DATA SHEET
SURFACE-MOUNT CERAMIC
MULTILAYER CAPACITORS
General purpose
Class 1, NP0
16 V TO 50 V
0.22 pF to 100 nF
Product Specification – November 26, 2019 V.18
RoHS compliant & Halogen Free
Product specification
Surface-Mount Ceramic Multilayer Capacitors
General Purpose
NP0
16 V to 50 V
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER, PHYCOMP
This specification describes NP0
series chip capacitors with leadfree terminations.
CTC & 12NC
APPLICATIONS
Consumer electronics for
example
- Tuners
- Television receivers
- All types of cameras
Telecommunications
Data processing
2
14
All part numbers are identified by the series, size, tolerance, TC material,
packing style, voltage, process code, termination and capacitance value.
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERRED )
CC
XXXX X X
(1)
NPO
(2) (3)
X
BN
XXX
(4)
(5)
(1) SIZE – INCH BASED (METRIC)
0201 (0603)
0402 (1005)
0603 (1608)
0805 (2012)
FEATURES
Supplied in tape on reel
Nickel-barrier end termination
RoHS compliant
Halogen Free compliant
1206 (3216)
1210 (3225)
1812 (4532)
(2) TOLERANCE
B = ± 0.1 pF
C = ± 0.25 pF
D = ± 0.5 pF
F = ± 1%
G = ± 2%
J = ± 5%
K = ± 10%
(3) PACKING STYLE
R = Paper/PE taping reel; Reel 7 inch
K = Blister taping reel; Reel 7 inch
P = Paper/PE taping reel; Reel 13 inch
F = Blister taping reel; Reel 13 inch
C = Bulk case
(4) RATED VOLTAGE
7 = 16 V
8 = 25 V
9 = 50 V
(5) CAPACITANCE VALUE
2 significant digits+number of zeros
The 3rd digit signifies the multiplying factor, and letter R is decimal point
Example: 121 = 12 x 101 = 120 pF
www.yageo.com
Nov. 26, 2019 V.18
General Purpose
3
14
16 V to 50 V
NP0
CONSTRUCTION
The capacitor consists of a
rectangular block of ceramic
dielectric in which a number of
interleaved metal electrodes
are contained. This structure
gives rise to a high capacitance
per unit volume.
terminations
electrodes
The inner electrodes
are connected to the two
end terminations
and finally covered with a layer
of plated tin (NiSn). The
terminations are lead-free.
A cross section of the structure
is shown in Fig.1.
MLB457
ceramic material
Fig. 1 Surface mounted multilayer ceramic capacitor construction
DIMENSION
OUTLINES
Table 1 For outlines see fig. 2
L4 (mm)
min.
L1 (mm)
W (mm)
0201
0402
0.6 ± 0.03
1.0 ± 0.05
0.3 ± 0.03
0.5 ± 0.05
0.10
0.15
0.20
0.35
0.20
0.40
0603
1.6 ± 0.10
0.8 ± 0.10
0.20
0.60
0.40
2.0 ± 0.10 (1)
1.25 ± 0.10 (1)
(2)
(2)
0.25
0.75
0.70
0.25
0.75
1.40
0805
2.0 ± 0.20
1.25 ± 0.20
T (MM)
L2 / L3 (mm)
min.
max.
TYPE
Refer to
table 2 to 5
3.2 ± 0.15 (1)
1.6 ± 0.15 (1)
3.2 ± 0.30 (2)
1.6 ± 0.20 (2)
1210
3.2 ± 0.20
2.5 ± 0.20
0.25
0.75
1.40
1812
4.5 ± 0.20
3.2 ± 0.20
0.25
0.75
2.20
1206
For dimension see Table 1
W
T
L2
L4
L1
L3
MBB211
Fig. 2 Surface
apacitor dimension
NOTE
1. Dimension for size 0805 and 1206, C ≤ 1 nF
2. Dimension for size 0805 and 1206, C > 1 nF
www.yageo.com
Nov. 26, 2019 V.18
General Purpose
CAPACITANCE RANGE & THICKNESS FOR NP0
Table 2 Sizes from 0201 to 0603
0201
0402
CAP.
