70  ECC Status Read 7A  Reset FF  Acceptable while Busy   HEX data bit assignment (Example) Serial Data Input: 80h 1 0 0 0 0 0 0 0 8 7 6 5 4 3 2 I/O1 Table 4. Read mode operation states -------- -------- -------- CLE ALE CE WE RE I/O1 to I/O8 Power Output select L L L H L Data output Active Output Deselect L L L H H High impedance Active H: VIH, L: VIL © 2012-2019 KIOXIA Corporation 22 2019-10-01C TC58BYG0S3HBAI6 DEVICE OPERATION Read Mode Read mode is set when the "00h" and “30h” commands are issued to the Command register. Between the two commands, a start address for the Read mode needs to be issued. After the initial power-on sequence, “00h” command is latched into the internal command register. Then the Read operation after the power-on sequence is executed by the setting of only four address cycles and “30h” command. The sequence of the block diagram are shown below (Refer to the detailed timing chart). CLE -------- CE -------- WE ALE -------- RE -------- RY / BY I/O 00h tR Busy Column Address M Page Address N 70h 30h Status 00h M+1 M M+2 Page Address N Start-address input M A data transfer operation from the cell array to the Data Cache -------via Page Buffer starts on the rising edge of WE in the 30h command input cycle (after the address information has been latched). The device will be in the Busy state during this transfer period. After the transfer period, the device returns to-------Ready state. Serial data can be output synchronously with the RE clock from the start address designated in the address input cycle. m Data Cache Page Buffer Select page N Cell array I/O1 to 8: m  2111 Random Column Address Change in Read Cycle CLE -------- CE -------- WE ALE -------- RE -------- Busy RY / BY tR Col. M I/O 70h 30h 00h Statu 00h M M1 M2 M3 E0h 05h M’ M’1 M’2 M’3 M’4 s Col. M Page N Page N Start from Col. M Start-address input M Select page N © 2012-2019 KIOXIA Corporation M’ Col. M’ Page N Start from Col. M’ During the serial data output from the register, the column address can be changed by inputting a new column address using the 05h and E0h commands. The data is read out in serially starting at the new column address. Random Column Address Change operation can be done multiple times within the same page. 23 2019-10-01C TC58BYG0S3HBAI6 ECC & Sector definition for ECC Internal ECC logic generates Error Correction Code during busy time in program operation. The ECC logic manages 9bit error detection and 8bit error correction in each 528Bytes of main data and spare data. A section of main field (512Bytes) and spare field (16Bytes) are paired for ECC. During Read operation, the device executes ECC of itself. Once Read operation is executed, Status Read Command (70h) can be issued to check the read status. The read status remains until other valid commands are executed. To use ECC function, below limitation must be considered. - A sector is the minimum unit for program operation and the number of program per page must not exceed 4. 2KByte Page Assignment 1st Main 2nd Main 3rd Main 4th Main 1st Spare 2nd Spare 3rd Spare 4th Spare 512B 512B 512B 512B 16B 16B 16B 16B Note) Internal ECC manages all data of Main area and Spare area. Definition of 528Byte Sector Sector Column Address (Byte) Main Field Spare Field 1st Sector 0 to 511 2,048 to 2,063 2nd Sector 512 to 1,023 2,064 to 2,079 3rd Sector 1,024 to 1,535 2,080 to 2,095 4th Sector 1,536 to 2,047 2,096 to 2,111 Note) The ECC parity code generated by internal ECC is stored in column addresses 2112-2175 and the user cannot access to these specific addresses. While using the Partial Page Program, the user must program the data to main field and spare field simultaneously by the definition of sector. © 2012-2019 KIOXIA Corporation 24 2019-10-01C TC58BYG0S3HBAI6 Auto Page Program Operation The device carries out an Auto Page Program operation when it receives a "10h" Program command after the address and data have been input. The sequence of command, address and data input is shown below (Refer to the detailed timing chart). CLE -------- CE -------- WE ALE -------- RE -------- RY / BY I/O Busy Din Din Din Din 80h Col. M Page P 70h 10h Status Out Data Data input Program The data is transferred (programmed) from the Data Cache via the -------Page Buffer to the selected page on the rising edge of WE following input of the “10h” command. After programming, the programmed data is transferred back to the Page Buffer to be automatically verified by the device. If the programming does not succeed, the Program/Verify operation is repeated by the device until success is achieved or until the maximum loop number set in the device is reached. Read & verification Selected page Random Column Address Change in Auto Page Program Operation The column address can be changed by the 85h command during the data input sequence of the Auto Page Program operation. Two address input cycles after the 85h command are recognized as a new column address for the data input. After the new data is input to the new column address, the 10h command initiates the actual data program into the selected page automatically. The Random Column Address Change operation can be repeated multiple times within the same page. 80h Din Col. M Din Din Din 85h Din Col. M’ Page N Col. M Din Din Din 10h 70h Status Busy Col. M’ Data input Program Read & verification Selected page © 2012-2019 KIOXIA Corporation 25 2019-10-01C TC58BYG0S3HBAI6 Auto Block Erase The Auto Block Erase operation starts on the rising edge of WE after the Erase Start command “D0h” which follows the Erase Setup command “60h”. This two-cycle process for Erase operations acts as an extra layer of protection from accidental erasure of data due to external noise. The device automatically executes the Erase and Verify operations. -------- 60 D0 Block Address input: 2 cycles 70 Status Read command Erase Start command I/O Pass Fail -------- RY / BY © 2012-2019 KIOXIA Corporation Busy 26 2019-10-01C TC58BYG0S3HBAI6 READ FOR COPY-BACK WITH DATA OUTPUT TIMING GUIDE Copy-Back operation is a sequence execution of Read for Copy-Back and of Copy-Back Program with the destination page address. A Read operation with “35h” command and the address of source page moves the whole 2112 bytes data into the internal data buffer. Bit errors are checked by sequential reading the data or by reading the status in read after read busy time (tR) to check if uncorrectable error occurs. In the case of there is no bit error or no uncorrectable error, the data don’t need to be reloaded. Therefore Copy-Back Program operation is initiated by issuing Page-Copy Data-Input command (85h) with the destination page address. Actual programming operation begins after Program Confirm command (10h) is issued. Once the program process starts, the Status Read command (70h) may be entered to read the status register. The system controller can detect the completion of a program cycle by monitoring the RY / BY output, or the Status Bit (I/O7) of the Status Register. When the Copy-Back Program is completed, the Write Status Bit (I/O1) may be checked. The command register remains in Status Read mode until another valid command is written to the command register. During Copy-Back Program, the data modification is possible using Random Data Input command (85h) as shown below. -------- Page Copy-Back Program Operation tR -------- tPROG RY / BY ”0” I/Ox 00h Add.(4 Cycles) ”0” I/O1 70h 35h 00h ”1” Col. Add.1,2 & Page Add.1,2 Source Address Data Output Pass Add.(4 Cycles) 85h 10h Col. Add.1,2 & Page Add.1,2 Destination Address Fail 70h I/O1 Pass ”1” Fail Page Copy-Back Program Operation with Random Data Input tR -------- A RY / BY ”0” I/Ox 00h Add.(4Cycles) 35h 70h I/O1 Col. Add.1,2 & Page Add.1,2 Source Address -------- RY / BY I/Ox ”1” 00h Data Output Fail tPROG A A A Pass 85h Add.(4Cycles) Data Col. Add.1,2 & Page Add.1,2 Destination Address 85h Add.