25 V
50 V
0.22 pF
0.3± 0.03
0.3± 0.03
0.47 pF
0.3± 0.03
0.82 pF
NP0
16 V to 50 V
4
14
0603
16 V
25 V
50 V
16 V
25 V
50 V
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
1.0 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
1.2 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
1.5 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
1.8 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
2.2 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
2.7 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
3.3 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
3.9 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
4.7 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
5.6 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
6.8 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
8.2 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
10 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
12 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
15 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
18 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
22 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
27 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
33 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
39 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
47 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
56 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
68 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
82 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
100 pF
0.3± 0.03
0.3± 0.03
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
NOTE
1. Values in shaded cells indicate thickness class in mm
2. Capacitance value of non E-12 series is on request
www.yageo.com
Nov. 26, 2019 V.18
General Purpose
NP0
16 V to 50 V
5
14
Table 3 Sizes from 0201 to 0603 (continued)
0201
CAP.
25 V
0402
50 V
0603
16 V
25 V
50 V
16 V
25 V
50 V
120 pF
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
150 pF
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
180 pF
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
220 pF
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
270 pF
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
330 pF
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
390 pF
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
470 pF
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
560 pF
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
680 pF
0.5± 0.05
0.5± 0.05
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
1.2 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
1.5 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
1.8 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
2.2 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
2.7 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
3.3 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
3.9 nF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.8± 0.1
820 pF
1.0 nF
0.5± 0.05
0.5± 0.05
0.5± 0.05
4.7 nF
5.6 nF
6.8 nF
8.2 nF
10 nF
12 nF
15 nF
18 nF
22 nF
33 nF
NOTE
www.yageo.com
Nov. 26, 2019 V.18
General Purpose
Table 4 Sizes from 0805 to 1812
0805
1206
CAP.
NP0
16 V to 50 V
1210
16 V
25 V
50 V
16 V
25 V
50 V
0.47 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.82 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.0 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.2 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.5 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.8 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
2.2 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
2.7 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
3.3 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
3.9 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
4.7 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
5.6 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
6.8 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
8.2 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
10 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
12 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
15 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
18 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
22 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
27 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
33 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
39 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
47 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
56 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