(2Cycles) Data 10h 70h Col. Add.1,2 There is no limitation for the number of repetition. © 2012-2019 KIOXIA Corporation 27 2019-10-01C TC58BYG0S3HBAI6 ID Read The device contains ID codes which can be used to identify the device type, the manufacturer, and features of the device. The ID codes can be read out under the following timing conditions: CLE tCEA -------- CE -------- WE tAR ALE -------- RE tREA I/O See table 5 90h 00h 98h A1h ID Read command Address 00 Maker code Device code 3rd Data See table 5 See table 5 4th Data 5th Data Table 5. Code table Description I/O8 I/O7 I/O6 I/O5 I/O4 I/O3 I/O2 I/O1 Hex Data 1st Data Maker Code 1 0 0 1 1 0 0 0 98h 2nd Data Device Code 1 0 1 0 0 0 0 1 A1h 3rd Data Chip Number, Cell Type 1 0 0 0 0 0 0 0 80h 4th Data Page Size, Block Size 0 0 0 1 0 1 0 1 15h 5th Data District Number 1 1 1 1 0 0 1 0 F2h 3rd Data Description Internal Chip Number Cell Type I/O8 I/O6 I/O5 I/O4 I/O3 1 2 4 8 2 level cell 4 level cell 8 level cell 16 level cell 0 0 1 1 Reserved © 2012-2019 KIOXIA Corporation I/O7 1 28 0 0 I/O2 I/O1 0 0 1 1 0 1 0 1 0 1 0 1 0 2019-10-01C TC58BYG0S3HBAI6 4th Data Description Page Size (without redundant area) 1 KB 2 KB 4 KB 8 KB Block Size (without redundant area) 64 KB 128 KB 256 KB 512 KB I/O Width I/O8 I/O7 I/O6 0 0 1 1 x8 x16 I/O5 I/O4 I/O3 I/O2 I/O1 0 0 1 1 0 1 0 1 I/O2 I/O1 1 0 0 1 0 1 0 1 Reserved 0 0 1 I/O4 I/O3 0 0 1 1 0 1 0 1 5th Data Description District Number ECC engine on chip I/O8 I/O6 I/O5 1 District 2 Districts 4 Districts 8 Districts With ECC engine 1 Reserved © 2012-2019 KIOXIA Corporation I/O7 1 29 1 1 2019-10-01C TC58BYG0S3HBAI6 Status Read The device automatically implements the execution and verification of the Program and Erase operations. The Status Read function is used to monitor the Ready/Busy status of the device, determine the result (Pass/Fail) of a Program or Erase operation, and determine whether the device is in Protect mode. The device status is output via the I/O port using RE after a “70h” command input. The Status Read command can also be used during a Read operation to monitor the Ready/Busy status and to find out the ECC result (Pass/Fail). The resulting information is outlined in Table 6. -------- Table 6. Status output table Definition Page Program Block Erase Read Pass/Fail Pass/Fail Pass/Fail(Uncorrectable) I/O1 Chip Status Pass: 0 I/O2 Not Used Invalid Invalid Invalid I/O3 Not Used 0 0 0 0 0 Normal or uncorrectable / Recommended to rewrite 0 0 0 Ready/Busy Ready/Busy Ready/Busy Ready/Busy Ready/Busy Ready/Busy Not Protected/Protected Not Protected/Protected Not Protected/Protected Fail: 1 Chip Read Status I/O4 Normal or uncorrectable: 0 Recommended to rewrite : 1 I/O5 Not Used I/O6 Ready/Busy Ready: 1 Busy: 0 I/O7 Ready/Busy Ready: 1 Busy: 0 I/O8 Write Protect Not Protected :1 Protected: 0 The Pass/Fail status on I/O1 is only valid during a Program/Erase/Read operation when the device is in the Ready state. © 2012-2019 KIOXIA Corporation 30 2019-10-01C TC58BYG0S3HBAI6 ECC Status Read The ECC Status Read function is used to monitor the Error Correction Status. The device can correct up to 8bit errors. ECC can be performed on the NAND Flash main and spare areas. The ECC Status Read function can also show the number of errors in a sector as a result of an ECC check during a Read operation. 8 7 6 5 Sector Information 4 3 2 I/O1 ECC Status ECC Status I/O4 to I/O1 ECC Status 0000 No Error 0001 1bit error(Correctable) 0010 2bit error(Correctable) 0011 3bit error(Correctable) 0100 4bit error(Correctable) 0101 5bit error(Correctable) 0110 6bit error(Correctable) 0111 7bit error(Correctable) 1000 8bit error(Correctable) 1111 Uncorrectable Error Sector Information I/O8 to I/O5 Sector Information 0000 1st Sector (Main and Spare area) 0001 2nd Sector (Main and Spare area) 0010 3rd Sector (Main and Spare area) 0011 4th Sector (Main and Spare area) Other Reserved © 2012-2019 KIOXIA Corporation 31 2019-10-01C TC58BYG0S3HBAI6 Reset The Reset mode stops all operations. For example, in case of a Program or Erase operation, the internally generated voltage is discharged to 0 volts and the device enters the Wait state. The response to a “FFh” Reset command input during the various device operations is as follows: When a Reset (FFh) command is input during Program operation 80 10 FF 00 Internal generated voltage -------- RY / BY tRST (max 10 s) © 2012-2019 KIOXIA Corporation 32 2019-10-01C TC58BYG0S3HBAI6 When a Reset (FFh) command is input during Erase operation D0 FF 00 Internal generated voltage -------- RY / BY tRST (max 500 s) When a Reset (FFh) command is input during Read operation 00 30 FF 00 -------- RY / BY tRST (max 5 s) When a Reset (FFh) command is input during Ready FF 00 -------- RY / BY tRST (max 5 s) When a Status Read command (70h) is input after a Reset FF 70 I/O status: Pass/Fail  Pass : Ready/Busy  Ready -------- RY / BY When two or more Reset commands are input in succession 10 (1) (2) (3) FF FF FF -------- RY / BY The second © 2012-2019 KIOXIA Corporation FF command is invalid, but the third 33 FF command is valid. 2019-10-01C TC58BYG0S3HBAI6 APPLICATION NOTES AND COMMENTS Power-on/off sequence (1) The timing sequence shown in the figure below is necessary for the power-on/off sequence. The device’s internal initialization starts after the power supply reaches an appropriate level during the power-on sequence. During the initialization the device Ready/Busy signal indicates the Busy state as shown in the figure below. In this time period, the acceptable commands are FFh or 70h. The WP signal is useful for protecting against data corruption at power-on/off. -------- 1.7 V 1.5 V VCC ≥ 1ms 0.5 V 0 V -------- 0.5 V Don’t care Don’t care -------- 1.7 V 1.5 V Don’t care -------- CE, WE, RE CLE, ALE -------- WP VIH VIL VIL 1 ms max 1 ms max Operation 100 s max 100 s max Invalid Invalid Invalid -------- RY / BY (2) Power-on Reset The following sequence is necessary because some input signals may not be stable at power-on. Power on FF Reset (3) Prohibition of unspecified commands The operation commands are listed in Table 3. Input of a command other than those specified in Table 3 is prohibited. Stored data may be corrupted if an unknown command is entered during the command cycle. (4) Restriction of commands while in the Busy state During the Busy state, do not input any command except 70h and FFh. © 2012-2019 KIOXIA Corporation 34 2019-10-01C TC58BYG0S3HBAI6 (5) Acceptable commands after Serial Data Input command “80h” Once the Serial Data Input command “80h” has been input, do not input any command other than the Column Address Change in Serial Data Input command “85h”, Auto Page Program command “10h” or the Reset command “FFh”. 80 FF -------- WE Address input -------- RY / BY If a command other than “85h”, “10h” or “FFh” is input, the Program operation is not performed and the device operation is set to the mode that the input command specifies. 80 XX 10 Mode specified by the command. Programming cannot be executed. Command other than “85h”, “10h” or “FFh” (6) Addressing for program operation Within a block, the pages must be programmed consecutively from the LSB (least significant bit) page of the block to the MSB (most significant bit) page of the block. Random page address programming is prohibited. From the LSB page to MSB page DATA IN: Data (1) e.g.) Random page program (Prohibition) Data (64) DATA IN: Data (1) Data register Data (64) Data register Page 0 Page 1 Page 2 (1) (2) (3) Page 0 Page 1 Page 2 (2) (32) (3) Page 31 (32) Page 31 (1) Page 63 (64) Page 63 (64) © 2012-2019 KIOXIA Corporation 35 2019-10-01C TC58BYG0S3HBAI6 (7) Status Read during a Read operation 00 Command 00 30 [A] 70 -------- CE -------- WE -------- RY / BY -------- RE Address N Status Read command input Status Read Status output The device status can be read out by inputting the Status Read command “70h” in Read mode. Once the device has been set to Status Read mode by a “70h” command, the device will not return to Read mode unless the Read command “00h” is input during [A]. If the Read command “00h” is input during [A], Status Read mode is reset, and the device returns to Read mode. In this case, data output starts automatically from address N and address input is unnecessary. (8) Auto programming failure Fail 80 10 70 80 I/O 10 Address Data M