68 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
82 pF
0.6± 0.1
0.6± 0.1
100 pF
0.6± 0.1
0.6± 0.1
6
14
1812
25 V
50 V
50 V
0.6± 0.1
1.25± 0.2
1.25± 0.2
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.22 pF
NOTE
www.yageo.com
Nov. 26, 2019 V.18
General Purpose
NP0
16 V to 50 V
7
14
Table 5 Sizes from 0805 to 1812 (continued)
0805
CAP.
1206
1210
1812
16 V
25 V
50 V
16 V
25 V
50 V
25 V
50 V
50 V
120 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
150 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
180 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
220 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
270 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
330 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
390 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
470 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
560 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
680 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
820 pF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.0 nF
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.2 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.5 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.8 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
2.2 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
2.7 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.6± 0.1
0.6± 0.1
0.6± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
3.3 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
3.9 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
4.7 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
5.6 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
6.8 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
1.25± 0.2
8.2 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
10 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
12 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
15 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
18 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
22 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
33 nF
0.85± 0.1
0.85± 0.1
0.85± 0.1
47 nF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.60± 0.2
1.60± 0.2
1.60± 0.2
1.60± 0.2
1.60± 0.2
1.60± 0.2
2.0± 0.2
2.0± 0.2
1.60± 0.2
1.60± 0.2
1.25± 0.2
56 nF
68 nF
82 nF
100 nF
NOTE
www.yageo.com
Nov. 26, 2019 V.18
General Purpose
NP0
16 V to 50 V
8
14
THICKNESS CLASSES AND PACKING QUANTITY
Table 6
SIZE
CODE
Ø 180 MM / 7 INCH
Paper
Blister
Ø 330 MM / 13 INCH
Paper
Blister
THICKNESS
CLASSIFICATION
TAPE WIDTH
QUANTITY PER REEL
0201
0.3 ± 0.03 mm
8 mm
15,000
50,000
0402
0.5 ± 0.05 mm
8 mm
10,000
50,000
50,000
0603
0.8 ± 0.1 mm
8 mm
4,000
15,000
15,000
0.6 ± 0.1 mm
8 mm
4,000
20,000
10,000
0.85 ± 0.1 mm
8 mm
4,000
15,000
8,000
1.25 ± 0.2 mm
8 mm
3,000
10,000
5,000
0.6 ± 0.1 mm
8 mm
4,000
20,000
0.85 ± 0.1 mm
8 mm
4,000
15,000
1.00 / 1.15 ± 0.1 mm
8 mm
3,000
10,000
1.25 ± 0.2 mm
8 mm
3,000
10,000
1.6 ± 0.15 mm
8 mm
2,500
10,000
1.6 ± 0.2 mm
8 mm
2,000
10,000
0.6 / 0.7 ± 0.1 mm
8 mm
4,000
15,000
0.85 ± 0.1 mm
8 mm
4,000
10,000
1.0 ± 0.1 mm
8 mm
3,000
10,000
1.15 ± 0.1 mm
8 mm
3,000
10,000
1.15 ± 0.15 mm
8 mm
3,000
10,000
1.25 ± 0.2 mm
8 mm
3,000
0805
1206
1210
1808
1812
QUANTITY
PER BULK CASE
1.5 ± 0.1 mm
8 mm
2,000
1.6 / 1.9 ± 0.2 mm
8 mm
2,000
2.0 ± 0.2 mm
8 mm
2,000
1,000
2.5 ± 0.2 mm
8 mm
1,000
500
1.15 ± 0.15 mm
12 mm
3,000
1.25 ± 0.2 mm
12 mm
3,000
1.35 ± 0.15 mm
12 mm
2,000
1.5 ± 0.1 mm
12 mm
2,000
1.6 ± 0.2 mm
12 mm
2,000
2.0 ± 0.2 mm
12 mm
2,000
0.6 / 0.85 ± 0.1 mm
12 mm
2,000
1.15 ± 0.1 mm
12 mm
1,000
1.15 ± 0.15 mm
12 mm
1,000
1.35 ± 0.15 mm
12 mm
1,000
1.5 ± 0.1 mm
12 mm
1,000
1.6 ± 0.2 mm
12 mm
1,000
2.0 ± 0.2 mm
12 mm
1,000
2.5 ± 0.2 mm
12 mm
500
www.yageo.com
Nov. 26, 2019 V.18
General Purpose
9
14
16 V to 50 V
NP0
ELECTRICAL CHARACTERISTICS
NP0 DIELECTRIC CAPACITORS; NISN TERMINATIONS
Unless otherwise stated all electrical values apply at an ambient temperature of 20± 1 °C, an atmospheric
pressure of 86 to 106 kPa, and a relative humidity of 63 to 67%.
Table 7
VALUE
DESCRIPTION
Capacitance range
0.22 pF to 100 nF
Capacitance tolerance
C < 10 pF
± 0.1 pF, ± 0.25 pF, ± 0.5 pF
C ≥ 10 pF
± 1%, ± 2%, ± 5%, ± 10%
C < 30 pF
≤ 1 / ( 400 + 20C )
C ≥ 30 pF
≤ 0.1 %
Dissipation factor (D.F.)
Insulation resistance after 1 minute at Ur (DC)
Rins ≥ 10 GΩ or Rins × Cr ≥ 500 seconds whichever is less
Maximum capacitance change as a function of temperature
(temperature characteristic/coefficient):
± 30 ppm/°C
Operating temperature range:
–55 °C to +125 °C
Sample limits (broken lines).