input Address Data N input 80 10 If the programming result for page address M is Fail, do not try to program the page to address N in another block without the data input sequence. Because the previous input data has been lost in the Data Cache, the same input sequence of 80h command, address and data have to be executed. M N -- -- - --- (9) -------- RY / BY: termination for the Ready/Busy pin (RY / BY) -------- A pull-up resistor needs to be used for termination because the RY / BY buffer consists of an open drain circuit. VCC VCC Ready VCC R Device Busy -------- RY / BY tr tf CL VCC  1.8 V Ta  25°C CL  30 pF VSS 1.5 s tr This data may vary from device to device. We recommend to use this data as a reference for selecting a resistor value. 1.0 s 10 ns tf tr 0.5 s 0 15 ns tf 5 ns 1 K 2 K 3 K 4 K R © 2012-2019 KIOXIA Corporation 36 2019-10-01C TC58BYG0S3HBAI6 (10) -------- Note regarding the WP signal -------- The Erase and Program operations are automatically reset when WP goes Low. The operations are enabled and disabled as follows: Enable Programming -------- WE DIN 80 10 -------- WP -------- RY / BY tWW (100 ns MIN) Disable Programming -------- WE DIN 80 10 -------- WP -------- RY / BY tWW (100 ns MIN) Enable Erasing -------- WE DIN 60 D0 -------- WP -------- RY / BY tWW (100 ns MIN) Disable Erasing -------- WE DIN 60 D0 -------- WP -------- RY / BY tWW (100 ns MIN) © 2012-2019 KIOXIA Corporation 37 2019-10-01C TC58BYG0S3HBAI6 (11) When five address cycles are input Although the device may read in a fifth address, it is ignored inside the chip. Read operation CLE -------- CE -------- WE ALE I/O 00h 30h Ignored Address input -------- RY / BY Program operation CLE -------- CE -------- WE ALE I/O 80h Ignored Address input © 2012-2019 KIOXIA Corporation 38 Data input 2019-10-01C TC58BYG0S3HBAI6 (12) Several programming cycles on the same page (Partial Page Program) ECC Parity Code is generated during program operation on Main area (512 byte) + Spare area (16byte). While using the Partial Page Program, the user must program the data to main field and spare field simultaneously by the definition of sector in section “ECC & Sector definition for ECC”. For example, each segment can be programmed individually as follows: Number of partial program cycles in the same page must not exceed 4. © 2012-2019 KIOXIA Corporation 39 2019-10-01C TC58BYG0S3HBAI6 (13) Invalid blocks (bad blocks) The device occasionally contains unusable blocks. Therefore, the following issues must be recognized: Bad Block Bad Block Please do not perform an erase operation to bad blocks. It may be impossible to recover the bad block’s information if the information is erased. Check if the device has any bad blocks after installation into the system. Refer to the test flow for bad block detection. Bad blocks which are detected by the test flow must be managed as unusable blocks by the system. A bad block does not affect the performance of good blocks because it is isolated from the bit lines by select gates. The number of valid blocks over the device lifetime is as follows: Valid (Good) Block Number MIN TYP. MAX UNIT 1004  1024 Blocks Bad Block Test Flow Regarding invalid blocks, bad block mark is in whole pages. Please read one column of any page in each block. If the data of the column is 00 (Hex), define the block as a bad block. For Bad Block Test Flow during Read Check, regardless of Status Read result (ECC Pass or Fail), use the read data value to make judgement for Bad Block. Start Block No  1 Fail Read Check Pass Block No.  Block No.  1 Entry Bad Block *1 No Last Block Yes End *1: No erase operation is allowed to detected bad blocks. © 2012-2019 KIOXIA Corporation 40 2019-10-01C TC58BYG0S3HBAI6 (14) Failure phenomena for Program, Erase and Read operations The device may fail during a Program, Erase or Read operation. The following possible failure modes should be considered when implementing a highly reliable system. FAILURE MODE DETECTION AND COUNTERMEASURE SEQUENCE Block Erase Failure Status Read after Erase  Block Replacement Page Programming Failure Status Read after Program  Block Replacement Read Check the ECC correction status by Status Read or ECC Status Read and take 9bit Failure(uncorrectable error) appropriate measures such as rewrite in consideration of Wear Leveling before uncorrectable ECC error occurs.  ECC: Error Correction Code. 8 bit correction per 528Bytes is executed in a device.  Block Replacement Program Error occurs Buffer memory Block A When an error happens in Block A, try to reprogram the data into another Block (Block B) by loading from an external buffer. Then, prevent further system accesses to Block A (by creating a bad block table or by using another appropriate scheme). Block B Erase When an error occurs during an Erase operation, prevent future accesses to this bad block (by creating a table within the system or by using another appropriate scheme). (15) Do not turn off the power before the Write/Erase operation is completed. Avoid using the device when the battery is low. Power shortage and/or power failure before the Write/Erase operation is completed will cause loss of data and/or damage to data. (16) Please refer to KIOXIA soldering temperature profile for detail. © 2012-2019 KIOXIA Corporation 41 2019-10-01C TC58BYG0S3HBAI6 (17) Reliability Guidance This reliability guidance is intended to notify some guidance related to using NAND Flash with 8 bit ECC for each 512 bytes. NAND Flash memory cells are gradually worn out and the reliability level of memory cells is degraded by repeating Write and Erase operation of ‘0’ data in each block. For detailed reliability data, please refer to the reliability note for each product. Although random bit errors may occur during use, it does not necessarily mean that a block is bad. Generally, a block should be marked as bad when a program status failure or erase status failure is detected. The reliability of NAND Flash memory cells during the actual usage on system level depends on the usage and environmental conditions. KIOXIA adopts the checker pattern data, 0x55 & 0xAA for alternative Write/Erase cycles, for the reliability test.  Write/Erase Endurance Write/Erase endurance failures may occur in a cell, page, or block, and are detected by doing a Status Read after either an Auto Page Program or Auto Block Erase operation. The cumulative bad block count will increase along with the number of Write/Erase cycles.  Data Retention The data in NAND Flash memory may change after a certain amount of storage time. This is due to charge loss or charge gain. After block erasure and reprogramming, the block may become usable again. Data Retention time is generally influenced by the number of Write/Erase cycles and temperature. Data Retention [Years] Here is a graph plotting the relationship between Write/Erase Endurance and Data Retention. Write/Erase Endurance [Cycles]  Read Disturb A Read operation may disturb the data in NAND Flash memory. The data may change due to charge gain. Usually, bit errors occur on other pages in the block, not the page being read. After a large number of read cycles (between block erases), a tiny charge may build up and can cause a cell to be soft programmed to another state. After block erasure and reprogramming, the block may become usable again. Read Disturb capability is generally influenced by the number of Write/Erase cycles. © 2012-2019 KIOXIA Corporation 42 2019-10-01C TC58BYG0S3HBAI6 (18) NAND Management NAND Management such as Bad Block Management, ECC treatment and Wear Leveling, but not limited to these treatments, should be recognized and incorporated in the system design. ECC treatment for read data is mandatory against random bit errors, and host should monitor ECC status to take appropriate measures such as rewrite in consideration of Wear Leveling before uncorrectable Error occurs. To realize robust system design, generally it is necessary to prevent the concentration of Write/Erase cycles at the specific blocks by adopting Wear Leveling which manages to distribute Write/Erase cycles evenly among NAND Flash