Requirement levels (dotted lines)
MEA607
CCB107
10
C
C
40
TC
(x10 6/K)
5
40
40
Fig. 3
80
120
T ( oC)
Typical temperature coefficient as a function of
temperature
10
Fig. 4
10
40
50
VDC (V)
Typical capacitance change with respect to
the capacitance at 1 V as a function of DC voltage
www.yageo.com
Nov. 26, 2019 V.18
General Purpose
NP0
16 V to 50 V
10
14
CCA044
10
tan
( 10 4)
7.5
5
2.5
80
120
T ( oC)
Fig. 5
Typical tan δ as a function of temperature
SOLDERING RECOMMENDATION
Table 8
SIZE
SOLDERING
0201
METHOD
Reflow
Reflow/Wave
0402
0603
0805
1206
≥ 1210
Reflow only
≥ 0.1 µF
≥ 1.0 µF
≥ 2.2 µF
≥ 4.7 µF
Reflow only
< 0.1 µF
< 1.0 µF
< 2.2 µF
< 4.7 µF
www.yageo.com
Nov. 26, 2019 V.18
General Purpose
NP0
16 V to 50 V
11
14
TESTS AND REQUIREMENTS
Table 9 Test procedures and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Mounting
IEC 6038421/22
4.3
The capacitors may be mounted on printed-circuit boards
or ceramic substrates
No visible damage
Visual
inspection
and dimensio
n check
4.4
Any applicable method using × 10 magnification
In accordance with specification
Capacitance
4.5.1
Class 1:
f = 1 MHz for C ≤ 1 nF, measuring at voltage 1 V rms at 20 °C
Within specified tolerance
f = 1 KHz for C > 1 nF, measuring at voltage 1 V rms at 20 °C
Dissipation
factor (D.F.)
4.5.2
Class 1:
f = 1 MHz for C ≤ 1 nF , measuring at voltage 1 V rms at 20 °C
Insulation
resistance
4.5.3
At Ur (DC) for 1 minute
Temperature
coefficient
4.6
Capacitance shall be measured by the steps shown in the
following table.
Class1:
∆ C/C: ± 30ppm
The capacitance change should be measured after 5 min at each
specified temperature stage.
Step
Temperature(℃)
a
25± 2
b
Lower temperature± 3℃
c
25± 2
d
Upper Temperature± 2℃
e
25± 2
Class2:
X7R: ∆ C/C: ± 15%
Y5V: ∆ C/C: 22~-82%
Class2:
X7R/X5R: ∆ C/C: ±15%
Y5V: ∆ C/C: 22~-82%
(1) Class I
Temperature Coefficient shall be calculated from the formula as
below
C2 - C1
Temp, Coefficient =
106 [ppm/℃]
C1 xΔT
C1: Capacitance at step c
C2: Capacitance at 125℃
∆T: 100℃(=125℃-25℃)
(2) Class II
Capacitance Change shall be calculated from the formula as
below
C2 - C1
∆C =
x 100%
C1
C2: Capacitance at step b or d
www.yageo.com
Nov. 26, 2019 V.18
TEST
Adhesion
Bond strength
of plating on
end face
TEST METHOD
General Purpose
NP0
16 V to 50 V
PROCEDURE
REQUIREMENTS
4.7
A force applied for 10 seconds to the line joining the
terminations and in a plane parallel to the substrate
Force
size ≥ 0603: 5N
size = 0402: 2.5N
size = 0201: 1N
4.8
Mounting in accordance with IEC 60384-22 paragraph 4.3
No visible damage
Conditions: bending 1 mm at a rate of 1 mm/s, radius jig 5
mm
12
14
∆C/C
Class 1:
NP0: within ± 1% or 0.5 pF
whichever is greater
Resistance to
soldering heat
IEC 60384- 4.9
21/22
Precondition: 150 +0/–10 °C for 1 hour, then keep for 24
± 1 hours at room temperature
Preheating: for size ≤ 1206: 120 °C to 150 °C for 1 minute
Dissolution of the end face plating shall
not exceed 25% of the length of the
edge concerned
Preheating: for size >1206: 100 °C to 120 °C for 1 minute
and 170 °C to 200 °C for 1 minute
Solder bath temperature: 260 ± 5 °C
∆C/C
Dipping time: 10 ± 0.5 seconds
Class 1:
NP0: within ± 0.5% or 0.5 pF
Recovery time: 24 ± 2 hours
D.F. within initial specified value
Rins within initial specified value
Solderability
4.10
Preheated the temperature of 80 °C to 140 °C
and maintained for 30 seconds to 60 seconds.