memory. And also it is necessary to avoid dummy ‘0’ data write, e.g. ‘0’ data padding, which accelerate block endurance degradation. Continuous Write and Erase cycling with high percentage of '0' bits in data pattern can lead to faster block endurance degradation. Example: NAND cell array with ‘0’ data padding 0 : “0” data cell 1 : “1” data cell 0 0 1 1 0 1 0 1 1 1 0 1 0 0 1 0 0 0 1 0 1 1 0 1 0 1 0 0 1 0 1 0 User data area 1 1 0 1 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 1 0 0 1 0 0 0 1 0 1 1 0 1 0 1 0 0 1 0 1 0 1 1 0 1 0 1 0 1 User data area Remaining area (a) Accelerate block endurance degradation by fixed dummy “0” data write © 2012-2019 KIOXIA Corporation 0 0 1 1 0 1 0 1 43 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Remaining area (b) “1” data for Remaining area (Recommended) 2019-10-01C TC58BYG0S3HBAI6 Package Dimensions Unit: mm Weight: 0.095g (typ.) © 2012-2019 KIOXIA Corporation 44 2019-10-01C TC58BYG0S3HBAI6 Revision History Date 2012-02-17 2012-03-21 2012-07-06 2012-08-31 2018-06-01 Rev. 0.10 0.11 0.2 1.00 1.10 2019-10-01 2.00 © 2012-2019 KIOXIA Corporation Description Preliminary version Miss-pin assignments (TOP VIEW) are corrected. Revised ID Table. Corrected typo. Deleted TENTATIVE/TBD notation. Corrected typo, and described some notes. Attached Reliability Guidance and NAND Management. Changed “RESTRICTIONS ON PRODUCT USE”. Rebrand as "KIOXIA" Corrected typo and described some notes. Removed Soldering Temperature and added note in ABSOLUET MAXIMUM RAITNGS, and added comments in APPLICATION NOTES AND COMMENTS. 45 2019-10-01C TC58BYG0S3HBAI6 RESTRICTIONS ON PRODUCT USE KIOXIA Corporation and its subsidiaries and affiliates are collectively referred to as “KIOXIA”. Hardware, software and systems described in this document are collectively referred to as “Product”.  KIOXIA reserves the right to make changes to the information in this document and related Product without notice.  This document and any information herein may not be reproduced without prior written permission from KIOXIA. Even with KIOXIA's written permission, reproduction is permissible only if reproduction is without alteration/omission.  Though KIOXIA works continually to improve Product's quality and reliability, Product can malfunction or fail. Customers are responsible for complying with safety standards and for providing adequate designs and safeguards for their hardware, software and systems which minimize risk and avoid situations in which a malfunction or failure of Product could cause loss of human life, bodily injury or damage to property, including data loss or corruption. Before customers use the Product, create designs including the Product, or incorporate the Product into their own applications, customers must also refer to and comply with (a) the latest versions of all relevant KIOXIA information, including without limitation, this document, the specifications, the data sheets and application notes for Product and the precautions and conditions set forth in the "Reliability Information" in KIOXIA Corporation’s website and (b) the instructions for the application with which the Product will be used with or for. Customers are solely responsible for all aspects of their own product design or applications, including but not limited to (a) determining the appropriateness of the use of this Product in such design or applications; (b) evaluating and determining the applicability of any information contained in this document, or in charts, diagrams, programs, algorithms, sample application circuits, or any other referenced documents; and (c) validating all operating parameters for such designs and applications. KIOXIA ASSUMES NO LIABILITY FOR CUSTOMERS' PRODUCT DESIGN OR APPLICATIONS.  PRODUCT IS NEITHER INTENDED NOR WARRANTED FOR USE IN EQUIPMENTS OR SYSTEMS THAT REQUIRE EXTRAORDINARILY HIGH LEVELS OF QUALITY AND/OR RELIABILITY, AND/OR A MALFUNCTION OR FAILURE OF WHICH MAY CAUSE LOSS OF HUMAN LIFE, BODILY INJURY, SERIOUS PROPERTY DAMAGE AND/OR SERIOUS PUBLIC IMPACT ("UNINTENDED USE"). Except for specific applications as expressly stated in this document, Unintended Use includes, without limitation, equipment used in nuclear facilities, equipment used in the aerospace industry, lifesaving and/or life supporting medical equipment, equipment used for automobiles, trains, ships and other transportation, traffic signaling equipment, equipment used to control combustions or explosions, safety devices, elevators and escalators, and devices related to power plant. IF YOU USE PRODUCT FOR UNINTENDED USE, KIOXIA ASSUMES NO LIABILITY FOR PRODUCT. For details, please contact your KIOXIA sales representative or contact us via our website.  Do not disassemble, analyze, reverse-engineer, alter, modify, translate or copy Product, whether in whole or in part.  Product shall not be used for or incorporated into any products or systems whose manufacture, use, or sale is prohibited under any applicable laws or regulations.  The information contained herein is presented only as guidance for Product use. No responsibility is assumed by KIOXIA for any infringement of patents or any other intellectual property rights of third parties that may result from the use of Product. No license to any intellectual property right is granted by this document, whether express or implied, by estoppel or otherwise.  ABSENT A WRITTEN SIGNED AGREEMENT, EXCEPT AS PROVIDED IN THE RELEVANT TERMS AND CONDITIONS OF SALE FOR PRODUCT, AND TO THE MAXIMUM EXTENT ALLOWABLE BY LAW, KIOXIA (1) ASSUMES NO LIABILITY WHATSOEVER, INCLUDING WITHOUT LIMITATION, INDIRECT, CONSEQUENTIAL, SPECIAL, OR INCIDENTAL DAMAGES OR LOSS, INCLUDING WITHOUT LIMITATION, LOSS OF PROFITS, LOSS OF OPPORTUNITIES, BUSINESS INTERRUPTION AND LOSS OF DATA, AND (2) DISCLAIMS ANY AND ALL EXPRESS OR IMPLIED WARRANTIES AND CONDITIONS RELATED TO SALE, USE OF PRODUCT, OR INFORMATION, INCLUDING WARRANTIES OR CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, ACCURACY OF INFORMATION, OR NONINFRINGEMENT.  Do not use or otherwise make available Product or related software or technology for any military purposes, including without limitation, for the design, development, use, stockpiling or manufacturing of nuclear, chemical, or biological weapons or missile technology products (mass destruction weapons). Product and related software and technology may be controlled under the applicable export laws and regulations including, without limitation, the Japanese Foreign Exchange and Foreign Trade Law and the U.S. Export Administration Regulations. Export and re-export of Product or related software or technology are strictly prohibited except in compliance with all applicable export laws and regulations.  Please contact your KIOXIA sales representative for details as to environmental matters such as the RoHS compatibility of Product. Please use Product in compliance with all applicable laws and regulations that regulate the inclusion or use of controlled substances, including without limitation, the EU RoHS Directive. KIOXIA ASSUMES NO LIABILITY FOR DAMAGES OR LOSSES OCCURRING AS A RESULT OF NONCOMPLIANCE WITH APPLICABLE LAWS AND REGULATIONS. © 2012-2019 KIOXIA Corporation 46 2019-10-01C
TC58BYG0S3HBAI6
物料型号:KIOXIA TC58BYG0S3HBAI6
器件简介: - 这是一款1.8V单电源供电的1Gbit(128M x 8位)NAND型电可擦可编程只读存储器(NAND E2PROM)。 - 它以(2048 + 64)字节 x 64页 x 1024块的组织形式存在。 - 具有2112字节的静态寄存器,允许以2112字节的增量在寄存器和存储器阵列之间传输程序和读取数据。
引脚分配: - 该芯片采用P-VFBGA67-0608-0.80-001封装,共有67个引脚。 - 引脚包括I/O端口(1/O1至1/O8)、片使能(CE)、写使能(WE)、读使能(RE)、命令锁存器使能(CLE)、地址锁存器使能(ALE)、写保护(WP)、就绪/忙(RY/BY)和电源(Vcc、Vss)等。
参数特性: - 电源电压(VCC)范围为1.7V至1.95V。 - 访问时间为40μs(典型值),读周期时间为25ns(最小值,CL=30pF)。 - 编程/擦除时间为自动页编程330μs/页(典型值),自动块擦除3.5ms/块(典型值)。 - 工作电流在读取(25ns周期)时最大为30mA,编程(平均)和擦除(平均)时也为30mA,待机时最大为50μA。
功能详解: - 支持的模式包括读取、复位、自动页编程、自动块擦除、状态读取、页拷贝和ECC状态读取。 - 该芯片内置ECC逻辑,能够对每528字节的数据进行8位的错误校正。
应用信息: - 适用于固态文件存储、声音记录、静态相机图像文件存储等需要高密度非易失性存储器数据存储的系统。
封装信息: - 封装类型为P-VFBGA67-0608-0.80-001,重量为0.095克(典型值)。
TC58BYG0S3HBAI6 价格&库存
很抱歉,暂时无法提供与“TC58BYG0S3HBAI6”相匹配的价格&库存,您可以联系我们找货
TC58BYG0S3HBAI6
  • 1+25.427821+3.29137
  • 10+23.7130510+3.06941
  • 25+23.0226525+2.98005
库存:27