The solder should cover over 95% of
the critical area of each termination
1. Temperature: 235± 5°C / Dipping time: 2 ± 0.5 s
2. Temperature: 245± 5°C / Dipping time: 3 ± 0.5 s
(lead free)Depth of immersion: 10mm
Rapid change
of
temperature
4.11
Preconditioning;
24 ± 1 hours at room temperature
5 cycles with following detail:
30 minutes at lower category temperature
30 minutes at upper category temperature
No visual damage
∆C/C
Class 1:
NP0: within ± 1% or 1 pF
Recovery time 24 ± 2 hours
D.F. meet initial specified value
Rins meet initial specified value
www.yageo.com
Nov. 26, 2019 V.18
TEST
Damp heat
with Ur load
General Purpose
16 V to 50 V
TEST METHOD
PROCEDURE
REQUIREMENTS
IEC 6038421/22
1. Preconditioning, class 2 only:
No visual damage after recovery
4.13
150 +0/-10 °C /1 hour, then keep for
24 ± 1 hour at room temp
2. Initial measure:
Spec: refer to initial spec C, D, IR
3. Damp heat test:
500 ± 12 hours at 40 ± 2 °C;
90 to 95% R.H. 1.0 Ur applied
4. Recovery:
Class 1: 6 to 24 hours
5. Final measure: C, D, IR
P.S. If the capacitance value is less than the minimum value
permitted, then after the other measurements have been
made the capacitor shall be preconditioned according to
“IEC 60384 4.1” and then the requirement shall be met.
Endurance
4.14
2. Initial measure:
3. Endurance test:
Temperature: NP0: 125 °C
Specified stress voltage applied for 1,000 hours:
Applied 2.0 x Ur for general product.
IEC 60384-1
4.6
14
Class 1:
NP0: within ± 2% or 1 pF
D.F.
Class 1:
NP0: ≤ 2 x specified value
Rins
Class 1:
NP0: ≥ 2,500 MΩ or Rins x Cr ≥ 25s
whichever is less
No visual damage
∆C/C
Class1:
D.F.
Class1:
Rins
Specified stress voltage applied for 1 minute
Ur ≤ 100 V: series applied 2.5 Ur
100 V < Ur ≤ 200 V series applied (1.5 Ur + 100)
200 V < Ur ≤ 500 V series applied (1.3 Ur + 100)
Ur > 500 V: 1.3 Ur
I: 7.5 mA
13
∆C/C
4. Recovery time: 24 ± 2 hours
Voltage proof
NP0
Class1:
NP0: ≥ 4,000 MΩ or Rins x Cr ≥ 40s
whichever is less
No breakdown or flashover
www.yageo.com
Nov. 26, 2019 V.18
General Purpose
NP0
16 V to 50 V
14
14
REVISION HISTORY
REVISION
DATE
CHANGE
NOTIFICATION
DESCRIPTION
Version 18
Nov. 26, 2019
- Update 1206/12nF to 47nF dimension
Version 17
Jul. 29, 2019
- Update 0805/10nF dimension
Version 16
Mar. 7, 2017
- 0805 L4 spec updated
Version 15
Nov. 21, 2016
- Product range updated
Version 14
Jul. 22, 2016
- Add 0805/8.2nF and 10nF/ 16V to 50V, T=1.25mm
Version 13
May. 16, 2016
Version 12
Feb. 16, 2016
Version 11
Sep. 11, 2014
Version 10
Feb. 18, 2014
Version 9
Jun. 17, 2013
Version 8
Aug 05, 2011
- Dimension updated
Version 7
Jun 14, 2011
Version 6
Jan 06, 2011
- Dimension updated
Version 5
Dec 29, 2010
- Dimension updated
Version 4
Nov 23, 2010
- Dimension updated
Version 3
Apr 20, 2010
- The statement of "Halogen Free" on the cover added
- Size1210 T=1.0mm SPQ added
- Dimension updated
- Dimension updated
Version 2
Oct 26, 2009
- Typo updated
Version 1
Jun 02, 2009
- 12NC code updated
Version 0
Apr 15, 2009
- New datasheet for general purpose NP0 series with RoHS compliant
- Replace the "16V to 50V" part of pdf files: NP0_16V_7, NP0_16V-to100V_6, NP0_25V_7, NP0_50-to-500V_11
- Combine 0201 from pdf files: UP-NP0X5RX7RY5V_0201_6.3-to-50V_2
and UY-NPOX5RX7RY5V_0201_6.3-to-50V_2
- Define global part number
- Description of "Halogen Free compliant" added
- Test method and procedure updated
www.yageo.com
Nov. 26, 2019 V.18
